Old 07-19-2005, 10:44 AM   #451 (permalink)
gtopistons's Avatar
gtopistons is an unknown quantity at this point
Default Re: FWD TT cars.. how many are there now?
I been had my swap about 9 months after gatecrasher...
[color=red]Twin Turbo Motor Swap DR500s, Turbo XS RFL Blow Off Valve, 8:1 with 3 Angle Valve Cut, Full Port and Polish, 2nd Generation Lifter Conversion, HKS Plugs, Intake, Forged Crank and Rods, Stillen 3inch Down Pipe (Pre & Main Cat Eliminator), 3inch exhaust w/ Dual N1 Style polished mufflers, Full ECU upgrade (replacement), Walbro 255LPH Fuel Pump, Apexi Super-AFC, Short Shifter, Poly-Urethane Motor Mounts, Quaife Limited Slip Differential, Ground Control Coilovers, Cusco J-Spec Rear Strut Tower Bar, Super Mac Front Strut Tower Bar, Stillen Cross Drilled Rotors, Metal Matrix Semi Metallic Brake Pads, 17X8 Konig Toxxins, Falken 451 255-45-17, Full Erebuni Shogun Kit w/ GTR 57inch Wing, Cobra Ram Air Hood Scoop, Shaved Turning Signals, Shaved Key Holes, Complete Color Change 1987 GM Silver Metallic, Custom Silver and Black Leather Interior w/ Carpet and Headliner Kit, H4 Headlight Conversion, Kenwood 600 Watt Amp, Kenwood In Dash MP3/CD, Audiobahn DVD/MP3/CD Player, JVC 5.8 LCD Display, Kicker Impulse Crossover w/ Remote Bass Controller, Absolute Speakers, Stinger 1.0 Digital Capacitor, Nitrous Express Purge Kit, NOS Fuel/NOS Solenoids, Autometer 5inch Tachometer w/ Shift Light, Autometer 60mm Boost Gauge, Autometer 52mm Air/Fuel Gauge, I/O 4 Point Roll Bar, SaBelt 4 Point Harness (2) , Custom 12's in trunk with NOS tank in the middle = 500HP
My car = www.Pcpages.com/silvergto
gtopistons is offline   Reply With Quote
Old 07-19-2005, 11:55 PM   #452 (permalink)
15t's ... ? yep
DigiiManDan3KGT's Avatar
Drives: 80Gig WesternDigital
Trader Rating: (7)
DigiiManDan3KGT Level 2DigiiManDan3KGT Level 2DigiiManDan3KGT Level 2
1. stu_04 (conversion) 3KGT SL ATX
2. punkasscrab (conversion) 3KGT 5 spd
3. SLguy (conversion) 3KGT ATX <---going down to 8:1
4. JB (engine swap) 3KGT 5spd
5. Mikes95RT (conversion) Stealth R/T 5 spd
6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo
7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1
8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original
9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd
10. X GTO X (engine swap) 3KGT (VR-2)
10.Thump`Master (conversion) 3KGT 5 spd
11. JAL (conversion) 3KGT SOHC TT
12. ZachRT (single turbo) Stealth RT
13. 3KHI (supercharged) 3KGT
14. Juko (supercharged) 3KGT
15. SLAYER4ALL (supercharged) 3KGT
16. Snake93gt (supercharged) 3KGT SL
17. Spawn (supercharged) 3KGT SOHC ATX
18. OhFoSho (engine swap) SOHC Stealth
19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd
20. shooter83 (engine swap) Stealth es 5spd
21. upyun (engine swap) 3kgt sl
22. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES
23. Evangelist (TT Conversion) Stealth ES/TT 5 spd
24. Blue-GTO (TT Conversion) 3kgt SL
25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd
26. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe
27. bigballsofpaint (TT conversion) 95 3k base....i finally finished
28. 92-3000GT (Single turbo) 3000gt sl 5spd
29. Optamix (engine swap) 3KGT SL 5spd
30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months)
31. Quintop (engine swap) '95 SL 5 sp
32. Jigzibit (conversion) '95 SL ATX
33. 93 Stealth R/T (TT conversion)
34. Bob The Great (TT conversion) 93 R/T AWD 5spd
35. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's
36. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness.
37. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT
38. 3000hybrid (TT swap) ATX to 5spd AWD tranny-
39. 95red3000gt (TT conversion) only one in Colorado!
40. Jeremy C (TT conversion) - weekend project
41. Vortac (TT Conversion) SL ATX
42. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd.
43. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD
44. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD
45. Import Power Online-132.97MPH/11.44-14bs/5spd AWD The new FWD Record
46.93_black_R/T - Finished May 2004
47. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu
48. rush6432 (TT conversion) 13Ts, VR4 ECU. 14.1 @ 103 (6 psi on 9Bs w/ stock clutch)
49. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 140K
50. Zumin3K - TT Swap) 9bs, TT ECU + Harness
51. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap
52. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL
53. aaron97- (conversion) 3000GT SL
54. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc
55. |4x4 nv| - (TT Conversion) TT ecu/LSD/450cc
56. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain
57. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo
58. kdog109sd (TT Conversion) - one of the first automatics to do it
59. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi
60. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX
61. KevD23 (single turbo) '94 stealth ATX
62. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife
63. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads
64. Pantherchams (Supercharged) 93 Stealth ES ATX
65. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT
66. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!)
67. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???)
68. Jomojr (TT Conversion 93 Base ATX)
69. Venom13132 (92 RT, swap 96 vr4 engine, 92vr4 ecu 92vr4 hharness)
70. Cobane (J-Spec Swap) 94 r/t 5-spd.
71. LeRoyDL (92 R/T DR650 TT Conv. JDM ECU, N/A harness) + (2 month old SBM will be running again in the next week)
72. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness.
73. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods
In Progress (remove your name when finished and add to completed list)
1. xtremewlr (conversion) collecting parts slowly
2. rtrotter (supercharged) 3KGT
3. Whitewavesea (single turbo) 3kgt Installation in progress
4. Aph (conversion) - Dec 17 '03
5. JRock4000 (conversion) 3000GT -should be done this January
6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad
7. Mitch007 (conversion) expected completion by beginning of summer
8. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend.
9. AkiraGT (TT swap already started)
10. StealthTT (just need turbos and ICs with pipes)
11. Chant (TT / SuperCharger Conversion) :0)
12. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger
13. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap.
14. Renegadex181- Saving money and collecting parts...to start by April 15th
15. templar - SLTT (94SL ATX)
16. YOGURT! - Parts purchased, waiting on Mykiss69 for delivery, (94SL MTX)
17. Clipse20 - 94TT Swap w/ JapSpec ECU & Harness
18. spaceace60 - 96'base w/98'tt vr4motor
19. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition
20. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500
21. Presto97sl - TT conversion ATX check sig for days until install
Green 1995 3000GT FWD-TT 8:1 // 15t Turbos // ATX to MTX // NA to TT // Purchased 11/12/02
White 1999 3000GT Black Dash/Tan Leather Interior // SOHC // MTX // Stock Daily Driver Purchased 7/25/07
Red.._1992 Stealth RT/TT Twin Turbo AWD // Organ Donor // Purchased 05/19/08
<-- Click Here Join FL3S
DigiiManDan3KGT is offline   Reply With Quote
Old 07-28-2005, 10:54 PM   #453 (permalink)
nobodylikeswoody
nobodylikeswood's Avatar
Drives: 300ZX TT/stealth TT
Trader Rating: (13)
nobodylikeswood is an unknown quantity at this point
22. nobodylikeswood - 94 SLuTT conversion 5spd
94 3000GT SL - sold
91 300ZX TT stage 6 - so much fun
93 Stealth TT (brothers car) - so pimp
3si-r.com member (western NY forum)
nobodylikeswood is offline   Reply With Quote
Old 07-29-2005, 09:11 AM   #454 (permalink)
MilkyClr69's Avatar
Trader Rating: (11)
MilkyClr69 is an unknown quantity at this point
22. MilkyClr69 - 96SL w/ 92JDMTT motor/5spd TT tranny waiting on parts
96 SL
MagnaFlow Catback, K&N Intake, 18 x 8 ADR Sterling, 245 40 18 Ecsta Supra, Limo/15% window tint, Cross-drilled and slotted rotors, 12" sealed IDMAX w/ 1000 Watt Hifonics amp. Infinity & JBL speakers powered by Hinfonics amp, Alpine 7893.
TT engine/tranny swap
Fixing a few problems and she'll be back on the road!
MilkyClr69 is offline   Reply With Quote
Old 07-29-2005, 09:57 AM   #455 (permalink)
L Burna
longddong's Avatar
Drives: 94' Dodge Stealth RT
Trader Rating: (49)
longddong is an unknown quantity at this point
74. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX
longddong is offline   Reply With Quote
Old 08-01-2005, 04:29 PM   #456 (permalink)
nobodylikeswoody
Trader Rating: (13)
23. Nobodylikeswood - 94 SL u TT conversion
Old 08-04-2005, 02:29 AM   #457 (permalink)
gto3000gt's Avatar
Drives: 92, 93 vr4
gto3000gt is an unknown quantity at this point
whats the difference between: tt conversion, coversion, and just a engine swap. Arnt they all tt conversion?
1999 3000GT:
injen intake, test pipe/race pipe, 3sx adjustable camber and toe arms, 3sx/addco 1" front sway bar, drilled/slotted rotors, painted calipers(red), ground control coilovers, KYB GR-2 struts, 18' stern ST-2 rims (chrome). 99 kazz lip inside: panasonic deck, sony amp, 10inch sub
Crashed
1992 3000GT VR-4: sold
1993 3000GT VR-4: (Daily Driver) IPS single shot, vac. reduction, egr block off plates, hks ssqv
1988 Nissan 200sx aka s12 (Fun car/ drift car/ project car) ca20e -> ca18det -> sr20det swap, 6 point roll cage, greddy fmic, mbc @ 12 psi, 3in turbo back, greddy rs bov, black safc II, walbro 255lph, s13 suspension conversion, s14 seats, gutted backseat back, SSR longchamps 7 offset, welded diff
gto3000gt is online now   Reply With Quote
Old 08-04-2005, 08:52 AM   #458 (permalink)
Banned from selling
Drives: 1998 3000GT FWD TT
SpeedFreakSteve is an unknown quantity at this point
TT conversion - using a non-turbo DOHC engine (10:1 compression) and adding all of the parts from a DOHC TT engine to make it TT (exhaust manifolds, turbos, precats, downpipe, fuel injectors, fuel pump, oil/coolant lines, etc)
TT engine swap - swapping in a TT engine (8:1 compression) in place of a non-turbo one
Conversion - ??? Not really a term used around here
SpeedFreakSteve is offline   Reply With Quote
Old 08-04-2005, 11:31 AM   #459 (permalink)
Venom Speed Shop
Venom13132's Avatar
Drives: Small Car Big Engine
Trader Rating: (101)
Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7
you beat me too it. Yepp steve is right as usual. And if they say just conversion they are probably talking about TT conversion. TT conversion is the most common because you dont have to buy a new engine. I did the TT swap because my NA engine crapped out on me and I got a deal on an 8:1 engine.
Venom13132 is offline   Reply With Quote
Old 08-04-2005, 01:20 PM   #460 (permalink)
3tripleOpimpin
Jon Mills's Avatar
Drives: FWD-TT
Trader Rating: (36)
Jon Mills is an unknown quantity at this point
Hey fred did you get your up and running? I would go 8:1 but I have a 50K 10:1 waiting to be put in once I blow mine. I say I will be 10:1 forever. I am buying 2 10:1 engines tomorrow for $400 for both! ha One of them the oil pump was going out. So I am going to take the pan off to see if everything is ok. The other one has low miles on it. This kid has them at his house and his dad is making him get rid of them! lol
[size=1]1942 Chevy Truck (custom everything)
95 FWD-TT SOLD!
New TOY C5 Vette!!
Jon Mills is offline   Reply With Quote
