14psi on 10:1 should be similar to 22psi on 8:1. Thats the great thing you can run 14psi on 9b's but not 22psi... so 9b's can be pushed farther on 10:1 than 8:1.
Your not gonna hit 14psi in 10:1 without water/alchy or race gas. Hopefully I'll end up with the FMIC and the water/alchy though.
I believe it was silver bullet (I think it was him at least) that ran 12 or 13 psi on pump all the time with 10:1. With a timing controller the possibility of 14psi on 10:1 becomes even more possible.
little exageration
14.5 on 8:1 is like 18.2 on 10:1
little bit more than 3 less than 4 psi difference. not 8
AEM Factory Trained Tuner
91VR4-3.0L-Stock heads and Cams-770AWHP 747AWTQ 30psi E100 Daily Driver 10.57@136mph
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
edit: no I checked and I thought I was right -- and that post above is worded wrong you mixed up 8:1 and 10:1 right
Remember last time when you were so sure on using that chart Chris and then you ended up being proven wrong, you couldn't quite use the equation the way you were using it.
