#671 (permalink) |
Resident rocket scientist
Yeah, honestly it's only a number. What matters is if your shit runs or not.
![]() 1993 3000GT FWD ATX TT - mods coming<---------------->2009 Honda Fit - 40 mpg ftw Topline Engineering ground wire kit Nov/Dec ground wire GB!!! |
#672 (permalink) |
Finally finished. Number 102.
1. stu_04 (conversion) 3KGT SL ATX 2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 11.Thump`Master (conversion) 3KGT 5 spd 12. JAL (conversion) 3KGT SOHC TT 13. ZachRT (single turbo) Stealth RT 14. 3KHI (Engine Swap) 3KGT DR-900's, Stage 3 Heads, Street Cams. 15. Juko (supercharged) 3KGT 16. SLAYER4ALL (supercharged) 3KGT 17. Snake93gt (supercharged) 3KGT SL 18. Spawn (supercharged) 3KGT SOHC ATX 19. OhFoSho (engine swap) SOHC Stealth 20. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 21. shooter83 (engine swap) Stealth es 5spd 22. upyun (engine swap) 3kgt sl 23. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES 24. Evangelist (TT Conversion) Stealth ES/TT 5 spd 25. Blue-GTO (TT Conversion) 3kgt SL 26. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 27. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 28. bigballsofpaint (TT conversion) 95 3k base....i finally finished 29. 92-3000GT (Single turbo) 3000gt sl 5spd 30. Optamix (engine swap) 3KGT SL 5spd 31. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 32. Quintop (engine swap) '95 SL 5 sp 33. Jigzibit (conversion) '95 SL ATX 34. 93 Stealth R/T (TT conversion) 35. Bob The Great (TT conversion) 93 R/T AWD 5spd 36. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's 37. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness. 38. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 39. 3000hybrid (TT swap) 97 base GT- ATX to 5spd AWD tranny w/SFR LSD 19T's 40. 95red3000gt (TT conversion) only one in Colorado! 41. Jeremy C (TT conversion) - weekend project 42. Vortac (TT Conversion) SL ATX 43. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 44. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD 45. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD 46. Import Power Online-Fastest-Quickest-Dyno Record 132.97MPH/11.44-14bs/519HP EVOIIIs-5spd AWD The new FWD Record 47.93_black_R/T - Finished May 2004 48. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 49. rush6432 ( Single turbo conversion, stock 10:1 motor) 50. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 156K 51. Zumin3K - TT Swap) 9bs, TT ECU + Harness 52. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 53. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 54. aaron97- (conversion) 3000GT SL 55. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 56. |4x4 nv| - (TT Swap) Evo3 16G's/Forged Internals(8.1:1 compression)/680cc injectors/Garrett FMIC/Propane/maftpro 57. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain/FMIC 58. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 59. kdog109sd (TT Conversion) - one of the first automatics to do it 60. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 61. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 62. KevD23 (single turbo) '94 stealth ATX 63. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife 64. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads 65. Pantherchams (Supercharged) 93 Stealth ES ATX 66. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT 67. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!) 68. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???) 69. Jomojr (TT Conversion 93 Base ATX) 70. Venom13132 (92 RT, swap 96 vr4 engine, 92vr4 ecu 92vr4 harness, 91 Getrag running FWD, LSD insert, TT Calipers) 71. Cobane (J-Spec Swap) 94 r/t 5-spd. 72. LeRoyDL (92 R/T DR650 Blow through TT Conv. JDM ECU, N/A harness) 73. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness. 74. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods 75. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX 76. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's 77.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2. 78. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500 79. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition 80. OneWingedAngel - 97 3000GT SL T/T conversion 81. 91StealthBaseTT - TT 10:1 compression fully rebuilt engine including valve job (: 82. PearlRyde - '92 TT Swap into a '99Base... Running on SOHC Tranny until i can rebuild the Getrag... 83. 94mitsumichael7 - 94 Stealth RT... FWD 9b's 8 psi, TT ECU, 10:1 motor, new EVERYTHING. lol. But its finally done and running!!! 84. templar - 94 3000GT ATX TT Conversion. 85. Nojinxz - .080 over supercharged running 6lbs boost - running very well 86. GTOGIRL3000 ~ 94 SL-TT and 5 speed NA MTX swap, 10:1 comp.,TT ECU and harness, SFR LSD. 87. Forsakenwolf - '91 ES-TT w/ 5spd NA MTX, 8:1 comp 88. white96tt - (engine swap) 95 Stealth Base ATX; 15gs/550 injectors/forged pistons, etc... (fired up for first time today 05/10/2006) 89. DSMGTO - 94 SL N/A motor, TT ECU, TT Fuel pump, 360 inj. 90. AyeKay 94 SL Twin Turbo with all the TT Parts 10:1 7lbs of Boost 91. blk92sl - now SLTT!!! just started her for the first time last night..6/17/06 92. Zeiss - 94 Stealth RT Luxury with 13gs 10:1 and SFR LSD insert. 93. Wildarmz - 94 SL TT, 92 TT Ecu, wastegate, SFR LSD, ACT2100, 3" Tanabe Hyper Medallion exhaust, ss downpipe. 94.MagnaVR4 - 99 base single cam to TT, 4bolt motor swap, 6spd,255 walbro, Greddy Type S, 3''exhaust ,Blitz Turbo Timer, 4 pistion brakes front, 2 pistion brakes rear, 95. SeekNStrike- Stock TT swap. blitz boost con. S-AFCII, AEM wideband, Auto meter boost + EGT guages. Supra pump. 6 psi. 96. Rican3kgt- (Supercharged) Low comp pistons with forged internals, 12psi, tt ecu 97. King_Milo- TT swap, many mods, still stock turbo's 98. Guywit94sl - TT conversion 94 SLTT 99. J-Groove - 9:1 Ross forged '95 base TT 100. 94ATXVR2- TT engine swap, 17g's and Atx to 5spd getrag conversion. 101. Gen13kgt - TT Engine Swap. Quaife LSD, RPS Flywheel, ACT 2600, 3SX Pulley, Stillen DP, no rear precat, custom catback, Turbo XS RFL, Setrab front mount oil cooler, DSM SMIC's, DNP IC Pipes, K&N FIPK, Turbo XS MBC, Poly mounts, Fuel Pump Rewire, Wabro 255... and a few more.. 102. 4u2nV - TT Conversion; 98SLTT; Stock 9b's @ 8PSI; Mod's in Sig. In Progress (remove your name when finished and add to completed list) 1. xtremewlr (conversion) collecting parts slowly 2. rtrotter (supercharged) 3KGT 3. Whitewavesea (single turbo) 3kgt Installation in progress 4. Aph (conversion) - Dec 17 '03 5. JRock4000 (conversion) 3000GT -should be done this January 6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 7. Mitch007 (conversion) expected completion by beginning of summer 8. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend. 9. AkiraGT (TT swap already started) 10. StealthTT (just need turbos and ICs with pipes) 11. Chant (TT / SuperCharger Conversion) :0) 12. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger 13. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap. 14. Renegadex181- Saving money and collecting parts...to start by April 15th XX. YOGURT! - MYKISS69 BLOWS didnt get my parts in time, sold to SONICBOUNCE17 15. Clipse20 - 94TT Swap w/ JapSpec ECU & Harness 16. spaceace60 - 96'base w/98'tt vr4motor 17. Presto97sl - TT conversion ATX check sig for days until install 18. MilkyClr69 - 96SL w/ 92JDMTT motor/5spd TT tranny waiting on parts 19. Nobodylikeswood - 94 SL u TT conversion 20. WolfSL - TT conversion - collecting parts 21. 92StealthR/T - Have all parts but oil cooler for my tt conversion 22. TruPnoyFlava - 94 base (VR4 swaP) 23. Ellery Clinton - Got all my parts... just need the 94/95 Harness and Ceramic Coat everything 24. Its Fwd - 94 base coming back to life, soon to be TT 25. My92Stealth - 92 Base, Putting in a TT this winter! 26. 2inTrbo - Some TT parts already installed...TRUELY IN PROGRESS!! 27. zack6G72- A few parts on there way and then a clutch replacement. 28. ATXSUX- gathering parts as we speak, lack downpipe, gauges, ECU and Harness and a couple of little things.[/quote]30. Guywit94sl - everythings bolted up, jus need to finish o2 and ecu wiring 29. Mr.30000-TT Conversion w/ 9b's converted to 13G's, ported manifolds, 450cc injectors. Just picking up the last tuning parts and misc bolts now...almost completed 30. 3startuna - limited by founds expected completion date summer 07 31. ryan94rt -I guess i should add myself, getting my block and heads back today and installing all TT parts this week. should be totallly completed in 2weeks! 32. 963KSLTT - hoping to be done by summer '07 =] 33. BigTyla - everything on but the oil pan[/quote]
1998 DOHC 3000GT - FWDTT - 309 FWHP @ 8 PSI
Modifications : Performance ; ATX -> VR-4 MTX Swap -> TT Conversion (9b's); Limited Slip Differential, RPS Street Max Clutch, RPS Lightened Flywheel, Short Shifter, MSD Spark Plug Wires and Spark Plugs, Air Intake, Unorthodox Underdrive Pulley, Stillen Downpipe, Rear Precat Eliminator, ATR Single Shot Exhaust, Fidanza Adjustable Cam Gears, Greddy Prfec-B Boost Controller, Greddy Type-S BOV, Nexus Gauges, Eibach Lowering Springs, Solid Motor Mounts, Dyna Batt, Kazera KZ-A Lightweight Rims, Fuzion ZRI Tires. Appearance ; Clear Corners |
#673 (permalink) |
Ryan94rt
2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 11.Thump`Master (conversion) 3KGT 5 spd 12. JAL (conversion) 3KGT SOHC TT 13. ZachRT (single turbo) Stealth RT 14. 3KHI (Engine Swap) 3KGT DR-900's, Stage 3 Heads, Street Cams. 15. Juko (supercharged) 3KGT 16. SLAYER4ALL (supercharged) 3KGT 17. Snake93gt (supercharged) 3KGT SL 18. Spawn (supercharged) 3KGT SOHC ATX 19. OhFoSho (engine swap) SOHC Stealth 20. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 21. shooter83 (engine swap) Stealth es 5spd 22. upyun (engine swap) 3kgt sl 23. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES 24. Evangelist (TT Conversion) Stealth ES/TT 5 spd 25. Blue-GTO (TT Conversion) 3kgt SL 26. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 27. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 28. bigballsofpaint (TT conversion) 95 3k base....i finally finished 29. 92-3000GT (Single turbo) 3000gt sl 5spd 30. Optamix (engine swap) 3KGT SL 5spd 31. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 32. Quintop (engine swap) '95 SL 5 sp 33. Jigzibit (conversion) '95 SL ATX 34. 93 Stealth R/T (TT conversion) 35. Bob The Great (TT conversion) 93 R/T AWD 5spd 36. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's 37. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness. 38. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 39. 3000hybrid (TT swap) 97 base GT- ATX to 5spd AWD tranny w/SFR LSD 19T's 40. 95red3000gt (TT conversion) only one in Colorado! 41. Jeremy C (TT conversion) - weekend project 42. Vortac (TT Conversion) SL ATX 43. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 44. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD 45. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD 46. Import Power Online-Fastest-Quickest-Dyno Record 132.97MPH/11.44-14bs/519HP EVOIIIs-5spd AWD The new FWD Record 47.93_black_R/T - Finished May 2004 48. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 49. rush6432 ( Single turbo conversion, stock 10:1 motor) 50. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 156K 51. Zumin3K - TT Swap) 9bs, TT ECU + Harness 52. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 53. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 54. aaron97- (conversion) 3000GT SL 55. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 56. |4x4 nv| - (TT Swap) Evo3 16G's/Forged Internals(8.1:1 compression)/680cc injectors/Garrett FMIC/Propane/maftpro 57. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain/FMIC 58. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 59. kdog109sd (TT Conversion) - one of the first automatics to do it 60. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 61. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 62. KevD23 (single turbo) '94 stealth ATX 63. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife 64. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads 65. Pantherchams (Supercharged) 93 Stealth ES ATX 66. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT 67. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!) 68. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???) 69. Jomojr (TT Conversion 93 Base ATX) 70. Venom13132 (92 RT, swap 96 vr4 engine, 92vr4 ecu 92vr4 harness, 91 Getrag running FWD, LSD insert, TT Calipers) 71. Cobane (J-Spec Swap) 94 r/t 5-spd. 72. LeRoyDL (92 R/T DR650 Blow through TT Conv. JDM ECU, N/A harness) 73. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness. 74. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods 75. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX 76. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's 77.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2. 78. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500 79. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition 80. OneWingedAngel - 97 3000GT SL T/T conversion 81. 91StealthBaseTT - TT 10:1 compression fully rebuilt engine including valve job (: 82. PearlRyde - '92 TT Swap into a '99Base... Running on SOHC Tranny until i can rebuild the Getrag... 83. 94mitsumichael7 - 94 Stealth RT... FWD 9b's 8 psi, TT ECU, 10:1 motor, new EVERYTHING. lol. But its finally done and running!!! 84. templar - 94 3000GT ATX TT Conversion. 85. Nojinxz - .080 over supercharged running 6lbs boost - running very well 86. GTOGIRL3000 ~ 94 SL-TT and 5 speed NA MTX swap, 10:1 comp.,TT ECU and harness, SFR LSD. 87. Forsakenwolf - '91 ES-TT w/ 5spd NA MTX, 8:1 comp 88. white96tt - (engine swap) 95 Stealth Base ATX; 15gs/550 injectors/forged pistons, etc... (fired up for first time today 05/10/2006) 89. DSMGTO - 94 SL N/A motor, TT ECU, TT Fuel pump, 360 inj. 90. AyeKay 94 SL Twin Turbo with all the TT Parts 10:1 7lbs of Boost 91. blk92sl - now SLTT!!! just started her for the first time last night..6/17/06 92. Zeiss - 94 Stealth RT Luxury with 13gs 10:1 and SFR LSD insert. 93. Wildarmz - 94 SL TT, 92 TT Ecu, wastegate, SFR LSD, ACT2100, 3" Tanabe Hyper Medallion exhaust, ss downpipe. 94.MagnaVR4 - 99 base single cam to TT, 4bolt motor swap, 6spd,255 walbro, Greddy Type S, 3''exhaust ,Blitz Turbo Timer, 4 pistion brakes front, 2 pistion brakes rear, 95. SeekNStrike- Stock TT swap. blitz boost con. S-AFCII, AEM wideband, Auto meter boost + EGT guages. Supra pump. 6 psi. 96. Rican3kgt- (Supercharged) Low comp pistons with forged internals, 12psi, tt ecu 97. King_Milo- TT swap, many mods, still stock turbo's 98. Guywit94sl - TT conversion 94 SLTT 99. J-Groove - 9:1 Ross forged '95 base TT 100. 94ATXVR2- TT engine swap, 17g's and Atx to 5spd getrag conversion. 101. Gen13kgt - TT Engine Swap. Quaife LSD, RPS Flywheel, ACT 2600, 3SX Pulley, Stillen DP, no rear precat, custom catback, Turbo XS RFL, Setrab front mount oil cooler, DSM SMIC's, DNP IC Pipes, K&N FIPK, Turbo XS MBC, Poly mounts, Fuel Pump Rewire, Wabro 255... and a few more.. 102. 4u2nV - TT Conversion; 98SLTT; Stock 9b's @ 8PSI; Mod's in Sig. 103 Ryan94rt- TT convo, Two many mods, really though. look 4 sig update soon. In Progress (remove your name when finished and add to completed list) 1. xtremewlr (conversion) collecting parts slowly 2. rtrotter (supercharged) 3KGT 3. Whitewavesea (single turbo) 3kgt Installation in progress 4. Aph (conversion) - Dec 17 '03 5. JRock4000 (conversion) 3000GT -should be done this January 6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 7. Mitch007 (conversion) expected completion by beginning of summer 8. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend. 9. AkiraGT (TT swap already started) 10. StealthTT (just need turbos and ICs with pipes) 11. Chant (TT / SuperCharger Conversion) :0) 12. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger 13. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap. 14. Renegadex181- Saving money and collecting parts...to start by April 15th XX. YOGURT! - MYKISS69 BLOWS didnt get my parts in time, sold to SONICBOUNCE17 15. Clipse20 - 94TT Swap w/ JapSpec ECU & Harness 16. spaceace60 - 96'base w/98'tt vr4motor 17. Presto97sl - TT conversion ATX check sig for days until install 18. MilkyClr69 - 96SL w/ 92JDMTT motor/5spd TT tranny waiting on parts 19. Nobodylikeswood - 94 SL u TT conversion 20. WolfSL - TT conversion - collecting parts 21. 92StealthR/T - Have all parts but oil cooler for my tt conversion 22. TruPnoyFlava - 94 base (VR4 swaP) 23. Ellery Clinton - Got all my parts... just need the 94/95 Harness and Ceramic Coat everything 24. Its Fwd - 94 base coming back to life, soon to be TT 25. My92Stealth - 92 Base, Putting in a TT this winter! 26. 2inTrbo - Some TT parts already installed...TRUELY IN PROGRESS!! 27. zack6G72- A few parts on there way and then a clutch replacement. 28. ATXSUX- gathering parts as we speak, lack downpipe, gauges, ECU and Harness and a couple of little things.[/quote]30. Guywit94sl - everythings bolted up, jus need to finish o2 and ecu wiring 29. Mr.30000-TT Conversion w/ 9b's converted to 13G's, ported manifolds, 450cc injectors. Just picking up the last tuning parts and misc bolts now...almost completed 30. 3startuna - limited by founds expected completion date summer 07 31. 963KSLTT - hoping to be done by summer '07 =] 32. BigTyla - everything on but the oil pan[/quote]
"Doing things right the first time,,, again, and again, and again."
#674 (permalink) |
Venom Speed Shop
2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 11.Thump`Master (conversion) 3KGT 5 spd 12. JAL (conversion) 3KGT SOHC TT 13. ZachRT (single turbo) Stealth RT 14. 3KHI (Engine Swap) 3KGT DR-900's, Stage 3 Heads, Street Cams. 15. Juko (supercharged) 3KGT 16. SLAYER4ALL (supercharged) 3KGT 17. Snake93gt (supercharged) 3KGT SL 18. Spawn (supercharged) 3KGT SOHC ATX 19. OhFoSho (engine swap) SOHC Stealth 20. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 21. shooter83 (engine swap) Stealth es 5spd 22. upyun (engine swap) 3kgt sl 23. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES 24. Evangelist (TT Conversion) Stealth ES/TT 5 spd 25. Blue-GTO (TT Conversion) 3kgt SL 26. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 27. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 28. bigballsofpaint (TT conversion) 95 3k base....i finally finished 29. 92-3000GT (Single turbo) 3000gt sl 5spd 30. Optamix (engine swap) 3KGT SL 5spd 31. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 32. Quintop (engine swap) '95 SL 5 sp 33. Jigzibit (conversion) '95 SL ATX 34. 93 Stealth R/T (TT conversion) 35. Bob The Great (TT conversion) 93 R/T AWD 5spd 36. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's 37. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness. 38. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 39. 3000hybrid (TT swap) 97 base GT- ATX to 5spd AWD tranny w/SFR LSD 19T's 40. 95red3000gt (TT conversion) only one in Colorado! 41. Jeremy C (TT conversion) - weekend project 42. Vortac (TT Conversion) SL ATX 43. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 44. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD 45. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD 46. Import Power Online-Fastest-Quickest-Dyno Record 132.97MPH/11.44-14bs/519HP EVOIIIs-5spd AWD The new FWD Record 47.93_black_R/T - Finished May 2004 48. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 49. rush6432 ( Single turbo conversion, stock 10:1 motor) 50. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 156K 51. Zumin3K - TT Swap) 9bs, TT ECU + Harness 52. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 53. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 54. aaron97- (conversion) 3000GT SL 55. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 56. |4x4 nv| - (TT Swap) Evo3 16G's/Forged Internals(8.1:1 compression)/680cc injectors/Garrett FMIC/Propane/maftpro 57. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain/FMIC 58. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 59. kdog109sd (TT Conversion) - one of the first automatics to do it 60. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 61. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 62. KevD23 (single turbo) '94 stealth ATX 63. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife 64. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads 65. Pantherchams (Supercharged) 93 Stealth ES ATX 66. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT 67. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!) 68. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???) 69. Jomojr (TT Conversion 93 Base ATX) 70. Cobane (J-Spec Swap) 94 r/t 5-spd. 71. LeRoyDL (92 R/T DR650 Blow through TT Conv. JDM ECU, N/A harness) 72. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness. 73. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods 74. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX 75. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's 76.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2. 77. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500 78. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition 79. OneWingedAngel - 97 3000GT SL T/T conversion 80. 91StealthBaseTT - TT 10:1 compression fully rebuilt engine including valve job (: 81. PearlRyde - '92 TT Swap into a '99Base... Running on SOHC Tranny until i can rebuild the Getrag... 82. 94mitsumichael7 - 94 Stealth RT... FWD 9b's 8 psi, TT ECU, 10:1 motor, new EVERYTHING. lol. But its finally done and running!!! 83. templar - 94 3000GT ATX TT Conversion. 84. Nojinxz - .080 over supercharged running 6lbs boost - running very well 85. GTOGIRL3000 ~ 94 SL-TT and 5 speed NA MTX swap, 10:1 comp.,TT ECU and harness, SFR LSD. 86. Forsakenwolf - '91 ES-TT w/ 5spd NA MTX, 8:1 comp 87. white96tt - (engine swap) 95 Stealth Base ATX; 15gs 88. DSMGTO - 94 SL N/A motor, TT ECU, TT Fuel pump, 360 inj. 89. AyeKay 94 SL Twin Turbo with all the TT Parts 10:1 7lbs of Boost 90. blk92sl - now SLTT!!! just started her for the first time last night..6/17/06 91. Zeiss - 94 Stealth RT Luxury with 13gs 10:1 and SFR LSD insert. 92. Wildarmz - 94 SL TT, 92 TT Ecu 93.MagnaVR4 - 99 base single cam to TT, 4bolt motor swap, 6spd 94. SeekNStrike- Stock TT swap. blitz boost con. S-AFCII 95. Rican3kgt- (Supercharged) Low comp pistons with forged internals, 12psi, tt ecu 96. King_Milo- TT swap, many mods, still stock turbo's 97. Guywit94sl - TT conversion 94 SLTT 98. J-Groove - 9:1 Ross forged '95 base TT 99. 94ATXVR2- TT engine swap, 17g's and Atx to 5spd getrag conversion. 100. Gen13kgt - TT Engine Swap. 101. 4u2nV - TT Conversion; 98SLTT; Stock 9b's @ 8PSI; Mod's in Sig. 102 Ryan94rt- TT convo, Two many mods In Progress (remove your name when finished and add to completed list) 1. xtremewlr (conversion) collecting parts slowly 2. rtrotter (supercharged) 3KGT 3. Whitewavesea (single turbo) 3kgt Installation in progress 4. Aph (conversion) - Dec 17 '03 5. JRock4000 (conversion) 3000GT -should be done this January 6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 7. Mitch007 (conversion) expected completion by beginning of summer 8. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend. 9. AkiraGT (TT swap already started) 10. StealthTT (just need turbos and ICs with pipes) 11. Chant (TT / SuperCharger Conversion) :0) 12. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger 13. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap. 14. Renegadex181- Saving money and collecting parts...to start by April 15th XX. YOGURT! - MYKISS69 BLOWS didnt get my parts in time, sold to SONICBOUNCE17 15. Clipse20 - 94TT Swap w/ JapSpec ECU & Harness 16. spaceace60 - 96'base w/98'tt vr4motor 17. Presto97sl - TT conversion ATX check sig for days until install 18. MilkyClr69 - 96SL w/ 92JDMTT motor/5spd TT tranny waiting on parts 19. Nobodylikeswood - 94 SL u TT conversion 20. WolfSL - TT conversion - collecting parts 21. 92StealthR/T - Have all parts but oil cooler for my tt conversion 22. TruPnoyFlava - 94 base (VR4 swaP) 23. Ellery Clinton - Got all my parts... just need the 94/95 Harness and Ceramic Coat everything 24. Its Fwd - 94 base coming back to life, soon to be TT 25. My92Stealth - 92 Base, Putting in a TT this winter! 26. 2inTrbo - Some TT parts already installed...TRUELY IN PROGRESS!! 27. zack6G72- A few parts on there way and then a clutch replacement. 28. ATXSUX- gathering parts as we speak, lack downpipe, gauges, ECU and Harness and a couple of little things.[/quote]30. Guywit94sl - everythings bolted up, jus need to finish o2 and ecu wiring 29. Mr.30000-TT Conversion w/ 9b's converted to 13G's, ported manifolds, 450cc injectors. Just picking up the last tuning parts and misc bolts now...almost completed 30. 3startuna - limited by founds expected completion date summer 07 31. 963KSLTT - hoping to be done by summer '07 =] 32. BigTyla - everything on but the oil pan[/quote] Removed my name from the complted list since mine got parted out. You guys that are in progress let me know if you need parts! __________________
#675 (permalink) |
2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 11.Thump`Master (conversion) 3KGT 5 spd 12. JAL (conversion) 3KGT SOHC TT 13. ZachRT (single turbo) Stealth RT 14. 3KHI (Engine Swap) 3KGT DR-900's, Stage 3 Heads, Street Cams. 15. Juko (supercharged) 3KGT 16. SLAYER4ALL (supercharged) 3KGT 17. Snake93gt (supercharged) 3KGT SL 18. Spawn (supercharged) 3KGT SOHC ATX 19. OhFoSho (engine swap) SOHC Stealth 20. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 21. shooter83 (engine swap) Stealth es 5spd 22. upyun (engine swap) 3kgt sl 23. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES 24. Evangelist (TT Conversion) Stealth ES/TT 5 spd 25. Blue-GTO (TT Conversion) 3kgt SL 26. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 27. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 28. bigballsofpaint (TT conversion) 95 3k base....i finally finished 29. 92-3000GT (Single turbo) 3000gt sl 5spd 30. Optamix (engine swap) 3KGT SL 5spd 31. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 32. Quintop (engine swap) '95 SL 5 sp 33. Jigzibit (conversion) '95 SL ATX 34. 93 Stealth R/T (TT conversion) 35. Bob The Great (TT conversion) 93 R/T AWD 5spd 36. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's 37. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness. 38. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 39. 3000hybrid (TT swap) 97 base GT- ATX to 5spd AWD tranny w/SFR LSD 19T's 40. 95red3000gt (TT conversion) only one in Colorado! 41. Jeremy C (TT conversion) - weekend project 42. Vortac (TT Conversion) SL ATX 43. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 44. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD 45. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD 46. Import Power Online-Fastest-Quickest-Dyno Record 132.97MPH/11.44-14bs/519HP EVOIIIs-5spd AWD The new FWD Record 47.93_black_R/T - Finished May 2004 48. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 49. rush6432 ( Single turbo conversion, stock 10:1 motor) 50. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 156K 51. Zumin3K - TT Swap) 9bs, TT ECU + Harness 52. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 53. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 54. aaron97- (conversion) 3000GT SL 55. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 56. |4x4 nv| - (TT Swap) Evo3 16G's/Forged Internals(8.1:1 compression)/680cc injectors/Garrett FMIC/Propane/maftpro 57. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain/FMIC 58. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 59. kdog109sd (TT Conversion) - one of the first automatics to do it 60. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 61. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 62. KevD23 (single turbo) '94 stealth ATX 63. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife 64. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads 65. Pantherchams (Supercharged) 93 Stealth ES ATX 66. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT 67. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!) 68. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???) 69. Jomojr (TT Conversion 93 Base ATX) 70. Cobane (J-Spec Swap) 94 r/t 5-spd. 71. LeRoyDL (92 R/T DR650 Blow through TT Conv. JDM ECU, N/A harness) 72. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness. 73. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods 74. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX 75. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's 76.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2. 77. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500 78. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition 79. OneWingedAngel - 97 3000GT SL T/T conversion 80. 91StealthBaseTT - TT 10:1 compression fully rebuilt engine including valve job (: 81. PearlRyde - '92 TT Swap into a '99Base... Running on SOHC Tranny until i can rebuild the Getrag... 82. 94mitsumichael7 - 94 Stealth RT... FWD 9b's 8 psi, TT ECU, 10:1 motor, new EVERYTHING. lol. But its finally done and running!!! 83. templar - 94 3000GT ATX TT Conversion. 84. Nojinxz - .080 over supercharged running 6lbs boost - running very well 85. GTOGIRL3000 ~ 94 SL-TT and 5 speed NA MTX swap, 10:1 comp.,TT ECU and harness, SFR LSD. 86. Forsakenwolf - '91 ES-TT w/ 5spd NA MTX, 8:1 comp 87. white96tt - (engine swap) 95 Stealth Base ATX; 15gs 88. DSMGTO - 94 SL N/A motor, TT ECU, TT Fuel pump, 360 inj. 89. AyeKay 94 SL Twin Turbo with all the TT Parts 10:1 7lbs of Boost 90. blk92sl - now SLTT!!! just started her for the first time last night..6/17/06 91. Zeiss - 94 Stealth RT Luxury with 13gs 10:1 and SFR LSD insert. 92. Wildarmz - 94 SL TT, 92 TT Ecu 93.MagnaVR4 - 99 base single cam to TT, 4bolt motor swap, 6spd 94. SeekNStrike- Stock TT swap. blitz boost con. S-AFCII 95. Rican3kgt- (Supercharged) Low comp pistons with forged internals, 12psi, tt ecu 96. King_Milo- TT swap, many mods, still stock turbo's 97. Guywit94sl - TT conversion 94 SLTT 98. J-Groove - 9:1 Ross forged '95 base TT 99. 94ATXVR2- TT engine swap, 17g's and Atx to 5spd getrag conversion. 100. Gen13kgt - TT Engine Swap. 101. 4u2nV - TT Conversion; 98SLTT; Stock 9b's @ 8PSI; Mod's in Sig. 102. Ryan94rt- TT convo, Two many mods 103. BigTyla - TT conversion on ATX with TT ECU In Progress (remove your name when finished and add to completed list) 1. xtremewlr (conversion) collecting parts slowly 2. rtrotter (supercharged) 3KGT 3. Whitewavesea (single turbo) 3kgt Installation in progress 4. Aph (conversion) - Dec 17 '03 5. JRock4000 (conversion) 3000GT -should be done this January 6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 7. Mitch007 (conversion) expected completion by beginning of summer 8. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend. 9. AkiraGT (TT swap already started) 10. StealthTT (just need turbos and ICs with pipes) 11. Chant (TT / SuperCharger Conversion) :0) 12. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger 13. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap. 14. Renegadex181- Saving money and collecting parts...to start by April 15th 15. Clipse20 - 94TT Swap w/ JapSpec ECU & Harness 16. spaceace60 - 96'base w/98'tt vr4motor 17. Presto97sl - TT conversion ATX check sig for days until install 18. MilkyClr69 - 96SL w/ 92JDMTT motor/5spd TT tranny waiting on parts 19. Nobodylikeswood - 94 SL u TT conversion 20. WolfSL - TT conversion - collecting parts 21. 92StealthR/T - Have all parts but oil cooler for my tt conversion 22. TruPnoyFlava - 94 base (VR4 swaP) 23. Ellery Clinton - Got all my parts... just need the 94/95 Harness and Ceramic Coat everything 24. Its Fwd - 94 base coming back to life, soon to be TT 25. My92Stealth - 92 Base, Putting in a TT this winter! 26. 2inTrbo - Some TT parts already installed...TRUELY IN PROGRESS!! 27. zack6G72- A few parts on there way and then a clutch replacement. 28. ATXSUX- gathering parts as we speak, lack downpipe, gauges, ECU and Harness and a couple of little things. 29. Guywit94sl - everythings bolted up, jus need to finish o2 and ecu wiring 30. Mr.30000-TT Conversion w/ 9b's converted to 13G's, ported manifolds, 450cc injectors. Just picking up the last tuning parts and misc bolts now...almost completed 31. 3startuna - limited by founds expected completion date summer 07 32. 963KSLTT - hoping to be done by summer '07 =] Finished up today. No leaks on the first startup! |
#676 (permalink) |
Now a VR-4 driver
2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 11.Thump`Master (conversion) 3KGT 5 spd 12. JAL (conversion) 3KGT SOHC TT 13. ZachRT (single turbo) Stealth RT 14. 3KHI (Engine Swap) 3KGT DR-900's, Stage 3 Heads, Street Cams. 15. Juko (supercharged) 3KGT 16. SLAYER4ALL (supercharged) 3KGT 17. Snake93gt (supercharged) 3KGT SL 18. Spawn (supercharged) 3KGT SOHC ATX 19. OhFoSho (engine swap) SOHC Stealth 20. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 21. shooter83 (engine swap) Stealth es 5spd 22. upyun (engine swap) 3kgt sl 23. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES 24. Evangelist (TT Conversion) Stealth ES/TT 5 spd 25. Blue-GTO (TT Conversion) 3kgt SL 26. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 27. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 28. bigballsofpaint (TT conversion) 95 3k base....i finally finished 29. 92-3000GT (Single turbo) 3000gt sl 5spd 30. Optamix (engine swap) 3KGT SL 5spd 31. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 32. Quintop (engine swap) '95 SL 5 sp 33. Jigzibit (conversion) '95 SL ATX 34. 93 Stealth R/T (TT conversion) 35. Bob The Great (TT conversion) 93 R/T AWD 5spd 36. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's 37. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness. 38. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 39. 3000hybrid (TT swap) 97 base GT- ATX to 5spd AWD tranny w/SFR LSD 19T's 40. 95red3000gt (TT conversion) only one in Colorado! 41. Jeremy C (TT conversion) - weekend project 42. Vortac (TT Conversion) SL ATX 43. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 44. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD 45. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD 46. Import Power Online-Fastest-Quickest-Dyno Record 132.97MPH/11.44-14bs/519HP EVOIIIs-5spd AWD The new FWD Record 47.93_black_R/T - Finished May 2004 48. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 49. rush6432 ( Single turbo conversion, stock 10:1 motor) 50. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 156K 51. Zumin3K - TT Swap) 9bs, TT ECU + Harness 52. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 53. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 54. aaron97- (conversion) 3000GT SL 55. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 56. |4x4 nv| - (TT Swap) Evo3 16G's/Forged Internals(8.1:1 compression)/680cc injectors/Garrett FMIC/Propane/maftpro 57. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain/FMIC 58. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 59. kdog109sd (TT Conversion) - one of the first automatics to do it 60. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 61. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 62. KevD23 (single turbo) '94 stealth ATX 63. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife 64. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads 65. Pantherchams (Supercharged) 93 Stealth ES ATX 66. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT 67. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!) 68. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???) 69. Jomojr (TT Conversion 93 Base ATX) 70. Cobane (J-Spec Swap) 94 r/t 5-spd. 71. LeRoyDL (92 R/T DR650 Blow through TT Conv. JDM ECU, N/A harness) 72. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness. 73. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods 74. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX 75. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's 76.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2. 77. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500 78. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition 79. OneWingedAngel - 97 3000GT SL T/T conversion 80. 91StealthBaseTT - TT 10:1 compression fully rebuilt engine including valve job (: 81. PearlRyde - '92 TT Swap into a '99Base... Running on SOHC Tranny until i can rebuild the Getrag... 82. 94mitsumichael7 - 94 Stealth RT... FWD 9b's 8 psi, TT ECU, 10:1 motor, new EVERYTHING. lol. But its finally done and running!!! 83. templar - 94 3000GT ATX TT Conversion. 84. Nojinxz - .080 over supercharged running 6lbs boost - running very well 85. GTOGIRL3000 ~ 94 SL-TT and 5 speed NA MTX swap, 10:1 comp.,TT ECU and harness, SFR LSD. 86. Forsakenwolf - '91 ES-TT w/ 5spd NA MTX, 8:1 comp 87. white96tt - (engine swap) 95 Stealth Base ATX; 15gs 88. DSMGTO - 94 SL N/A motor, TT ECU, TT Fuel pump, 360 inj. 89. AyeKay 94 SL Twin Turbo with all the TT Parts 10:1 7lbs of Boost 90. blk92sl - now SLTT!!! just started her for the first time last night..6/17/06 91. Zeiss - 94 Stealth RT Luxury with 13gs 10:1 and SFR LSD insert. 92. Wildarmz - 94 SL TT, 92 TT Ecu 93.MagnaVR4 - 99 base single cam to TT, 4bolt motor swap, 6spd 94. SeekNStrike- Stock TT swap. blitz boost con. S-AFCII 95. Rican3kgt- (Supercharged) Low comp pistons with forged internals, 12psi, tt ecu 96. King_Milo- TT swap, many mods, still stock turbo's 97. Guywit94sl - TT conversion 94 SLTT 98. J-Groove - 9:1 Ross forged '95 base TT 99. 94ATXVR2- TT engine swap, 17g's and Atx to 5spd getrag conversion. 100. Gen13kgt - TT Engine Swap. 101. 4u2nV - TT Conversion; 98SLTT; Stock 9b's @ 8PSI; Mod's in Sig. 102. Ryan94rt- TT convo, Two many mods 103. BigTyla - TT conversion on ATX with TT ECU In Progress (remove your name when finished and add to completed list) 1. xtremewlr (conversion) collecting parts slowly 2. rtrotter (supercharged) 3KGT 3. Whitewavesea (single turbo) 3kgt Installation in progress 4. Aph (conversion) - Dec 17 '03 5. JRock4000 (conversion) 3000GT -should be done this January 6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 7. Mitch007 (conversion) expected completion by beginning of summer 8. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend. 9. AkiraGT (TT swap already started) 10. StealthTT (just need turbos and ICs with pipes) 11. Chant (TT / SuperCharger Conversion) :0) 12. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger 13. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap. 14. Renegadex181- Saving money and collecting parts...to start by April 15th 15. Clipse20 - 94TT Swap w/ JapSpec ECU & Harness 16. spaceace60 - 96'base w/98'tt vr4motor 17. Presto97sl - TT conversion ATX check sig for days until install 18. MilkyClr69 - 96SL w/ 92JDMTT motor/5spd TT tranny waiting on parts 19. Nobodylikeswood - 94 SL u TT conversion 20. WolfSL - TT conversion - collecting parts 21. 92StealthR/T - Have all parts but oil cooler for my tt conversion 22. TruPnoyFlava - 94 base (VR4 swaP) 23. Ellery Clinton - Got all my parts... just need the 94/95 Harness and Ceramic Coat everything 24. Its Fwd - 94 base coming back to life, soon to be TT 25. My92Stealth - 92 Base, Putting in a TT this winter! 26. 2inTrbo - Some TT parts already installed...TRUELY IN PROGRESS!! 27. zack6G72- A few parts on there way and then a clutch replacement. 28. ATXSUX- gathering parts as we speak, lack downpipe, gauges, ECU and Harness and a couple of little things. 29. Guywit94sl - everythings bolted up, jus need to finish o2 and ecu wiring 30. Mr.30000-TT Conversion w/ 9b's converted to 13G's, ported manifolds, 450cc injectors. Just picking up the last tuning parts and misc bolts now...almost completed 31. 3startuna - limited by founds expected completion date summer 07 32. 963KSLTT - hoping to be done by summer '07 =] 33.boardFreak5 - very, very soon, fmic, 4 in. exhaust etc.
Gewalt evoII's
#677 (permalink) | |
Forum user
#678 (permalink) |
Forum user
Originally Posted by boardFreak5
1. stu_04 (conversion) 3KGT SL ATX 2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 11.Thump`Master (conversion) 3KGT 5 spd 12. JAL (conversion) 3KGT SOHC TT 13. ZachRT (single turbo) Stealth RT 14. 3KHI (Engine Swap) 3KGT DR-900's, Stage 3 Heads, Street Cams. 15. Juko (supercharged) 3KGT 16. SLAYER4ALL (supercharged) 3KGT 17. Snake93gt (supercharged) 3KGT SL 18. Spawn (supercharged) 3KGT SOHC ATX 19. OhFoSho (engine swap) SOHC Stealth 20. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 21. shooter83 (engine swap) Stealth es 5spd 22. upyun (engine swap) 3kgt sl 23. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES 24. Evangelist (TT Conversion) Stealth ES/TT 5 spd 25. Blue-GTO (TT Conversion) 3kgt SL 26. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 27. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 28. bigballsofpaint (TT conversion) 95 3k base....i finally finished 29. 92-3000GT (Single turbo) 3000gt sl 5spd 30. Optamix (engine swap) 3KGT SL 5spd 31. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 32. Quintop (engine swap) '95 SL 5 sp 33. Jigzibit (conversion) '95 SL ATX 34. 93 Stealth R/T (TT conversion) 35. Bob The Great (TT conversion) 93 R/T AWD 5spd 36. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's 37. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness. 38. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 39. 3000hybrid (TT swap) 97 base GT- ATX to 5spd AWD tranny w/SFR LSD 19T's 40. 95red3000gt (TT conversion) only one in Colorado! 41. Jeremy C (TT conversion) - weekend project 42. Vortac (TT Conversion) SL ATX 43. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 44. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD 45. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD 46. Import Power Online-Fastest-Quickest-Dyno Record 132.97MPH/11.44-14bs/519HP EVOIIIs-5spd AWD The new FWD Record 47.93_black_R/T - Finished May 2004 48. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 49. rush6432 ( Single turbo conversion, stock 10:1 motor) 50. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 156K 51. Zumin3K - TT Swap) 9bs, TT ECU + Harness 52. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 53. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 54. aaron97- (conversion) 3000GT SL 55. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 56. |4x4 nv| - (TT Swap) Evo3 16G's/Forged Internals(8.1:1 compression)/680cc injectors/Garrett FMIC/Propane/maftpro 57. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain/FMIC 58. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 59. kdog109sd (TT Conversion) - one of the first automatics to do it 60. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 61. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 62. KevD23 (single turbo) '94 stealth ATX 63. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife 64. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads 65. Pantherchams (Supercharged) 93 Stealth ES ATX 66. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT 67. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!) 68. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???) 69. Jomojr (TT Conversion 93 Base ATX) 70. Cobane (J-Spec Swap) 94 r/t 5-spd. 71. LeRoyDL (92 R/T DR650 Blow through TT Conv. JDM ECU, N/A harness) 72. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness. 73. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods 74. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX 75. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's 76.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2. 77. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500 78. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition 79. OneWingedAngel - 97 3000GT SL T/T conversion 80. 91StealthBaseTT - TT 10:1 compression fully rebuilt engine including valve job (: 81. PearlRyde - '92 TT Swap into a '99Base... Running on SOHC Tranny until i can rebuild the Getrag... 82. 94mitsumichael7 - 94 Stealth RT... FWD 9b's 8 psi, TT ECU, 10:1 motor, new EVERYTHING. lol. But its finally done and running!!! 83. templar - 94 3000GT ATX TT Conversion. 84. Nojinxz - .080 over supercharged running 6lbs boost - running very well 85. GTOGIRL3000 ~ 94 SL-TT and 5 speed NA MTX swap, 10:1 comp.,TT ECU and harness, SFR LSD. 86. Forsakenwolf - '91 ES-TT w/ 5spd NA MTX, 8:1 comp 87. white96tt - (engine swap) 95 Stealth Base ATX; 15gs 88. DSMGTO - 94 SL N/A motor, TT ECU, TT Fuel pump, 360 inj. 89. AyeKay 94 SL Twin Turbo with all the TT Parts 10:1 7lbs of Boost 90. blk92sl - now SLTT!!! just started her for the first time last night..6/17/06 91. Zeiss - 94 Stealth RT Luxury with 13gs 10:1 and SFR LSD insert. 92. Wildarmz - 94 SL TT, 92 TT Ecu 93.MagnaVR4 - 99 base single cam to TT, 4bolt motor swap, 6spd 94. SeekNStrike- Stock TT swap. blitz boost con. S-AFCII 95. Rican3kgt- (Supercharged) Low comp pistons with forged internals, 12psi, tt ecu 96. King_Milo- TT swap, many mods, still stock turbo's 97. Guywit94sl - TT conversion 94 SLTT 98. J-Groove - 9:1 Ross forged '95 base TT 99. 94ATXVR2- TT engine swap, 17g's and Atx to 5spd getrag conversion. 100. Gen13kgt - TT Engine Swap. 101. 4u2nV - TT Conversion; 98SLTT; Stock 9b's @ 8PSI; Mod's in Sig. 102. Ryan94rt- TT convo, Two many mods 103. BigTyla - TT conversion on ATX with TT ECU 104. Rowlandzz - JDM TT Swap running smooth 105. Ghetoriger12 - single turbo supert70 running 21psi. running and happy... In Progress (remove your name when finished and add to completed list) 1. xtremewlr (conversion) collecting parts slowly 2. rtrotter (supercharged) 3KGT 3. Whitewavesea (single turbo) 3kgt Installation in progress 4. Aph (conversion) - Dec 17 '03 5. JRock4000 (conversion) 3000GT -should be done this January 6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 7. Mitch007 (conversion) expected completion by beginning of summer 8. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend. 9. AkiraGT (TT swap already started) 10. StealthTT (just need turbos and ICs with pipes) 11. Chant (TT / SuperCharger Conversion) :0) 12. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger 13. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap. 14. Renegadex181- Saving money and collecting parts...to start by April 15th 15. Clipse20 - 94TT Swap w/ JapSpec ECU & Harness 16. spaceace60 - 96'base w/98'tt vr4motor 17. Presto97sl - TT conversion ATX check sig for days until install 18. MilkyClr69 - 96SL w/ 92JDMTT motor/5spd TT tranny waiting on parts 19. Nobodylikeswood - 94 SL u TT conversion 20. WolfSL - TT conversion - collecting parts 21. 92StealthR/T - Have all parts but oil cooler for my tt conversion 22. TruPnoyFlava - 94 base (VR4 swaP) 23. Ellery Clinton - Got all my parts... just need the 94/95 Harness and Ceramic Coat everything 24. Its Fwd - 94 base coming back to life, soon to be TT 25. My92Stealth - 92 Base, Putting in a TT this winter! 26. 2inTrbo - Some TT parts already installed...TRUELY IN PROGRESS!! 27. zack6G72- A few parts on there way and then a clutch replacement. 28. ATXSUX- gathering parts as we speak, lack downpipe, gauges, ECU and Harness and a couple of little things. 29. Guywit94sl - everythings bolted up, jus need to finish o2 and ecu wiring 30. Mr.30000-TT Conversion w/ 9b's converted to 13G's, ported manifolds, 450cc injectors. Just picking up the last tuning parts and misc bolts now...almost completed 31. 3startuna - limited by founds expected completion date summer 07 32. 963KSLTT - hoping to be done by summer '07 =] 33.boardFreak5 - very, very soon, fmic, 4 in. exhaust etc. |
