Old 08-10-2008, 09:19 PM   #751 (permalink)
I mean,,,come,,on
chrisgtoman's Avatar
Drives: Never-EndingMoneyPit
Trader Rating: (24)
chrisgtoman Level 1chrisgtoman Level 1
Default Re: FWD TT cars.. how many are there now?
1. stu_04 (conversion) 3KGT SL ATX
2. punkasscrab (conversion) 3KGT 5 spd
3. SLguy (conversion) 3KGT ATX <---going down to 8:1
4. JB (engine swap) 3KGT 5spd
5. Mikes95RT (conversion) Stealth R/T 5 spd
6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo
7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1
8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original
9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd
10. X GTO X (engine swap) 3KGT (VR-2)
11.Thump`Master (conversion) 3KGT 5 spd
12. JAL (conversion) 3KGT SOHC TT
13. ZachRT (single turbo) Stealth RT
14. 3KHI (Engine Swap) 3KGT DR-900's, Stage 3 Heads, Street Cams.
15. Juko (supercharged) 3KGT
16. SLAYER4ALL (supercharged) 3KGT
17. Snake93gt (supercharged) 3KGT SL
18. Spawn (supercharged) 3KGT SOHC ATX
19. OhFoSho (engine swap) SOHC Stealth
20. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd
21. shooter83 (engine swap) Stealth es 5spd - now AWD converted (7-06-08)
22. upyun (engine swap) 3kgt sl
23. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES
24. Evangelist (TT Conversion) Stealth ES/TT 5 spd
25. Blue-GTO (TT Conversion) 3kgt SL
26. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd
27. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe
28. bigballsofpaint (TT conversion) 95 3k base....i finally finished
29. 92-3000GT (Single turbo) 3000gt sl 5spd
30. Optamix (engine swap) 3KGT SL 5spd
31. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months)
32. Quintop (engine swap) '95 SL 5 sp
33. Jigzibit (conversion) '95 SL ATX
34. 93 Stealth R/T (TT conversion)
35. Bob The Great (TT conversion) 93 R/T AWD 5spd
36. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's
37. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness.
38. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT
39. 3000hybrid (TT swap) 97 base GT- ATX to 5spd AWD tranny w/SFR LSD 19T's
40. 95red3000gt (TT conversion) only one in Colorado!
41. Jeremy C (TT conversion) - weekend project
42. Vortac (TT Conversion) SL ATX
43. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd.
44. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD
45. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD
46. Import Power Online-Fastest-Quickest-Dyno Record 132.97MPH/11.44-14bs/519HP EVOIIIs-5spd AWD The new FWD Record
47.93_black_R/T - Finished May 2004
48. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu
49. rush6432 ( Single turbo conversion, stock 10:1 motor)
50. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 156K
51. Zumin3K - TT Swap) 9bs, TT ECU + Harness
52. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap
53. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL
54. aaron97- (conversion) 3000GT SL
55. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc
56. |4x4 nv| - (TT Swap) Evo3 16G's/Forged Internals(8.1:1 compression)/680cc injectors/Garrett FMIC/Propane/maftpro
57. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain/FMIC
58. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo
59. kdog109sd (TT Conversion) - one of the first automatics to do it
60. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi
61. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX
62. KevD23 (single turbo) '94 stealth ATX
63. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife
64. LVA3KGT (TT Swap) DR500s 390FWHP, 410 FWTQ @ 17psi
65. Pantherchams (Supercharged) 93 Stealth ES ATX
66. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT
67. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!)
68. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???)
69. Jomojr (TT Conversion 93 Base ATX)
70. Cobane (J-Spec Swap) 94 r/t 5-spd.
71. LeRoyDL (92 R/T DR650 Blow through TT Conv. JDM ECU, N/A harness)
72. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness.
73. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods
74. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX
75. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's
76.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2.
77. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500
78. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition
79. OneWingedAngel - 97 3000GT SL T/T conversion
80. 91StealthBaseTT - TT 10:1 compression fully rebuilt engine including valve job (:
81. PearlRyde - '92 TT Swap into a '99Base... Running on SOHC Tranny until i can rebuild the Getrag...
82. 94mitsumichael7 - 94 Stealth RT... FWD 9b's 8 psi, TT ECU, 10:1 motor, new EVERYTHING. lol. But its finally done and running!!!
83. templar - 94 3000GT ATX TT Conversion.
84. Nojinxz - .080 over supercharged running 6lbs boost - running very well
85. GTOGIRL3000 ~ 94 SL-TT and 5 speed NA MTX swap, 10:1 comp.,TT ECU and harness, SFR LSD.
86. Forsakenwolf - '91 ES-TT w/ 5spd NA MTX, 8:1 comp
87. white96tt - (engine swap) 95 Stealth Base ATX; 15gs
88. DSMGTO - 94 SL N/A motor, TT ECU, TT Fuel pump, 360 inj.
89. AyeKay 94 SL Twin Turbo with all the TT Parts 10:1 7lbs of Boost
90. blk92sl - now SLTT!!! just started her for the first time last night..6/17/06
91. Zeiss - 94 Stealth RT Luxury with 13gs 10:1 and SFR LSD insert.
92. Wildarmz - 94 SL TT, 92 TT Ecu
93.MagnaVR4 - 99 base single cam to TT, 4bolt motor swap, 6spd
94. SeekNStrike- Stock TT swap. blitz boost con. S-AFCII
95. Rican3kgt- (Supercharged) Low comp pistons with forged internals, 12psi, tt ecu
96. King_Milo- TT swap, many mods, still stock turbo's
97. Guywit94sl - TT conversion 94 SLTT
98. J-Groove - 9:1 Ross forged '95 base TT
99. 94ATXVR2- TT engine swap, 17g's and Atx to 5spd getrag conversion.
100. Gen13kgt - TT Engine Swap.
101. 4u2nV - TT Conversion; 98SLTT; Stock 9b's @ 8PSI; Mod's in Sig.
102. Ryan94rt- TT convo, Two many mods
103. BigTyla - TT conversion on ATX with TT ECU
104. Rowlandzz - JDM TT Swap running smooth
105. Ghetoriger12 - single turbo supert70 running 21psi. running and happy...
106. Mr.30000 - TT Conversion w/ Custom Hybrid 13T's and a bunch of BPU on a 95 Base 3000GT
107. Tug - 9b's, TT ecu, 360cc injectors, 10:1 motor, VR4 heads
108. boardFreak5 - front mount, 4inch ICH, 99lifters, getting tuned soon
109. green-lantern - 95 base TT lots of mods and having fun
110. Yask4it- 91 R/T Auto TT conversion with mods
111. Fbc_978- 93 3000gt base TT conversion with bpu
112. thetjkid- 92 r/t stealth tt conversion running great
113. maTT- 92 SOHC ATX -> 8:1 DOHC TT ATX
114. Mudvaynedude122 - 95 base dohc mtx - vr4 motor and 5 speed getrag
115. Chrisgtoman - 91 TT Conversion on ATX with TT ECU
1991 Twin Turbo ATX with TT ECU
I do not know what weapons will be used in WW3, but I do know that WW4 will be fought with sticks and stones. - Albert Einstein.
chrisgtoman is offline   Reply With Quote
Old 08-18-2008, 10:05 AM   #752 (permalink)
single@'s Avatar
Drives: 94 SL SINGLE TURBO
single@ is an unknown quantity at this point
Mitsubishi Re: FWD TT cars.. how many are there now?
I Have A Single Turbo My Self But Mines Was Internal Wastegate Im Thinking On Buying Another Turbo But Is Going To Be External .......my Question Is Do I Need One Or Two Wastegates.
single@ is offline   Reply With Quote
Old 08-18-2008, 12:00 PM   #753 (permalink)
Drives: 98 sl
98slept Level 398slept Level 398slept Level 398slept Level 3
116. 98slept - BPU 98 sl MTX 95 vr4 ecu/98 harness running 5 psi.
98 SL TWIN TURBO
TT 9b's at 5psi/ 95 TT ecu/Ebay precat eliminators and downpipe/3sx lightweight pulley/k&N intake/Fidanza lightweight flywheel/Centerforce dual friction clutch/walbro 255 fuel pump/MP solid motor mounts/Passport gauges/99 front conversion/l.e.d gauges/needles
98slept is offline   Reply With Quote
Old 09-05-2008, 07:19 PM   #754 (permalink)
Bkphate's Avatar
Bkphate Bkphate Bkphate
lets add bkphate into this list
95 SL swap 91 vr4 5 speed
Bkphate is offline   Reply With Quote
Old 09-08-2008, 01:34 PM   #755 (permalink)
One Wheel Wonder
B-Man0660's Avatar
Drives: '92 3000gt SL
B-Man0660 Level 5B-Man0660 Level 5B-Man0660 Level 5B-Man0660 Level 5B-Man0660 Level 5B-Man0660 Level 5
I just finished mine adding it to the list
117. Bkphate - 95 SL swap 91 vr4 5 speed
118. B-Man0660 - 92 SL 10:1 fwd tranny wastegate for now.
15.0009sec@93.00mph 1/4mi
http://www.stealth316.com/2-calc-hp-et-mph.htm <-216hp-269hp according to this.
B-Man0660 is offline   Reply With Quote
Old 09-21-2008, 08:03 PM   #756 (permalink)
VR4-GASM's Avatar
Drives: other ppl's cars
Trader Rating: (10)
VR4-GASM Level 4VR4-GASM Level 4VR4-GASM Level 4VR4-GASM Level 4VR4-GASM Level 4
119. VR4-GASM- 95 base 3kgt- 10:1, 9b's @ 10psi, stock trans for now
1995 3000GT Base BPU+ (10:1 @ 10psi)
HKS, Apex-i, GReddy, AEM, K&N, Stillen, ACT, 3SX Performance, Maximal Performance, Ground Zero Performance.
*500+ FWHP soon to be in the works*
VR4-GASM is offline   Reply With Quote
Old 10-09-2008, 04:43 PM   #757 (permalink)
brandon3000gt is an unknown quantity at this point
what should I search if I need to know all the parts and labor cost?
Thanks.
brandon3000gt is offline   Reply With Quote
Old 10-23-2008, 08:35 AM   #758 (permalink)
Drives: 94 stealth TT conver
mitchoreed is an unknown quantity at this point
im in progress, engine swap on a 94 stealth RT. for the guys who've finished the FWD swap, how are your trannies holding up? and how much boost are you pushing?
mitchoreed is offline   Reply With Quote
Old 10-23-2008, 02:41 PM   #759 (permalink)
VA 3S
Tool Man's Avatar
Drives: 94 3000GT NA
Trader Rating: (27)
Tool Man Level 7Tool Man Level 7Tool Man Level 7Tool Man Level 7Tool Man Level 7Tool Man Level 7Tool Man Level 7Tool Man Level 7Tool Man Level 7Tool Man Level 7Tool Man Level 7
120.Tool Man 94 Base 3K GT 10:1 13G's FWD 5 speed wastegate for now.
Pics of my car, click me!_______ August 2006 ROTM
DSM 13Gs, gutted pre-cats, 3" after market downpipe with 3" high flow Cat,Custom 3" stainless steel catback dual exhaust,Modified oil pan & Stainless steel oil return lines,APEXI S-AFC2, Manual Boost Controller, Front and rear Polly mounts. Running waste gate for now ( 7 PSI ) until I get to a Dyno.
Tool Man is offline   Reply With Quote
Old 11-08-2008, 08:55 PM   #760 (permalink)
SoCal3S Member
ballermj23's Avatar
Drives: 1993 3000gt SL
ballermj23 is an unknown quantity at this point
SO WHERES the website people were talking in making for a tutorial on a conversion / TT swap ????
Im willing to make the website from scratch... i am website builder... and a 300gt lover...
names Avalible for a 3000gt swap website.
3siswap.com AVAILABLE
3siconversion.com AVAILABLE
3kgtswap.com AVAILABLE
3kgtconversion.com AVAILABLE
suggestions???
let me know....
ballermj23 is offline   Reply With Quote
