Old 09-24-2003, 04:31 PM   #71 (permalink)
Paintball is cheaper
bigballsofpaint's Avatar
Drives: 95 3k, 03 vue
Trader Rating: (25)
bigballsofpaint is an unknown quantity at this point
Default
SPEC clutch from 3sx......why do i need to hotwire the pump and get bigger injectors? TT's run 12 psi fine with the stockys, im only going to run 10 to race which is maybe once a month.....
no more 3/s, saturn vue for now.
bigballsofpaint is offline   Reply With Quote
Old 09-24-2003, 05:15 PM   #72 (permalink)
Speed Factor
Greedy_Bones's Avatar
Drives: Super ES TT
Trader Rating: (46)
Greedy_Bones is an unknown quantity at this point
Default
Becuase you may get a good bit of detonation and blow your engine. Some guys can run 10psi on a 10:1 compression motor and have no problems, but another guy can do it and KABOOM, there goes your motor. TT's can run 12psi np, but they are running 8:1 compression, not 10:1. That makes a HUGE difference, even with just 2psi. If you want to go to the track and run say 10 or 12psi on your 10:1 motor, slap in 4 or 5 gallons of 112-116 leaded race gas. That will lower your detonation and your engine will be A LOT less prone to breaking. Either that or add some alcohol or propane injection.
Ty
Speed Factor
Greedy_Bones is offline   Reply With Quote
Old 09-24-2003, 06:03 PM   #73 (permalink)
Trader Rating: (25)
Default
i plan on propane....hmmm mayb ill just run 8 to race...i dont have the $$ for bigger injectors right now with a new fuel pump.
Old 09-24-2003, 07:09 PM   #74 (permalink)
SLAYER4ALL is an unknown quantity at this point
Default i guess my cars been a freak of nature.....
Ive been running 9 to 9.5 pounds of boost depending on the weather and havent had a problem yet with the car goin kaboom except for my belts shredding over and over again fuckin knight gotta love him
95 mitsubishi 3000GT
SLAYER4ALL is offline   Reply With Quote
Old 09-24-2003, 07:45 PM   #75 (permalink)
Speed kills drive a honda
X GTO X's Avatar
Drives: 92 3000gt (VR-2)
X GTO X is an unknown quantity at this point
Default 22psi
22psi on stock turbos
g -tech it ran a 13.4
www.3sny.com
92 3000gt vr-2 (HyBrId)
FWD Twin turbo
Ross .30 over forged pistons, forged crank, 550 injectors, 255 walbro,Apexi AFC, Apexi-AFCR,HKS Sequential bov, Apexi turbo timer,3sx short throw shifter, Auto meter boost guage,Auto meter air/fuel guage,Auto meter shift light, 9mm Spearco Magnum wires, gutted pre cats, egr block off plates, Full custom 3in exhaust dual Apexi N1's, ATR Downpipe, Quaife lsd, falcon 6 puck sprung hub seramic disc,H&R springs, 18in advans, custom dash kit,
comming bomex kit and paint job
X GTO X is offline   Reply With Quote
Old 09-24-2003, 08:52 PM   #76 (permalink)
Default hmmmm.....
isnt that a little slow for that much boost?
Old 09-24-2003, 09:04 PM   #77 (permalink)
3/S Addict
Iceman3K15's Avatar
Drives: 1994 RT/TT
Trader Rating: (10)
Iceman3K15 is an unknown quantity at this point
Default
you can't run 22 psi on stock turbos.....
1994 RT/TT DR Turn Key Car, SOLD but never forgotten
Intake/Turbos/Exhaust: ARC2 w/82mm MAS, Apex ITC, Greddy Type-S BOV, DR-650s, DN o2 housings, ATR downpipe, ATR Single-Shot Cat-Back
Fuel: Denso Fuel Pump, Hot wire kit, Denso 720cc Injectors, Snow Performance Methonal Injection
Ingition: MSD 8.5mm ignition wires, NGK 9's at .024
Engine: new Mitsu shortblock, 3rd gen lifters, Unorthodox lightened crank pulley
Control: Blitz DSBC, Blitz FATT, Greddy Boost and EGT gauges
Drivetrain: 3SX S/S clutch hose, RPS Max Street Disc Clutch, RPS flywheel, cross drilled rotors w/ stainless braided brakes lines, 5Zigen FN01R-C 18x9.5s, Kuhmo Ecsta Supra's 265/35/18
Other: 3SX poly motor mounts, DR carbon fiber spark plug cover, 99 front end, carbon fiber hood, 15% tint
1994 SL TT 8:1 motor swap, Quiafe LSD, etc. SOLD
Iceman3K15 is offline   Reply With Quote
Old 09-24-2003, 11:37 PM   #78 (permalink)
YEA ME!!!
Gonskanator's Avatar
Drives: 3000GTand 300ZX TT's
Gonskanator is an unknown quantity at this point
Default Re: 22psi
Gonskanator is offline   Reply With Quote
Old 09-25-2003, 11:37 AM   #79 (permalink)
newbie
punkasscrab is an unknown quantity at this point
Default
hmm ..... peeps seem to be having different results.
With 360's and a hotwired walboro I can only run between 9 and 12 psi dependant on ambient temperature without knock (8:1 pistons in a N/A engine).
I'm sure I could push it higher and be fine but it is more than fast enough at 9 psi with 13g's.
91 octane is the highest available here. Are people really able to run more than 12 psi on the stock injectors and crap gas ?
'91 ES - Twin turbo conversion
aka - punkasscrab2
punkasscrab is offline   Reply With Quote
Old 09-25-2003, 11:55 AM   #80 (permalink)
Banned from selling
Drives: 1998 3000GT FWD TT
SpeedFreakSteve is an unknown quantity at this point
Default
12psi on 91 octane is about as high as you'd want to go. You really should upgrade your injectors though. It may be the cause of your knock. If you use a datalogger, you can find out whether your injectors are maxed out, I'm guessing that they are.
Isn't the elevation fairly high where you live? That probably affects things somehow as well. I have friends where I live that drive around everyday with their boost at 15 on 93 octane.. I believe that they turn it down to 12-13 when they only can get 91 octane.
SpeedFreakSteve is offline   Reply With Quote
