Old 11-11-2007, 12:22 PM   #711 (permalink)
vyper1 is an unknown quantity at this point
Default Re: FWD TT cars.. how many are there now?
i finished my TT swap the end of the summer this year took just over a week
vyper1 is offline   Reply With Quote
Old 12-16-2007, 12:58 PM   #712 (permalink)
cyber bully
Trader Rating: (7)
green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7
done or is just the beginning
Old 12-24-2007, 08:06 PM   #713 (permalink)
cyber bully
Trader Rating: (7)
1. stu_04 (conversion) 3KGT SL ATX
2. punkasscrab (conversion) 3KGT 5 spd
3. SLguy (conversion) 3KGT ATX <---going down to 8:1
4. JB (engine swap) 3KGT 5spd
5. Mikes95RT (conversion) Stealth R/T 5 spd
6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo
7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1
8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original
9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd
10. X GTO X (engine swap) 3KGT (VR-2)
11.Thump`Master (conversion) 3KGT 5 spd
12. JAL (conversion) 3KGT SOHC TT
13. ZachRT (single turbo) Stealth RT
14. 3KHI (Engine Swap) 3KGT DR-900's, Stage 3 Heads, Street Cams.
15. Juko (supercharged) 3KGT
16. SLAYER4ALL (supercharged) 3KGT
17. Snake93gt (supercharged) 3KGT SL
18. Spawn (supercharged) 3KGT SOHC ATX
19. OhFoSho (engine swap) SOHC Stealth
20. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd
21. shooter83 (engine swap) Stealth es 5spd
22. upyun (engine swap) 3kgt sl
23. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES
24. Evangelist (TT Conversion) Stealth ES/TT 5 spd
25. Blue-GTO (TT Conversion) 3kgt SL
26. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd
27. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe
28. bigballsofpaint (TT conversion) 95 3k base....i finally finished
29. 92-3000GT (Single turbo) 3000gt sl 5spd
30. Optamix (engine swap) 3KGT SL 5spd
31. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months)
32. Quintop (engine swap) '95 SL 5 sp
33. Jigzibit (conversion) '95 SL ATX
34. 93 Stealth R/T (TT conversion)
35. Bob The Great (TT conversion) 93 R/T AWD 5spd
36. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's
37. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness.
38. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT
39. 3000hybrid (TT swap) 97 base GT- ATX to 5spd AWD tranny w/SFR LSD 19T's
40. 95red3000gt (TT conversion) only one in Colorado!
41. Jeremy C (TT conversion) - weekend project
42. Vortac (TT Conversion) SL ATX
43. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd.
44. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD
45. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD
46. Import Power Online-Fastest-Quickest-Dyno Record 132.97MPH/11.44-14bs/519HP EVOIIIs-5spd AWD The new FWD Record
47.93_black_R/T - Finished May 2004
48. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu
49. rush6432 ( Single turbo conversion, stock 10:1 motor)
50. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 156K
51. Zumin3K - TT Swap) 9bs, TT ECU + Harness
52. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap
53. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL
54. aaron97- (conversion) 3000GT SL
55. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc
56. |4x4 nv| - (TT Swap) Evo3 16G's/Forged Internals(8.1:1 compression)/680cc injectors/Garrett FMIC/Propane/maftpro
57. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain/FMIC
58. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo
59. kdog109sd (TT Conversion) - one of the first automatics to do it
60. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi
61. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX
62. KevD23 (single turbo) '94 stealth ATX
63. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife
64. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads
65. Pantherchams (Supercharged) 93 Stealth ES ATX
66. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT
67. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!)
68. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???)
69. Jomojr (TT Conversion 93 Base ATX)
70. Cobane (J-Spec Swap) 94 r/t 5-spd.
71. LeRoyDL (92 R/T DR650 Blow through TT Conv. JDM ECU, N/A harness)
72. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness.
73. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods
74. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX
75. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's
76.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2.
77. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500
78. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition
79. OneWingedAngel - 97 3000GT SL T/T conversion
80. 91StealthBaseTT - TT 10:1 compression fully rebuilt engine including valve job (:
81. PearlRyde - '92 TT Swap into a '99Base... Running on SOHC Tranny until i can rebuild the Getrag...
82. 94mitsumichael7 - 94 Stealth RT... FWD 9b's 8 psi, TT ECU, 10:1 motor, new EVERYTHING. lol. But its finally done and running!!!
83. templar - 94 3000GT ATX TT Conversion.
84. Nojinxz - .080 over supercharged running 6lbs boost - running very well
85. GTOGIRL3000 ~ 94 SL-TT and 5 speed NA MTX swap, 10:1 comp.,TT ECU and harness, SFR LSD.
86. Forsakenwolf - '91 ES-TT w/ 5spd NA MTX, 8:1 comp
87. white96tt - (engine swap) 95 Stealth Base ATX; 15gs
88. DSMGTO - 94 SL N/A motor, TT ECU, TT Fuel pump, 360 inj.
89. AyeKay 94 SL Twin Turbo with all the TT Parts 10:1 7lbs of Boost
90. blk92sl - now SLTT!!! just started her for the first time last night..6/17/06
91. Zeiss - 94 Stealth RT Luxury with 13gs 10:1 and SFR LSD insert.
92. Wildarmz - 94 SL TT, 92 TT Ecu
93.MagnaVR4 - 99 base single cam to TT, 4bolt motor swap, 6spd
94. SeekNStrike- Stock TT swap. blitz boost con. S-AFCII
95. Rican3kgt- (Supercharged) Low comp pistons with forged internals, 12psi, tt ecu
96. King_Milo- TT swap, many mods, still stock turbo's
97. Guywit94sl - TT conversion 94 SLTT
98. J-Groove - 9:1 Ross forged '95 base TT
99. 94ATXVR2- TT engine swap, 17g's and Atx to 5spd getrag conversion.
100. Gen13kgt - TT Engine Swap.
101. 4u2nV - TT Conversion; 98SLTT; Stock 9b's @ 8PSI; Mod's in Sig.
102. Ryan94rt- TT convo, Two many mods
103. BigTyla - TT conversion on ATX with TT ECU
104. Rowlandzz - JDM TT Swap running smooth
105. Ghetoriger12 - single turbo supert70 running 21psi. running and happy...
106. Mr.30000 - TT Conversion w/ Custom Hybrid 13T's and a bunch of BPU on a 95 Base 3000GT
107. Tug - 9b's, TT ecu, 360cc injectors, 10:1 motor, VR4 heads
108. boardFreak5 - front mount, 4inch ICH, 99lifters, getting tuned soon
109. green-lantern - 95 base TT lots of mods and having fun
________________________________________________________
In Progress (remove your name when finished and add to completed list)
1. xtremewlr (conversion) collecting parts slowly
2. rtrotter (supercharged) 3KGT
3. Whitewavesea (single turbo) 3kgt Installation in progress
4. Aph (conversion) - Dec 17 '03
5. JRock4000 (conversion) 3000GT -should be done this January
6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad
7. Mitch007 (conversion) expected completion by beginning of summer
8. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend.
9. AkiraGT (TT swap already started)
10. StealthTT (just need turbos and ICs with pipes)
11. Chant (TT / SuperCharger Conversion) :0)
12. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger
13. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap.
14. Renegadex181- Saving money and collecting parts...to start by April 15th
15. Clipse20 - 94TT Swap w/ JapSpec ECU & Harness
16. spaceace60 - 96'base w/98'tt vr4motor
17. Presto97sl - TT conversion ATX check sig for days until install
18. MilkyClr69 - 96SL w/ 92JDMTT motor/5spd TT tranny waiting on parts
19. Nobodylikeswood - 94 SL u TT conversion
20. WolfSL - TT conversion - collecting parts
21. 92StealthR/T - Have all parts but oil cooler for my tt conversion
22. TruPnoyFlava - 94 base (VR4 swaP)
23. Ellery Clinton - Got all my parts... just need the 94/95 Harness and Ceramic Coat everything
24. Its Fwd - 94 base coming back to life, soon to be TT
25. My92Stealth - 92 Base, Putting in a TT this winter!
26. 2inTrbo - Some TT parts already installed...TRUELY IN PROGRESS!!
27. zack6G72- A few parts on there way and then a clutch replacement.
28. ATXSUX- gathering parts as we speak, lack downpipe, gauges, ECU and Harness and a couple of little things.
29. Guywit94sl - everythings bolted up, jus need to finish o2 and ecu wiring
30. 3startuna - limited by founds expected completion date summer 07
31. 963KSLTT - hoping to be done by summer '07 =]
Old 12-24-2007, 08:19 PM   #714 (permalink)
Forum user
raven1231's Avatar
Drives: Singleturbo3k/Z31T
raven1231 Level 1raven1231 Level 1
Nice to see yours is done
Built and Tuned By RUSH6432 and IPS motorsports
Currently 384whp@wategate 6.8psi
Weight=2890lbs
(Currently down.probably will be for awhile if not for good)
raven1231 is offline   Reply With Quote
Old 12-24-2007, 08:42 PM   #715 (permalink)
R3KGT's Avatar
Drives: 91 3KGT FWDTTATX
R3KGT is an unknown quantity at this point
110. r3kgt-91 3KGT Base Automatic TT engine conversion
R3KGT is offline   Reply With Quote
Old 12-27-2007, 08:33 AM   #716 (permalink)
Born In Italy
italiano3kgt's Avatar
Drives: 1993 3000gt vr4
italiano3kgt is an unknown quantity at this point
aaahhhh this looks like a great place to post and get some good advice....
i have a 1993 3000gt base model automatic..this is my plan. im going to take my car to a customization shop called millennium in va. im going to get a turbo engine (vr-4 engine) put in with a manual transmission. my engine now has 208,000 miles and its about done.. then im going with the basic twin 9b's setup..BUT the only problem with this is its around 8 grand.. everyone says sell it and buy a vr-4.. but i cant let my baby go i have had way to many cosmetic things done.. so is this the only route i can take?? has anyone else done something similar to this??
italiano3kgt is offline   Reply With Quote
Old 12-27-2007, 10:47 AM   #717 (permalink)
cyber bully
Trader Rating: (7)
For 8000 you could buy a vr4 and keep the n/a. If you are not going to do the work yourself you will have to pay someone to do it.
btw you should probably start a thread instead of useing this one.
Old 02-20-2008, 05:41 AM   #718 (permalink)
Forum user
raven1231's Avatar
you cant be serious
Old 02-20-2008, 08:00 AM   #719 (permalink)
Resident rocket scientist
BigTyla's Avatar
Drives: '93 3000GT ATX TT
Trader Rating: (173)
BigTyla Level 5BigTyla Level 5BigTyla Level 5BigTyla Level 5BigTyla Level 5BigTyla Level 5
Originally Posted by raven1231 View Post
you cant be serious
Leave the three month old posts alone.
1993 3000GT FWD ATX TT - daily<----------------------->1984 Nissan Maxima - project
Old 02-21-2008, 06:18 AM   #720 (permalink)
OhFoSho's Avatar
Drives: 95 Base Stealth TT
OhFoSho is an unknown quantity at this point
I have done something like that.....
just not the auto to manual trans swap.
95 Base Stealth TT motor swap
motor
15gs, 550 cc denso, FMIC, Altered's fuel system, Hot wired Fuel pump, lightweight flywheel, RPS III, SSC Bov, Super AFC, perfec B, gutted pre-cats w/ AAM exhaust.
Wheels
Volk gram lights wrapped with street slicks
Suspention
KYB-2s, Intrax, 3sx front sway bar, Cusco rear strut bar.
Exterior
99 front bumper, 92 Stealth TT sides, 91 R/T sail panels, 97 wing, 95 GT rear bumper, GTO tail lights, 94 GT center piece, shaved emblems, trunk key hole, antenna, and reverse lights.
Interior
Dynamat, Dynamat, Dynamat (doors 2 layers, entire car, and waiting on trunk) charcoal A pillar and headliner conversion, TT charcoal visors, Avic N-1, XM radio, JL 500/1, JL 10w7, Boston Z6 front speakers..and coming soon JL 300/2
OhFoSho is offline   Reply With Quote
