Old 12-05-2005, 01:08 PM   #551 (permalink)
Corn Its whats for boost
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (217)
Default Re: FWD TT cars.. how many are there now?
I ran 12-14psi on 110 octane for many months with a few bursts over 20psi on accident. Until the woops over 30psi accident
And that was on a 156K NA stock bottom end
AEM Factory Trained Tuner
91VR4-3.0L-Stock heads and Cams-770AWHP 747AWTQ 30psi E100 Daily Driver 10.57@136mph
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
NG09 Title Sponsor
3SX Performance
3SX Performance Service Email
Old 12-05-2005, 01:10 PM   #552 (permalink)
TajMan's Avatar
Drives: 93SOHCMTX
Trader Rating: (25)
TajMan is an unknown quantity at this point
My N/A bottom end has around 100K miles on it, just like my car.
former 3/Ss: '92 R/T, '94 3KGT, modded '92 R/T TT
'93/94/97 Stealth-3000GT SOHC MTX 277K miles
-custom 1G R/T-2G GT front bumper
-TT wheels
-2G TT front brakes
'79 Yamaha XS11 special
TajMan is offline   Reply With Quote
Old 12-05-2005, 01:48 PM   #553 (permalink)
100% MEAT
Ellery Clinton's Avatar
Drives: 3000GT NA
Trader Rating: (24)
Ellery Clinton is an unknown quantity at this point
how are boost spike prevented?
2003 C32 AMG
1995 3000GT - sold 12/14/06
Ellery Clinton is offline   Reply With Quote
Old 12-05-2005, 02:02 PM   #554 (permalink)
Racing
Barefoot's Avatar
Drives: 92R/T - converted ;)
Trader Rating: (31)
Barefoot Level 1Barefoot Level 1Barefoot Level 1
hey, thats alot like mine, 154k NA stock bottom end, but i ran 93 octane... and a 17 psi killed it, not 30...
92 Dodge Stealth R/T AWD/TT (TD05) converted ( 11.894 @ 120.56 - 18 psi -> Video )
SOUTHEAST DRAG DAY 2009! DOOO EEEET!
Barefoot is offline   Reply With Quote
Old 12-05-2005, 02:04 PM   #555 (permalink)
Racing
Barefoot's Avatar
Trader Rating: (31)
you can use the warn feature on a EBC, and watch your guage more often than i do.
however the warn feature wont save you in a case like mine, where the vac line came off the y-pipe..
Old 12-05-2005, 02:07 PM   #556 (permalink)
3tripleOpimpin
Jon Mills's Avatar
Drives: FWD-TT
Trader Rating: (36)
Jon Mills is an unknown quantity at this point
I got 152K on mine right now. I am running 93 octane at 10psi for the last 8K miles. With not much tunning at all.
[size=1]1942 Chevy Truck (custom everything)
95 FWD-TT SOLD!
New TOY C5 Vette!!
Jon Mills is offline   Reply With Quote
Old 12-20-2005, 03:57 AM   #557 (permalink)
Wishin' I had a vr4 :(
3kGTbase's Avatar
Drives: 02 Chevy Silverado
3kGTbase is an unknown quantity at this point
Originally Posted by PearlRyde
1. stu_04 (conversion) 3KGT SL ATX
2. punkasscrab (conversion) 3KGT 5 spd
3. SLguy (conversion) 3KGT ATX <---going down to 8:1
4. JB (engine swap) 3KGT 5spd
5. Mikes95RT (conversion) Stealth R/T 5 spd
6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo
7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1
8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original
9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd
10. X GTO X (engine swap) 3KGT (VR-2)
10.Thump`Master (conversion) 3KGT 5 spd
11. JAL (conversion) 3KGT SOHC TT
12. ZachRT (single turbo) Stealth RT
13. 3KHI (supercharged) 3KGT
14. Juko (supercharged) 3KGT
15. SLAYER4ALL (supercharged) 3KGT
16. Snake93gt (supercharged) 3KGT SL
17. Spawn (supercharged) 3KGT SOHC ATX
18. OhFoSho (engine swap) SOHC Stealth
19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd
20. shooter83 (engine swap) Stealth es 5spd
21. upyun (engine swap) 3kgt sl
22. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES
23. Evangelist (TT Conversion) Stealth ES/TT 5 spd
24. Blue-GTO (TT Conversion) 3kgt SL
25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd
26. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe
27. bigballsofpaint (TT conversion) 95 3k base....i finally finished
28. 92-3000GT (Single turbo) 3000gt sl 5spd
29. Optamix (engine swap) 3KGT SL 5spd
30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months)
31. Quintop (engine swap) '95 SL 5 sp
32. Jigzibit (conversion) '95 SL ATX
33. 93 Stealth R/T (TT conversion)
34. Bob The Great (TT conversion) 93 R/T AWD 5spd
35. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's
36. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness.
37. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT
38. 3000hybrid (TT swap) ATX to 5spd AWD tranny-
39. 95red3000gt (TT conversion) only one in Colorado!
40. Jeremy C (TT conversion) - weekend project
41. Vortac (TT Conversion) SL ATX
42. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd.
43. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD
44. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD
45. Import Power Online-Fastest-Quickest-Dyno Record 132.97MPH/11.44-14bs/519HP EVOIIIs-5spd AWD The new FWD Record
46.93_black_R/T - Finished May 2004
47. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu
48. rush6432 (TT conversion) 13Ts, VR4 ECU. 14.1 @ 103 (6 psi on 9Bs w/ stock clutch)
49. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 140K
50. Zumin3K - TT Swap) 9bs, TT ECU + Harness
51. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap
52. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL
53. aaron97- (conversion) 3000GT SL
54. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc
55. |4x4 nv| - (TT Conversion) TT ecu/LSD Insert/450cc/5 Speed Getrag (113 mph on 9b's )
56. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain/FMIC
57. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo
58. kdog109sd (TT Conversion) - one of the first automatics to do it
59. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi
60. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX
61. KevD23 (single turbo) '94 stealth ATX
62. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife
63. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads
64. Pantherchams (Supercharged) 93 Stealth ES ATX
65. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT
66. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!)
67. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???)
68. Jomojr (TT Conversion 93 Base ATX)
69. Venom13132 (92 RT, swap 96 vr4 engine, 92vr4 ecu 92vr4 hharness)
70. Cobane (J-Spec Swap) 94 r/t 5-spd.
71. LeRoyDL (92 R/T DR650 TT Conv. JDM ECU, N/A harness) + (2 month old SBM will be running again in the next week)
72. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness.
73. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods
74. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX
75. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's
76.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2.
77. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500
78. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition
79. OneWingedAngel - 97 3000GT SL T/T conversion
80. 91StealthBaseTT - TT 10:1 compression fully rebuilt engine including valve job (:
In Progress (remove your name when finished and add to completed list)
1. xtremewlr (conversion) collecting parts slowly
2. rtrotter (supercharged) 3KGT
3. Whitewavesea (single turbo) 3kgt Installation in progress
4. Aph (conversion) - Dec 17 '03
5. JRock4000 (conversion) 3000GT -should be done this January
6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad
7. Mitch007 (conversion) expected completion by beginning of summer
8. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend.
9. AkiraGT (TT swap already started)
10. StealthTT (just need turbos and ICs with pipes)
11. Chant (TT / SuperCharger Conversion) :0)
12. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger
13. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap.
14. Renegadex181- Saving money and collecting parts...to start by April 15th
15. templar - SLTT (94SL ATX)
XX. YOGURT! - MYKISS69 BLOWS didnt get my parts in time, sold to SONICBOUNCE17
17. Clipse20 - 94TT Swap w/ JapSpec ECU & Harness
18. spaceace60 - 96'base w/98'tt vr4motor
19. Presto97sl - TT conversion ATX check sig for days until install
20. MilkyClr69 - 96SL w/ 92JDMTT motor/5spd TT tranny waiting on parts
21. Nobodylikeswood - 94 SL u TT conversion
22. WolfSL - TT conversion - collecting parts
23. 92StealthR/T - Have all parts but oil cooler for my tt conversion
24. nojinxz - the 10th supercharged gt on here... waiting on install by rippmods
25. PearlRyde - '92 TT Swap into a '99Base... Both Motors pulled!!!
10 months after the SOHC began to bore me. It's all finally coming together (Now if i could only get away from this thing called work for a bit)
IPO, I hope the rain passes, i'm rooting for you to break all the records.
P.S. Thanks for the MBC. Your website is great!
Rob
Actually, I was number 43 on the list. I don't know how the hell it got erased lol. I got smart and bought a v8
Sold the '94 FWDTT 3kgt. I now own a Chevy Silverado. Some day I'll own a VR4...I'm in love....
My web site: www.geocities.com/mo0cow2003
~Get TT conversion info, and more!~
3kGTbase is offline   Reply With Quote
Old 12-20-2005, 04:19 AM   #558 (permalink)
No one's style compares.
Arkady's Avatar
Drives: desolves your esophu
Arkady is an unknown quantity at this point
Holy crap!! You guys blew up. I think when I first joined there were maybe two of you... Iceman and someone else. Well props guys. Jesus....
xSabrielx: So Chris kills ex-g/f's, burns their bodies then dates their best friends? Plus he dates homeless guys then kills them too?
BlackTopVR4: No no no, he ships them to Lithuania, sleeps w/the best friend, has her sexually assaulted by a homeless guy then kills them both...
Jeff: Chris likes his women like he likes his coffee; hot and black.
Master X: I hate you.
Arkady is offline   Reply With Quote
Old 12-23-2005, 03:47 PM   #559 (permalink)
gtopistons's Avatar
gtopistons is an unknown quantity at this point
No one ever added me, LOL I did it back in the day with punkasscrab and gatecrasher!! lol
[color=red]Twin Turbo Motor Swap DR500s, Turbo XS RFL Blow Off Valve, 8:1 with 3 Angle Valve Cut, Full Port and Polish, 2nd Generation Lifter Conversion, HKS Plugs, Intake, Forged Crank and Rods, Stillen 3inch Down Pipe (Pre & Main Cat Eliminator), 3inch exhaust w/ Dual N1 Style polished mufflers, Full ECU upgrade (replacement), Walbro 255LPH Fuel Pump, Apexi Super-AFC, Short Shifter, Poly-Urethane Motor Mounts, Quaife Limited Slip Differential, Ground Control Coilovers, Cusco J-Spec Rear Strut Tower Bar, Super Mac Front Strut Tower Bar, Stillen Cross Drilled Rotors, Metal Matrix Semi Metallic Brake Pads, 17X8 Konig Toxxins, Falken 451 255-45-17, Full Erebuni Shogun Kit w/ GTR 57inch Wing, Cobra Ram Air Hood Scoop, Shaved Turning Signals, Shaved Key Holes, Complete Color Change 1987 GM Silver Metallic, Custom Silver and Black Leather Interior w/ Carpet and Headliner Kit, H4 Headlight Conversion, Kenwood 600 Watt Amp, Kenwood In Dash MP3/CD, Audiobahn DVD/MP3/CD Player, JVC 5.8 LCD Display, Kicker Impulse Crossover w/ Remote Bass Controller, Absolute Speakers, Stinger 1.0 Digital Capacitor, Nitrous Express Purge Kit, NOS Fuel/NOS Solenoids, Autometer 5inch Tachometer w/ Shift Light, Autometer 60mm Boost Gauge, Autometer 52mm Air/Fuel Gauge, I/O 4 Point Roll Bar, SaBelt 4 Point Harness (2) , Custom 12's in trunk with NOS tank in the middle = 500HP
My car = www.Pcpages.com/silvergto
gtopistons is offline   Reply With Quote
Old 12-23-2005, 07:28 PM   #560 (permalink)
NG09 Associate Sponsor
Venom13132's Avatar
Drives: Small Car Big Engine
Trader Rating: (109)
Venom13132 Level 1Venom13132 Level 1
you have to add yourself.. you can put yourself at the front but you have to change all the numbers after you..
Venom13132 is offline   Reply With Quote
