Old 10-12-2005, 02:55 PM   #511 (permalink)
Banned from selling
Drives: 1998 3000GT FWD TT
SpeedFreakSteve is an unknown quantity at this point
Default Re: FWD TT cars.. how many are there now?
Originally Posted by Import Power
pure 100% benchracing, but if my 10.91 @ 142mph run was a 1.7 instead of 1.9 that would cut at the LEAST .4 off the et and even as high as .6.
That makes it 10.51 to 10.31
That's assuming that your new traction mods only affect your first 60'. I think we both know that they will affect more than that.. especially the few tenths of a second after everything shift.
SpeedFreakSteve is offline   Reply With Quote
Old 10-12-2005, 03:06 PM   #512 (permalink)
Corn Its whats for boost
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (217)
Yeah, I just don't want to bench race too extreme.
I just want to better my times before the season ends.
This firday may be the last Chance.
AEM Factory Trained Tuner
91VR4-3.0L-Stock heads and Cams-770AWHP 747AWTQ 30psi E100 Daily Driver 10.57@136mph
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
NG09 Title Sponsor
3SX Performance
3SX Performance Service Email
Import Power is online now   Reply With Quote
Old 10-13-2005, 02:24 PM   #513 (permalink)
The Monkey On Your Back
Gorilla's Avatar
Gorilla is an unknown quantity at this point
How we looking Imp? Ready for a run tomorrow?
Gorilla is offline   Reply With Quote
Old 10-13-2005, 03:12 PM   #514 (permalink)
raining now and calling for rain tomorrow.
Old 10-28-2005, 03:49 PM   #515 (permalink)
One of the Tripod
PearlRyde's Avatar
Drives: '99 3kGT FWD-TT
Trader Rating: (25)
PearlRyde is an unknown quantity at this point
1. stu_04 (conversion) 3KGT SL ATX
2. punkasscrab (conversion) 3KGT 5 spd
3. SLguy (conversion) 3KGT ATX <---going down to 8:1
4. JB (engine swap) 3KGT 5spd
5. Mikes95RT (conversion) Stealth R/T 5 spd
6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo
7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1
8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original
9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd
10. X GTO X (engine swap) 3KGT (VR-2)
10.Thump`Master (conversion) 3KGT 5 spd
11. JAL (conversion) 3KGT SOHC TT
12. ZachRT (single turbo) Stealth RT
13. 3KHI (supercharged) 3KGT
14. Juko (supercharged) 3KGT
15. SLAYER4ALL (supercharged) 3KGT
16. Snake93gt (supercharged) 3KGT SL
17. Spawn (supercharged) 3KGT SOHC ATX
18. OhFoSho (engine swap) SOHC Stealth
19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd
20. shooter83 (engine swap) Stealth es 5spd
21. upyun (engine swap) 3kgt sl
22. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES
23. Evangelist (TT Conversion) Stealth ES/TT 5 spd
24. Blue-GTO (TT Conversion) 3kgt SL
25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd
26. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe
27. bigballsofpaint (TT conversion) 95 3k base....i finally finished
28. 92-3000GT (Single turbo) 3000gt sl 5spd
29. Optamix (engine swap) 3KGT SL 5spd
30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months)
31. Quintop (engine swap) '95 SL 5 sp
32. Jigzibit (conversion) '95 SL ATX
33. 93 Stealth R/T (TT conversion)
34. Bob The Great (TT conversion) 93 R/T AWD 5spd
35. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's
36. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness.
37. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT
38. 3000hybrid (TT swap) ATX to 5spd AWD tranny-
39. 95red3000gt (TT conversion) only one in Colorado!
40. Jeremy C (TT conversion) - weekend project
41. Vortac (TT Conversion) SL ATX
42. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd.
43. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD
44. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD
45. Import Power Online-Fastest-Quickest-Dyno Record 132.97MPH/11.44-14bs/519HP EVOIIIs-5spd AWD The new FWD Record
46.93_black_R/T - Finished May 2004
47. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu
48. rush6432 (TT conversion) 13Ts, VR4 ECU. 14.1 @ 103 (6 psi on 9Bs w/ stock clutch)
49. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 140K
50. Zumin3K - TT Swap) 9bs, TT ECU + Harness
51. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap
52. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL
53. aaron97- (conversion) 3000GT SL
54. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc
55. |4x4 nv| - (TT Conversion) TT ecu/LSD Insert/450cc/5 Speed Getrag (113 mph on 9b's )
56. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain/FMIC
57. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo
58. kdog109sd (TT Conversion) - one of the first automatics to do it
59. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi
60. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX
61. KevD23 (single turbo) '94 stealth ATX
62. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife
63. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads
64. Pantherchams (Supercharged) 93 Stealth ES ATX
65. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT
66. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!)
67. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???)
68. Jomojr (TT Conversion 93 Base ATX)
69. Venom13132 (92 RT, swap 96 vr4 engine, 92vr4 ecu 92vr4 hharness)
70. Cobane (J-Spec Swap) 94 r/t 5-spd.
71. LeRoyDL (92 R/T DR650 TT Conv. JDM ECU, N/A harness) + (2 month old SBM will be running again in the next week)
72. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness.
73. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods
74. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX
75. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's
76.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2.
77. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500
78. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition
79. OneWingedAngel - 97 3000GT SL T/T conversion
80. 91StealthBaseTT - TT 10:1 compression fully rebuilt engine including valve job (:
In Progress (remove your name when finished and add to completed list)
1. xtremewlr (conversion) collecting parts slowly
2. rtrotter (supercharged) 3KGT
3. Whitewavesea (single turbo) 3kgt Installation in progress
4. Aph (conversion) - Dec 17 '03
5. JRock4000 (conversion) 3000GT -should be done this January
6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad
7. Mitch007 (conversion) expected completion by beginning of summer
8. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend.
9. AkiraGT (TT swap already started)
10. StealthTT (just need turbos and ICs with pipes)
11. Chant (TT / SuperCharger Conversion) :0)
12. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger
13. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap.
14. Renegadex181- Saving money and collecting parts...to start by April 15th
15. templar - SLTT (94SL ATX)
XX. YOGURT! - MYKISS69 BLOWS didnt get my parts in time, sold to SONICBOUNCE17
17. Clipse20 - 94TT Swap w/ JapSpec ECU & Harness
18. spaceace60 - 96'base w/98'tt vr4motor
19. Presto97sl - TT conversion ATX check sig for days until install
20. MilkyClr69 - 96SL w/ 92JDMTT motor/5spd TT tranny waiting on parts
21. Nobodylikeswood - 94 SL u TT conversion
22. WolfSL - TT conversion - collecting parts
23. 92StealthR/T - Have all parts but oil cooler for my tt conversion
24. nojinxz - the 10th supercharged gt on here... waiting on install by rippmods
25. PearlRyde - '92 TT Swap into a '99Base... Both Motors pulled!!!
10 months after the SOHC began to bore me. It's all finally coming together (Now if i could only get away from this thing called work for a bit)
IPO, I hope the rain passes, i'm rooting for you to break all the records.
P.S. Thanks for the MBC. Your website is great!
Rob
Image hosted by Photobucket.com
PearlRyde is offline   Reply With Quote
Old 10-28-2005, 06:22 PM   #516 (permalink)
Meglomaniac
VR-4 0wnz j00's Avatar
Drives: 95 3000GT VR-4
VR-4 0wnz j00 is an unknown quantity at this point
Im in progess and have gathered about 2/3 of the parts. Saving up for the rest. Hoping to have everything in a month or 2.
1995 3000GT VR-4 Black Bone Stock
Sold - 1994 Mitsubishi 3000GT Pearl White Base
VR-4 0wnz j00 is offline   Reply With Quote
Old 10-29-2005, 12:14 AM   #517 (permalink)
Drives: 93 Stealth R/T 1/2TT
Trader Rating: (8)
93 Stealth R/T is an unknown quantity at this point
Looking back on this i'm just amazed at the amount of people that have converted. When I started my conversion there were only 4 or 5 finished conversions, now it looks like there will be almost 200 by years end.
1993 Stealth RT w/ TT conv and then some...
I've grounded myself from the key until I'm convinced it has enough engine protection mods to not blow up.
93 Stealth R/T is offline   Reply With Quote
Old 10-29-2005, 12:38 AM   #518 (permalink)
AND we have hit 10's AND own the trap record and are the ONLY ones to break 140mph.
Old 10-29-2005, 11:03 AM   #519 (permalink)
Drives: White 3000GT SL
Devious3KGTSL is an unknown quantity at this point
In Progress... 95 SL TT conversion.
Devious3KGTSL is offline   Reply With Quote
Old 10-31-2005, 09:07 AM   #520 (permalink)
Drives: 94 3000GT SL TT
94ATXVR2 is an unknown quantity at this point
94ATXVR2 (TT engine swap, tt wiring harness, tt ecu) 3KGT ATX it will be done by end of this week
94ATXVR2 is offline   Reply With Quote
