#722 (permalink) |
Paid Member
1. stu_04 (conversion) 3KGT SL ATX 2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 11.Thump`Master (conversion) 3KGT 5 spd 12. JAL (conversion) 3KGT SOHC TT 13. ZachRT (single turbo) Stealth RT 14. 3KHI (Engine Swap) 3KGT DR-900's, Stage 3 Heads, Street Cams. 15. Juko (supercharged) 3KGT 16. SLAYER4ALL (supercharged) 3KGT 17. Snake93gt (supercharged) 3KGT SL 18. Spawn (supercharged) 3KGT SOHC ATX 19. OhFoSho (engine swap) SOHC Stealth 20. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 21. shooter83 (engine swap) Stealth es 5spd 22. upyun (engine swap) 3kgt sl 23. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES 24. Evangelist (TT Conversion) Stealth ES/TT 5 spd 25. Blue-GTO (TT Conversion) 3kgt SL 26. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 27. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 28. bigballsofpaint (TT conversion) 95 3k base....i finally finished 29. 92-3000GT (Single turbo) 3000gt sl 5spd 30. Optamix (engine swap) 3KGT SL 5spd 31. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 32. Quintop (engine swap) '95 SL 5 sp 33. Jigzibit (conversion) '95 SL ATX 34. 93 Stealth R/T (TT conversion) 35. Bob The Great (TT conversion) 93 R/T AWD 5spd 36. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's 37. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness. 38. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 39. 3000hybrid (TT swap) 97 base GT- ATX to 5spd AWD tranny w/SFR LSD 19T's 40. 95red3000gt (TT conversion) only one in Colorado! 41. Jeremy C (TT conversion) - weekend project 42. Vortac (TT Conversion) SL ATX 43. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 44. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD 45. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD 46. Import Power Online-Fastest-Quickest-Dyno Record 132.97MPH/11.44-14bs/519HP EVOIIIs-5spd AWD The new FWD Record 47.93_black_R/T - Finished May 2004 48. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 49. rush6432 ( Single turbo conversion, stock 10:1 motor) 50. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 156K 51. Zumin3K - TT Swap) 9bs, TT ECU + Harness 52. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 53. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 54. aaron97- (conversion) 3000GT SL 55. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 56. |4x4 nv| - (TT Swap) Evo3 16G's/Forged Internals(8.1:1 compression)/680cc injectors/Garrett FMIC/Propane/maftpro 57. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain/FMIC 58. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 59. kdog109sd (TT Conversion) - one of the first automatics to do it 60. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 61. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 62. KevD23 (single turbo) '94 stealth ATX 63. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife 64. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads 65. Pantherchams (Supercharged) 93 Stealth ES ATX 66. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT 67. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!) 68. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???) 69. Jomojr (TT Conversion 93 Base ATX) 70. Cobane (J-Spec Swap) 94 r/t 5-spd. 71. LeRoyDL (92 R/T DR650 Blow through TT Conv. JDM ECU, N/A harness) 72. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness. 73. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods 74. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX 75. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's 76.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2. 77. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500 78. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition 79. OneWingedAngel - 97 3000GT SL T/T conversion 80. 91StealthBaseTT - TT 10:1 compression fully rebuilt engine including valve job (: 81. PearlRyde - '92 TT Swap into a '99Base... Running on SOHC Tranny until i can rebuild the Getrag... 82. 94mitsumichael7 - 94 Stealth RT... FWD 9b's 8 psi, TT ECU, 10:1 motor, new EVERYTHING. lol. But its finally done and running!!! 83. templar - 94 3000GT ATX TT Conversion. 84. Nojinxz - .080 over supercharged running 6lbs boost - running very well 85. GTOGIRL3000 ~ 94 SL-TT and 5 speed NA MTX swap, 10:1 comp.,TT ECU and harness, SFR LSD. 86. Forsakenwolf - '91 ES-TT w/ 5spd NA MTX, 8:1 comp 87. white96tt - (engine swap) 95 Stealth Base ATX; 15gs 88. DSMGTO - 94 SL N/A motor, TT ECU, TT Fuel pump, 360 inj. 89. AyeKay 94 SL Twin Turbo with all the TT Parts 10:1 7lbs of Boost 90. blk92sl - now SLTT!!! just started her for the first time last night..6/17/06 91. Zeiss - 94 Stealth RT Luxury with 13gs 10:1 and SFR LSD insert. 92. Wildarmz - 94 SL TT, 92 TT Ecu 93.MagnaVR4 - 99 base single cam to TT, 4bolt motor swap, 6spd 94. SeekNStrike- Stock TT swap. blitz boost con. S-AFCII 95. Rican3kgt- (Supercharged) Low comp pistons with forged internals, 12psi, tt ecu 96. King_Milo- TT swap, many mods, still stock turbo's 97. Guywit94sl - TT conversion 94 SLTT 98. J-Groove - 9:1 Ross forged '95 base TT 99. 94ATXVR2- TT engine swap, 17g's and Atx to 5spd getrag conversion. 100. Gen13kgt - TT Engine Swap. 101. 4u2nV - TT Conversion; 98SLTT; Stock 9b's @ 8PSI; Mod's in Sig. 102. Ryan94rt- TT convo, Two many mods 103. BigTyla - TT conversion on ATX with TT ECU 104. Rowlandzz - JDM TT Swap running smooth 105. Ghetoriger12 - single turbo supert70 running 21psi. running and happy... 106. Mr.30000 - TT Conversion w/ Custom Hybrid 13T's and a bunch of BPU on a 95 Base 3000GT 107. Tug - 9b's, TT ecu, 360cc injectors, 10:1 motor, VR4 heads 108. boardFreak5 - front mount, 4inch ICH, 99lifters, getting tuned soon 109. green-lantern - 95 base TT lots of mods and having fun ________________________________________________________ In Progress (remove your name when finished and add to completed list) 1. xtremewlr (conversion) collecting parts slowly 2. rtrotter (supercharged) 3KGT 3. Whitewavesea (single turbo) 3kgt Installation in progress 4. Aph (conversion) - Dec 17 '03 5. JRock4000 (conversion) 3000GT -should be done this January 6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 7. Mitch007 (conversion) expected completion by beginning of summer 8. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend. 9. AkiraGT (TT swap already started) 10. StealthTT (just need turbos and ICs with pipes) 11. Chant (TT / SuperCharger Conversion) :0) 12. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger 13. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap. 14. Renegadex181- Saving money and collecting parts...to start by April 15th 15. Clipse20 - 94TT Swap w/ JapSpec ECU & Harness 16. spaceace60 - 96'base w/98'tt vr4motor 17. Presto97sl - TT conversion ATX check sig for days until install 18. MilkyClr69 - 96SL w/ 92JDMTT motor/5spd TT tranny waiting on parts 19. Nobodylikeswood - 94 SL u TT conversion 20. WolfSL - TT conversion - collecting parts 21. 92StealthR/T - Have all parts but oil cooler for my tt conversion 22. TruPnoyFlava - 94 base (VR4 swaP) 23. Ellery Clinton - Got all my parts... just need the 94/95 Harness and Ceramic Coat everything 24. Its Fwd - 94 base coming back to life, soon to be TT 25. My92Stealth - 92 Base, Putting in a TT this winter! 26. 2inTrbo - Some TT parts already installed...TRUELY IN PROGRESS!! 27. zack6G72- A few parts on there way and then a clutch replacement. 28. ATXSUX- gathering parts as we speak, lack downpipe, gauges, ECU and Harness and a couple of little things. 29. Guywit94sl - everythings bolted up, jus need to finish o2 and ecu wiring 30. 3startuna - limited by founds expected completion date summer 07 31. 963KSLTT - hoping to be done by summer '07 =] 32. BStewart87 - ( 15g TT Swap | ATX --> MTX ) - Summer 2007!!! |
#723 (permalink) |
Resident rocket scientist
I thought we got rid of the "in progress" list!!!
![]() 1993 3000GT FWD ATX TT - daily<----------------------->1984 Nissan Maxima - project Topline Engineering ground wire kit |
#724 (permalink) |
2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 11.Thump`Master (conversion) 3KGT 5 spd 12. JAL (conversion) 3KGT SOHC TT 13. ZachRT (single turbo) Stealth RT 14. 3KHI (Engine Swap) 3KGT DR-900's, Stage 3 Heads, Street Cams. 15. Juko (supercharged) 3KGT 16. SLAYER4ALL (supercharged) 3KGT 17. Snake93gt (supercharged) 3KGT SL 18. Spawn (supercharged) 3KGT SOHC ATX 19. OhFoSho (engine swap) SOHC Stealth 20. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 21. shooter83 (engine swap) Stealth es 5spd 22. upyun (engine swap) 3kgt sl 23. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES 24. Evangelist (TT Conversion) Stealth ES/TT 5 spd 25. Blue-GTO (TT Conversion) 3kgt SL 26. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 27. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 28. bigballsofpaint (TT conversion) 95 3k base....i finally finished 29. 92-3000GT (Single turbo) 3000gt sl 5spd 30. Optamix (engine swap) 3KGT SL 5spd 31. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 32. Quintop (engine swap) '95 SL 5 sp 33. Jigzibit (conversion) '95 SL ATX 34. 93 Stealth R/T (TT conversion) 35. Bob The Great (TT conversion) 93 R/T AWD 5spd 36. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's 37. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness. 38. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 39. 3000hybrid (TT swap) 97 base GT- ATX to 5spd AWD tranny w/SFR LSD 19T's 40. 95red3000gt (TT conversion) only one in Colorado! 41. Jeremy C (TT conversion) - weekend project 42. Vortac (TT Conversion) SL ATX 43. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 44. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD 45. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD 46. Import Power Online-Fastest-Quickest-Dyno Record 132.97MPH/11.44-14bs/519HP EVOIIIs-5spd AWD The new FWD Record 47.93_black_R/T - Finished May 2004 48. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 49. rush6432 ( Single turbo conversion, stock 10:1 motor) 50. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 156K 51. Zumin3K - TT Swap) 9bs, TT ECU + Harness 52. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 53. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 54. aaron97- (conversion) 3000GT SL 55. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 56. |4x4 nv| - (TT Swap) Evo3 16G's/Forged Internals(8.1:1 compression)/680cc injectors/Garrett FMIC/Propane/maftpro 57. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain/FMIC 58. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 59. kdog109sd (TT Conversion) - one of the first automatics to do it 60. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 61. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 62. KevD23 (single turbo) '94 stealth ATX 63. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife 64. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads 65. Pantherchams (Supercharged) 93 Stealth ES ATX 66. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT 67. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!) 68. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???) 69. Jomojr (TT Conversion 93 Base ATX) 70. Cobane (J-Spec Swap) 94 r/t 5-spd. 71. LeRoyDL (92 R/T DR650 Blow through TT Conv. JDM ECU, N/A harness) 72. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness. 73. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods 74. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX 75. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's 76.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2. 77. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500 78. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition 79. OneWingedAngel - 97 3000GT SL T/T conversion 80. 91StealthBaseTT - TT 10:1 compression fully rebuilt engine including valve job (: 81. PearlRyde - '92 TT Swap into a '99Base... Running on SOHC Tranny until i can rebuild the Getrag... 82. 94mitsumichael7 - 94 Stealth RT... FWD 9b's 8 psi, TT ECU, 10:1 motor, new EVERYTHING. lol. But its finally done and running!!! 83. templar - 94 3000GT ATX TT Conversion. 84. Nojinxz - .080 over supercharged running 6lbs boost - running very well 85. GTOGIRL3000 ~ 94 SL-TT and 5 speed NA MTX swap, 10:1 comp.,TT ECU and harness, SFR LSD. 86. Forsakenwolf - '91 ES-TT w/ 5spd NA MTX, 8:1 comp 87. white96tt - (engine swap) 95 Stealth Base ATX; 15gs 88. DSMGTO - 94 SL N/A motor, TT ECU, TT Fuel pump, 360 inj. 89. AyeKay 94 SL Twin Turbo with all the TT Parts 10:1 7lbs of Boost 90. blk92sl - now SLTT!!! just started her for the first time last night..6/17/06 91. Zeiss - 94 Stealth RT Luxury with 13gs 10:1 and SFR LSD insert. 92. Wildarmz - 94 SL TT, 92 TT Ecu 93.MagnaVR4 - 99 base single cam to TT, 4bolt motor swap, 6spd 94. SeekNStrike- Stock TT swap. blitz boost con. S-AFCII 95. Rican3kgt- (Supercharged) Low comp pistons with forged internals, 12psi, tt ecu 96. King_Milo- TT swap, many mods, still stock turbo's 97. Guywit94sl - TT conversion 94 SLTT 98. J-Groove - 9:1 Ross forged '95 base TT 99. 94ATXVR2- TT engine swap, 17g's and Atx to 5spd getrag conversion. 100. Gen13kgt - TT Engine Swap. 101. 4u2nV - TT Conversion; 98SLTT; Stock 9b's @ 8PSI; Mod's in Sig. 102. Ryan94rt- TT convo, Two many mods 103. BigTyla - TT conversion on ATX with TT ECU 104. Rowlandzz - JDM TT Swap running smooth 105. Ghetoriger12 - single turbo supert70 running 21psi. running and happy... 106. Mr.30000 - TT Conversion w/ Custom Hybrid 13T's and a bunch of BPU on a 95 Base 3000GT 107. Tug - 9b's, TT ecu, 360cc injectors, 10:1 motor, VR4 heads 108. boardFreak5 - front mount, 4inch ICH, 99lifters, getting tuned soon 109. green-lantern - 95 base TT lots of mods and having fun 110. Yask4it- 91 R/T Auto TT conversion with mods ________________________________________________________ In Progress (remove your name when finished and add to completed list) 1. xtremewlr (conversion) collecting parts slowly 2. rtrotter (supercharged) 3KGT 3. Whitewavesea (single turbo) 3kgt Installation in progress 4. Aph (conversion) - Dec 17 '03 5. JRock4000 (conversion) 3000GT -should be done this January 6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 7. Mitch007 (conversion) expected completion by beginning of summer 8. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend. 9. AkiraGT (TT swap already started) 10. StealthTT (just need turbos and ICs with pipes) 11. Chant (TT / SuperCharger Conversion) :0) 12. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger 13. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap. 14. Renegadex181- Saving money and collecting parts...to start by April 15th 15. Clipse20 - 94TT Swap w/ JapSpec ECU & Harness 16. spaceace60 - 96'base w/98'tt vr4motor 17. Presto97sl - TT conversion ATX check sig for days until install 18. MilkyClr69 - 96SL w/ 92JDMTT motor/5spd TT tranny waiting on parts 19. Nobodylikeswood - 94 SL u TT conversion 20. WolfSL - TT conversion - collecting parts 21. 92StealthR/T - Have all parts but oil cooler for my tt conversion 22. TruPnoyFlava - 94 base (VR4 swaP) 23. Ellery Clinton - Got all my parts... just need the 94/95 Harness and Ceramic Coat everything 24. Its Fwd - 94 base coming back to life, soon to be TT 25. My92Stealth - 92 Base, Putting in a TT this winter! 26. 2inTrbo - Some TT parts already installed...TRUELY IN PROGRESS!! 27. zack6G72- A few parts on there way and then a clutch replacement. 28. ATXSUX- gathering parts as we speak, lack downpipe, gauges, ECU and Harness and a couple of little things. 29. Guywit94sl - everythings bolted up, jus need to finish o2 and ecu wiring 30. 3startuna - limited by founds expected completion date summer 07 31. 963KSLTT - hoping to be done by summer '07 =] 32. BStewart87 - ( 15g TT Swap | ATX --> MTX ) - Summer 2007!!! |
#726 (permalink) |
Bolton Masssss
2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 11.Thump`Master (conversion) 3KGT 5 spd 12. JAL (conversion) 3KGT SOHC TT 13. ZachRT (single turbo) Stealth RT 14. 3KHI (Engine Swap) 3KGT DR-900's, Stage 3 Heads, Street Cams. 15. Juko (supercharged) 3KGT 16. SLAYER4ALL (supercharged) 3KGT 17. Snake93gt (supercharged) 3KGT SL 18. Spawn (supercharged) 3KGT SOHC ATX 19. OhFoSho (engine swap) SOHC Stealth 20. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 21. shooter83 (engine swap) Stealth es 5spd 22. upyun (engine swap) 3kgt sl 23. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES 24. Evangelist (TT Conversion) Stealth ES/TT 5 spd 25. Blue-GTO (TT Conversion) 3kgt SL 26. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 27. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 28. bigballsofpaint (TT conversion) 95 3k base....i finally finished 29. 92-3000GT (Single turbo) 3000gt sl 5spd 30. Optamix (engine swap) 3KGT SL 5spd 31. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 32. Quintop (engine swap) '95 SL 5 sp 33. Jigzibit (conversion) '95 SL ATX 34. 93 Stealth R/T (TT conversion) 35. Bob The Great (TT conversion) 93 R/T AWD 5spd 36. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's 37. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness. 38. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 39. 3000hybrid (TT swap) 97 base GT- ATX to 5spd AWD tranny w/SFR LSD 19T's 40. 95red3000gt (TT conversion) only one in Colorado! 41. Jeremy C (TT conversion) - weekend project 42. Vortac (TT Conversion) SL ATX 43. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 44. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD 45. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD 46. Import Power Online-Fastest-Quickest-Dyno Record 132.97MPH/11.44-14bs/519HP EVOIIIs-5spd AWD The new FWD Record 47.93_black_R/T - Finished May 2004 48. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 49. rush6432 ( Single turbo conversion, stock 10:1 motor) 50. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 156K 51. Zumin3K - TT Swap) 9bs, TT ECU + Harness 52. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 53. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 54. aaron97- (conversion) 3000GT SL 55. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 56. |4x4 nv| - (TT Swap) Evo3 16G's/Forged Internals(8.1:1 compression)/680cc injectors/Garrett FMIC/Propane/maftpro 57. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain/FMIC 58. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 59. kdog109sd (TT Conversion) - one of the first automatics to do it 60. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 61. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 62. KevD23 (single turbo) '94 stealth ATX 63. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife 64. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads 65. Pantherchams (Supercharged) 93 Stealth ES ATX 66. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT 67. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!) 68. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???) 69. Jomojr (TT Conversion 93 Base ATX) 70. Cobane (J-Spec Swap) 94 r/t 5-spd. 71. LeRoyDL (92 R/T DR650 Blow through TT Conv. JDM ECU, N/A harness) 72. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness. 73. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods 74. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX 75. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's 76.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2. 77. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500 78. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition 79. OneWingedAngel - 97 3000GT SL T/T conversion 80. 91StealthBaseTT - TT 10:1 compression fully rebuilt engine including valve job (: 81. PearlRyde - '92 TT Swap into a '99Base... Running on SOHC Tranny until i can rebuild the Getrag... 82. 94mitsumichael7 - 94 Stealth RT... FWD 9b's 8 psi, TT ECU, 10:1 motor, new EVERYTHING. lol. But its finally done and running!!! 83. templar - 94 3000GT ATX TT Conversion. 84. Nojinxz - .080 over supercharged running 6lbs boost - running very well 85. GTOGIRL3000 ~ 94 SL-TT and 5 speed NA MTX swap, 10:1 comp.,TT ECU and harness, SFR LSD. 86. Forsakenwolf - '91 ES-TT w/ 5spd NA MTX, 8:1 comp 87. white96tt - (engine swap) 95 Stealth Base ATX; 15gs 88. DSMGTO - 94 SL N/A motor, TT ECU, TT Fuel pump, 360 inj. 89. AyeKay 94 SL Twin Turbo with all the TT Parts 10:1 7lbs of Boost 90. blk92sl - now SLTT!!! just started her for the first time last night..6/17/06 91. Zeiss - 94 Stealth RT Luxury with 13gs 10:1 and SFR LSD insert. 92. Wildarmz - 94 SL TT, 92 TT Ecu 93.MagnaVR4 - 99 base single cam to TT, 4bolt motor swap, 6spd 94. SeekNStrike- Stock TT swap. blitz boost con. S-AFCII 95. Rican3kgt- (Supercharged) Low comp pistons with forged internals, 12psi, tt ecu 96. King_Milo- TT swap, many mods, still stock turbo's 97. Guywit94sl - TT conversion 94 SLTT 98. J-Groove - 9:1 Ross forged '95 base TT 99. 94ATXVR2- TT engine swap, 17g's and Atx to 5spd getrag conversion. 100. Gen13kgt - TT Engine Swap. 101. 4u2nV - TT Conversion; 98SLTT; Stock 9b's @ 8PSI; Mod's in Sig. 102. Ryan94rt- TT convo, Two many mods 103. BigTyla - TT conversion on ATX with TT ECU 104. Rowlandzz - JDM TT Swap running smooth 105. Ghetoriger12 - single turbo supert70 running 21psi. running and happy... 106. Mr.30000 - TT Conversion w/ Custom Hybrid 13T's and a bunch of BPU on a 95 Base 3000GT 107. Tug - 9b's, TT ecu, 360cc injectors, 10:1 motor, VR4 heads 108. boardFreak5 - front mount, 4inch ICH, 99lifters, getting tuned soon 109. green-lantern - 95 base TT lots of mods and having fun 110. Yask4it- 91 R/T Auto TT conversion with mods 111. Fbc_978- 93 3000gt base TT conversion with bpu ________________________________________________________ In Progress (remove your name when finished and add to completed list) 1. xtremewlr (conversion) collecting parts slowly 2. rtrotter (supercharged) 3KGT 3. Whitewavesea (single turbo) 3kgt Installation in progress 4. Aph (conversion) - Dec 17 '03 5. JRock4000 (conversion) 3000GT -should be done this January 6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 7. Mitch007 (conversion) expected completion by beginning of summer 8. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend. 9. AkiraGT (TT swap already started) 10. StealthTT (just need turbos and ICs with pipes) 11. Chant (TT / SuperCharger Conversion) :0) 12. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger 13. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap. 14. Renegadex181- Saving money and collecting parts...to start by April 15th 15. Clipse20 - 94TT Swap w/ JapSpec ECU & Harness 16. spaceace60 - 96'base w/98'tt vr4motor 17. Presto97sl - TT conversion ATX check sig for days until install 18. MilkyClr69 - 96SL w/ 92JDMTT motor/5spd TT tranny waiting on parts 19. Nobodylikeswood - 94 SL u TT conversion 20. WolfSL - TT conversion - collecting parts 21. 92StealthR/T - Have all parts but oil cooler for my tt conversion 22. TruPnoyFlava - 94 base (VR4 swaP) 23. Ellery Clinton - Got all my parts... just need the 94/95 Harness and Ceramic Coat everything 24. Its Fwd - 94 base coming back to life, soon to be TT 25. My92Stealth - 92 Base, Putting in a TT this winter! 26. 2inTrbo - Some TT parts already installed...TRUELY IN PROGRESS!! 27. zack6G72- A few parts on there way and then a clutch replacement. 28. ATXSUX- gathering parts as we speak, lack downpipe, gauges, ECU and Harness and a couple of little things. 29. Guywit94sl - everythings bolted up, jus need to finish o2 and ecu wiring 30. 3startuna - limited by founds expected completion date summer 07 31. 963KSLTT - hoping to be done by summer '07 =] 32. BStewart87 - ( 15g TT Swap | ATX --> MTX ) - Summer 2007!!!
TT conversion- DONE
AEM UEGO, 3 inch downpipe, 3sx aluminum crank pulley, MSD wires, Polished plenum, Cusco strut tower bars, Turbo xs rfl(yea im stalling), Palmlll, Toyo Proxes, K&N, Stage 2 SouthBend clutch 13.7 @ 109...aka no traction and a bad launch 92 VR-4....work in progress. http://www.3si.org/forum/f1/project-...5/#post4899857 |
#730 (permalink) |
2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 11.Thump`Master (conversion) 3KGT 5 spd 12. JAL (conversion) 3KGT SOHC TT 13. ZachRT (single turbo) Stealth RT 14. 3KHI (Engine Swap) 3KGT DR-900's, Stage 3 Heads, Street Cams. 15. Juko (supercharged) 3KGT 16. SLAYER4ALL (supercharged) 3KGT 17. Snake93gt (supercharged) 3KGT SL 18. Spawn (supercharged) 3KGT SOHC ATX 19. OhFoSho (engine swap) SOHC Stealth 20. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 21. shooter83 (engine swap) Stealth es 5spd 22. upyun (engine swap) 3kgt sl 23. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES 24. Evangelist (TT Conversion) Stealth ES/TT 5 spd 25. Blue-GTO (TT Conversion) 3kgt SL 26. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 27. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 28. bigballsofpaint (TT conversion) 95 3k base....i finally finished 29. 92-3000GT (Single turbo) 3000gt sl 5spd 30. Optamix (engine swap) 3KGT SL 5spd 31. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 32. Quintop (engine swap) '95 SL 5 sp 33. Jigzibit (conversion) '95 SL ATX 34. 93 Stealth R/T (TT conversion) 35. Bob The Great (TT conversion) 93 R/T AWD 5spd 36. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's 37. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness. 38. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 39. 3000hybrid (TT swap) 97 base GT- ATX to 5spd AWD tranny w/SFR LSD 19T's 40. 95red3000gt (TT conversion) only one in Colorado! 41. Jeremy C (TT conversion) - weekend project 42. Vortac (TT Conversion) SL ATX 43. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 44. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD 45. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD 46. Import Power Online-Fastest-Quickest-Dyno Record 132.97MPH/11.44-14bs/519HP EVOIIIs-5spd AWD The new FWD Record 47.93_black_R/T - Finished May 2004 48. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 49. rush6432 ( Single turbo conversion, stock 10:1 motor) 50. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 156K 51. Zumin3K - TT Swap) 9bs, TT ECU + Harness 52. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 53. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 54. aaron97- (conversion) 3000GT SL 55. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 56. |4x4 nv| - (TT Swap) Evo3 16G's/Forged Internals(8.1:1 compression)/680cc injectors/Garrett FMIC/Propane/maftpro 57. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain/FMIC 58. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 59. kdog109sd (TT Conversion) - one of the first automatics to do it 60. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 61. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 62. KevD23 (single turbo) '94 stealth ATX 63. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife 64. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads 65. Pantherchams (Supercharged) 93 Stealth ES ATX 66. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT 67. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!) 68. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???) 69. Jomojr (TT Conversion 93 Base ATX) 70. Cobane (J-Spec Swap) 94 r/t 5-spd. 71. LeRoyDL (92 R/T DR650 Blow through TT Conv. JDM ECU, N/A harness) 72. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness. 73. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods 74. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX 75. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's 76.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2. 77. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500 78. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition 79. OneWingedAngel - 97 3000GT SL T/T conversion 80. 91StealthBaseTT - TT 10:1 compression fully rebuilt engine including valve job (: 81. PearlRyde - '92 TT Swap into a '99Base... Running on SOHC Tranny until i can rebuild the Getrag... 82. 94mitsumichael7 - 94 Stealth RT... FWD 9b's 8 psi, TT ECU, 10:1 motor, new EVERYTHING. lol. But its finally done and running!!! 83. templar - 94 3000GT ATX TT Conversion. 84. Nojinxz - .080 over supercharged running 6lbs boost - running very well 85. GTOGIRL3000 ~ 94 SL-TT and 5 speed NA MTX swap, 10:1 comp.,TT ECU and harness, SFR LSD. 86. Forsakenwolf - '91 ES-TT w/ 5spd NA MTX, 8:1 comp 87. white96tt - (engine swap) 95 Stealth Base ATX; 15gs 88. DSMGTO - 94 SL N/A motor, TT ECU, TT Fuel pump, 360 inj. 89. AyeKay 94 SL Twin Turbo with all the TT Parts 10:1 7lbs of Boost 90. blk92sl - now SLTT!!! just started her for the first time last night..6/17/06 91. Zeiss - 94 Stealth RT Luxury with 13gs 10:1 and SFR LSD insert. 92. Wildarmz - 94 SL TT, 92 TT Ecu 93.MagnaVR4 - 99 base single cam to TT, 4bolt motor swap, 6spd 94. SeekNStrike- Stock TT swap. blitz boost con. S-AFCII 95. Rican3kgt- (Supercharged) Low comp pistons with forged internals, 12psi, tt ecu 96. King_Milo- TT swap, many mods, still stock turbo's 97. Guywit94sl - TT conversion 94 SLTT 98. J-Groove - 9:1 Ross forged '95 base TT 99. 94ATXVR2- TT engine swap, 17g's and Atx to 5spd getrag conversion. 100. Gen13kgt - TT Engine Swap. 101. 4u2nV - TT Conversion; 98SLTT; Stock 9b's @ 8PSI; Mod's in Sig. 102. Ryan94rt- TT convo, Two many mods 103. BigTyla - TT conversion on ATX with TT ECU 104. Rowlandzz - JDM TT Swap running smooth 105. Ghetoriger12 - single turbo supert70 running 21psi. running and happy... 106. Mr.30000 - TT Conversion w/ Custom Hybrid 13T's and a bunch of BPU on a 95 Base 3000GT 107. Tug - 9b's, TT ecu, 360cc injectors, 10:1 motor, VR4 heads 108. boardFreak5 - front mount, 4inch ICH, 99lifters, getting tuned soon 109. green-lantern - 95 base TT lots of mods and having fun 110. Yask4it- 91 R/T Auto TT conversion with mods 111. Fbc_978- 93 3000gt base TT conversion with bpu 112. thetjkid- 92 r/t stealth tt conversion running great ________________________________________________________ In Progress (remove your name when finished and add to completed list) 1. xtremewlr (conversion) collecting parts slowly 2. rtrotter (supercharged) 3KGT 3. Whitewavesea (single turbo) 3kgt Installation in progress 4. Aph (conversion) - Dec 17 '03 5. JRock4000 (conversion) 3000GT -should be done this January 6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 7. Mitch007 (conversion) expected completion by beginning of summer 8. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend. 9. AkiraGT (TT swap already started) 10. StealthTT (just need turbos and ICs with pipes) 11. Chant (TT / SuperCharger Conversion) :0) 12. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger 13. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap. 14. Renegadex181- Saving money and collecting parts...to start by April 15th 15. Clipse20 - 94TT Swap w/ JapSpec ECU & Harness 16. spaceace60 - 96'base w/98'tt vr4motor 17. Presto97sl - TT conversion ATX check sig for days until install 18. MilkyClr69 - 96SL w/ 92JDMTT motor/5spd TT tranny waiting on parts 19. Nobodylikeswood - 94 SL u TT conversion 20. WolfSL - TT conversion - collecting parts 21. 92StealthR/T - Have all parts but oil cooler for my tt conversion 22. TruPnoyFlava - 94 base (VR4 swaP) 23. Ellery Clinton - Got all my parts... just need the 94/95 Harness and Ceramic Coat everything 24. Its Fwd - 94 base coming back to life, soon to be TT 25. My92Stealth - 92 Base, Putting in a TT this winter! 26. 2inTrbo - Some TT parts already installed...TRUELY IN PROGRESS!! 27. zack6G72- A few parts on there way and then a clutch replacement. 28. ATXSUX- gathering parts as we speak, lack downpipe, gauges, ECU and Harness and a couple of little things. 29. Guywit94sl - everythings bolted up, jus need to finish o2 and ecu wiring 30. 3startuna - limited by founds expected completion date summer 07 31. 963KSLTT - hoping to be done by summer '07 =] 32. BStewart87 - ( 15g TT Swap | ATX --> MTX ) - Summer 2007!!!
In the middle of my TT conversion. stock 9Bs, stock intercoolers, doing 120k tuneup, replacing rod bearings main bearings and thrust bearings, maximal performance front and rear solid motor mounts, safc II, and in the near future hopefully a FWD converted getrag tranny.
