Old 08-04-2005, 08:36 PM   #461 (permalink)
Venom Speed Shop
Venom13132's Avatar
Drives: Small Car Big Engine
Trader Rating: (101)
Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7
Default Re: FWD TT cars.. how many are there now?
Originally Posted by Jon Mills
Hey fred did you get your up and running? I would go 8:1 but I have a 50K 10:1 waiting to be put in once I blow mine. I say I will be 10:1 forever. I am buying 2 10:1 engines tomorrow for $400 for both! ha One of them the oil pump was going out. So I am going to take the pan off to see if everything is ok. The other one has low miles on it. This kid has them at his house and his dad is making him get rid of them! lol
well ive got it close. I think im having difficutly with the differences in the CAS so ive been waiting for almost two weeks for a guy on the boards here to send me a 91-92 cas to replace my 96 cam/crank sensor with. Yeah 10:1 is cool too. less boost same power!!
Venom13132 is offline   Reply With Quote
Old 08-05-2005, 08:43 PM   #462 (permalink)
Row faster!
WolfSL's Avatar
Drives: 92 VR4 & 98 SL
WolfSL is an unknown quantity at this point
In Progress (remove your name when finished and add to completed list)
1. xtremewlr (conversion) collecting parts slowly
2. rtrotter (supercharged) 3KGT
3. Whitewavesea (single turbo) 3kgt Installation in progress
4. Aph (conversion) - Dec 17 '03
5. JRock4000 (conversion) 3000GT -should be done this January
6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad
7. Mitch007 (conversion) expected completion by beginning of summer
8. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend.
9. AkiraGT (TT swap already started)
10. StealthTT (just need turbos and ICs with pipes)
11. Chant (TT / SuperCharger Conversion) :0)
12. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger
13. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap.
14. Renegadex181- Saving money and collecting parts...to start by April 15th
15. templar - SLTT (94SL ATX)
16. YOGURT! - Parts purchased, waiting on Mykiss69 for delivery, (94SL MTX)
17. Clipse20 - 94TT Swap w/ JapSpec ECU & Harness
18. spaceace60 - 96'base w/98'tt vr4motor
19. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition
20. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500
21. Presto97sl - TT conversion ATX check sig for days until install
22. MilkyClr69 - 96SL w/ 92JDMTT motor/5spd TT tranny waiting on parts
23. Nobodylikeswood - 94 SL u TT conversion
24. WolfSL - TT conversion - collecting parts
Well I came about some extra cash to spend so I decided to start prepping my car for the conversion, hopefully I'll be able to get all the parts before next summer.
<-- How I plan on going fast
1992 VR-4 - It is being fixed (finally)
1998 SL - DD
WolfSL is offline   Reply With Quote
Old 08-15-2005, 11:07 AM   #463 (permalink)
ccrunner84's Avatar
Drives: 92 Stealth RT/TT FWD
Trader Rating: (16)
ccrunner84 is an unknown quantity at this point
1. stu_04 (conversion) 3KGT SL ATX
2. punkasscrab (conversion) 3KGT 5 spd
3. SLguy (conversion) 3KGT ATX <---going down to 8:1
4. JB (engine swap) 3KGT 5spd
5. Mikes95RT (conversion) Stealth R/T 5 spd
6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo
7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1
8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original
9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd
10. X GTO X (engine swap) 3KGT (VR-2)
10.Thump`Master (conversion) 3KGT 5 spd
11. JAL (conversion) 3KGT SOHC TT
12. ZachRT (single turbo) Stealth RT
13. 3KHI (supercharged) 3KGT
14. Juko (supercharged) 3KGT
15. SLAYER4ALL (supercharged) 3KGT
16. Snake93gt (supercharged) 3KGT SL
17. Spawn (supercharged) 3KGT SOHC ATX
18. OhFoSho (engine swap) SOHC Stealth
19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd
20. shooter83 (engine swap) Stealth es 5spd
21. upyun (engine swap) 3kgt sl
22. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES
23. Evangelist (TT Conversion) Stealth ES/TT 5 spd
24. Blue-GTO (TT Conversion) 3kgt SL
25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd
26. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe
27. bigballsofpaint (TT conversion) 95 3k base....i finally finished
28. 92-3000GT (Single turbo) 3000gt sl 5spd
29. Optamix (engine swap) 3KGT SL 5spd
30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months)
31. Quintop (engine swap) '95 SL 5 sp
32. Jigzibit (conversion) '95 SL ATX
33. 93 Stealth R/T (TT conversion)
34. Bob The Great (TT conversion) 93 R/T AWD 5spd
35. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's
36. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness.
37. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT
38. 3000hybrid (TT swap) ATX to 5spd AWD tranny-
39. 95red3000gt (TT conversion) only one in Colorado!
40. Jeremy C (TT conversion) - weekend project
41. Vortac (TT Conversion) SL ATX
42. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd.
43. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD
44. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD
45. Import Power Online-132.97MPH/11.44-14bs/5spd AWD The new FWD Record
46.93_black_R/T - Finished May 2004
47. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu
48. rush6432 (TT conversion) 13Ts, VR4 ECU. 14.1 @ 103 (6 psi on 9Bs w/ stock clutch)
49. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 140K
50. Zumin3K - TT Swap) 9bs, TT ECU + Harness
51. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap
52. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL
53. aaron97- (conversion) 3000GT SL
54. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc
55. |4x4 nv| - (TT Conversion) TT ecu/LSD/450cc
56. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain
57. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo
58. kdog109sd (TT Conversion) - one of the first automatics to do it
59. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi
60. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX
61. KevD23 (single turbo) '94 stealth ATX
62. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife
63. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads
64. Pantherchams (Supercharged) 93 Stealth ES ATX
65. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT
66. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!)
67. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???)
68. Jomojr (TT Conversion 93 Base ATX)
69. Venom13132 (92 RT, swap 96 vr4 engine, 92vr4 ecu 92vr4 hharness)
70. Cobane (J-Spec Swap) 94 r/t 5-spd.
71. LeRoyDL (92 R/T DR650 TT Conv. JDM ECU, N/A harness) + (2 month old SBM will be running again in the next week)
72. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness.
73. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods
74. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX
75. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's
ccrunner84 is offline   Reply With Quote
Old 08-15-2005, 11:09 AM   #464 (permalink)
Wanna be TT
Chris95RT's Avatar
Drives: 95 R/T (1 of 57)
Trader Rating: (10)
Chris95RT is an unknown quantity at this point
76.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2.
Figured I should add my name up here, looks like we might get to 100!
'95 Dodge Stealth R/T
Need quality transmission work? http://northbendtech.com/
Chris95RT is offline   Reply With Quote
Old 08-28-2005, 04:52 PM   #465 (permalink)
Xtreme2k2's Avatar
Drives: 98 SL
Trader Rating: (36)
Xtreme2k2 is an unknown quantity at this point
Damn, almost forgot, haha
77. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500
20. Presto97sl - TT conversion ATX check sig for days until install
21. MilkyClr69 - 96SL w/ 92JDMTT motor/5spd TT tranny waiting on parts
22. Nobodylikeswood - 94 SL u TT conversion
23. WolfSL - TT conversion - collecting parts
98 Pearl White 3000GT SL *FOR SALE*
Xtreme2k2 is offline   Reply With Quote
Old 08-28-2005, 06:42 PM   #466 (permalink)
Corn Its whats for boost
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (210)
Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7
And now the FWD TT has broken the 500 wheel horsepower barrier, making it over 600 (aprox. 625) crank HP
519FWHP 487 Ft-Lbs @ 25psi
http://www.3si.org/forum/showthread.php?p=3136724
AEM Factory Trained Tuner
91VR4-3.0L-Stock heads and Cams-762AWHP 747AWTQ 30psi E100 Daily Driver 10.63@121mph
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
91VR4 Red-17Gs w/supporting mods-sold
93SLTT/T2
91VR4 Pearl White-sold
91VR4 Black-sold
92VR4 Sandstone-sold
94VR4 Green-sold
93VR4 Pearl White-sold
NG09 Title Sponsor
3SX Performance
3SX Performance Service Email
Old 08-28-2005, 07:03 PM   #467 (permalink)
Xtreme2k2's Avatar
Drives: 98 SL
Trader Rating: (36)
so whens that IPO TD05 kit come out
Old 08-28-2005, 07:05 PM   #468 (permalink)
I want some better ETs first
Old 08-28-2005, 07:07 PM   #469 (permalink)
Xtreme2k2's Avatar
Drives: 98 SL
Trader Rating: (36)
Alrighty then, giving me time to make some more money for it I see
Old 08-28-2005, 10:49 PM   #470 (permalink)
Import Chop House
YOGURT!'s Avatar
Drives: '03 350Z Track
Trader Rating: (51)
YOGURT! Level 2YOGURT! Level 2YOGURT! Level 2
XX. YOGURT! - MYKISS69 BLOWS didnt get my parts in time, sold to SONICBOUNCE17
As of 1/28/08 I am 3S-less
'03 Nissan 350Z Track Edition
Super Black Brembos-LSD-Nav-M6
[K&N Drop in][Radiator Cooling Plate][TopSpeed Pullies]
[Grounding Kit][PowerLab 3/8"][TopSpeed TP]
13.86 @ 101.3 (without pullies) Ran at NYIRP
1995 Eagle Talon TSI AWD
White 5spd.
[FMIC][Turboback][intake][BlitzDD][Walbro]
Former Cars: All Dearly Missed.
2005 Nissan Altima SE-R Black
1993 3000GT Base Red 5spd
1992 Dodge Stealth ES Black 5Spd
1994 Dodge Stealth RT/TT Pearl Yellow 473 AWHP 6spd
1994 3000GT SL Danube Blue 5spd
1993 3000GT Base Green 14.0@101 5spd
Nitrous+
FQuick.com
Take a look at Fquick, its Myspace for your car!
YOGURT! is offline   Reply With Quote
