#661 (permalink) |
JOnny BOy
1. stu_04 (conversion) 3KGT SL ATX
2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 10.Thump`Master (conversion) 3KGT 5 spd 11. JAL (conversion) 3KGT SOHC TT 12. ZachRT (single turbo) Stealth RT 13. 3KHI (Engine Swap) 3KGT DR-900's, Stage 3 Heads, Street Cams. 14. Juko (supercharged) 3KGT 15. SLAYER4ALL (supercharged) 3KGT 16. Snake93gt (supercharged) 3KGT SL 17. Spawn (supercharged) 3KGT SOHC ATX 18. OhFoSho (engine swap) SOHC Stealth 19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 20. shooter83 (engine swap) Stealth es 5spd 21. upyun (engine swap) 3kgt sl 22. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES 23. Evangelist (TT Conversion) Stealth ES/TT 5 spd 24. Blue-GTO (TT Conversion) 3kgt SL 25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 26. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 27. bigballsofpaint (TT conversion) 95 3k base....i finally finished 28. 92-3000GT (Single turbo) 3000gt sl 5spd 29. Optamix (engine swap) 3KGT SL 5spd 30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 31. Quintop (engine swap) '95 SL 5 sp 32. Jigzibit (conversion) '95 SL ATX 33. 93 Stealth R/T (TT conversion) 34. Bob The Great (TT conversion) 93 R/T AWD 5spd 35. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's 36. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness. 37. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 38. 3000hybrid (TT swap) 97 base GT- ATX to 5spd AWD tranny w/SFR LSD 19T's 39. 95red3000gt (TT conversion) only one in Colorado! 40. Jeremy C (TT conversion) - weekend project 41. Vortac (TT Conversion) SL ATX 42. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 43. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD 44. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD 45. Import Power Online-Fastest-Quickest-Dyno Record 132.97MPH/11.44-14bs/519HP EVOIIIs-5spd AWD The new FWD Record 46.93_black_R/T - Finished May 2004 47. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 48. rush6432 ( Single turbo conversion, stock 10:1 motor) 49. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 156K 50. Zumin3K - TT Swap) 9bs, TT ECU + Harness 51. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 52. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 53. aaron97- (conversion) 3000GT SL 54. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 55. |4x4 nv| - (TT Swap) Evo3 16G's/Forged Internals(8.1:1 compression)/680cc injectors/Garrett FMIC/Propane/maftpro 56. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain/FMIC 57. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 58. kdog109sd (TT Conversion) - one of the first automatics to do it 59. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 60. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 61. KevD23 (single turbo) '94 stealth ATX 62. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife 63. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads 64. Pantherchams (Supercharged) 93 Stealth ES ATX 65. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT 66. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!) 67. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???) 68. Jomojr (TT Conversion 93 Base ATX) 69. Venom13132 (92 RT, swap 96 vr4 engine, 92vr4 ecu 92vr4 harness, 91 Getrag running FWD, LSD insert, TT Calipers) 70. Cobane (J-Spec Swap) 94 r/t 5-spd. 71. LeRoyDL (92 R/T DR650 Blow through TT Conv. JDM ECU, N/A harness) 72. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness. 73. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods 74. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX 75. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's 76.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2. 77. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500 78. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition 79. OneWingedAngel - 97 3000GT SL T/T conversion 80. 91StealthBaseTT - TT 10:1 compression fully rebuilt engine including valve job (: 81. PearlRyde - '92 TT Swap into a '99Base... Running on SOHC Tranny until i can rebuild the Getrag... 82. 94mitsumichael7 - 94 Stealth RT... FWD 9b's 8 psi, TT ECU, 10:1 motor, new EVERYTHING. lol. But its finally done and running!!! 83. templar - 94 3000GT ATX TT Conversion. 84. Nojinxz - .080 over supercharged running 6lbs boost - running very well 85. GTOGIRL3000 ~ 94 SL-TT and 5 speed NA MTX swap, 10:1 comp.,TT ECU and harness, SFR LSD. 86. Forsakenwolf - '91 ES-TT w/ 5spd NA MTX, 8:1 comp 87. white96tt - (engine swap) 95 Stealth Base ATX; 15gs/550 injectors/forged pistons, etc... (fired up for first time today 05/10/2006) 88. DSMGTO - 94 SL N/A motor, TT ECU, TT Fuel pump, 360 inj. 89. AyeKay 94 SL Twin Turbo with all the TT Parts 10:1 7lbs of Boost 90. blk92sl - now SLTT!!! just started her for the first time last night..6/17/06 91. Zeiss - 94 Stealth RT Luxury with 13gs 10:1 and SFR LSD insert. 92. Wildarmz - 94 SL TT, 92 TT Ecu, wastegate, SFR LSD, ACT2100, 3" Tanabe Hyper Medallion exhaust, ss downpipe. 93.MagnaVR4 - 99 base single cam to TT, 4bolt motor swap, 6spd,255 walbro, Greddy Type S, 3''exhaust ,Blitz Turbo Timer, 4 pistion brakes front, 2 pistion brakes rear, 94. SeekNStrike- Stock TT swap. blitz boost con. S-AFCII, AEM wideband, Auto meter boost + EGT guages. Supra pump. 6 psi. 95. Rican3kgt- (Supercharged) Low comp pistons with forged internals, 12psi, tt ecu 96. King_Milo- TT swap, many mods, still stock turbo's 97. Guywit94sl - TT conversion 94 SLTT 98. J-Groove - 9:1 Ross forged '95 base TT In Progress (remove your name when finished and add to completed list) 1. xtremewlr (conversion) collecting parts slowly 2. rtrotter (supercharged) 3KGT 3. Whitewavesea (single turbo) 3kgt Installation in progress 4. Aph (conversion) - Dec 17 '03 5. JRock4000 (conversion) 3000GT -should be done this January 6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 7. Mitch007 (conversion) expected completion by beginning of summer 8. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend. 9. AkiraGT (TT swap already started) 10. StealthTT (just need turbos and ICs with pipes) 11. Chant (TT / SuperCharger Conversion) :0) 12. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger 13. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap. 14. Renegadex181- Saving money and collecting parts...to start by April 15th XX. YOGURT! - MYKISS69 BLOWS didnt get my parts in time, sold to SONICBOUNCE17 15. Clipse20 - 94TT Swap w/ JapSpec ECU & Harness 16. spaceace60 - 96'base w/98'tt vr4motor 17. Presto97sl - TT conversion ATX check sig for days until install 18. MilkyClr69 - 96SL w/ 92JDMTT motor/5spd TT tranny waiting on parts 19. Nobodylikeswood - 94 SL u TT conversion 20. WolfSL - TT conversion - collecting parts 21. 92StealthR/T - Have all parts but oil cooler for my tt conversion 22. TruPnoyFlava - 94 base (VR4 swaP) 23. Ellery Clinton - Got all my parts... just need the 94/95 Harness and Ceramic Coat everything 24. Its Fwd - 94 base coming back to life, soon to be TT 25. My92Stealth - 92 Base, Putting in a TT this winter! 26. 2inTrbo - Some TT parts already installed...TRUELY IN PROGRESS!! 27. zack6G72- A few parts on there way and then a clutch replacement. 28. ATXSUX- gathering parts as we speak, lack downpipe, gauges, ECU and Harness and a couple of little things.[/quote]30. Guywit94sl - everythings bolted up, jus need to finish o2 and ecu wiring 29. Mr.30000-TT Conversions with ported manifolds and 13G Turbos 30. 3startuna - limited by founds expected completion date summer 07 31. ryan94rt -I guess i should add myself, getting my block and heads back today and installing all TT parts this week. should be totallly completed in 2weeks! 32. 963KSLTT - hoping to be done by summer '07 =] |
#662 (permalink) |
I love her▼
2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 10.Thump`Master (conversion) 3KGT 5 spd 11. JAL (conversion) 3KGT SOHC TT 12. ZachRT (single turbo) Stealth RT 13. 3KHI (supercharged) 3KGT 14. Juko (supercharged) 3KGT 15. SLAYER4ALL (supercharged) 3KGT 16. Snake93gt (supercharged) 3KGT SL 17. Spawn (supercharged) 3KGT SOHC ATX 18. OhFoSho (engine swap) SOHC Stealth 19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 20. shooter83 (engine swap) Stealth es 5spd 21. upyun (engine swap) 3kgt sl 22. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES 23. Evangelist (TT Conversion) Stealth ES/TT 5 spd 24. Blue-GTO (TT Conversion) 3kgt SL 25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 26. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 27. bigballsofpaint (TT conversion) 95 3k base....i finally finished 28. 92-3000GT (Single turbo) 3000gt sl 5spd 29. Optamix (engine swap) 3KGT SL 5spd 30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 31. Quintop (engine swap) '95 SL 5 sp 32. Jigzibit (conversion) '95 SL ATX 33. 93 Stealth R/T (TT conversion) 34. Bob The Great (TT conversion) 93 R/T AWD 5spd 35. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's 36. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness. 37. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 38. 3000hybrid (TT swap) 97 base GT- ATX to 5spd AWD tranny w/SFR LSD 19T's 39. 95red3000gt (TT conversion) only one in Colorado! 40. Jeremy C (TT conversion) - weekend project 41. Vortac (TT Conversion) SL ATX 42. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 43. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD 44. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD 45. Import Power Online-Fastest-Quickest-Dyno Record 132.97MPH/11.44-14bs/519HP EVOIIIs-5spd AWD The new FWD Record 46.93_black_R/T - Finished May 2004 47. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 48. rush6432 ( Single turbo conversion, stock 10:1 motor) 49. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 156K 50. Zumin3K - TT Swap) 9bs, TT ECU + Harness 51. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 52. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 53. aaron97- (conversion) 3000GT SL 54. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 55. |4x4 nv| - (TT Swap) Evo3 16G's/Forged Internals(8.1:1 compression)/680cc injectors/Garrett FMIC/Propane/maftpro 56. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain/FMIC 57. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 58. kdog109sd (TT Conversion) - one of the first automatics to do it 59. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 60. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 61. KevD23 (single turbo) '94 stealth ATX 62. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife 63. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads 64. Pantherchams (Supercharged) 93 Stealth ES ATX 65. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT 66. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!) 67. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???) 68. Jomojr (TT Conversion 93 Base ATX) 69. Venom13132 (92 RT, swap 96 vr4 engine, 92vr4 ecu 92vr4 harness, 91 Getrag running FWD, LSD insert, TT Calipers) 70. Cobane (J-Spec Swap) 94 r/t 5-spd. 71. LeRoyDL (92 R/T DR650 TT Conv. JDM ECU, N/A harness) + (2 month old SBM will be running again in the next week) 72. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness. 73. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods 74. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX 75. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's 76.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2. 77. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500 78. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition 79. OneWingedAngel - 97 3000GT SL T/T conversion 80. 91StealthBaseTT - TT 10:1 compression fully rebuilt engine including valve job (: 81. PearlRyde - '92 TT Swap into a '99Base... Running on SOHC Tranny until i can rebuild the Getrag... 82. 94mitsumichael7 - 94 Stealth RT... FWD 9b's 8 psi, TT ECU, 10:1 motor, new EVERYTHING. lol. But its finally done and running!!! 83. templar - 94 3000GT ATX TT Conversion. 84. Nojinxz - .080 over supercharged running 6lbs boost - running very well 85. GTOGIRL3000 ~ 94 SL-TT and 5 speed NA MTX swap, 10:1 comp.,TT ECU and harness, SFR LSD. 86. Forsakenwolf - '91 ES-TT w/ 5spd NA MTX, 8:1 comp 87. white96tt - (engine swap) 95 Stealth Base ATX; 15gs/550 injectors/forged pistons, etc... (fired up for first time today 05/10/2006) 88. DSMGTO - 94 SL N/A motor, TT ECU, TT Fuel pump, 360 inj. 89. AyeKay 94 SL Twin Turbo with all the TT Parts 10:1 7lbs of Boost 90. blk92sl - now SLTT!!! just started her for the first time last night..6/17/06 91. Zeiss - 94 Stealth RT Luxury with 13gs 10:1 and SFR LSD insert. 92. Wildarmz - 94 SL TT, 92 TT Ecu, wastegate, SFR LSD, ACT2100, 3" Tanabe Hyper Medallion exhaust, ss downpipe. 93.MagnaVR4 - 99 base single cam to TT, 4bolt motor swap, 6spd,255 walbro, Greddy Type S, 3''exhaust ,Blitz Turbo Timer, 4 pistion brakes front, 2 pistion brakes rear, 94. SeekNStrike- Stock TT swap. blitz boost con. S-AFCII, AEM wideband, Auto meter boost + EGT guages. Supra pump. 6 psi. 95. Rican3kgt- (Supercharged) Low comp pistons with forged internals, 12psi, tt ecu 96. King_Milo- TT swap, many mods, still stock turbo's In Progress (remove your name when finished and add to completed list) 1. xtremewlr (conversion) collecting parts slowly 2. rtrotter (supercharged) 3KGT 3. Whitewavesea (single turbo) 3kgt Installation in progress 4. Aph (conversion) - Dec 17 '03 5. JRock4000 (conversion) 3000GT -should be done this January 6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 7. Mitch007 (conversion) expected completion by beginning of summer 8. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend. 9. AkiraGT (TT swap already started) 10. StealthTT (just need turbos and ICs with pipes) 11. Chant (TT / SuperCharger Conversion) :0) 12. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger 13. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap. 14. Renegadex181- Saving money and collecting parts...to start by April 15th XX. YOGURT! - MYKISS69 BLOWS didnt get my parts in time, sold to SONICBOUNCE17 15. Clipse20 - 94TT Swap w/ JapSpec ECU & Harness 16. spaceace60 - 96'base w/98'tt vr4motor 17. Presto97sl - TT conversion ATX check sig for days until install 18. MilkyClr69 - 96SL w/ 92JDMTT motor/5spd TT tranny waiting on parts 19. Nobodylikeswood - 94 SL u TT conversion 20. WolfSL - TT conversion - collecting parts 21. 92StealthR/T - Have all parts but oil cooler for my tt conversion 22. TruPnoyFlava - 94 base (VR4 swaP) 23. Ellery Clinton - Got all my parts... just need the 94/95 Harness and Ceramic Coat everything 24. Its Fwd - 94 base coming back to life, soon to be TT 25. My92Stealth - 92 Base, Putting in a TT this winter! 26. 2inTrbo - Some TT parts already installed...TRUELY IN PROGRESS!! 27. J-Groove - Waiting on the mail to bring in the last few parts. 28. zack6G72- A few parts on there way and then a clutch replacement. 29. ATXSUX- gathering parts as we speak, lack downpipe, gauges, ECU and Harness and a couple of little things.[/quote]30. Guywit94sl - everythings bolted up, jus need to finish o2 and ecu wiring 30. Mr.30000-TT Conversion w/ 9b's converted to 13G's, ported manifolds, 450cc injectors. Just picking up the last tuning parts and misc bolts now...almost completed
#663 (permalink) |
2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 10.Thump`Master (conversion) 3KGT 5 spd 11. JAL (conversion) 3KGT SOHC TT 12. ZachRT (single turbo) Stealth RT 13. 3KHI (Engine Swap) 3KGT DR-900's, Stage 3 Heads, Street Cams. 14. Juko (supercharged) 3KGT 15. SLAYER4ALL (supercharged) 3KGT 16. Snake93gt (supercharged) 3KGT SL 17. Spawn (supercharged) 3KGT SOHC ATX 18. OhFoSho (engine swap) SOHC Stealth 19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 20. shooter83 (engine swap) Stealth es 5spd 21. upyun (engine swap) 3kgt sl 22. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES 23. Evangelist (TT Conversion) Stealth ES/TT 5 spd 24. Blue-GTO (TT Conversion) 3kgt SL 25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 26. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 27. bigballsofpaint (TT conversion) 95 3k base....i finally finished 28. 92-3000GT (Single turbo) 3000gt sl 5spd 29. Optamix (engine swap) 3KGT SL 5spd 30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 31. Quintop (engine swap) '95 SL 5 sp 32. Jigzibit (conversion) '95 SL ATX 33. 93 Stealth R/T (TT conversion) 34. Bob The Great (TT conversion) 93 R/T AWD 5spd 35. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's 36. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness. 37. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 38. 3000hybrid (TT swap) 97 base GT- ATX to 5spd AWD tranny w/SFR LSD 19T's 39. 95red3000gt (TT conversion) only one in Colorado! 40. Jeremy C (TT conversion) - weekend project 41. Vortac (TT Conversion) SL ATX 42. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 43. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD 44. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD 45. Import Power Online-Fastest-Quickest-Dyno Record 132.97MPH/11.44-14bs/519HP EVOIIIs-5spd AWD The new FWD Record 46.93_black_R/T - Finished May 2004 47. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 48. rush6432 ( Single turbo conversion, stock 10:1 motor) 49. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 156K 50. Zumin3K - TT Swap) 9bs, TT ECU + Harness 51. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 52. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 53. aaron97- (conversion) 3000GT SL 54. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 55. |4x4 nv| - (TT Swap) Evo3 16G's/Forged Internals(8.1:1 compression)/680cc injectors/Garrett FMIC/Propane/maftpro 56. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain/FMIC 57. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 58. kdog109sd (TT Conversion) - one of the first automatics to do it 59. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 60. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 61. KevD23 (single turbo) '94 stealth ATX 62. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife 63. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads 64. Pantherchams (Supercharged) 93 Stealth ES ATX 65. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT 66. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!) 67. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???) 68. Jomojr (TT Conversion 93 Base ATX) 69. Venom13132 (92 RT, swap 96 vr4 engine, 92vr4 ecu 92vr4 harness, 91 Getrag running FWD, LSD insert, TT Calipers) 70. Cobane (J-Spec Swap) 94 r/t 5-spd. 71. LeRoyDL (92 R/T DR650 Blow through TT Conv. JDM ECU, N/A harness) 72. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness. 73. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods 74. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX 75. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's 76.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2. 77. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500 78. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition 79. OneWingedAngel - 97 3000GT SL T/T conversion 80. 91StealthBaseTT - TT 10:1 compression fully rebuilt engine including valve job (: 81. PearlRyde - '92 TT Swap into a '99Base... Running on SOHC Tranny until i can rebuild the Getrag... 82. 94mitsumichael7 - 94 Stealth RT... FWD 9b's 8 psi, TT ECU, 10:1 motor, new EVERYTHING. lol. But its finally done and running!!! 83. templar - 94 3000GT ATX TT Conversion. 84. Nojinxz - .080 over supercharged running 6lbs boost - running very well 85. GTOGIRL3000 ~ 94 SL-TT and 5 speed NA MTX swap, 10:1 comp.,TT ECU and harness, SFR LSD. 86. Forsakenwolf - '91 ES-TT w/ 5spd NA MTX, 8:1 comp 87. white96tt - (engine swap) 95 Stealth Base ATX; 15gs/550 injectors/forged pistons, etc... (fired up for first time today 05/10/2006) 88. DSMGTO - 94 SL N/A motor, TT ECU, TT Fuel pump, 360 inj. 89. AyeKay 94 SL Twin Turbo with all the TT Parts 10:1 7lbs of Boost 90. blk92sl - now SLTT!!! just started her for the first time last night..6/17/06 91. Zeiss - 94 Stealth RT Luxury with 13gs 10:1 and SFR LSD insert. 92. Wildarmz - 94 SL TT, 92 TT Ecu, wastegate, SFR LSD, ACT2100, 3" Tanabe Hyper Medallion exhaust, ss downpipe. 93.MagnaVR4 - 99 base single cam to TT, 4bolt motor swap, 6spd,255 walbro, Greddy Type S, 3''exhaust ,Blitz Turbo Timer, 4 pistion brakes front, 2 pistion brakes rear, 94. SeekNStrike- Stock TT swap. blitz boost con. S-AFCII, AEM wideband, Auto meter boost + EGT guages. Supra pump. 6 psi. 95. Rican3kgt- (Supercharged) Low comp pistons with forged internals, 12psi, tt ecu 96. King_Milo- TT swap, many mods, still stock turbo's 97. Guywit94sl - TT conversion 94 SLTT 98. J-Groove - 9:1 Ross forged '95 base TT In Progress (remove your name when finished and add to completed list) 1. xtremewlr (conversion) collecting parts slowly 2. rtrotter (supercharged) 3KGT 3. Whitewavesea (single turbo) 3kgt Installation in progress 4. Aph (conversion) - Dec 17 '03 5. JRock4000 (conversion) 3000GT -should be done this January 6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 7. Mitch007 (conversion) expected completion by beginning of summer 8. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend. 9. AkiraGT (TT swap already started) 10. StealthTT (just need turbos and ICs with pipes) 11. Chant (TT / SuperCharger Conversion) :0) 12. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger 13. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap. 14. Renegadex181- Saving money and collecting parts...to start by April 15th XX. YOGURT! - MYKISS69 BLOWS didnt get my parts in time, sold to SONICBOUNCE17 15. Clipse20 - 94TT Swap w/ JapSpec ECU & Harness 16. spaceace60 - 96'base w/98'tt vr4motor 17. Presto97sl - TT conversion ATX check sig for days until install 18. MilkyClr69 - 96SL w/ 92JDMTT motor/5spd TT tranny waiting on parts 19. Nobodylikeswood - 94 SL u TT conversion 20. WolfSL - TT conversion - collecting parts 21. 92StealthR/T - Have all parts but oil cooler for my tt conversion 22. TruPnoyFlava - 94 base (VR4 swaP) 23. Ellery Clinton - Got all my parts... just need the 94/95 Harness and Ceramic Coat everything 24. Its Fwd - 94 base coming back to life, soon to be TT 25. My92Stealth - 92 Base, Putting in a TT this winter! 26. 2inTrbo - Some TT parts already installed...TRUELY IN PROGRESS!! 27. zack6G72- A few parts on there way and then a clutch replacement. 28. ATXSUX- gathering parts as we speak, lack downpipe, gauges, ECU and Harness and a couple of little things.[/quote]30. Guywit94sl - everythings bolted up, jus need to finish o2 and ecu wiring 29. Mr.30000-TT Conversion w/ 9b's converted to 13G's, ported manifolds, 450cc injectors. Just picking up the last tuning parts and misc bolts now...almost completed 30. 3startuna - limited by founds expected completion date summer 07 31. ryan94rt -I guess i should add myself, getting my block and heads back today and installing all TT parts this week. should be totallly completed in 2weeks! 32. 963KSLTT - hoping to be done by summer '07 =]
![]() 95 TT Swap www.sounddomain.com/id/mitsu3khi |
#664 (permalink) |
Resident rocket scientist
Not sure if you guys noticed, but there were two #10s. I fixed the list up. Maybe I can be done in time to be #100.
![]() 1. stu_04 (conversion) 3KGT SL ATX 2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 11.Thump`Master (conversion) 3KGT 5 spd 12. JAL (conversion) 3KGT SOHC TT 13. ZachRT (single turbo) Stealth RT 14. 3KHI (Engine Swap) 3KGT DR-900's, Stage 3 Heads, Street Cams. 15. Juko (supercharged) 3KGT 16. SLAYER4ALL (supercharged) 3KGT 17. Snake93gt (supercharged) 3KGT SL 18. Spawn (supercharged) 3KGT SOHC ATX 19. OhFoSho (engine swap) SOHC Stealth 20. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 21. shooter83 (engine swap) Stealth es 5spd 22. upyun (engine swap) 3kgt sl 23. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES 24. Evangelist (TT Conversion) Stealth ES/TT 5 spd 25. Blue-GTO (TT Conversion) 3kgt SL 26. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 27. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 28. bigballsofpaint (TT conversion) 95 3k base....i finally finished 29. 92-3000GT (Single turbo) 3000gt sl 5spd 30. Optamix (engine swap) 3KGT SL 5spd 31. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 32. Quintop (engine swap) '95 SL 5 sp 33. Jigzibit (conversion) '95 SL ATX 34. 93 Stealth R/T (TT conversion) 35. Bob The Great (TT conversion) 93 R/T AWD 5spd 36. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's 37. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness. 38. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 39. 3000hybrid (TT swap) 97 base GT- ATX to 5spd AWD tranny w/SFR LSD 19T's 40. 95red3000gt (TT conversion) only one in Colorado! 41. Jeremy C (TT conversion) - weekend project 42. Vortac (TT Conversion) SL ATX 43. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 44. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD 45. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD 46. Import Power Online-Fastest-Quickest-Dyno Record 132.97MPH/11.44-14bs/519HP EVOIIIs-5spd AWD The new FWD Record 47.93_black_R/T - Finished May 2004 48. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 49. rush6432 ( Single turbo conversion, stock 10:1 motor) 50. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 156K 51. Zumin3K - TT Swap) 9bs, TT ECU + Harness 52. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 53. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 54. aaron97- (conversion) 3000GT SL 55. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 56. |4x4 nv| - (TT Swap) Evo3 16G's/Forged Internals(8.1:1 compression)/680cc injectors/Garrett FMIC/Propane/maftpro 57. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain/FMIC 58. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 59. kdog109sd (TT Conversion) - one of the first automatics to do it 60. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 61. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 62. KevD23 (single turbo) '94 stealth ATX 63. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife 64. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads 65. Pantherchams (Supercharged) 93 Stealth ES ATX 66. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT 67. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!) 68. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???) 69. Jomojr (TT Conversion 93 Base ATX) 70. Venom13132 (92 RT, swap 96 vr4 engine, 92vr4 ecu 92vr4 harness, 91 Getrag running FWD, LSD insert, TT Calipers) 71. Cobane (J-Spec Swap) 94 r/t 5-spd. 72. LeRoyDL (92 R/T DR650 Blow through TT Conv. JDM ECU, N/A harness) 73. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness. 74. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods 75. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX 76. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's 77.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2. 78. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500 79. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition 80. OneWingedAngel - 97 3000GT SL T/T conversion 81. 91StealthBaseTT - TT 10:1 compression fully rebuilt engine including valve job (: 82. PearlRyde - '92 TT Swap into a '99Base... Running on SOHC Tranny until i can rebuild the Getrag... 83. 94mitsumichael7 - 94 Stealth RT... FWD 9b's 8 psi, TT ECU, 10:1 motor, new EVERYTHING. lol. But its finally done and running!!! 84. templar - 94 3000GT ATX TT Conversion. 85. Nojinxz - .080 over supercharged running 6lbs boost - running very well 86. GTOGIRL3000 ~ 94 SL-TT and 5 speed NA MTX swap, 10:1 comp.,TT ECU and harness, SFR LSD. 87. Forsakenwolf - '91 ES-TT w/ 5spd NA MTX, 8:1 comp 88. white96tt - (engine swap) 95 Stealth Base ATX; 15gs/550 injectors/forged pistons, etc... (fired up for first time today 05/10/2006) 89. DSMGTO - 94 SL N/A motor, TT ECU, TT Fuel pump, 360 inj. 90. AyeKay 94 SL Twin Turbo with all the TT Parts 10:1 7lbs of Boost 91. blk92sl - now SLTT!!! just started her for the first time last night..6/17/06 92. Zeiss - 94 Stealth RT Luxury with 13gs 10:1 and SFR LSD insert. 93. Wildarmz - 94 SL TT, 92 TT Ecu, wastegate, SFR LSD, ACT2100, 3" Tanabe Hyper Medallion exhaust, ss downpipe. 94.MagnaVR4 - 99 base single cam to TT, 4bolt motor swap, 6spd,255 walbro, Greddy Type S, 3''exhaust ,Blitz Turbo Timer, 4 pistion brakes front, 2 pistion brakes rear, 95. SeekNStrike- Stock TT swap. blitz boost con. S-AFCII, AEM wideband, Auto meter boost + EGT guages. Supra pump. 6 psi. 96. Rican3kgt- (Supercharged) Low comp pistons with forged internals, 12psi, tt ecu 97. King_Milo- TT swap, many mods, still stock turbo's 98. Guywit94sl - TT conversion 94 SLTT 99. J-Groove - 9:1 Ross forged '95 base TT In Progress (remove your name when finished and add to completed list) 1. xtremewlr (conversion) collecting parts slowly 2. rtrotter (supercharged) 3KGT 3. Whitewavesea (single turbo) 3kgt Installation in progress 4. Aph (conversion) - Dec 17 '03 5. JRock4000 (conversion) 3000GT -should be done this January 6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 7. Mitch007 (conversion) expected completion by beginning of summer 8. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend. 9. AkiraGT (TT swap already started) 10. StealthTT (just need turbos and ICs with pipes) 11. Chant (TT / SuperCharger Conversion) :0) 12. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger 13. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap. 14. Renegadex181- Saving money and collecting parts...to start by April 15th XX. YOGURT! - MYKISS69 BLOWS didnt get my parts in time, sold to SONICBOUNCE17 15. Clipse20 - 94TT Swap w/ JapSpec ECU & Harness 16. spaceace60 - 96'base w/98'tt vr4motor 17. Presto97sl - TT conversion ATX check sig for days until install 18. MilkyClr69 - 96SL w/ 92JDMTT motor/5spd TT tranny waiting on parts 19. Nobodylikeswood - 94 SL u TT conversion 20. WolfSL - TT conversion - collecting parts 21. 92StealthR/T - Have all parts but oil cooler for my tt conversion 22. TruPnoyFlava - 94 base (VR4 swaP) 23. Ellery Clinton - Got all my parts... just need the 94/95 Harness and Ceramic Coat everything 24. Its Fwd - 94 base coming back to life, soon to be TT 25. My92Stealth - 92 Base, Putting in a TT this winter! 26. 2inTrbo - Some TT parts already installed...TRUELY IN PROGRESS!! 27. zack6G72- A few parts on there way and then a clutch replacement. 28. ATXSUX- gathering parts as we speak, lack downpipe, gauges, ECU and Harness and a couple of little things.[/quote]30. Guywit94sl - everythings bolted up, jus need to finish o2 and ecu wiring 29. Mr.30000-TT Conversion w/ 9b's converted to 13G's, ported manifolds, 450cc injectors. Just picking up the last tuning parts and misc bolts now...almost completed 30. 3startuna - limited by founds expected completion date summer 07 31. ryan94rt -I guess i should add myself, getting my block and heads back today and installing all TT parts this week. should be totallly completed in 2weeks! 32. 963KSLTT - hoping to be done by summer '07 =] 33. BigTyla - everything on but the oil pan
![]() 1993 3000GT FWD ATX TT - mods coming<---------------->2009 Honda Fit - 40 mpg ftw Topline Engineering ground wire kit Nov/Dec ground wire GB!!! |
#666 (permalink) |
I have been done for over a year but just decided to put my name on the list. lol I have no clue why i didnt earlier
1. stu_04 (conversion) 3KGT SL ATX 2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 11.Thump`Master (conversion) 3KGT 5 spd 12. JAL (conversion) 3KGT SOHC TT 13. ZachRT (single turbo) Stealth RT 14. 3KHI (Engine Swap) 3KGT DR-900's, Stage 3 Heads, Street Cams. 15. Juko (supercharged) 3KGT 16. SLAYER4ALL (supercharged) 3KGT 17. Snake93gt (supercharged) 3KGT SL 18. Spawn (supercharged) 3KGT SOHC ATX 19. OhFoSho (engine swap) SOHC Stealth 20. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 21. shooter83 (engine swap) Stealth es 5spd 22. upyun (engine swap) 3kgt sl 23. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES 24. Evangelist (TT Conversion) Stealth ES/TT 5 spd 25. Blue-GTO (TT Conversion) 3kgt SL 26. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 27. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 28. bigballsofpaint (TT conversion) 95 3k base....i finally finished 29. 92-3000GT (Single turbo) 3000gt sl 5spd 30. Optamix (engine swap) 3KGT SL 5spd 31. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 32. Quintop (engine swap) '95 SL 5 sp 33. Jigzibit (conversion) '95 SL ATX 34. 93 Stealth R/T (TT conversion) 35. Bob The Great (TT conversion) 93 R/T AWD 5spd 36. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's 37. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness. 38. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 39. 3000hybrid (TT swap) 97 base GT- ATX to 5spd AWD tranny w/SFR LSD 19T's 40. 95red3000gt (TT conversion) only one in Colorado! 41. Jeremy C (TT conversion) - weekend project 42. Vortac (TT Conversion) SL ATX 43. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 44. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD 45. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD 46. Import Power Online-Fastest-Quickest-Dyno Record 132.97MPH/11.44-14bs/519HP EVOIIIs-5spd AWD The new FWD Record 47.93_black_R/T - Finished May 2004 48. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 49. rush6432 ( Single turbo conversion, stock 10:1 motor) 50. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 156K 51. Zumin3K - TT Swap) 9bs, TT ECU + Harness 52. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 53. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 54. aaron97- (conversion) 3000GT SL 55. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 56. |4x4 nv| - (TT Swap) Evo3 16G's/Forged Internals(8.1:1 compression)/680cc injectors/Garrett FMIC/Propane/maftpro 57. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain/FMIC 58. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 59. kdog109sd (TT Conversion) - one of the first automatics to do it 60. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 61. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 62. KevD23 (single turbo) '94 stealth ATX 63. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife 64. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads 65. Pantherchams (Supercharged) 93 Stealth ES ATX 66. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT 67. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!) 68. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???) 69. Jomojr (TT Conversion 93 Base ATX) 70. Venom13132 (92 RT, swap 96 vr4 engine, 92vr4 ecu 92vr4 harness, 91 Getrag running FWD, LSD insert, TT Calipers) 71. Cobane (J-Spec Swap) 94 r/t 5-spd. 72. LeRoyDL (92 R/T DR650 Blow through TT Conv. JDM ECU, N/A harness) 73. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness. 74. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods 75. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX 76. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's 77.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2. 78. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500 79. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition 80. OneWingedAngel - 97 3000GT SL T/T conversion 81. 91StealthBaseTT - TT 10:1 compression fully rebuilt engine including valve job (: 82. PearlRyde - '92 TT Swap into a '99Base... Running on SOHC Tranny until i can rebuild the Getrag... 83. 94mitsumichael7 - 94 Stealth RT... FWD 9b's 8 psi, TT ECU, 10:1 motor, new EVERYTHING. lol. But its finally done and running!!! 84. templar - 94 3000GT ATX TT Conversion. 85. Nojinxz - .080 over supercharged running 6lbs boost - running very well 86. GTOGIRL3000 ~ 94 SL-TT and 5 speed NA MTX swap, 10:1 comp.,TT ECU and harness, SFR LSD. 87. Forsakenwolf - '91 ES-TT w/ 5spd NA MTX, 8:1 comp 88. white96tt - (engine swap) 95 Stealth Base ATX; 15gs/550 injectors/forged pistons, etc... (fired up for first time today 05/10/2006) 89. DSMGTO - 94 SL N/A motor, TT ECU, TT Fuel pump, 360 inj. 90. AyeKay 94 SL Twin Turbo with all the TT Parts 10:1 7lbs of Boost 91. blk92sl - now SLTT!!! just started her for the first time last night..6/17/06 92. Zeiss - 94 Stealth RT Luxury with 13gs 10:1 and SFR LSD insert. 93. Wildarmz - 94 SL TT, 92 TT Ecu, wastegate, SFR LSD, ACT2100, 3" Tanabe Hyper Medallion exhaust, ss downpipe. 94.MagnaVR4 - 99 base single cam to TT, 4bolt motor swap, 6spd,255 walbro, Greddy Type S, 3''exhaust ,Blitz Turbo Timer, 4 pistion brakes front, 2 pistion brakes rear, 95. SeekNStrike- Stock TT swap. blitz boost con. S-AFCII, AEM wideband, Auto meter boost + EGT guages. Supra pump. 6 psi. 96. Rican3kgt- (Supercharged) Low comp pistons with forged internals, 12psi, tt ecu 97. King_Milo- TT swap, many mods, still stock turbo's 98. Guywit94sl - TT conversion 94 SLTT 99. J-Groove - 9:1 Ross forged '95 base TT 100. 94ATXVR2- TT engine swap, 17g's and Atx to 5spd getrag conversion. In Progress (remove your name when finished and add to completed list) 1. xtremewlr (conversion) collecting parts slowly 2. rtrotter (supercharged) 3KGT 3. Whitewavesea (single turbo) 3kgt Installation in progress 4. Aph (conversion) - Dec 17 '03 5. JRock4000 (conversion) 3000GT -should be done this January 6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 7. Mitch007 (conversion) expected completion by beginning of summer 8. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend. 9. AkiraGT (TT swap already started) 10. StealthTT (just need turbos and ICs with pipes) 11. Chant (TT / SuperCharger Conversion) :0) 12. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger 13. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap. 14. Renegadex181- Saving money and collecting parts...to start by April 15th XX. YOGURT! - MYKISS69 BLOWS didnt get my parts in time, sold to SONICBOUNCE17 15. Clipse20 - 94TT Swap w/ JapSpec ECU & Harness 16. spaceace60 - 96'base w/98'tt vr4motor 17. Presto97sl - TT conversion ATX check sig for days until install 18. MilkyClr69 - 96SL w/ 92JDMTT motor/5spd TT tranny waiting on parts 19. Nobodylikeswood - 94 SL u TT conversion 20. WolfSL - TT conversion - collecting parts 21. 92StealthR/T - Have all parts but oil cooler for my tt conversion 22. TruPnoyFlava - 94 base (VR4 swaP) 23. Ellery Clinton - Got all my parts... just need the 94/95 Harness and Ceramic Coat everything 24. Its Fwd - 94 base coming back to life, soon to be TT 25. My92Stealth - 92 Base, Putting in a TT this winter! 26. 2inTrbo - Some TT parts already installed...TRUELY IN PROGRESS!! 27. zack6G72- A few parts on there way and then a clutch replacement. 28. ATXSUX- gathering parts as we speak, lack downpipe, gauges, ECU and Harness and a couple of little things.[/quote]30. Guywit94sl - everythings bolted up, jus need to finish o2 and ecu wiring 29. Mr.30000-TT Conversion w/ 9b's converted to 13G's, ported manifolds, 450cc injectors. Just picking up the last tuning parts and misc bolts now...almost completed 30. 3startuna - limited by founds expected completion date summer 07 31. ryan94rt -I guess i should add myself, getting my block and heads back today and installing all TT parts this week. should be totallly completed in 2weeks! 32. 963KSLTT - hoping to be done by summer '07 =] 33. BigTyla - everything on but the oil pan[/quote]
![]() ![]() 8:1 TT Engine, 93 TT ECU, TEC-17g's, AWD/FWD 5spd Getrag, Spec Stage 3 Clutch, ebay FMIC kit, Precision 525cc Injectors, Apexi S-afc 2, MBC@ 16psi, 3" Stillen Downpipe, 3" Single Exhaust, HKS SSQV bov, AEM UEGO WIdeband, Hotwired supra fuel pump, IPS Y-Pipe, Dejon tool intake pipes Weight = 2860lbs, 396 FWHP, 117.85 trap speed (hks intercooler kit, atx tranny, n/a ecu,front 9b and much more for sale!!) |
#668 (permalink) |
I finishied today. First try she started right up. Its a TT Swap with many mods... Soon I'll start a thread about it with pics....
![]() 1. stu_04 (conversion) 3KGT SL ATX 2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 11.Thump`Master (conversion) 3KGT 5 spd 12. JAL (conversion) 3KGT SOHC TT 13. ZachRT (single turbo) Stealth RT 14. 3KHI (Engine Swap) 3KGT DR-900's, Stage 3 Heads, Street Cams. 15. Juko (supercharged) 3KGT 16. SLAYER4ALL (supercharged) 3KGT 17. Snake93gt (supercharged) 3KGT SL 18. Spawn (supercharged) 3KGT SOHC ATX 19. OhFoSho (engine swap) SOHC Stealth 20. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 21. shooter83 (engine swap) Stealth es 5spd 22. upyun (engine swap) 3kgt sl 23. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES 24. Evangelist (TT Conversion) Stealth ES/TT 5 spd 25. Blue-GTO (TT Conversion) 3kgt SL 26. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 27. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 28. bigballsofpaint (TT conversion) 95 3k base....i finally finished 29. 92-3000GT (Single turbo) 3000gt sl 5spd 30. Optamix (engine swap) 3KGT SL 5spd 31. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 32. Quintop (engine swap) '95 SL 5 sp 33. Jigzibit (conversion) '95 SL ATX 34. 93 Stealth R/T (TT conversion) 35. Bob The Great (TT conversion) 93 R/T AWD 5spd 36. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's 37. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness. 38. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 39. 3000hybrid (TT swap) 97 base GT- ATX to 5spd AWD tranny w/SFR LSD 19T's 40. 95red3000gt (TT conversion) only one in Colorado! 41. Jeremy C (TT conversion) - weekend project 42. Vortac (TT Conversion) SL ATX 43. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 44. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD 45. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD 46. Import Power Online-Fastest-Quickest-Dyno Record 132.97MPH/11.44-14bs/519HP EVOIIIs-5spd AWD The new FWD Record 47.93_black_R/T - Finished May 2004 48. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 49. rush6432 ( Single turbo conversion, stock 10:1 motor) 50. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 156K 51. Zumin3K - TT Swap) 9bs, TT ECU + Harness 52. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 53. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 54. aaron97- (conversion) 3000GT SL 55. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 56. |4x4 nv| - (TT Swap) Evo3 16G's/Forged Internals(8.1:1 compression)/680cc injectors/Garrett FMIC/Propane/maftpro 57. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain/FMIC 58. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 59. kdog109sd (TT Conversion) - one of the first automatics to do it 60. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 61. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 62. KevD23 (single turbo) '94 stealth ATX 63. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife 64. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads 65. Pantherchams (Supercharged) 93 Stealth ES ATX 66. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT 67. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!) 68. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???) 69. Jomojr (TT Conversion 93 Base ATX) 70. Venom13132 (92 RT, swap 96 vr4 engine, 92vr4 ecu 92vr4 harness, 91 Getrag running FWD, LSD insert, TT Calipers) 71. Cobane (J-Spec Swap) 94 r/t 5-spd. 72. LeRoyDL (92 R/T DR650 Blow through TT Conv. JDM ECU, N/A harness) 73. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness. 74. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods 75. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX 76. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's 77.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2. 78. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500 79. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition 80. OneWingedAngel - 97 3000GT SL T/T conversion 81. 91StealthBaseTT - TT 10:1 compression fully rebuilt engine including valve job (: 82. PearlRyde - '92 TT Swap into a '99Base... Running on SOHC Tranny until i can rebuild the Getrag... 83. 94mitsumichael7 - 94 Stealth RT... FWD 9b's 8 psi, TT ECU, 10:1 motor, new EVERYTHING. lol. But its finally done and running!!! 84. templar - 94 3000GT ATX TT Conversion. 85. Nojinxz - .080 over supercharged running 6lbs boost - running very well 86. GTOGIRL3000 ~ 94 SL-TT and 5 speed NA MTX swap, 10:1 comp.,TT ECU and harness, SFR LSD. 87. Forsakenwolf - '91 ES-TT w/ 5spd NA MTX, 8:1 comp 88. white96tt - (engine swap) 95 Stealth Base ATX; 15gs/550 injectors/forged pistons, etc... (fired up for first time today 05/10/2006) 89. DSMGTO - 94 SL N/A motor, TT ECU, TT Fuel pump, 360 inj. 90. AyeKay 94 SL Twin Turbo with all the TT Parts 10:1 7lbs of Boost 91. blk92sl - now SLTT!!! just started her for the first time last night..6/17/06 92. Zeiss - 94 Stealth RT Luxury with 13gs 10:1 and SFR LSD insert. 93. Wildarmz - 94 SL TT, 92 TT Ecu, wastegate, SFR LSD, ACT2100, 3" Tanabe Hyper Medallion exhaust, ss downpipe. 94.MagnaVR4 - 99 base single cam to TT, 4bolt motor swap, 6spd,255 walbro, Greddy Type S, 3''exhaust ,Blitz Turbo Timer, 4 pistion brakes front, 2 pistion brakes rear, 95. SeekNStrike- Stock TT swap. blitz boost con. S-AFCII, AEM wideband, Auto meter boost + EGT guages. Supra pump. 6 psi. 96. Rican3kgt- (Supercharged) Low comp pistons with forged internals, 12psi, tt ecu 97. King_Milo- TT swap, many mods, still stock turbo's 98. Guywit94sl - TT conversion 94 SLTT 99. J-Groove - 9:1 Ross forged '95 base TT 100. 94ATXVR2- TT engine swap, 17g's and Atx to 5spd getrag conversion. 101. Gen13kgt - TT Engine Swap. Quaife LSD, RPS Flywheel, ACT 2600, 3SX Pulley, Stillen DP, no rear precat, custom catback, Turbo XS RFL, Setrab front mount oil cooler, DSM SMIC's, DNP IC Pipes, K&N FIPK, Turbo XS MBC, Poly mounts, Fuel Pump Rewire, Wabro 255... and a few more.. Last edited by Gen1 3kgt : 04-30-2007 at 03:07 PM. |
