Old 08-02-2007, 04:14 PM   #691 (permalink)
I own car? Car PWNS me?
TajMan's Avatar
Drives: '00 R1!
Trader Rating: (25)
TajMan is an unknown quantity at this point
Default Re: FWD TT cars.. how many are there now?
thanks for reminding me
former 3/Ss: '92 R/T, '94 3KGT, modded '92 R/T TT
'00 R1 I've got in Jersey for the summer!
TajMan is offline   Reply With Quote
Old 08-02-2007, 07:38 PM   #692 (permalink)
Crash diet for car geeks
Drives: 1993 3000GT ATX
vertigospiral88 is an unknown quantity at this point
N/p, just saw a post of his before I read yours -- made it easier to remember .
Tom
vertigospiral88 is offline   Reply With Quote
Old 10-07-2007, 09:29 PM   #693 (permalink)
Now a VR-4 driver
boardFreak5's Avatar
Drives: 94 VR-4, 93 fwdtt.
boardFreak5 is an unknown quantity at this point
1. stu_04 (conversion) 3KGT SL ATX
2. punkasscrab (conversion) 3KGT 5 spd
3. SLguy (conversion) 3KGT ATX <---going down to 8:1
4. JB (engine swap) 3KGT 5spd
5. Mikes95RT (conversion) Stealth R/T 5 spd
6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo
7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1
8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original
9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd
10. X GTO X (engine swap) 3KGT (VR-2)
11.Thump`Master (conversion) 3KGT 5 spd
12. JAL (conversion) 3KGT SOHC TT
13. ZachRT (single turbo) Stealth RT
14. 3KHI (Engine Swap) 3KGT DR-900's, Stage 3 Heads, Street Cams.
15. Juko (supercharged) 3KGT
16. SLAYER4ALL (supercharged) 3KGT
17. Snake93gt (supercharged) 3KGT SL
18. Spawn (supercharged) 3KGT SOHC ATX
19. OhFoSho (engine swap) SOHC Stealth
20. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd
21. shooter83 (engine swap) Stealth es 5spd
22. upyun (engine swap) 3kgt sl
23. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES
24. Evangelist (TT Conversion) Stealth ES/TT 5 spd
25. Blue-GTO (TT Conversion) 3kgt SL
26. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd
27. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe
28. bigballsofpaint (TT conversion) 95 3k base....i finally finished
29. 92-3000GT (Single turbo) 3000gt sl 5spd
30. Optamix (engine swap) 3KGT SL 5spd
31. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months)
32. Quintop (engine swap) '95 SL 5 sp
33. Jigzibit (conversion) '95 SL ATX
34. 93 Stealth R/T (TT conversion)
35. Bob The Great (TT conversion) 93 R/T AWD 5spd
36. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's
37. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness.
38. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT
39. 3000hybrid (TT swap) 97 base GT- ATX to 5spd AWD tranny w/SFR LSD 19T's
40. 95red3000gt (TT conversion) only one in Colorado!
41. Jeremy C (TT conversion) - weekend project
42. Vortac (TT Conversion) SL ATX
43. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd.
44. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD
45. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD
46. Import Power Online-Fastest-Quickest-Dyno Record 132.97MPH/11.44-14bs/519HP EVOIIIs-5spd AWD The new FWD Record
47.93_black_R/T - Finished May 2004
48. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu
49. rush6432 ( Single turbo conversion, stock 10:1 motor)
50. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 156K
51. Zumin3K - TT Swap) 9bs, TT ECU + Harness
52. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap
53. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL
54. aaron97- (conversion) 3000GT SL
55. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc
56. |4x4 nv| - (TT Swap) Evo3 16G's/Forged Internals(8.1:1 compression)/680cc injectors/Garrett FMIC/Propane/maftpro
57. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain/FMIC
58. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo
59. kdog109sd (TT Conversion) - one of the first automatics to do it
60. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi
61. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX
62. KevD23 (single turbo) '94 stealth ATX
63. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife
64. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads
65. Pantherchams (Supercharged) 93 Stealth ES ATX
66. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT
67. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!)
68. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???)
69. Jomojr (TT Conversion 93 Base ATX)
70. Cobane (J-Spec Swap) 94 r/t 5-spd.
71. LeRoyDL (92 R/T DR650 Blow through TT Conv. JDM ECU, N/A harness)
72. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness.
73. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods
74. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX
75. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's
76.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2.
77. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500
78. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition
79. OneWingedAngel - 97 3000GT SL T/T conversion
80. 91StealthBaseTT - TT 10:1 compression fully rebuilt engine including valve job (:
81. PearlRyde - '92 TT Swap into a '99Base... Running on SOHC Tranny until i can rebuild the Getrag...
82. 94mitsumichael7 - 94 Stealth RT... FWD 9b's 8 psi, TT ECU, 10:1 motor, new EVERYTHING. lol. But its finally done and running!!!
83. templar - 94 3000GT ATX TT Conversion.
84. Nojinxz - .080 over supercharged running 6lbs boost - running very well
85. GTOGIRL3000 ~ 94 SL-TT and 5 speed NA MTX swap, 10:1 comp.,TT ECU and harness, SFR LSD.
86. Forsakenwolf - '91 ES-TT w/ 5spd NA MTX, 8:1 comp
87. white96tt - (engine swap) 95 Stealth Base ATX; 15gs
88. DSMGTO - 94 SL N/A motor, TT ECU, TT Fuel pump, 360 inj.
89. AyeKay 94 SL Twin Turbo with all the TT Parts 10:1 7lbs of Boost
90. blk92sl - now SLTT!!! just started her for the first time last night..6/17/06
91. Zeiss - 94 Stealth RT Luxury with 13gs 10:1 and SFR LSD insert.
92. Wildarmz - 94 SL TT, 92 TT Ecu
93.MagnaVR4 - 99 base single cam to TT, 4bolt motor swap, 6spd
94. SeekNStrike- Stock TT swap. blitz boost con. S-AFCII
95. Rican3kgt- (Supercharged) Low comp pistons with forged internals, 12psi, tt ecu
96. King_Milo- TT swap, many mods, still stock turbo's
97. Guywit94sl - TT conversion 94 SLTT
98. J-Groove - 9:1 Ross forged '95 base TT
99. 94ATXVR2- TT engine swap, 17g's and Atx to 5spd getrag conversion.
100. Gen13kgt - TT Engine Swap.
101. 4u2nV - TT Conversion; 98SLTT; Stock 9b's @ 8PSI; Mod's in Sig.
102. Ryan94rt- TT convo, Two many mods
103. BigTyla - TT conversion on ATX with TT ECU
104. Rowlandzz - JDM TT Swap running smooth
105. Ghetoriger12 - single turbo supert70 running 21psi. running and happy...
106. Mr.30000 - TT Conversion w/ Custom Hybrid 13T's and a bunch of BPU on a 95 Base 3000GT
107. Tug - 9b's, TT ecu, 360cc injectors, 10:1 motor, VR4 heads
108. boardFreak5 - ATX, 1st gen tt ecu, 10:1 compression, etc.
________________________________________________________________
In Progress (remove your name when finished and add to completed list)
1. xtremewlr (conversion) collecting parts slowly
2. rtrotter (supercharged) 3KGT
3. Whitewavesea (single turbo) 3kgt Installation in progress
4. Aph (conversion) - Dec 17 '03
5. JRock4000 (conversion) 3000GT -should be done this January
6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad
7. Mitch007 (conversion) expected completion by beginning of summer
8. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend.
9. AkiraGT (TT swap already started)
10. StealthTT (just need turbos and ICs with pipes)
11. Chant (TT / SuperCharger Conversion) :0)
12. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger
13. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap.
14. Renegadex181- Saving money and collecting parts...to start by April 15th
15. Clipse20 - 94TT Swap w/ JapSpec ECU & Harness
16. spaceace60 - 96'base w/98'tt vr4motor
17. Presto97sl - TT conversion ATX check sig for days until install
18. MilkyClr69 - 96SL w/ 92JDMTT motor/5spd TT tranny waiting on parts
19. Nobodylikeswood - 94 SL u TT conversion
20. WolfSL - TT conversion - collecting parts
21. 92StealthR/T - Have all parts but oil cooler for my tt conversion
22. TruPnoyFlava - 94 base (VR4 swaP)
23. Ellery Clinton - Got all my parts... just need the 94/95 Harness and Ceramic Coat everything
24. Its Fwd - 94 base coming back to life, soon to be TT
25. My92Stealth - 92 Base, Putting in a TT this winter!
26. 2inTrbo - Some TT parts already installed...TRUELY IN PROGRESS!!
27. zack6G72- A few parts on there way and then a clutch replacement.
28. ATXSUX- gathering parts as we speak, lack downpipe, gauges, ECU and Harness and a couple of little things.
29. Guywit94sl - everythings bolted up, jus need to finish o2 and ecu wiring
30. 3startuna - limited by founds expected completion date summer 07
31. 963KSLTT - hoping to be done by summer '07 =]
Gewalt evoII's
boardFreak5 is offline   Reply With Quote
Old 10-08-2007, 09:32 AM   #694 (permalink)
2 Time Member of SBC
DigiiManDan3KGT's Avatar
Drives: 80Gig WesternDigital
Trader Rating: (7)
DigiiManDan3KGT is an unknown quantity at this point
I love how people add there silly little mods to the list..
its like 95 TT SWAP 8:1, with Clear Corners.
1 day im going to edit the entire list and take out all the crap
Green 1995 3000GT FWD-TT 8:1 // ATX to MTX // NA to TT // Completed in 2005 // Purchased 11/12/02
White 1999 3000GT Black Dash/Tan Leather Interior // SOHC // MTX // Stock Daily Driver Purchased 7/25/07
Red.._1992 Stealth RT/TT Twin Turbo AWD // Project Car for AWD // Purchased 05/19/08
<-- Click Here Join FL3S
DigiiManDan3KGT is offline   Reply With Quote
Old 10-08-2007, 09:42 AM   #695 (permalink)
"The Fisherman"
pyun's Avatar
Drives: around scaring birds
Trader Rating: (75)
pyun is an unknown quantity at this point
I love that too hahaha
Not that an AWD converted FWD tranny is a silly mod, but you know what I mean .... just being a wiseass again
pyun is offline   Reply With Quote
Old 10-08-2007, 09:57 AM   #696 (permalink)
Trader Rating: (7)
bah you missed the point.
Showing the type of car IE (Transmission type, swap vs conv, and Stock or modded?) is different from the people saying, (RFL BOV, Autometer gauges, Leather steering wheel wrap, etc)
:P
Old 10-08-2007, 12:16 PM   #697 (permalink)
calialx1's Avatar
Drives: 92' 3000Gt Sl
calialx1 is an unknown quantity at this point
I have a 92' SL and om lookin for a 93+ TT for a full engine swap. Any one know were I can find one?
calialx1 is offline   Reply With Quote
Old 10-10-2007, 11:53 AM   #698 (permalink)
Xtreme2k2's Avatar
Drives: 98 SLuTT
Trader Rating: (36)
Xtreme2k2 is an unknown quantity at this point
Remove me, kthxbye.
98 Pearl White 3000GT SLuTT (in the process of being de-whored)
Going back to stock and being sold.
Check out my parts for sale thread!!!
Xtreme2k2 is offline   Reply With Quote
Old 10-10-2007, 12:21 PM   #699 (permalink)
Venom Speed Shop
Venom13132's Avatar
Drives: Small Car Big Engine
Trader Rating: (99)
Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7
6. mitsugtocars (conversion) 3KGT 5 spd, 13T/9b Combo
9. Gonskanator (gt pro conversion) GT347's 3kgt 5spd
20. Telepathy (conversion) Stealth R/T 5 spd
36. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD 18T's
39. 3000hybrid (TT swap) 97 base GT- 5spd AWD tranny w/SFR LSD 19T's
47.93_black_R/T
49. rush6432 ( Single turbo) stock 10:1 motor
53. moneypitGT- (TT Swap) tt ecu/harness/3KGT SL
56. |4x4 nv| - (TT Swap) Evo3 16G's/(8.1:1 compression)/680cc injectors/Garrett FMIC/Propane/maftpro/AWD
72. AJP52987 (95 3000gt, TT conversion) 95 VR4 ECU 94 VR4 harness.
73. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-FWD GETRAG
77. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition
78. OneWingedAngel - 97 3000GT SL T/T conversion
79. 91StealthBaseTT - TT 10:1
80. PearlRyde - '92 TT Swap into a '99Base...
81. 94mitsumichael7 - 94 Stealth RT... FWD 9b's 8 psi, TT ECU, 10:1 motor
82. templar - 94 3000GT ATX TT Conversion.
83. Nojinxz - .080 over supercharged running 6lbs boost
84. GTOGIRL3000 ~ 94 SL-TT and 5 speed NA MTX swap, 10:1 comp.,TT ECU and harness
85. Forsakenwolf - '91 ES-TT w/ 5spd NA MTX, 8:1 comp
86. white96tt - (engine swap) 95 Stealth Base ATX; 15gs
87. DSMGTO - 94 SL N/A motor, TT ECU, TT Fuel pump, 360 inj.
88. AyeKay 94 SL Twin Turbo
89. blk92sl - now SLTT!!!
90. Zeiss - 94 Stealth RT Luxury with 13gs 10:1 and SFR LSD insert.
91. Wildarmz - 94 SL TT, 92 TT Ecu
92.MagnaVR4 - 99 base single cam to TT, 4bolt motor swap, 6spd
93. SeekNStrike- Stock TT swap. blitz boost con. S-AFCII
94. Rican3kgt- (Supercharged) Low comp pistons with forged internals, TTECU
95. King_Milo- TT swap
96. Guywit94sl - TT conversion 94 SLTT
97. J-Groove - 9:1 Ross forged '95 base TT
98. 94ATXVR2- TT engine swap, 17g's and Atx to 5spd getrag.
99. Gen13kgt - TT Engine Swap.
100. 4u2nV - TT Conversion; 98SLTT; Stock 9b's @ 8PSI;
101. Ryan94rt- TT convo
102. BigTyla - TT conversion on ATX with TT ECU
103. Rowlandzz - JDM TT Swap
104. Ghetoriger12 - single turbo supert70 running 21psi. running and happy...
105. Mr.30000 - TT Conversion w/ Custom Hybrid 13T's 95 Base 3kgt
108. boardFreak5 - front mount, 4inch ICH, 99lifters
UPDATED LIST
Venom13132 is offline   Reply With Quote
Old 10-10-2007, 12:27 PM   #700 (permalink)
Trader Rating: (7)
nice work guy
