#651 (permalink) |
I love her▼
1. stu_04 (conversion) 3KGT SL ATX
2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 10.Thump`Master (conversion) 3KGT 5 spd 11. JAL (conversion) 3KGT SOHC TT 12. ZachRT (single turbo) Stealth RT 13. 3KHI (supercharged) 3KGT 14. Juko (supercharged) 3KGT 15. SLAYER4ALL (supercharged) 3KGT 16. Snake93gt (supercharged) 3KGT SL 17. Spawn (supercharged) 3KGT SOHC ATX 18. OhFoSho (engine swap) SOHC Stealth 19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 20. shooter83 (engine swap) Stealth es 5spd 21. upyun (engine swap) 3kgt sl 22. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES 23. Evangelist (TT Conversion) Stealth ES/TT 5 spd 24. Blue-GTO (TT Conversion) 3kgt SL 25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 26. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 27. bigballsofpaint (TT conversion) 95 3k base....i finally finished 28. 92-3000GT (Single turbo) 3000gt sl 5spd 29. Optamix (engine swap) 3KGT SL 5spd 30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 31. Quintop (engine swap) '95 SL 5 sp 32. Jigzibit (conversion) '95 SL ATX 33. 93 Stealth R/T (TT conversion) 34. Bob The Great (TT conversion) 93 R/T AWD 5spd 35. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's 36. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness. 37. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 38. 3000hybrid (TT swap) 97 base GT- ATX to 5spd AWD tranny w/SFR LSD 19T's 39. 95red3000gt (TT conversion) only one in Colorado! 40. Jeremy C (TT conversion) - weekend project 41. Vortac (TT Conversion) SL ATX 42. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 43. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD 44. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD 45. Import Power Online-Fastest-Quickest-Dyno Record 132.97MPH/11.44-14bs/519HP EVOIIIs-5spd AWD The new FWD Record 46.93_black_R/T - Finished May 2004 47. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 48. rush6432 ( Single turbo conversion, stock 10:1 motor) 49. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 156K 50. Zumin3K - TT Swap) 9bs, TT ECU + Harness 51. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 52. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 53. aaron97- (conversion) 3000GT SL 54. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 55. |4x4 nv| - (TT Swap) Evo3 16G's/Forged Internals(8.1:1 compression)/680cc injectors/Garrett FMIC/Propane/maftpro 56. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain/FMIC 57. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 58. kdog109sd (TT Conversion) - one of the first automatics to do it 59. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 60. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 61. KevD23 (single turbo) '94 stealth ATX 62. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife 63. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads 64. Pantherchams (Supercharged) 93 Stealth ES ATX 65. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT 66. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!) 67. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???) 68. Jomojr (TT Conversion 93 Base ATX) 69. Venom13132 (92 RT, swap 96 vr4 engine, 92vr4 ecu 92vr4 harness, 91 Getrag running FWD, LSD insert, TT Calipers) 70. Cobane (J-Spec Swap) 94 r/t 5-spd. 71. LeRoyDL (92 R/T DR650 TT Conv. JDM ECU, N/A harness) + (2 month old SBM will be running again in the next week) 72. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness. 73. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods 74. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX 75. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's 76.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2. 77. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500 78. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition 79. OneWingedAngel - 97 3000GT SL T/T conversion 80. 91StealthBaseTT - TT 10:1 compression fully rebuilt engine including valve job (: 81. PearlRyde - '92 TT Swap into a '99Base... Running on SOHC Tranny until i can rebuild the Getrag... 82. 94mitsumichael7 - 94 Stealth RT... FWD 9b's 8 psi, TT ECU, 10:1 motor, new EVERYTHING. lol. But its finally done and running!!! 83. templar - 94 3000GT ATX TT Conversion. 84. Nojinxz - .080 over supercharged running 6lbs boost - running very well 85. GTOGIRL3000 ~ 94 SL-TT and 5 speed NA MTX swap, 10:1 comp.,TT ECU and harness, SFR LSD. 86. Forsakenwolf - '91 ES-TT w/ 5spd NA MTX, 8:1 comp 87. white96tt - (engine swap) 95 Stealth Base ATX; 15gs/550 injectors/forged pistons, etc... (fired up for first time today 05/10/2006) 88. DSMGTO - 94 SL N/A motor, TT ECU, TT Fuel pump, 360 inj. 89. AyeKay 94 SL Twin Turbo with all the TT Parts 10:1 7lbs of Boost 90. blk92sl - now SLTT!!! just started her for the first time last night..6/17/06 91. Zeiss - 94 Stealth RT Luxury with 13gs 10:1 and SFR LSD insert. 92. Wildarmz - 94 SL TT, 92 TT Ecu, wastegate, SFR LSD, ACT2100, 3" Tanabe Hyper Medallion exhaust, ss downpipe. 93.MagnaVR4 - 99 base single cam to TT, 4bolt motor swap, 6spd,255 walbro, Greddy Type S, 3''exhaust ,Blitz Turbo Timer, 4 pistion brakes front, 2 pistion brakes rear, 94. SeekNStrike- Stock TT swap. blitz boost con. S-AFCII, AEM wideband, Auto meter boost + EGT guages. Supra pump. 6 psi. 95. Rican3kgt- (Supercharged) Low comp pistons with forged internals, 12psi, tt ecu 96. King_Milo- TT swap, many mods, still stock turbo's In Progress (remove your name when finished and add to completed list) 1. xtremewlr (conversion) collecting parts slowly 2. rtrotter (supercharged) 3KGT 3. Whitewavesea (single turbo) 3kgt Installation in progress 4. Aph (conversion) - Dec 17 '03 5. JRock4000 (conversion) 3000GT -should be done this January 6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 7. Mitch007 (conversion) expected completion by beginning of summer 8. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend. 9. AkiraGT (TT swap already started) 10. StealthTT (just need turbos and ICs with pipes) 11. Chant (TT / SuperCharger Conversion) :0) 12. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger 13. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap. 14. Renegadex181- Saving money and collecting parts...to start by April 15th XX. YOGURT! - MYKISS69 BLOWS didnt get my parts in time, sold to SONICBOUNCE17 15. Clipse20 - 94TT Swap w/ JapSpec ECU & Harness 16. spaceace60 - 96'base w/98'tt vr4motor 17. Presto97sl - TT conversion ATX check sig for days until install 18. MilkyClr69 - 96SL w/ 92JDMTT motor/5spd TT tranny waiting on parts 19. Nobodylikeswood - 94 SL u TT conversion 20. WolfSL - TT conversion - collecting parts 21. 92StealthR/T - Have all parts but oil cooler for my tt conversion 22. TruPnoyFlava - 94 base (VR4 swaP) 23. Ellery Clinton - Got all my parts... just need the 94/95 Harness and Ceramic Coat everything 24. Its Fwd - 94 base coming back to life, soon to be TT 25. My92Stealth - 92 Base, Putting in a TT this winter! 26. 2inTrbo - Some TT parts already installed...TRUELY IN PROGRESS!! 27. J-Groove - Waiting on the mail to bring in the last few parts. 28. zack6G72- A few parts on there way and then a clutch replacement. 29. ATXSUX- gathering parts as we speak, lack downpipe, gauges, ECU and Harness and a couple of little things.[/quote]30. Guywit94sl - everythings bolted up, jus need to finish o2 and ecu wiring 30. Mr.30000-TT Conversion w/ 9b's converted to 13G's. Just picking up the last tuning parts and misc bolts now...almost completed Last edited by Mr.3000 : 03-26-2007 at 11:57 AM. Reason: changed plans |
#652 (permalink) |
Damn It!
2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 10.Thump`Master (conversion) 3KGT 5 spd 11. JAL (conversion) 3KGT SOHC TT 12. ZachRT (single turbo) Stealth RT 13. 3KHI (supercharged) 3KGT 14. Juko (supercharged) 3KGT 15. SLAYER4ALL (supercharged) 3KGT 16. Snake93gt (supercharged) 3KGT SL 17. Spawn (supercharged) 3KGT SOHC ATX 18. OhFoSho (engine swap) SOHC Stealth 19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 20. shooter83 (engine swap) Stealth es 5spd 21. upyun (engine swap) 3kgt sl 22. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES 23. Evangelist (TT Conversion) Stealth ES/TT 5 spd 24. Blue-GTO (TT Conversion) 3kgt SL 25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 26. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 27. bigballsofpaint (TT conversion) 95 3k base....i finally finished 28. 92-3000GT (Single turbo) 3000gt sl 5spd 29. Optamix (engine swap) 3KGT SL 5spd 30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 31. Quintop (engine swap) '95 SL 5 sp 32. Jigzibit (conversion) '95 SL ATX 33. 93 Stealth R/T (TT conversion) 34. Bob The Great (TT conversion) 93 R/T AWD 5spd 35. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's 36. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness. 37. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 38. 3000hybrid (TT swap) 97 base GT- ATX to 5spd AWD tranny w/SFR LSD 19T's 39. 95red3000gt (TT conversion) only one in Colorado! 40. Jeremy C (TT conversion) - weekend project 41. Vortac (TT Conversion) SL ATX 42. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 43. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD 44. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD 45. Import Power Online-Fastest-Quickest-Dyno Record 132.97MPH/11.44-14bs/519HP EVOIIIs-5spd AWD The new FWD Record 46.93_black_R/T - Finished May 2004 47. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 48. rush6432 ( Single turbo conversion, stock 10:1 motor) 49. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 156K 50. Zumin3K - TT Swap) 9bs, TT ECU + Harness 51. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 52. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 53. aaron97- (conversion) 3000GT SL 54. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 55. |4x4 nv| - (TT Swap) Evo3 16G's/Forged Internals(8.1:1 compression)/680cc injectors/Garrett FMIC/Propane/maftpro 56. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain/FMIC 57. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 58. kdog109sd (TT Conversion) - one of the first automatics to do it 59. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 60. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 61. KevD23 (single turbo) '94 stealth ATX 62. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife 63. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads 64. Pantherchams (Supercharged) 93 Stealth ES ATX 65. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT 66. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!) 67. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???) 68. Jomojr (TT Conversion 93 Base ATX) 69. Venom13132 (92 RT, swap 96 vr4 engine, 92vr4 ecu 92vr4 harness, 91 Getrag running FWD, LSD insert, TT Calipers) 70. Cobane (J-Spec Swap) 94 r/t 5-spd. 71. LeRoyDL (92 R/T DR650 TT Conv. JDM ECU, N/A harness) + (2 month old SBM will be running again in the next week) 72. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness. 73. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods 74. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX 75. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's 76.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2. 77. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500 78. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition 79. OneWingedAngel - 97 3000GT SL T/T conversion 80. 91StealthBaseTT - TT 10:1 compression fully rebuilt engine including valve job (: 81. PearlRyde - '92 TT Swap into a '99Base... Running on SOHC Tranny until i can rebuild the Getrag... 82. 94mitsumichael7 - 94 Stealth RT... FWD 9b's 8 psi, TT ECU, 10:1 motor, new EVERYTHING. lol. But its finally done and running!!! 83. templar - 94 3000GT ATX TT Conversion. 84. Nojinxz - .080 over supercharged running 6lbs boost - running very well 85. GTOGIRL3000 ~ 94 SL-TT and 5 speed NA MTX swap, 10:1 comp.,TT ECU and harness, SFR LSD. 86. Forsakenwolf - '91 ES-TT w/ 5spd NA MTX, 8:1 comp 87. white96tt - (engine swap) 95 Stealth Base ATX; 15gs/550 injectors/forged pistons, etc... (fired up for first time today 05/10/2006) 88. DSMGTO - 94 SL N/A motor, TT ECU, TT Fuel pump, 360 inj. 89. AyeKay 94 SL Twin Turbo with all the TT Parts 10:1 7lbs of Boost 90. blk92sl - now SLTT!!! just started her for the first time last night..6/17/06 91. Zeiss - 94 Stealth RT Luxury with 13gs 10:1 and SFR LSD insert. 92. Wildarmz - 94 SL TT, 92 TT Ecu, wastegate, SFR LSD, ACT2100, 3" Tanabe Hyper Medallion exhaust, ss downpipe. 93.MagnaVR4 - 99 base single cam to TT, 4bolt motor swap, 6spd,255 walbro, Greddy Type S, 3''exhaust ,Blitz Turbo Timer, 4 pistion brakes front, 2 pistion brakes rear, 94. SeekNStrike- Stock TT swap. blitz boost con. S-AFCII, AEM wideband, Auto meter boost + EGT guages. Supra pump. 6 psi. 95. Rican3kgt- (Supercharged) Low comp pistons with forged internals, 12psi, tt ecu 96. King_Milo- TT swap, many mods, still stock turbo's In Progress (remove your name when finished and add to completed list) 1. xtremewlr (conversion) collecting parts slowly 2. rtrotter (supercharged) 3KGT 3. Whitewavesea (single turbo) 3kgt Installation in progress 4. Aph (conversion) - Dec 17 '03 5. JRock4000 (conversion) 3000GT -should be done this January 6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 7. Mitch007 (conversion) expected completion by beginning of summer 8. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend. 9. AkiraGT (TT swap already started) 10. StealthTT (just need turbos and ICs with pipes) 11. Chant (TT / SuperCharger Conversion) :0) 12. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger 13. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap. 14. Renegadex181- Saving money and collecting parts...to start by April 15th XX. YOGURT! - MYKISS69 BLOWS didnt get my parts in time, sold to SONICBOUNCE17 15. Clipse20 - 94TT Swap w/ JapSpec ECU & Harness 16. spaceace60 - 96'base w/98'tt vr4motor 17. Presto97sl - TT conversion ATX check sig for days until install 18. MilkyClr69 - 96SL w/ 92JDMTT motor/5spd TT tranny waiting on parts 19. Nobodylikeswood - 94 SL u TT conversion 20. WolfSL - TT conversion - collecting parts 21. 92StealthR/T - Have all parts but oil cooler for my tt conversion 22. TruPnoyFlava - 94 base (VR4 swaP) 23. Ellery Clinton - Got all my parts... just need the 94/95 Harness and Ceramic Coat everything 24. Its Fwd - 94 base coming back to life, soon to be TT 25. My92Stealth - 92 Base, Putting in a TT this winter! 26. 2inTrbo - Some TT parts already installed...TRUELY IN PROGRESS!! 27. J-Groove - Waiting on the mail to bring in the last few parts. 28. zack6G72- A few parts on there way and then a clutch replacement. 29. ATXSUX- gathering parts as we speak, lack downpipe, gauges, ECU and Harness and a couple of little things.[/quote]30. Guywit94sl - everythings bolted up, jus need to finish o2 and ecu wiring 30. Mr.30000-Planned 6G72TT swap/AWD Getrag Tranny swap...Final stages of negotiations with company who has swap. Other parts are on their way as we speak 31. 3startuna - limited by founds expected completion date summer 07 ![]()
96 3000GT FWD TT -Rebuilt 2 bolt 8:1 block, balanced stock internals, valve job, 99 Lifters, Maximal Performance Motor mounts and valve cover!! Quaife LSD, ACT Max Extreme 6 puck, RPS flywheel, Greddy emanage Ultimate, custom fuel system i designed my self, profec B spec2, walbro 255lph, stock turbos, Braided steel upper and lower radiator hoses, KNN FPIK, FMIC, FM oil cooler, cusco Oil catch can, stillen DP, IPS 3" single, Full AC delete, stripped interior, Corbeau Forza 2 seat, 2 inch harness, ALL Greddy electronic gauges, brakes: 4 piston calipers from Yogurts TT, Hawk pads, Valvoline DOT 4, Russells steel lines
![]() Coming soon: Tranny number 3 ![]() Special thanks: IPS, Maximal Performance, 3SX, Evans Performance and all 3si and FL3s members that sold me parts |
#653 (permalink) |
Frat Daddy
2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 10.Thump`Master (conversion) 3KGT 5 spd 11. JAL (conversion) 3KGT SOHC TT 12. ZachRT (single turbo) Stealth RT 13. 3KHI (supercharged) 3KGT 14. Juko (supercharged) 3KGT 15. SLAYER4ALL (supercharged) 3KGT 16. Snake93gt (supercharged) 3KGT SL 17. Spawn (supercharged) 3KGT SOHC ATX 18. OhFoSho (engine swap) SOHC Stealth 19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 20. shooter83 (engine swap) Stealth es 5spd 21. upyun (engine swap) 3kgt sl 22. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES 23. Evangelist (TT Conversion) Stealth ES/TT 5 spd 24. Blue-GTO (TT Conversion) 3kgt SL 25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 26. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 27. bigballsofpaint (TT conversion) 95 3k base....i finally finished 28. 92-3000GT (Single turbo) 3000gt sl 5spd 29. Optamix (engine swap) 3KGT SL 5spd 30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 31. Quintop (engine swap) '95 SL 5 sp 32. Jigzibit (conversion) '95 SL ATX 33. 93 Stealth R/T (TT conversion) 34. Bob The Great (TT conversion) 93 R/T AWD 5spd 35. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's 36. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness. 37. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 38. 3000hybrid (TT swap) 97 base GT- ATX to 5spd AWD tranny w/SFR LSD 19T's 39. 95red3000gt (TT conversion) only one in Colorado! 40. Jeremy C (TT conversion) - weekend project 41. Vortac (TT Conversion) SL ATX 42. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 43. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD 44. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD 45. Import Power Online-Fastest-Quickest-Dyno Record 132.97MPH/11.44-14bs/519HP EVOIIIs-5spd AWD The new FWD Record 46.93_black_R/T - Finished May 2004 47. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 48. rush6432 ( Single turbo conversion, stock 10:1 motor) 49. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 156K 50. Zumin3K - TT Swap) 9bs, TT ECU + Harness 51. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 52. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 53. aaron97- (conversion) 3000GT SL 54. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 55. |4x4 nv| - (TT Swap) Evo3 16G's/Forged Internals(8.1:1 compression)/680cc injectors/Garrett FMIC/Propane/maftpro 56. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain/FMIC 57. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 58. kdog109sd (TT Conversion) - one of the first automatics to do it 59. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 60. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 61. KevD23 (single turbo) '94 stealth ATX 62. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife 63. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads 64. Pantherchams (Supercharged) 93 Stealth ES ATX 65. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT 66. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!) 67. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???) 68. Jomojr (TT Conversion 93 Base ATX) 69. Venom13132 (92 RT, swap 96 vr4 engine, 92vr4 ecu 92vr4 harness, 91 Getrag running FWD, LSD insert, TT Calipers) 70. Cobane (J-Spec Swap) 94 r/t 5-spd. 71. LeRoyDL (92 R/T DR650 TT Conv. JDM ECU, N/A harness) + (2 month old SBM will be running again in the next week) 72. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness. 73. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods 74. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX 75. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's 76.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2. 77. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500 78. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition 79. OneWingedAngel - 97 3000GT SL T/T conversion 80. 91StealthBaseTT - TT 10:1 compression fully rebuilt engine including valve job (: 81. PearlRyde - '92 TT Swap into a '99Base... Running on SOHC Tranny until i can rebuild the Getrag... 82. 94mitsumichael7 - 94 Stealth RT... FWD 9b's 8 psi, TT ECU, 10:1 motor, new EVERYTHING. lol. But its finally done and running!!! 83. templar - 94 3000GT ATX TT Conversion. 84. Nojinxz - .080 over supercharged running 6lbs boost - running very well 85. GTOGIRL3000 ~ 94 SL-TT and 5 speed NA MTX swap, 10:1 comp.,TT ECU and harness, SFR LSD. 86. Forsakenwolf - '91 ES-TT w/ 5spd NA MTX, 8:1 comp 87. white96tt - (engine swap) 95 Stealth Base ATX; 15gs/550 injectors/forged pistons, etc... (fired up for first time today 05/10/2006) 88. DSMGTO - 94 SL N/A motor, TT ECU, TT Fuel pump, 360 inj. 89. AyeKay 94 SL Twin Turbo with all the TT Parts 10:1 7lbs of Boost 90. blk92sl - now SLTT!!! just started her for the first time last night..6/17/06 91. Zeiss - 94 Stealth RT Luxury with 13gs 10:1 and SFR LSD insert. 92. Wildarmz - 94 SL TT, 92 TT Ecu, wastegate, SFR LSD, ACT2100, 3" Tanabe Hyper Medallion exhaust, ss downpipe. 93.MagnaVR4 - 99 base single cam to TT, 4bolt motor swap, 6spd,255 walbro, Greddy Type S, 3''exhaust ,Blitz Turbo Timer, 4 pistion brakes front, 2 pistion brakes rear, 94. SeekNStrike- Stock TT swap. blitz boost con. S-AFCII, AEM wideband, Auto meter boost + EGT guages. Supra pump. 6 psi. 95. Rican3kgt- (Supercharged) Low comp pistons with forged internals, 12psi, tt ecu 96. King_Milo- TT swap, many mods, still stock turbo's 97. Guywit94sl - TT conversion 94 SLTT In Progress (remove your name when finished and add to completed list) 1. xtremewlr (conversion) collecting parts slowly 2. rtrotter (supercharged) 3KGT 3. Whitewavesea (single turbo) 3kgt Installation in progress 4. Aph (conversion) - Dec 17 '03 5. JRock4000 (conversion) 3000GT -should be done this January 6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 7. Mitch007 (conversion) expected completion by beginning of summer 8. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend. 9. AkiraGT (TT swap already started) 10. StealthTT (just need turbos and ICs with pipes) 11. Chant (TT / SuperCharger Conversion) :0) 12. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger 13. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap. 14. Renegadex181- Saving money and collecting parts...to start by April 15th XX. YOGURT! - MYKISS69 BLOWS didnt get my parts in time, sold to SONICBOUNCE17 15. Clipse20 - 94TT Swap w/ JapSpec ECU & Harness 16. spaceace60 - 96'base w/98'tt vr4motor 17. Presto97sl - TT conversion ATX check sig for days until install 18. MilkyClr69 - 96SL w/ 92JDMTT motor/5spd TT tranny waiting on parts 19. Nobodylikeswood - 94 SL u TT conversion 20. WolfSL - TT conversion - collecting parts 21. 92StealthR/T - Have all parts but oil cooler for my tt conversion 22. TruPnoyFlava - 94 base (VR4 swaP) 23. Ellery Clinton - Got all my parts... just need the 94/95 Harness and Ceramic Coat everything 24. Its Fwd - 94 base coming back to life, soon to be TT 25. My92Stealth - 92 Base, Putting in a TT this winter! 26. 2inTrbo - Some TT parts already installed...TRUELY IN PROGRESS!! 27. J-Groove - Waiting on the mail to bring in the last few parts. 28. zack6G72- A few parts on there way and then a clutch replacement. 29. ATXSUX- gathering parts as we speak, lack downpipe, gauges, ECU and Harness and a couple of little things.[/quote]30. Guywit94sl - everythings bolted up, jus need to finish o2 and ecu wiring 30. Mr.30000-Planned 6G72TT swap/AWD Getrag Tranny swap...Final stages of negotiations with company who has swap. Other parts are on their way as we speak 31. 3startuna - limited by founds expected completion date summer 07 |
#654 (permalink) |
Ryan94rt
2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 10.Thump`Master (conversion) 3KGT 5 spd 11. JAL (conversion) 3KGT SOHC TT 12. ZachRT (single turbo) Stealth RT 13. 3KHI (supercharged) 3KGT 14. Juko (supercharged) 3KGT 15. SLAYER4ALL (supercharged) 3KGT 16. Snake93gt (supercharged) 3KGT SL 17. Spawn (supercharged) 3KGT SOHC ATX 18. OhFoSho (engine swap) SOHC Stealth 19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 20. shooter83 (engine swap) Stealth es 5spd 21. upyun (engine swap) 3kgt sl 22. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES 23. Evangelist (TT Conversion) Stealth ES/TT 5 spd 24. Blue-GTO (TT Conversion) 3kgt SL 25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 26. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 27. bigballsofpaint (TT conversion) 95 3k base....i finally finished 28. 92-3000GT (Single turbo) 3000gt sl 5spd 29. Optamix (engine swap) 3KGT SL 5spd 30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 31. Quintop (engine swap) '95 SL 5 sp 32. Jigzibit (conversion) '95 SL ATX 33. 93 Stealth R/T (TT conversion) 34. Bob The Great (TT conversion) 93 R/T AWD 5spd 35. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's 36. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness. 37. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 38. 3000hybrid (TT swap) 97 base GT- ATX to 5spd AWD tranny w/SFR LSD 19T's 39. 95red3000gt (TT conversion) only one in Colorado! 40. Jeremy C (TT conversion) - weekend project 41. Vortac (TT Conversion) SL ATX 42. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 43. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD 44. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD 45. Import Power Online-Fastest-Quickest-Dyno Record 132.97MPH/11.44-14bs/519HP EVOIIIs-5spd AWD The new FWD Record 46.93_black_R/T - Finished May 2004 47. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 48. rush6432 ( Single turbo conversion, stock 10:1 motor) 49. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 156K 50. Zumin3K - TT Swap) 9bs, TT ECU + Harness 51. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 52. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 53. aaron97- (conversion) 3000GT SL 54. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 55. |4x4 nv| - (TT Swap) Evo3 16G's/Forged Internals(8.1:1 compression)/680cc injectors/Garrett FMIC/Propane/maftpro 56. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain/FMIC 57. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 58. kdog109sd (TT Conversion) - one of the first automatics to do it 59. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 60. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 61. KevD23 (single turbo) '94 stealth ATX 62. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife 63. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads 64. Pantherchams (Supercharged) 93 Stealth ES ATX 65. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT 66. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!) 67. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???) 68. Jomojr (TT Conversion 93 Base ATX) 69. Venom13132 (92 RT, swap 96 vr4 engine, 92vr4 ecu 92vr4 harness, 91 Getrag running FWD, LSD insert, TT Calipers) 70. Cobane (J-Spec Swap) 94 r/t 5-spd. 71. LeRoyDL (92 R/T DR650 TT Conv. JDM ECU, N/A harness) + (2 month old SBM will be running again in the next week) 72. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness. 73. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods 74. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX 75. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's 76.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2. 77. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500 78. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition 79. OneWingedAngel - 97 3000GT SL T/T conversion 80. 91StealthBaseTT - TT 10:1 compression fully rebuilt engine including valve job (: 81. PearlRyde - '92 TT Swap into a '99Base... Running on SOHC Tranny until i can rebuild the Getrag... 82. 94mitsumichael7 - 94 Stealth RT... FWD 9b's 8 psi, TT ECU, 10:1 motor, new EVERYTHING. lol. But its finally done and running!!! 83. templar - 94 3000GT ATX TT Conversion. 84. Nojinxz - .080 over supercharged running 6lbs boost - running very well 85. GTOGIRL3000 ~ 94 SL-TT and 5 speed NA MTX swap, 10:1 comp.,TT ECU and harness, SFR LSD. 86. Forsakenwolf - '91 ES-TT w/ 5spd NA MTX, 8:1 comp 87. white96tt - (engine swap) 95 Stealth Base ATX; 15gs/550 injectors/forged pistons, etc... (fired up for first time today 05/10/2006) 88. DSMGTO - 94 SL N/A motor, TT ECU, TT Fuel pump, 360 inj. 89. AyeKay 94 SL Twin Turbo with all the TT Parts 10:1 7lbs of Boost 90. blk92sl - now SLTT!!! just started her for the first time last night..6/17/06 91. Zeiss - 94 Stealth RT Luxury with 13gs 10:1 and SFR LSD insert. 92. Wildarmz - 94 SL TT, 92 TT Ecu, wastegate, SFR LSD, ACT2100, 3" Tanabe Hyper Medallion exhaust, ss downpipe. 93.MagnaVR4 - 99 base single cam to TT, 4bolt motor swap, 6spd,255 walbro, Greddy Type S, 3''exhaust ,Blitz Turbo Timer, 4 pistion brakes front, 2 pistion brakes rear, 94. SeekNStrike- Stock TT swap. blitz boost con. S-AFCII, AEM wideband, Auto meter boost + EGT guages. Supra pump. 6 psi. 95. Rican3kgt- (Supercharged) Low comp pistons with forged internals, 12psi, tt ecu 96. King_Milo- TT swap, many mods, still stock turbo's 97. Guywit94sl - TT conversion 94 SLTT In Progress (remove your name when finished and add to completed list) 1. xtremewlr (conversion) collecting parts slowly 2. rtrotter (supercharged) 3KGT 3. Whitewavesea (single turbo) 3kgt Installation in progress 4. Aph (conversion) - Dec 17 '03 5. JRock4000 (conversion) 3000GT -should be done this January 6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 7. Mitch007 (conversion) expected completion by beginning of summer 8. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend. 9. AkiraGT (TT swap already started) 10. StealthTT (just need turbos and ICs with pipes) 11. Chant (TT / SuperCharger Conversion) :0) 12. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger 13. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap. 14. Renegadex181- Saving money and collecting parts...to start by April 15th XX. YOGURT! - MYKISS69 BLOWS didnt get my parts in time, sold to SONICBOUNCE17 15. Clipse20 - 94TT Swap w/ JapSpec ECU & Harness 16. spaceace60 - 96'base w/98'tt vr4motor 17. Presto97sl - TT conversion ATX check sig for days until install 18. MilkyClr69 - 96SL w/ 92JDMTT motor/5spd TT tranny waiting on parts 19. Nobodylikeswood - 94 SL u TT conversion 20. WolfSL - TT conversion - collecting parts 21. 92StealthR/T - Have all parts but oil cooler for my tt conversion 22. TruPnoyFlava - 94 base (VR4 swaP) 23. Ellery Clinton - Got all my parts... just need the 94/95 Harness and Ceramic Coat everything 24. Its Fwd - 94 base coming back to life, soon to be TT 25. My92Stealth - 92 Base, Putting in a TT this winter! 26. 2inTrbo - Some TT parts already installed...TRUELY IN PROGRESS!! 27. J-Groove - Waiting on the mail to bring in the last few parts. 28. zack6G72- A few parts on there way and then a clutch replacement. 29. ATXSUX- gathering parts as we speak, lack downpipe, gauges, ECU and Harness and a couple of little things.[/quote]30. Guywit94sl - everythings bolted up, jus need to finish o2 and ecu wiring 30. Mr.30000-Planned 6G72TT swap/AWD Getrag Tranny swap...Final stages of negotiations with company who has swap. Other parts are on their way as we speak 31. 3startuna - limited by founds expected completion date summer 07 32. ryan94rt -I guess i should add myself, getting my block and heads back today and installing all TT parts this week. should be totallly completed in 2weeks!
"Doing things right the first time,,, again, and again, and again."
#655 (permalink) |
I FINALLY GET TO BE ON THE DONE LIST!!!!!
1. stu_04 (conversion) 3KGT SL ATX 2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 10.Thump`Master (conversion) 3KGT 5 spd 11. JAL (conversion) 3KGT SOHC TT 12. ZachRT (single turbo) Stealth RT 13. 3KHI (supercharged) 3KGT 14. Juko (supercharged) 3KGT 15. SLAYER4ALL (supercharged) 3KGT 16. Snake93gt (supercharged) 3KGT SL 17. Spawn (supercharged) 3KGT SOHC ATX 18. OhFoSho (engine swap) SOHC Stealth 19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 20. shooter83 (engine swap) Stealth es 5spd 21. upyun (engine swap) 3kgt sl 22. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES 23. Evangelist (TT Conversion) Stealth ES/TT 5 spd 24. Blue-GTO (TT Conversion) 3kgt SL 25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 26. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 27. bigballsofpaint (TT conversion) 95 3k base....i finally finished 28. 92-3000GT (Single turbo) 3000gt sl 5spd 29. Optamix (engine swap) 3KGT SL 5spd 30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 31. Quintop (engine swap) '95 SL 5 sp 32. Jigzibit (conversion) '95 SL ATX 33. 93 Stealth R/T (TT conversion) 34. Bob The Great (TT conversion) 93 R/T AWD 5spd 35. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's 36. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness. 37. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 38. 3000hybrid (TT swap) 97 base GT- ATX to 5spd AWD tranny w/SFR LSD 19T's 39. 95red3000gt (TT conversion) only one in Colorado! 40. Jeremy C (TT conversion) - weekend project 41. Vortac (TT Conversion) SL ATX 42. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 43. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD 44. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD 45. Import Power Online-Fastest-Quickest-Dyno Record 132.97MPH/11.44-14bs/519HP EVOIIIs-5spd AWD The new FWD Record 46.93_black_R/T - Finished May 2004 47. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 48. rush6432 ( Single turbo conversion, stock 10:1 motor) 49. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 156K 50. Zumin3K - TT Swap) 9bs, TT ECU + Harness 51. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 52. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 53. aaron97- (conversion) 3000GT SL 54. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 55. |4x4 nv| - (TT Swap) Evo3 16G's/Forged Internals(8.1:1 compression)/680cc injectors/Garrett FMIC/Propane/maftpro 56. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain/FMIC 57. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 58. kdog109sd (TT Conversion) - one of the first automatics to do it 59. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 60. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 61. KevD23 (single turbo) '94 stealth ATX 62. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife 63. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads 64. Pantherchams (Supercharged) 93 Stealth ES ATX 65. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT 66. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!) 67. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???) 68. Jomojr (TT Conversion 93 Base ATX) 69. Venom13132 (92 RT, swap 96 vr4 engine, 92vr4 ecu 92vr4 harness, 91 Getrag running FWD, LSD insert, TT Calipers) 70. Cobane (J-Spec Swap) 94 r/t 5-spd. 71. LeRoyDL (92 R/T DR650 TT Conv. JDM ECU, N/A harness) + (2 month old SBM will be running again in the next week) 72. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness. 73. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods 74. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX 75. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's 76.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2. 77. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500 78. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition 79. OneWingedAngel - 97 3000GT SL T/T conversion 80. 91StealthBaseTT - TT 10:1 compression fully rebuilt engine including valve job (: 81. PearlRyde - '92 TT Swap into a '99Base... Running on SOHC Tranny until i can rebuild the Getrag... 82. 94mitsumichael7 - 94 Stealth RT... FWD 9b's 8 psi, TT ECU, 10:1 motor, new EVERYTHING. lol. But its finally done and running!!! 83. templar - 94 3000GT ATX TT Conversion. 84. Nojinxz - .080 over supercharged running 6lbs boost - running very well 85. GTOGIRL3000 ~ 94 SL-TT and 5 speed NA MTX swap, 10:1 comp.,TT ECU and harness, SFR LSD. 86. Forsakenwolf - '91 ES-TT w/ 5spd NA MTX, 8:1 comp 87. white96tt - (engine swap) 95 Stealth Base ATX; 15gs/550 injectors/forged pistons, etc... (fired up for first time today 05/10/2006) 88. DSMGTO - 94 SL N/A motor, TT ECU, TT Fuel pump, 360 inj. 89. AyeKay 94 SL Twin Turbo with all the TT Parts 10:1 7lbs of Boost 90. blk92sl - now SLTT!!! just started her for the first time last night..6/17/06 91. Zeiss - 94 Stealth RT Luxury with 13gs 10:1 and SFR LSD insert. 92. Wildarmz - 94 SL TT, 92 TT Ecu, wastegate, SFR LSD, ACT2100, 3" Tanabe Hyper Medallion exhaust, ss downpipe. 93.MagnaVR4 - 99 base single cam to TT, 4bolt motor swap, 6spd,255 walbro, Greddy Type S, 3''exhaust ,Blitz Turbo Timer, 4 pistion brakes front, 2 pistion brakes rear, 94. SeekNStrike- Stock TT swap. blitz boost con. S-AFCII, AEM wideband, Auto meter boost + EGT guages. Supra pump. 6 psi. 95. Rican3kgt- (Supercharged) Low comp pistons with forged internals, 12psi, tt ecu 96. King_Milo- TT swap, many mods, still stock turbo's 97. Guywit94sl - TT conversion 94 SLTT 98. J-Groove - 9:1 Ross forged '95 base TT In Progress (remove your name when finished and add to completed list) 1. xtremewlr (conversion) collecting parts slowly 2. rtrotter (supercharged) 3KGT 3. Whitewavesea (single turbo) 3kgt Installation in progress 4. Aph (conversion) - Dec 17 '03 5. JRock4000 (conversion) 3000GT -should be done this January 6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 7. Mitch007 (conversion) expected completion by beginning of summer 8. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend. 9. AkiraGT (TT swap already started) 10. StealthTT (just need turbos and ICs with pipes) 11. Chant (TT / SuperCharger Conversion) :0) 12. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger 13. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap. 14. Renegadex181- Saving money and collecting parts...to start by April 15th XX. YOGURT! - MYKISS69 BLOWS didnt get my parts in time, sold to SONICBOUNCE17 15. Clipse20 - 94TT Swap w/ JapSpec ECU & Harness 16. spaceace60 - 96'base w/98'tt vr4motor 17. Presto97sl - TT conversion ATX check sig for days until install 18. MilkyClr69 - 96SL w/ 92JDMTT motor/5spd TT tranny waiting on parts 19. Nobodylikeswood - 94 SL u TT conversion 20. WolfSL - TT conversion - collecting parts 21. 92StealthR/T - Have all parts but oil cooler for my tt conversion 22. TruPnoyFlava - 94 base (VR4 swaP) 23. Ellery Clinton - Got all my parts... just need the 94/95 Harness and Ceramic Coat everything 24. Its Fwd - 94 base coming back to life, soon to be TT 25. My92Stealth - 92 Base, Putting in a TT this winter! 26. 2inTrbo - Some TT parts already installed...TRUELY IN PROGRESS!! 27. zack6G72- A few parts on there way and then a clutch replacement. 28. ATXSUX- gathering parts as we speak, lack downpipe, gauges, ECU and Harness and a couple of little things.[/quote]30. Guywit94sl - everythings bolted up, jus need to finish o2 and ecu wiring 29. Mr.30000-Planned 6G72TT swap/AWD Getrag Tranny swap...Final stages of negotiations with company who has swap. Other parts are on their way as we speak 30. 3startuna - limited by founds expected completion date summer 07 31. ryan94rt -I guess i should add myself, getting my block and heads back today and installing all TT parts this week. should be totallly completed in 2weeks!
#657 (permalink) | |
I put my self up there when I got serious about sourcing parts. -John |
#658 (permalink) |
Updating mines
1. stu_04 (conversion) 3KGT SL ATX 2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 10.Thump`Master (conversion) 3KGT 5 spd 11. JAL (conversion) 3KGT SOHC TT 12. ZachRT (single turbo) Stealth RT 13. 3KHI (Engine Swap) 3KGT DR-900's, Stage 3 Heads, Street Cams. 14. Juko (supercharged) 3KGT 15. SLAYER4ALL (supercharged) 3KGT 16. Snake93gt (supercharged) 3KGT SL 17. Spawn (supercharged) 3KGT SOHC ATX 18. OhFoSho (engine swap) SOHC Stealth 19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 20. shooter83 (engine swap) Stealth es 5spd 21. upyun (engine swap) 3kgt sl 22. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES 23. Evangelist (TT Conversion) Stealth ES/TT 5 spd 24. Blue-GTO (TT Conversion) 3kgt SL 25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 26. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 27. bigballsofpaint (TT conversion) 95 3k base....i finally finished 28. 92-3000GT (Single turbo) 3000gt sl 5spd 29. Optamix (engine swap) 3KGT SL 5spd 30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 31. Quintop (engine swap) '95 SL 5 sp 32. Jigzibit (conversion) '95 SL ATX 33. 93 Stealth R/T (TT conversion) 34. Bob The Great (TT conversion) 93 R/T AWD 5spd 35. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's 36. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness. 37. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 38. 3000hybrid (TT swap) 97 base GT- ATX to 5spd AWD tranny w/SFR LSD 19T's 39. 95red3000gt (TT conversion) only one in Colorado! 40. Jeremy C (TT conversion) - weekend project 41. Vortac (TT Conversion) SL ATX 42. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 43. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD 44. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD 45. Import Power Online-Fastest-Quickest-Dyno Record 132.97MPH/11.44-14bs/519HP EVOIIIs-5spd AWD The new FWD Record 46.93_black_R/T - Finished May 2004 47. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 48. rush6432 ( Single turbo conversion, stock 10:1 motor) 49. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 156K 50. Zumin3K - TT Swap) 9bs, TT ECU + Harness 51. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 52. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 53. aaron97- (conversion) 3000GT SL 54. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 55. |4x4 nv| - (TT Swap) Evo3 16G's/Forged Internals(8.1:1 compression)/680cc injectors/Garrett FMIC/Propane/maftpro 56. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain/FMIC 57. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 58. kdog109sd (TT Conversion) - one of the first automatics to do it 59. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 60. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 61. KevD23 (single turbo) '94 stealth ATX 62. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife 63. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads 64. Pantherchams (Supercharged) 93 Stealth ES ATX 65. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT 66. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!) 67. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???) 68. Jomojr (TT Conversion 93 Base ATX) 69. Venom13132 (92 RT, swap 96 vr4 engine, 92vr4 ecu 92vr4 harness, 91 Getrag running FWD, LSD insert, TT Calipers) 70. Cobane (J-Spec Swap) 94 r/t 5-spd. 71. LeRoyDL (92 R/T DR650 TT Conv. JDM ECU, N/A harness) + (2 month old SBM will be running again in the next week) 72. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness. 73. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods 74. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX 75. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's 76.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2. 77. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500 78. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition 79. OneWingedAngel - 97 3000GT SL T/T conversion 80. 91StealthBaseTT - TT 10:1 compression fully rebuilt engine including valve job (: 81. PearlRyde - '92 TT Swap into a '99Base... Running on SOHC Tranny until i can rebuild the Getrag... 82. 94mitsumichael7 - 94 Stealth RT... FWD 9b's 8 psi, TT ECU, 10:1 motor, new EVERYTHING. lol. But its finally done and running!!! 83. templar - 94 3000GT ATX TT Conversion. 84. Nojinxz - .080 over supercharged running 6lbs boost - running very well 85. GTOGIRL3000 ~ 94 SL-TT and 5 speed NA MTX swap, 10:1 comp.,TT ECU and harness, SFR LSD. 86. Forsakenwolf - '91 ES-TT w/ 5spd NA MTX, 8:1 comp 87. white96tt - (engine swap) 95 Stealth Base ATX; 15gs/550 injectors/forged pistons, etc... (fired up for first time today 05/10/2006) 88. DSMGTO - 94 SL N/A motor, TT ECU, TT Fuel pump, 360 inj. 89. AyeKay 94 SL Twin Turbo with all the TT Parts 10:1 7lbs of Boost 90. blk92sl - now SLTT!!! just started her for the first time last night..6/17/06 91. Zeiss - 94 Stealth RT Luxury with 13gs 10:1 and SFR LSD insert. 92. Wildarmz - 94 SL TT, 92 TT Ecu, wastegate, SFR LSD, ACT2100, 3" Tanabe Hyper Medallion exhaust, ss downpipe. 93.MagnaVR4 - 99 base single cam to TT, 4bolt motor swap, 6spd,255 walbro, Greddy Type S, 3''exhaust ,Blitz Turbo Timer, 4 pistion brakes front, 2 pistion brakes rear, 94. SeekNStrike- Stock TT swap. blitz boost con. S-AFCII, AEM wideband, Auto meter boost + EGT guages. Supra pump. 6 psi. 95. Rican3kgt- (Supercharged) Low comp pistons with forged internals, 12psi, tt ecu 96. King_Milo- TT swap, many mods, still stock turbo's 97. Guywit94sl - TT conversion 94 SLTT 98. J-Groove - 9:1 Ross forged '95 base TT In Progress (remove your name when finished and add to completed list) 1. xtremewlr (conversion) collecting parts slowly 2. rtrotter (supercharged) 3KGT 3. Whitewavesea (single turbo) 3kgt Installation in progress 4. Aph (conversion) - Dec 17 '03 5. JRock4000 (conversion) 3000GT -should be done this January 6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 7. Mitch007 (conversion) expected completion by beginning of summer 8. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend. 9. AkiraGT (TT swap already started) 10. StealthTT (just need turbos and ICs with pipes) 11. Chant (TT / SuperCharger Conversion) :0) 12. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger 13. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap. 14. Renegadex181- Saving money and collecting parts...to start by April 15th XX. YOGURT! - MYKISS69 BLOWS didnt get my parts in time, sold to SONICBOUNCE17 15. Clipse20 - 94TT Swap w/ JapSpec ECU & Harness 16. spaceace60 - 96'base w/98'tt vr4motor 17. Presto97sl - TT conversion ATX check sig for days until install 18. MilkyClr69 - 96SL w/ 92JDMTT motor/5spd TT tranny waiting on parts 19. Nobodylikeswood - 94 SL u TT conversion 20. WolfSL - TT conversion - collecting parts 21. 92StealthR/T - Have all parts but oil cooler for my tt conversion 22. TruPnoyFlava - 94 base (VR4 swaP) 23. Ellery Clinton - Got all my parts... just need the 94/95 Harness and Ceramic Coat everything 24. Its Fwd - 94 base coming back to life, soon to be TT 25. My92Stealth - 92 Base, Putting in a TT this winter! 26. 2inTrbo - Some TT parts already installed...TRUELY IN PROGRESS!! 27. zack6G72- A few parts on there way and then a clutch replacement. 28. ATXSUX- gathering parts as we speak, lack downpipe, gauges, ECU and Harness and a couple of little things.[/quote]30. Guywit94sl - everythings bolted up, jus need to finish o2 and ecu wiring 29. Mr.30000-Planned 6G72TT swap/AWD Getrag Tranny swap...Final stages of negotiations with company who has swap. Other parts are on their way as we speak 30. 3startuna - limited by founds expected completion date summer 07 31. ryan94rt -I guess i should add myself, getting my block and heads back today and installing all TT parts this week. should be totallly completed in 2weeks!
![]() 95 TT Swap www.sounddomain.com/id/mitsu3khi |
#659 (permalink) |
I love her▼
Updating mine: 1. stu_04 (conversion) 3KGT SL ATX 2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 10.Thump`Master (conversion) 3KGT 5 spd 11. JAL (conversion) 3KGT SOHC TT 12. ZachRT (single turbo) Stealth RT 13. 3KHI (Engine Swap) 3KGT DR-900's, Stage 3 Heads, Street Cams. 14. Juko (supercharged) 3KGT 15. SLAYER4ALL (supercharged) 3KGT 16. Snake93gt (supercharged) 3KGT SL 17. Spawn (supercharged) 3KGT SOHC ATX 18. OhFoSho (engine swap) SOHC Stealth 19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 20. shooter83 (engine swap) Stealth es 5spd 21. upyun (engine swap) 3kgt sl 22. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES 23. Evangelist (TT Conversion) Stealth ES/TT 5 spd 24. Blue-GTO (TT Conversion) 3kgt SL 25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 26. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 27. bigballsofpaint (TT conversion) 95 3k base....i finally finished 28. 92-3000GT (Single turbo) 3000gt sl 5spd 29. Optamix (engine swap) 3KGT SL 5spd 30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 31. Quintop (engine swap) '95 SL 5 sp 32. Jigzibit (conversion) '95 SL ATX 33. 93 Stealth R/T (TT conversion) 34. Bob The Great (TT conversion) 93 R/T AWD 5spd 35. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's 36. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness. 37. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 38. 3000hybrid (TT swap) 97 base GT- ATX to 5spd AWD tranny w/SFR LSD 19T's 39. 95red3000gt (TT conversion) only one in Colorado! 40. Jeremy C (TT conversion) - weekend project 41. Vortac (TT Conversion) SL ATX 42. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 43. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD 44. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD 45. Import Power Online-Fastest-Quickest-Dyno Record 132.97MPH/11.44-14bs/519HP EVOIIIs-5spd AWD The new FWD Record 46.93_black_R/T - Finished May 2004 47. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 48. rush6432 ( Single turbo conversion, stock 10:1 motor) 49. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 156K 50. Zumin3K - TT Swap) 9bs, TT ECU + Harness 51. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 52. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 53. aaron97- (conversion) 3000GT SL 54. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 55. |4x4 nv| - (TT Swap) Evo3 16G's/Forged Internals(8.1:1 compression)/680cc injectors/Garrett FMIC/Propane/maftpro 56. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain/FMIC 57. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 58. kdog109sd (TT Conversion) - one of the first automatics to do it 59. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 60. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 61. KevD23 (single turbo) '94 stealth ATX 62. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife 63. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads 64. Pantherchams (Supercharged) 93 Stealth ES ATX 65. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT 66. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!) 67. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???) 68. Jomojr (TT Conversion 93 Base ATX) 69. Venom13132 (92 RT, swap 96 vr4 engine, 92vr4 ecu 92vr4 harness, 91 Getrag running FWD, LSD insert, TT Calipers) 70. Cobane (J-Spec Swap) 94 r/t 5-spd. 71. LeRoyDL (92 R/T DR650 TT Conv. JDM ECU, N/A harness) + (2 month old SBM will be running again in the next week) 72. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness. 73. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods 74. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX 75. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's 76.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2. 77. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500 78. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition 79. OneWingedAngel - 97 3000GT SL T/T conversion 80. 91StealthBaseTT - TT 10:1 compression fully rebuilt engine including valve job (: 81. PearlRyde - '92 TT Swap into a '99Base... Running on SOHC Tranny until i can rebuild the Getrag... 82. 94mitsumichael7 - 94 Stealth RT... FWD 9b's 8 psi, TT ECU, 10:1 motor, new EVERYTHING. lol. But its finally done and running!!! 83. templar - 94 3000GT ATX TT Conversion. |
