#632 (permalink) |
Brees-y in the Big Easy
1. stu_04 (conversion) 3KGT SL ATX
2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 10.Thump`Master (conversion) 3KGT 5 spd 11. JAL (conversion) 3KGT SOHC TT 12. ZachRT (single turbo) Stealth RT 13. 3KHI (supercharged) 3KGT 14. Juko (supercharged) 3KGT 15. SLAYER4ALL (supercharged) 3KGT 16. Snake93gt (supercharged) 3KGT SL 17. Spawn (supercharged) 3KGT SOHC ATX 18. OhFoSho (engine swap) SOHC Stealth 19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 20. shooter83 (engine swap) Stealth es 5spd 21. upyun (engine swap) 3kgt sl 22. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES 23. Evangelist (TT Conversion) Stealth ES/TT 5 spd 24. Blue-GTO (TT Conversion) 3kgt SL 25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 26. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 27. bigballsofpaint (TT conversion) 95 3k base....i finally finished 28. 92-3000GT (Single turbo) 3000gt sl 5spd 29. Optamix (engine swap) 3KGT SL 5spd 30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 31. Quintop (engine swap) '95 SL 5 sp 32. Jigzibit (conversion) '95 SL ATX 33. 93 Stealth R/T (TT conversion) 34. Bob The Great (TT conversion) 93 R/T AWD 5spd 35. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's 36. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness. 37. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 38. 3000hybrid (TT swap) ATX to 5spd AWD tranny- 39. 95red3000gt (TT conversion) only one in Colorado! 40. Jeremy C (TT conversion) - weekend project 41. Vortac (TT Conversion) SL ATX 42. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 43. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD 44. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD 45. Import Power Online-Fastest-Quickest-Dyno Record 132.97MPH/11.44-14bs/519HP EVOIIIs-5spd AWD The new FWD Record 46.93_black_R/T - Finished May 2004 47. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 48. rush6432 (TT conversion) 13Ts, VR4 ECU. 14.1 @ 103 (6 psi on 9Bs w/ stock clutch) 49. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 156K 50. Zumin3K - TT Swap) 9bs, TT ECU + Harness 51. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 52. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 53. aaron97- (conversion) 3000GT SL 54. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 55. |4x4 nv| - (TT Conversion) TT ecu/LSD Insert/450cc/5 Speed Getrag (113 mph on 9b's ) 56. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain/FMIC 57. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 58. kdog109sd (TT Conversion) - one of the first automatics to do it 59. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 60. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 61. KevD23 (single turbo) '94 stealth ATX 62. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife 63. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads 64. Pantherchams (Supercharged) 93 Stealth ES ATX 65. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT 66. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!) 67. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???) 68. Jomojr (TT Conversion 93 Base ATX) 69. Venom13132 (92 RT, swap 96 vr4 engine, 92vr4 ecu 92vr4 hharness) 70. Cobane (J-Spec Swap) 94 r/t 5-spd. 71. LeRoyDL (92 R/T DR650 TT Conv. JDM ECU, N/A harness) + (2 month old SBM will be running again in the next week) 72. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness. 73. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods 74. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX 75. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's 76.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2. 77. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500 78. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition 79. OneWingedAngel - 97 3000GT SL T/T conversion 80. 91StealthBaseTT - TT 10:1 compression fully rebuilt engine including valve job (: 81. PearlRyde - '92 TT Swap into a '99Base... Running on SOHC Tranny until i can rebuild the Getrag... 82. 94mitsumichael7 - 94 Stealth RT... FWD 9b's 8 psi, TT ECU, 10:1 motor, new EVERYTHING. lol. But its finally done and running!!! 83. templar - 94 3000GT ATX TT Conversion. 84. Nojinxz - .080 over supercharged running 6lbs boost - running very well 85. GTOGIRL3000 ~ 94 SL-TT and 5 speed NA MTX swap, 10:1 comp.,TT ECU and harness, SFR LSD. 86. Forsakenwolf - '91 ES-TT w/ 5spd NA MTX, 8:1 comp 87. white96tt - (engine swap) 95 Stealth Base ATX; 15gs/550 injectors/forged pistons, etc... (fired up for first time today 05/10/2006) 88. DSMGTO - 94 SL N/A motor, TT ECU, TT Fuel pump, 360 inj. 89. AyeKay 94 SL Twin Turbo with all the TT Parts 10:1 7lbs of Boost 90. Wildarmz 94 SL TT, 92 TT Ecu, wastegate, SFR LSD, ACT2100, 3" Tanabe Hyper Medallion exhaust, ss downpipe. In Progress (remove your name when finished and add to completed list) 1. xtremewlr (conversion) collecting parts slowly 2. rtrotter (supercharged) 3KGT 3. Whitewavesea (single turbo) 3kgt Installation in progress 4. Aph (conversion) - Dec 17 '03 5. JRock4000 (conversion) 3000GT -should be done this January 6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 7. Mitch007 (conversion) expected completion by beginning of summer 8. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend. 9. AkiraGT (TT swap already started) 10. StealthTT (just need turbos and ICs with pipes) 11. Chant (TT / SuperCharger Conversion) :0) 12. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger 13. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap. 14. Renegadex181- Saving money and collecting parts...to start by April 15th XX. YOGURT! - MYKISS69 BLOWS didnt get my parts in time, sold to SONICBOUNCE17 15. Clipse20 - 94TT Swap w/ JapSpec ECU & Harness 16. spaceace60 - 96'base w/98'tt vr4motor 17. Presto97sl - TT conversion ATX check sig for days until install 18. MilkyClr69 - 96SL w/ 92JDMTT motor/5spd TT tranny waiting on parts 19. Nobodylikeswood - 94 SL u TT conversion 20. WolfSL - TT conversion - collecting parts 21. 92StealthR/T - Have all parts but oil cooler for my tt conversion 22. TruPnoyFlava - 94 base (VR4 swaP) 23. Ellery Clinton - Got all my parts... just need the 94/95 Harness and Ceramic Coat everything 24. Its Fwd - 94 base coming back to life, soon to be TT 25. My92Stealth - 92 Base, Putting in a TT this winter! 26. 2inTrbo - Some TT parts already installed...TRUELY IN PROGRESS!! 27. J-Groove - Waiting on the mail to bring in the last few parts. 28. zack6G72- A few parts on there way and then a clutch replacement. 29. ATXSUX- gathering parts as we speak, lack downpipe, gauges, ECU and Harness and a couple of little things. 30. blk92sl- she's torn apart already...halfway there! ETA 5/21/2006 (This sunday!)
summer classes
#633 (permalink) |
DETROIT HOME OF TECHNO
2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 10.Thump`Master (conversion) 3KGT 5 spd 11. JAL (conversion) 3KGT SOHC TT 12. ZachRT (single turbo) Stealth RT 13. 3KHI (supercharged) 3KGT 14. Juko (supercharged) 3KGT 15. SLAYER4ALL (supercharged) 3KGT 16. Snake93gt (supercharged) 3KGT SL 17. Spawn (supercharged) 3KGT SOHC ATX 18. OhFoSho (engine swap) SOHC Stealth 19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 20. shooter83 (engine swap) Stealth es 5spd 21. upyun (engine swap) 3kgt sl 22. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES 23. Evangelist (TT Conversion) Stealth ES/TT 5 spd 24. Blue-GTO (TT Conversion) 3kgt SL 25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 26. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 27. bigballsofpaint (TT conversion) 95 3k base....i finally finished 28. 92-3000GT (Single turbo) 3000gt sl 5spd 29. Optamix (engine swap) 3KGT SL 5spd 30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 31. Quintop (engine swap) '95 SL 5 sp 32. Jigzibit (conversion) '95 SL ATX 33. 93 Stealth R/T (TT conversion) 34. Bob The Great (TT conversion) 93 R/T AWD 5spd 35. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's 36. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness. 37. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 38. 3000hybrid (TT swap) ATX to 5spd AWD tranny- 39. 95red3000gt (TT conversion) only one in Colorado! 40. Jeremy C (TT conversion) - weekend project 41. Vortac (TT Conversion) SL ATX 42. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 43. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD 44. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD 45. Import Power Online-Fastest-Quickest-Dyno Record 132.97MPH/11.44-14bs/519HP EVOIIIs-5spd AWD The new FWD Record 46.93_black_R/T - Finished May 2004 47. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 48. rush6432 (TT conversion) 13Ts, VR4 ECU. 14.1 @ 103 (6 psi on 9Bs w/ stock clutch) 49. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 156K 50. Zumin3K - TT Swap) 9bs, TT ECU + Harness 51. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 52. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 53. aaron97- (conversion) 3000GT SL 54. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 55. |4x4 nv| - (TT Conversion) TT ecu/LSD Insert/450cc/5 Speed Getrag (113 mph on 9b's ) 56. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain/FMIC 57. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 58. kdog109sd (TT Conversion) - one of the first automatics to do it 59. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 60. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 61. KevD23 (single turbo) '94 stealth ATX 62. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife 63. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads 64. Pantherchams (Supercharged) 93 Stealth ES ATX 65. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT 66. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!) 67. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???) 68. Jomojr (TT Conversion 93 Base ATX) 69. Venom13132 (92 RT, swap 96 vr4 engine, 92vr4 ecu 92vr4 hharness) 70. Cobane (J-Spec Swap) 94 r/t 5-spd. 71. LeRoyDL (92 R/T DR650 TT Conv. JDM ECU, N/A harness) + (2 month old SBM will be running again in the next week) 72. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness. 73. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods 74. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX 75. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's 76.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2. 77. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500 78. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition 79. OneWingedAngel - 97 3000GT SL T/T conversion 80. 91StealthBaseTT - TT 10:1 compression fully rebuilt engine including valve job (: 81. PearlRyde - '92 TT Swap into a '99Base... Running on SOHC Tranny until i can rebuild the Getrag... 82. 94mitsumichael7 - 94 Stealth RT... FWD 9b's 8 psi, TT ECU, 10:1 motor, new EVERYTHING. lol. But its finally done and running!!! 83. templar - 94 3000GT ATX TT Conversion. 84. Nojinxz - .080 over supercharged running 6lbs boost - running very well 85. GTOGIRL3000 ~ 94 SL-TT and 5 speed NA MTX swap, 10:1 comp.,TT ECU and harness, SFR LSD. 86. Forsakenwolf - '91 ES-TT w/ 5spd NA MTX, 8:1 comp 87. white96tt - (engine swap) 95 Stealth Base ATX; 15gs/550 injectors/forged pistons, etc... (fired up for first time today 05/10/2006) 88. DSMGTO - 94 SL N/A motor, TT ECU, TT Fuel pump, 360 inj. 89. AyeKay 94 SL Twin Turbo with all the TT Parts 10:1 7lbs of Boost 90. Wildarmz 94 SL TT, 92 TT Ecu, wastegate, SFR LSD, ACT2100, 3" Tanabe Hyper Medallion exhaust, ss downpipe. In Progress (remove your name when finished and add to completed list) 1. xtremewlr (conversion) collecting parts slowly 2. rtrotter (supercharged) 3KGT 3. Whitewavesea (single turbo) 3kgt Installation in progress 4. Aph (conversion) - Dec 17 '03 5. JRock4000 (conversion) 3000GT -should be done this January 6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 7. Mitch007 (conversion) expected completion by beginning of summer 8. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend. 9. AkiraGT (TT swap already started) 10. StealthTT (just need turbos and ICs with pipes) 11. Chant (TT / SuperCharger Conversion) :0) 12. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger 13. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap. 14. Renegadex181- Saving money and collecting parts...to start by April 15th XX. YOGURT! - MYKISS69 BLOWS didnt get my parts in time, sold to SONICBOUNCE17 15. Clipse20 - 94TT Swap w/ JapSpec ECU & Harness 16. spaceace60 - 96'base w/98'tt vr4motor 17. Presto97sl - TT conversion ATX check sig for days until install 18. MilkyClr69 - 96SL w/ 92JDMTT motor/5spd TT tranny waiting on parts 19. Nobodylikeswood - 94 SL u TT conversion 20. WolfSL - TT conversion - collecting parts 21. 92StealthR/T - Have all parts but oil cooler for my tt conversion 22. TruPnoyFlava - 94 base (VR4 swaP) 23. Ellery Clinton - Got all my parts... just need the 94/95 Harness and Ceramic Coat everything 24. Its Fwd - 94 base coming back to life, soon to be TT 25. My92Stealth - 92 Base, Putting in a TT this winter! 26. 2inTrbo - Some TT parts already installed...TRUELY IN PROGRESS!! 27. J-Groove - Waiting on the mail to bring in the last few parts. 28. zack6G72- A few parts on there way and then a clutch replacement. 29. ATXSUX- gathering parts as we speak, lack downpipe, gauges, ECU and Harness and a couple of little things. 30. blk92sl- she's torn apart already...halfway there! ETA 5/21/2006 (This sunday!) 31. djserax313-93 tt conversion Base 5 speed. Got all parts about to start the hard part.
Audi A4 Quattro, 19 mb italia wheels, 20% tint,cai,remus exhaust,2"drop, porche 996tt calipers,more to come...
SOLD 93 Base Model 3000gt, Fidanza Clutch, Fidanza lightweight flywheel, OZ Racing wheels 18x9 rear 18x8 front wrapped in Dunlop sp9000's, no rear seats, exchanged my spare tire for my AAA card. ![]() |
#634 (permalink) |
Resident rocket scientist
Something tells me that "in progress" list is a little old.
![]() 1993 3000GT FWD ATX TT - daily<----------------------->1984 Nissan Maxima - project Topline Engineering ground wire kit |
#635 (permalink) |
you can add 93stealthman to the list, finished my swap a year ago thats running strong
already beat a camaro ss, numerous gt s and one that was supercharged, a auto c5 and too many imports to list already at 14 psi, fwd baby! |
#636 (permalink) |
2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 10.Thump`Master (conversion) 3KGT 5 spd 11. JAL (conversion) 3KGT SOHC TT 12. ZachRT (single turbo) Stealth RT 13. 3KHI (supercharged) 3KGT 14. Juko (supercharged) 3KGT 15. SLAYER4ALL (supercharged) 3KGT 16. Snake93gt (supercharged) 3KGT SL 17. Spawn (supercharged) 3KGT SOHC ATX 18. OhFoSho (engine swap) SOHC Stealth 19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 20. shooter83 (engine swap) Stealth es 5spd 21. upyun (engine swap) 3kgt sl 22. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES 23. Evangelist (TT Conversion) Stealth ES/TT 5 spd 24. Blue-GTO (TT Conversion) 3kgt SL 25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 26. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 27. bigballsofpaint (TT conversion) 95 3k base....i finally finished 28. 92-3000GT (Single turbo) 3000gt sl 5spd 29. Optamix (engine swap) 3KGT SL 5spd 30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 31. Quintop (engine swap) '95 SL 5 sp 32. Jigzibit (conversion) '95 SL ATX 33. 93 Stealth R/T (TT conversion) 34. Bob The Great (TT conversion) 93 R/T AWD 5spd 35. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's 36. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness. 37. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 38. 3000hybrid (TT swap) ATX to 5spd AWD tranny- 39. 95red3000gt (TT conversion) only one in Colorado! 40. Jeremy C (TT conversion) - weekend project 41. Vortac (TT Conversion) SL ATX 42. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 43. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD 44. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD 45. Import Power Online-Fastest-Quickest-Dyno Record 132.97MPH/11.44-14bs/519HP EVOIIIs-5spd AWD The new FWD Record 46.93_black_R/T - Finished May 2004 47. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 48. rush6432 (TT conversion) 13Ts, VR4 ECU. 14.1 @ 103 (6 psi on 9Bs w/ stock clutch) 49. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 156K 50. Zumin3K - TT Swap) 9bs, TT ECU + Harness 51. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 52. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 53. aaron97- (conversion) 3000GT SL 54. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 55. |4x4 nv| - (TT Conversion) TT ecu/LSD Insert/450cc/5 Speed Getrag (113 mph on 9b's ) 56. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain/FMIC 57. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 58. kdog109sd (TT Conversion) - one of the first automatics to do it 59. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 60. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 61. KevD23 (single turbo) '94 stealth ATX 62. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife 63. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads 64. Pantherchams (Supercharged) 93 Stealth ES ATX 65. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT 66. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!) 67. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???) 68. Jomojr (TT Conversion 93 Base ATX) 69. Venom13132 (92 RT, swap 96 vr4 engine, 92vr4 ecu 92vr4 hharness) 70. Cobane (J-Spec Swap) 94 r/t 5-spd. 71. LeRoyDL (92 R/T DR650 TT Conv. JDM ECU, N/A harness) + (2 month old SBM will be running again in the next week) 72. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness. 73. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods 74. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX 75. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's 76.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2. 77. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500 78. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition 79. OneWingedAngel - 97 3000GT SL T/T conversion 80. 91StealthBaseTT - TT 10:1 compression fully rebuilt engine including valve job (: 81. PearlRyde - '92 TT Swap into a '99Base... Running on SOHC Tranny until i can rebuild the Getrag... 82. 94mitsumichael7 - 94 Stealth RT... FWD 9b's 8 psi, TT ECU, 10:1 motor, new EVERYTHING. lol. But its finally done and running!!! 83. templar - 94 3000GT ATX TT Conversion. 84. Nojinxz - .080 over supercharged running 6lbs boost - running very well 85. GTOGIRL3000 ~ 94 SL-TT and 5 speed NA MTX swap, 10:1 comp.,TT ECU and harness, SFR LSD. 86. Forsakenwolf - '91 ES-TT w/ 5spd NA MTX, 8:1 comp 87. white96tt - (engine swap) 95 Stealth Base ATX; 15gs/550 injectors/forged pistons, etc... (fired up for first time today 05/10/2006) 88. DSMGTO - 94 SL N/A motor, TT ECU, TT Fuel pump, 360 inj. 89. AyeKay 94 SL Twin Turbo with all the TT Parts 10:1 7lbs of Boost 90. Wildarmz 94 SL TT, 92 TT Ecu, wastegate, SFR LSD, ACT2100, 3" Tanabe Hyper Medallion exhaust, ss downpipe. 91.MagnaVR4 99 base single cam to TT, 4bolt motor swap, 6spd,255 walbro, Greddy Type S, 3''exhaust ,Blitz Turbo Timer, 4 piston brakes front, 2 piston brakes rear In Progress (remove your name when finished and add to completed list) 1. xtremewlr (conversion) collecting parts slowly 2. rtrotter (supercharged) 3KGT 3. Whitewavesea (single turbo) 3kgt Installation in progress 4. Aph (conversion) - Dec 17 '03 5. JRock4000 (conversion) 3000GT -should be done this January 6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 7. Mitch007 (conversion) expected completion by beginning of summer 8. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend. 9. AkiraGT (TT swap already started) 10. StealthTT (just need turbos and ICs with pipes) 11. Chant (TT / SuperCharger Conversion) :0) 12. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger 13. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap. 14. Renegadex181- Saving money and collecting parts...to start by April 15th XX. YOGURT! - MYKISS69 BLOWS didnt get my parts in time, sold to SONICBOUNCE17 15. Clipse20 - 94TT Swap w/ JapSpec ECU & Harness 16. spaceace60 - 96'base w/98'tt vr4motor 17. Presto97sl - TT conversion ATX check sig for days until install 18. MilkyClr69 - 96SL w/ 92JDMTT motor/5spd TT tranny waiting on parts 19. Nobodylikeswood - 94 SL u TT conversion 20. WolfSL - TT conversion - collecting parts 21. 92StealthR/T - Have all parts but oil cooler for my tt conversion 22. TruPnoyFlava - 94 base (VR4 swaP) 23. Ellery Clinton - Got all my parts... just need the 94/95 Harness and Ceramic Coat everything 24. Its Fwd - 94 base coming back to life, soon to be TT 25. My92Stealth - 92 Base, Putting in a TT this winter! 26. 2inTrbo - Some TT parts already installed...TRUELY IN PROGRESS!! 27. J-Groove - Waiting on the mail to bring in the last few parts. 28. zack6G72- A few parts on there way and then a clutch replacement. 29. ATXSUX- gathering parts as we speak, lack downpipe, gauges, ECU and Harness and a couple of little things. 30. blk92sl- she's torn apart already...halfway there! ETA 5/21/2006 (This sunday!) 31. djserax313-93 tt conversion Base 5 speed. Got all parts about to start the hard part.
![]() 1994 3000GT Base ATX (Daily Driver) 1999 3000GT Base Twin Turbo (fun car)Last edited by MagnaVR4 : 09-19-2006 at 07:00 AM. |
#637 (permalink) |
me and zeiss keep getting dropped from the list...... but oh well
![]() 1. stu_04 (conversion) 3KGT SL ATX 2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 10.Thump`Master (conversion) 3KGT 5 spd 11. JAL (conversion) 3KGT SOHC TT 12. ZachRT (single turbo) Stealth RT 13. 3KHI (supercharged) 3KGT 14. Juko (supercharged) 3KGT 15. SLAYER4ALL (supercharged) 3KGT 16. Snake93gt (supercharged) 3KGT SL 17. Spawn (supercharged) 3KGT SOHC ATX 18. OhFoSho (engine swap) SOHC Stealth 19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 20. shooter83 (engine swap) Stealth es 5spd 21. upyun (engine swap) 3kgt sl 22. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES 23. Evangelist (TT Conversion) Stealth ES/TT 5 spd 24. Blue-GTO (TT Conversion) 3kgt SL 25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 26. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 27. bigballsofpaint (TT conversion) 95 3k base....i finally finished 28. 92-3000GT (Single turbo) 3000gt sl 5spd 29. Optamix (engine swap) 3KGT SL 5spd 30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 31. Quintop (engine swap) '95 SL 5 sp 32. Jigzibit (conversion) '95 SL ATX 33. 93 Stealth R/T (TT conversion) 34. Bob The Great (TT conversion) 93 R/T AWD 5spd 35. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's 36. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness. 37. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 38. 3000hybrid (TT swap) 97 base GT- ATX to 5spd AWD tranny w/SFR LSD 19T's 39. 95red3000gt (TT conversion) only one in Colorado! 40. Jeremy C (TT conversion) - weekend project 41. Vortac (TT Conversion) SL ATX 42. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 43. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD 44. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD 45. Import Power Online-Fastest-Quickest-Dyno Record 132.97MPH/11.44-14bs/519HP EVOIIIs-5spd AWD The new FWD Record 46.93_black_R/T - Finished May 2004 47. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 48. rush6432 ( Single turbo conversion, stock 10:1 motor) 49. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 156K 50. Zumin3K - TT Swap) 9bs, TT ECU + Harness 51. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 52. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 53. aaron97- (conversion) 3000GT SL 54. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 55. |4x4 nv| - (TT Conversion) TT ecu/LSD Insert/450cc/5 Speed Getrag (113 mph on 9b's ) 56. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain/FMIC 57. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 58. kdog109sd (TT Conversion) - one of the first automatics to do it 59. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 60. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 61. KevD23 (single turbo) '94 stealth ATX 62. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife 63. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads 64. Pantherchams (Supercharged) 93 Stealth ES ATX 65. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT 66. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!) 67. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???) 68. Jomojr (TT Conversion 93 Base ATX) 69. Venom13132 (92 RT, swap 96 vr4 engine, 92vr4 ecu 92vr4 hharness) 70. Cobane (J-Spec Swap) 94 r/t 5-spd. 71. LeRoyDL (92 R/T DR650 TT Conv. JDM ECU, N/A harness) + (2 month old SBM will be running again in the next week) 72. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness. 73. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods 74. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX 75. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's 76.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2. 77. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500 78. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition 79. OneWingedAngel - 97 3000GT SL T/T conversion 80. 91StealthBaseTT - TT 10:1 compression fully rebuilt engine including valve job (: 81. PearlRyde - '92 TT Swap into a '99Base... Running on SOHC Tranny until i can rebuild the Getrag... 82. 94mitsumichael7 - 94 Stealth RT... FWD 9b's 8 psi, TT ECU, 10:1 motor, new EVERYTHING. lol. But its finally done and running!!! 83. templar - 94 3000GT ATX TT Conversion. 84. Nojinxz - .080 over supercharged running 6lbs boost - running very well 85. GTOGIRL3000 ~ 94 SL-TT and 5 speed NA MTX swap, 10:1 comp.,TT ECU and harness, SFR LSD. 86. Forsakenwolf - '91 ES-TT w/ 5spd NA MTX, 8:1 comp 87. white96tt - (engine swap) 95 Stealth Base ATX; 15gs/550 injectors/forged pistons, etc... (fired up for first time today 05/10/2006) 88. DSMGTO - 94 SL N/A motor, TT ECU, TT Fuel pump, 360 inj. 89. AyeKay 94 SL Twin Turbo with all the TT Parts 10:1 7lbs of Boost 90. blk92sl - now SLTT!!! just started her for the first time last night..6/17/06 91. Zeiss - 94 Stealth RT Luxury with 13gs 10:1 and SFR LSD insert. 92. Wildarmz - 94 SL TT, 92 TT Ecu, wastegate, SFR LSD, ACT2100, 3" Tanabe Hyper Medallion exhaust, ss downpipe. 93.MagnaVR4 - 99 base single cam to TT, 4bolt motor swap, 6spd,255 walbro, Greddy Type S, 3''exhaust ,Blitz Turbo Timer, 4 pistion brakes front, 2 pistion brakes rear, In Progress (remove your name when finished and add to completed list) 1. xtremewlr (conversion) collecting parts slowly 2. rtrotter (supercharged) 3KGT 3. Whitewavesea (single turbo) 3kgt Installation in progress 4. Aph (conversion) - Dec 17 '03 5. JRock4000 (conversion) 3000GT -should be done this January 6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 7. Mitch007 (conversion) expected completion by beginning of summer 8. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend. 9. AkiraGT (TT swap already started) 10. StealthTT (just need turbos and ICs with pipes) 11. Chant (TT / SuperCharger Conversion) :0) 12. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger 13. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap. 14. Renegadex181- Saving money and collecting parts...to start by April 15th XX. YOGURT! - MYKISS69 BLOWS didnt get my parts in time, sold to SONICBOUNCE17 15. Clipse20 - 94TT Swap w/ JapSpec ECU & Harness 16. spaceace60 - 96'base w/98'tt vr4motor 17. Presto97sl - TT conversion ATX check sig for days until install 18. MilkyClr69 - 96SL w/ 92JDMTT motor/5spd TT tranny waiting on parts 19. Nobodylikeswood - 94 SL u TT conversion 20. WolfSL - TT conversion - collecting parts 21. 92StealthR/T - Have all parts but oil cooler for my tt conversion 22. TruPnoyFlava - 94 base (VR4 swaP) 23. Ellery Clinton - Got all my parts... just need the 94/95 Harness and Ceramic Coat everything 24. Its Fwd - 94 base coming back to life, soon to be TT 25. My92Stealth - 92 Base, Putting in a TT this winter! 26. 2inTrbo - Some TT parts already installed...TRUELY IN PROGRESS!! 27. J-Groove - Waiting on the mail to bring in the last few parts. 28. zack6G72- A few parts on there way and then a clutch replacement. 29. ATXSUX- gathering parts as we speak, lack downpipe, gauges, ECU and Harness and a couple of little things.
1992 3000GT SLTT Engine completly rebuilt with DR Cams/Lifter springs/99 lifters, K&N FIPK w/Removed Resonator, Greddy BOV, Custom True-Dual Exhaust (Downpipe Back), DynaMax TZ Series Clutch, 3SX Lightweight Pulley, SFR Poly Motor Mounts, SFR LSD, 15g's, 550cc injecters, Walbro 255, Greddy Emanage Blue, TurboXS Dual Stage MBC, NGK Wires, Iridium Plugs, Big Tyla Ground Wires, Maximal Performence Front Strut Bar, Pivot Sleepy Eye Headlight Controller, Valentine One Radar/Laser Detector |
#638 (permalink) |
Venom Speed Shop
2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 10.Thump`Master (conversion) 3KGT 5 spd 11. JAL (conversion) 3KGT SOHC TT 12. ZachRT (single turbo) Stealth RT 13. 3KHI (supercharged) 3KGT 14. Juko (supercharged) 3KGT 15. SLAYER4ALL (supercharged) 3KGT 16. Snake93gt (supercharged) 3KGT SL 17. Spawn (supercharged) 3KGT SOHC ATX 18. OhFoSho (engine swap) SOHC Stealth 19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 20. shooter83 (engine swap) Stealth es 5spd 21. upyun (engine swap) 3kgt sl 22. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES 23. Evangelist (TT Conversion) Stealth ES/TT 5 spd 24. Blue-GTO (TT Conversion) 3kgt SL 25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 26. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 27. bigballsofpaint (TT conversion) 95 3k base....i finally finished 28. 92-3000GT (Single turbo) 3000gt sl 5spd 29. Optamix (engine swap) 3KGT SL 5spd 30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 31. Quintop (engine swap) '95 SL 5 sp 32. Jigzibit (conversion) '95 SL ATX 33. 93 Stealth R/T (TT conversion) 34. Bob The Great (TT conversion) 93 R/T AWD 5spd 35. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's 36. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness. 37. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 38. 3000hybrid (TT swap) 97 base GT- ATX to 5spd AWD tranny w/SFR LSD 19T's 39. 95red3000gt (TT conversion) only one in Colorado! 40. Jeremy C (TT conversion) - weekend project 41. Vortac (TT Conversion) SL ATX 42. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 43. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD 44. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD 45. Import Power Online-Fastest-Quickest-Dyno Record 132.97MPH/11.44-14bs/519HP EVOIIIs-5spd AWD The new FWD Record 46.93_black_R/T - Finished May 2004 47. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 48. rush6432 ( Single turbo conversion, stock 10:1 motor) 49. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 156K 50. Zumin3K - TT Swap) 9bs, TT ECU + Harness 51. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 52. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 53. aaron97- (conversion) 3000GT SL 54. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 55. |4x4 nv| - (TT Conversion) TT ecu/LSD Insert/450cc/5 Speed Getrag (113 mph on 9b's ) 56. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain/FMIC 57. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 58. kdog109sd (TT Conversion) - one of the first automatics to do it 59. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 60. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 61. KevD23 (single turbo) '94 stealth ATX 62. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife 63. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads 64. Pantherchams (Supercharged) 93 Stealth ES ATX 65. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT 66. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!) 67. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???) 68. Jomojr (TT Conversion 93 Base ATX) 69. Venom13132 (92 RT, swap 96 vr4 engine, 92vr4 ecu 92vr4 harness, 91 Getrag running FWD, LSD insert, TT Calipers) 70. Cobane (J-Spec Swap) 94 r/t 5-spd. 71. LeRoyDL (92 R/T DR650 TT Conv. JDM ECU, N/A harness) + (2 month old SBM will be running again in the next week) 72. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness. 73. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods 74. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX 75. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's 76.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2. 77. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500 78. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition 79. OneWingedAngel - 97 3000GT SL T/T conversion 80. 91StealthBaseTT - TT 10:1 compression fully rebuilt engine including valve job (: 81. PearlRyde - '92 TT Swap into a '99Base... Running on SOHC Tranny until i can rebuild the Getrag... 82. 94mitsumichael7 - 94 Stealth RT... FWD 9b's 8 psi, TT ECU, 10:1 motor, new EVERYTHING. lol. But its finally done and running!!! 83. templar - 94 3000GT ATX TT Conversion. 84. Nojinxz - .080 over supercharged running 6lbs boost - running very well 85. GTOGIRL3000 ~ 94 SL-TT and 5 speed NA MTX swap, 10:1 comp.,TT ECU and harness, SFR LSD. 86. Forsakenwolf - '91 ES-TT w/ 5spd NA MTX, 8:1 comp 87. white96tt - (engine swap) 95 Stealth Base ATX; 15gs/550 injectors/forged pistons, etc... (fired up for first time today 05/10/2006) 88. DSMGTO - 94 SL N/A motor, TT ECU, TT Fuel pump, 360 inj. 89. AyeKay 94 SL Twin Turbo with all the TT Parts 10:1 7lbs of Boost 90. blk92sl - now SLTT!!! just started her for the first time last night..6/17/06 91. Zeiss - 94 Stealth RT Luxury with 13gs 10:1 and SFR LSD insert. 92. Wildarmz - 94 SL TT, 92 TT Ecu, wastegate, SFR LSD, ACT2100, 3" Tanabe Hyper Medallion exhaust, ss downpipe. 93.MagnaVR4 - 99 base single cam to TT, 4bolt motor swap, 6spd,255 walbro, Greddy Type S, 3''exhaust ,Blitz Turbo Timer, 4 pistion brakes front, 2 pistion brakes rear, In Progress (remove your name when finished and add to completed list) 1. xtremewlr (conversion) collecting parts slowly 2. rtrotter (supercharged) 3KGT 3. Whitewavesea (single turbo) 3kgt Installation in progress 4. Aph (conversion) - Dec 17 '03 5. JRock4000 (conversion) 3000GT -should be done this January 6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 7. Mitch007 (conversion) expected completion by beginning of summer 8. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend. 9. AkiraGT (TT swap already started) 10. StealthTT (just need turbos and ICs with pipes) 11. Chant (TT / SuperCharger Conversion) :0) 12. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger 13. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap. 14. Renegadex181- Saving money and collecting parts...to start by April 15th XX. YOGURT! - MYKISS69 BLOWS didnt get my parts in time, sold to SONICBOUNCE17 15. Clipse20 - 94TT Swap w/ JapSpec ECU & Harness 16. spaceace60 - 96'base w/98'tt vr4motor 17. Presto97sl - TT conversion ATX check sig for days until install 18. MilkyClr69 - 96SL w/ 92JDMTT motor/5spd TT tranny waiting on parts 19. Nobodylikeswood - 94 SL u TT conversion 20. WolfSL - TT conversion - collecting parts 21. 92StealthR/T - Have all parts but oil cooler for my tt conversion 22. TruPnoyFlava - 94 base (VR4 swaP) 23. Ellery Clinton - Got all my parts... just need the 94/95 Harness and Ceramic Coat everything 24. Its Fwd - 94 base coming back to life, soon to be TT 25. My92Stealth - 92 Base, Putting in a TT this winter! 26. 2inTrbo - Some TT parts already installed...TRUELY IN PROGRESS!! 27. J-Groove - Waiting on the mail to bring in the last few parts. 28. zack6G72- A few parts on there way and then a clutch replacement. 29. ATXSUX- gathering parts as we speak, lack downpipe, gauges, ECU and Harness and a couple of little things. Had to update a few things on mine
#639 (permalink) | |
Racing
1. stu_04 (conversion) 3KGT SL ATX 2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 10.Thump`Master (conversion) 3KGT 5 spd 11. JAL (conversion) 3KGT SOHC TT 12. ZachRT (single turbo) Stealth RT 13. 3KHI (supercharged) 3KGT 14. Juko (supercharged) 3KGT 15. SLAYER4ALL (supercharged) 3KGT 16. Snake93gt (supercharged) 3KGT SL 17. Spawn (supercharged) 3KGT SOHC ATX 18. OhFoSho (engine swap) SOHC Stealth 19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 20. shooter83 (engine swap) Stealth es 5spd 21. upyun (engine swap) 3kgt sl 22. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES 23. Evangelist (TT Conversion) Stealth ES/TT 5 spd 24. Blue-GTO (TT Conversion) 3kgt SL 25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 26. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 27. bigballsofpaint (TT conversion) 95 3k base....i finally finished 28. 92-3000GT (Single turbo) 3000gt sl 5spd 29. Optamix (engine swap) 3KGT SL 5spd 30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 31. Quintop (engine swap) '95 SL 5 sp 32. Jigzibit (conversion) '95 SL ATX 33. 93 Stealth R/T (TT conversion) 34. Bob The Great (TT conversion) 93 R/T AWD 5spd 35. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's 36. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness. 37. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 38. 3000hybrid (TT swap) 97 base GT- ATX to 5spd AWD tranny w/SFR LSD 19T's 39. 95red3000gt (TT conversion) only one in Colorado! 40. Jeremy C (TT conversion) - weekend project 41. Vortac (TT Conversion) SL ATX 42. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 43. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD 44. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD 45. Import Power Online-Fastest-Quickest-Dyno Record 132.97MPH/11.44-14bs/519HP EVOIIIs-5spd AWD The new FWD Record 46.93_black_R/T - Finished May 2004 47. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 48. rush6432 ( Single turbo conversion, stock 10:1 motor) 49. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 156K 50. Zumin3K - TT Swap) 9bs, TT ECU + Harness 51. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 52. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 53. aaron97- (conversion) 3000GT SL 54. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 55. |4x4 nv| - (TT Swap) Evo3 16G's/Forged Internals(8.1:1 compression)/680cc injectors/Garrett FMIC/Propane/maftpro 56. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain/FMIC 57. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 58. kdog109sd (TT Conversion) - one of the first automatics to do it 59. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 60. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 61. KevD23 (single turbo) '94 stealth ATX 62. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife 63. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads 64. Pantherchams (Supercharged) 93 Stealth ES ATX 65. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT 66. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!) 67. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???) 68. Jomojr (TT Conversion 93 Base ATX) 69. Venom13132 (92 RT, swap 96 vr4 engine, 92vr4 ecu 92vr4 harness, 91 Getrag running FWD, LSD insert, TT Calipers) 70. Cobane (J-Spec Swap) 94 r/t 5-spd. 71. LeRoyDL (92 R/T DR650 TT Conv. JDM ECU, N/A harness) + (2 month old SBM will be running again in the next week) 72. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness. 73. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods 74. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX 75. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's 76.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2. 77. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500 78. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition 79. OneWingedAngel - 97 3000GT SL T/T conversion 80. 91StealthBaseTT - TT 10:1 compression fully rebuilt engine including valve job (: 81. PearlRyde - '92 TT Swap into a '99Base... Running on SOHC Tranny until i can rebuild the Getrag... 82. 94mitsumichael7 - 94 Stealth RT... FWD 9b's 8 psi, TT ECU, 10:1 motor, new EVERYTHING. lol. But its finally done and running!!! 83. templar - 94 3000GT ATX TT Conversion. 84. Nojinxz - .080 over supercharged running 6lbs boost - running very well 85. GTOGIRL3000 ~ 94 SL-TT and 5 speed NA MTX swap, 10:1 comp.,TT ECU and harness, SFR LSD. 86. Forsakenwolf - '91 ES-TT w/ 5spd NA MTX, 8:1 comp 87. white96tt - (engine swap) 95 Stealth Base ATX; 15gs/550 injectors/forged pistons, etc... (fired up for first time today 05/10/2006) 88. DSMGTO - 94 SL N/A motor, TT ECU, TT Fuel pump, 360 inj. 89. AyeKay 94 SL Twin Turbo with all the TT Parts 10:1 7lbs of Boost 90. blk92sl - now SLTT!!! just started her for the first time last night..6/17/06 91. Zeiss - 94 Stealth RT Luxury with 13gs 10:1 and SFR LSD insert. 92. Wildarmz - 94 SL TT, 92 TT Ecu, wastegate, SFR LSD, ACT2100, 3" Tanabe Hyper Medallion exhaust, ss downpipe. 93.MagnaVR4 - 99 base single cam to TT, 4bolt motor swap, 6spd,255 walbro, Greddy Type S, 3''exhaust ,Blitz Turbo Timer, 4 pistion brakes front, 2 pistion brakes rear, In Progress (remove your name when finished and add to completed list) 1. xtremewlr (conversion) collecting parts slowly 2. rtrotter (supercharged) 3KGT 3. Whitewavesea (single turbo) 3kgt Installation in progress 4. Aph (conversion) - Dec 17 '03 5. JRock4000 (conversion) 3000GT -should be done this January 6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 7. Mitch007 (conversion) expected completion by beginning of summer 8. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend. 9. AkiraGT (TT swap already started) 10. StealthTT (just need turbos and ICs with pipes) 11. Chant (TT / SuperCharger Conversion) :0) 12. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger 13. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap. 14. Renegadex181- Saving money and collecting parts...to start by April 15th XX. YOGURT! - MYKISS69 BLOWS didnt get my parts in time, sold to SONICBOUNCE17 15. Clipse20 - 94TT Swap w/ JapSpec ECU & Harness 16. spaceace60 - 96'base w/98'tt vr4motor 17. Presto97sl - TT conversion ATX check sig for days until install 18. MilkyClr69 - 96SL w/ 92JDMTT motor/5spd TT tranny waiting on parts 19. Nobodylikeswood - 94 SL u TT conversion 20. WolfSL - TT conversion - collecting parts 21. 92StealthR/T - Have all parts but oil cooler for my tt conversion 22. TruPnoyFlava - 94 base (VR4 swaP) 23. Ellery Clinton - Got all my parts... just need the 94/95 Harness and Ceramic Coat everything 24. Its Fwd - 94 base coming back to life, soon to be TT 25. My92Stealth - 92 Base, Putting in a TT this winter! 26. 2inTrbo - Some TT parts already installed...TRUELY IN PROGRESS!! 27. J-Groove - Waiting on the mail to bring in the last few parts. 28. zack6G72- A few parts on there way and then a clutch replacement. 29. ATXSUX- gathering parts as we speak, lack downpipe, gauges, ECU and Harness and a couple of little things.
92 Dodge Stealth R/T AWD/TT (TD05) converted ( 11.894 @ 120.56 - 18 psi -> Video )
![]() Twin TD05H EvoIII 16G's - Garrett FMIC - PTE 680cc - IPO Propane Injection - Maftpro - SouthBend DXD-F - PST CFDS - Northbend OS - Kaaz LSD - Cianci Victory Hood - Cianci Novara Bumper - Forged Internals 1mm over - and MUCH more.. |
#640 (permalink) |
Sweet,
1. stu_04 (conversion) 3KGT SL ATX 2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 10.Thump`Master (conversion) 3KGT 5 spd 11. JAL (conversion) 3KGT SOHC TT 12. ZachRT (single turbo) Stealth RT 13. 3KHI (supercharged) 3KGT 14. Juko (supercharged) 3KGT 15. SLAYER4ALL (supercharged) 3KGT 16. Snake93gt (supercharged) 3KGT SL 17. Spawn (supercharged) 3KGT SOHC ATX 18. OhFoSho (engine swap) SOHC Stealth 19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 20. shooter83 (engine swap) Stealth es 5spd 21. upyun (engine swap) 3kgt sl 22. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES 23. Evangelist (TT Conversion) Stealth ES/TT 5 spd 24. Blue-GTO (TT Conversion) 3kgt SL 25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 26. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 27. bigballsofpaint (TT conversion) 95 3k base....i finally finished 28. 92-3000GT (Single turbo) 3000gt sl 5spd 29. Optamix (engine swap) 3KGT SL 5spd 30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 31. Quintop (engine swap) '95 SL 5 sp 32. Jigzibit (conversion) '95 SL ATX 33. 93 Stealth R/T (TT conversion) 34. Bob The Great (TT conversion) 93 R/T AWD 5spd 35. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's 36. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness. 37. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 38. 3000hybrid (TT swap) 97 base GT- ATX to 5spd AWD tranny w/SFR LSD 19T's 39. 95red3000gt (TT conversion) only one in Colorado! 40. Jeremy C (TT conversion) - weekend project 41. Vortac (TT Conversion) SL ATX 42. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 43. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD 44. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD 45. Import Power Online-Fastest-Quickest-Dyno Record 132.97MPH/11.44-14bs/519HP EVOIIIs-5spd AWD The new FWD Record 46.93_black_R/T - Finished May 2004 47. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 48. rush6432 ( Single turbo conversion, stock 10:1 motor) 49. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 156K 50. Zumin3K - TT Swap) 9bs, TT ECU + Harness 51. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 52. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 53. aaron97- (conversion) 3000GT SL 54. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 55. |4x4 nv| - (TT Swap) Evo3 16G's/Forged Internals(8.1:1 compression)/680cc injectors/Garrett FMIC/Propane/maftpro 56. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain/FMIC 57. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 58. kdog109sd (TT Conversion) - one of the first automatics to do it 59. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 60. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 61. KevD23 (single turbo) '94 stealth ATX 62. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife 63. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads 64. Pantherchams (Supercharged) 93 Stealth ES ATX 65. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT 66. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!) 67. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???) 68. Jomojr (TT Conversion 93 Base ATX) 69. Venom13132 (92 RT, swap 96 vr4 engine, 92vr4 ecu 92vr4 harness, 91 Getrag running FWD, LSD insert, TT Calipers) 70. Cobane (J-Spec Swap) 94 r/t 5-spd. 71. LeRoyDL (92 R/T DR650 TT Conv. JDM ECU, N/A harness) + (2 month old SBM will be running again in the next week) 72. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness. 73. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods 74. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX 75. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's 76.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2. 77. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500 78. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition 79. OneWingedAngel - 97 3000GT SL T/T conversion 80. 91StealthBaseTT - TT 10:1 compression fully rebuilt engine including valve job (: 81. PearlRyde - '92 TT Swap into a '99Base... Running on SOHC Tranny until i can rebuild the Getrag... 82. 94mitsumichael7 - 94 Stealth RT... FWD 9b's 8 psi, TT ECU, 10:1 motor, new EVERYTHING. lol. But its finally done and running!!! 83. templar - 94 3000GT ATX TT Conversion. 84. Nojinxz - .080 over supercharged running 6lbs boost - running very well 85. GTOGIRL3000 ~ 94 SL-TT and 5 speed NA MTX swap, 10:1 comp.,TT ECU and harness, SFR LSD. 86. Forsakenwolf - '91 ES-TT w/ 5spd NA MTX, 8:1 comp 87. white96tt - (engine swap) 95 Stealth Base ATX; 15gs/550 injectors/forged pistons, etc... (fired up for first time today 05/10/2006) 88. DSMGTO - 94 SL N/A motor, TT ECU, TT Fuel pump, 360 inj. 89. AyeKay 94 SL Twin Turbo with all the TT Parts 10:1 7lbs of Boost 90. blk92sl - now SLTT!!! just started her for the first time last night..6/17/06 91. Zeiss - 94 Stealth RT Luxury with 13gs 10:1 and SFR LSD insert. 92. Wildarmz - 94 SL TT, 92 TT Ecu, wastegate, SFR LSD, ACT2100, 3" Tanabe Hyper Medallion exhaust, ss downpipe. 93.MagnaVR4 - 99 base single cam to TT, 4bolt motor swap, 6spd,255 walbro, Greddy Type S, 3''exhaust ,Blitz Turbo Timer, 4 pistion brakes front, 2 pistion brakes rear, 94. SeekNStrike- Stock TT swap. blitz boost con. S-AFCII, AEM wideband, Auto meter boost + EGT guages. Supra pump. 6 psi. In Progress (remove your name when finished and add to completed list) 1. xtremewlr (conversion) collecting parts slowly 2. rtrotter (supercharged) 3KGT 3. Whitewavesea (single turbo) 3kgt Installation in progress 4. Aph (conversion) - Dec 17 '03 5. JRock4000 (conversion) 3000GT -should be done this January 6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 7. Mitch007 (conversion) expected completion by beginning of summer 8. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend. 9. AkiraGT (TT swap already started) 10. StealthTT (just need turbos and ICs with pipes) 11. Chant (TT / SuperCharger Conversion) :0) 12. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger 13. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap. 14. Renegadex181- Saving money and collecting parts...to start by April 15th XX. YOGURT! - MYKISS69 BLOWS didnt get my parts in time, sold to SONICBOUNCE17 15. Clipse20 - 94TT Swap w/ JapSpec ECU & Harness 16. spaceace60 - 96'base w/98'tt vr4motor 17. Presto97sl - TT conversion ATX check sig for days until install 18. MilkyClr69 - 96SL w/ 92JDMTT motor/5spd TT tranny waiting on parts 19. Nobodylikeswood - 94 SL u TT conversion 20. WolfSL - TT conversion - collecting parts 21. 92StealthR/T - Have all parts but oil cooler for my tt conversion 22. TruPnoyFlava - 94 base (VR4 swaP) 23. Ellery Clinton - Got all my parts... just need the 94/95 Harness and Ceramic Coat everything 24. Its Fwd - 94 base coming back to life, soon to be TT 25. My92Stealth - 92 Base, Putting in a TT this winter! 26. 2inTrbo - Some TT parts already installed...TRUELY IN PROGRESS!! 27. J-Groove - Waiting on the mail to bring in the last few parts. 28. zack6G72- A few parts on there way and then a clutch replacement. 29. ATXSUX- gathering parts as we speak, lack downpipe, gauges, ECU and Harness and a couple of little things. Last edited by SeekNStrike : 11-07-2006 at 01:14 AM. |
