Old 06-28-2005, 08:34 PM   #441 (permalink)
Row faster!
WolfSL's Avatar
Drives: 92 VR4 & 98 SL
WolfSL is an unknown quantity at this point
Default Re: FWD TT cars.. how many are there now?
1. xtremewlr (conversion) collecting parts slowly
2. rtrotter (supercharged) 3KGT
3. Whitewavesea (single turbo) 3kgt Installation in progress
4. Aph (conversion) - Dec 17 '03
5. JRock4000 (conversion) 3000GT -should be done this January
6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad
7. Mitch007 (conversion) expected completion by beginning of summer
8. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend.
9. AkiraGT (TT swap already started)
10. StealthTT (just need turbos and ICs with pipes)
11. Chant (TT / SuperCharger Conversion) :0)
12. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger
13. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap.
14. Renegadex181- Saving money and collecting parts...to start by April 15th
15. templar - SLTT (94SL ATX)
16. YOGURT! - Parts purchased, waiting on Mykiss69 for delivery, (94SL MTX)
17. Clipse20 - 94TT Swap w/ JapSpec ECU & Harness
18. spaceace60 - 96'base w/98'tt vr4motor
19. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition.
Taking myself off the list for a little bit since college is a bit more important than making my car faster at the moment. I will do the conversion one day, but for now it has to wait.
WolfSL is offline   Reply With Quote
Old 06-28-2005, 08:42 PM   #442 (permalink)
Banned from selling
Drives: 1998 3000GT FWD TT
SpeedFreakSteve is an unknown quantity at this point
Had to update my setup after some recent changes....
1. stu_04 (conversion) 3KGT SL ATX
2. punkasscrab (conversion) 3KGT 5 spd
3. SLguy (conversion) 3KGT ATX <---going down to 8:1
4. JB (engine swap) 3KGT 5spd
5. Mikes95RT (conversion) Stealth R/T 5 spd
6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo
7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1
8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original
9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd
10. X GTO X (engine swap) 3KGT (VR-2)
10.Thump`Master (conversion) 3KGT 5 spd
11. JAL (conversion) 3KGT SOHC TT
12. ZachRT (single turbo) Stealth RT
13. 3KHI (supercharged) 3KGT
14. Juko (supercharged) 3KGT
15. SLAYER4ALL (supercharged) 3KGT
16. Snake93gt (supercharged) 3KGT SL
17. Spawn (supercharged) 3KGT SOHC ATX
18. OhFoSho (engine swap) SOHC Stealth
19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd
20. shooter83 (engine swap) Stealth es 5spd
21. upyun (engine swap) 3kgt sl
22. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES
23. Evangelist (TT Conversion) Stealth ES/TT 5 spd
24. Blue-GTO (TT Conversion) 3kgt SL
25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd
26. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe
27. bigballsofpaint (TT conversion) 95 3k base....i finally finished
28. 92-3000GT (Single turbo) 3000gt sl 5spd
29. Optamix (engine swap) 3KGT SL 5spd
30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months)
31. Quintop (engine swap) '95 SL 5 sp
32. Jigzibit (conversion) '95 SL ATX
33. 93 Stealth R/T (TT conversion)
34. Bob The Great (TT conversion) 93 R/T AWD 5spd
35. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's
36. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness.
37. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT
38. 3000hybrid (TT swap) ATX to 5spd AWD tranny-
39. 95red3000gt (TT conversion) only one in Colorado!
40. Jeremy C (TT conversion) - weekend project
41. Vortac (TT Conversion) SL ATX
42. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd.
43. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD
44. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD
45. Import Power Online-132.97MPH/11.44-14bs/5spd AWD The new FWD Record
46.93_black_R/T - Finished May 2004
47. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu
48. rush6432 (TT conversion) 13Ts, VR4 ECU. 14.1 @ 103 (6 psi on 9Bs w/ stock clutch)
49. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 140K
50. Zumin3K - TT Swap) 9bs, TT ECU + Harness
51. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap
52. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL
53. aaron97- (conversion) 3000GT SL
54. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc
55. |4x4 nv| - (TT Conversion) TT ecu/LSD/450cc
56. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain
57. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo
58. kdog109sd (TT Conversion) - one of the first automatics to do it
59. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi
60. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX
61. KevD23 (single turbo) '94 stealth ATX
62. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife
63. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads
64. Pantherchams (Supercharged) 93 Stealth ES ATX
65. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT
66. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!)
67. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???)
68. Jomojr (TT Conversion 93 Base ATX)
69. Venom13132 (92 RT, swap 96 vr4 engine, 92vr4 ecu 92vr4 hharness)
70. Cobane (J-Spec Swap) 94 r/t 5-spd.
71. LeRoyDL (92 R/T DR650 TT Conv. JDM ECU, N/A harness) + (2 month old SBM will be running again in the next week)
In Progress (remove your name when finished and add to completed list)
SpeedFreakSteve is offline   Reply With Quote
Old 07-01-2005, 01:10 AM   #443 (permalink)
JB
Quickest FWD 3000GT
JB's Avatar
JB is an unknown quantity at this point
Godddd DAAAME!!!!... there's a lot of TT FWD cars now! Congrats to everyone that made the switch. Unfortunately I am selling my car and so its gonna be -1 off the list.
J.B HOANG
Quickest FWD 3000GT/Stealth Record WAS
11.8 @ 113.05mph
12.1 @ 119.10mph ....STILL ain't nothing YET!!!
My best FWD 60'... 1.797
Race vid (MIR Imports Vs. Domestics Finals)
http://www.alteredatmosphere.com/_vid/worldcup02.wmv
Race vid (Atco Supra Vs. RX7 Event) (Old 3/S FWD Record Run)
http://3kgt.bowtiecrawler.com/vids/AAM/AAMAtco.mpg
Streetracer's 99VR4 Vs. 2002 Porsche 911 Turbo vid
http://www.alteredatmosphere.com/_vid/99vr4atnopi.wmv
AAM and Customers Street/Off Road Fun vid
http://www.alteredatmosphere.com/_vid/aamcruise.wmv
JB is offline   Reply With Quote
Old 07-03-2005, 11:49 AM   #444 (permalink)
Xtreme2k2's Avatar
Drives: 09 GTI
Trader Rating: (37)
Xtreme2k2 is an unknown quantity at this point
20. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500
98 Pearl White 3000GT SL *Traded in* Good Night Sweet Prince
09 GTI
Xtreme2k2 is offline   Reply With Quote
Old 07-04-2005, 12:23 AM   #445 (permalink)
Racing
Barefoot's Avatar
Drives: 92R/T - converted ;)
Trader Rating: (31)
Barefoot Level 1Barefoot Level 1Barefoot Level 1
how many FWD TT's are going to ng?!
ill be there autocross and dragracing, hope there is good FWD TT competition
92 Dodge Stealth R/T AWD/TT (TD05) converted ( 11.894 @ 120.56 - 18 psi -> Video )
SOUTHEAST DRAG DAY 2010! DOOO EEEET!
Barefoot is offline   Reply With Quote
Old 07-04-2005, 12:26 AM   #446 (permalink)
Corn Its whats for boost
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (217)
I think I might show up When is it?
91VR4-3.0L-Stock heads and Cams-811AWHP 747AWTQ Daily Driver 10.57@141mph
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
NG09 and NG10 Title Sponsor
3SX Performance
3SX Performance Service Email
Carolina 3S Forum
Import Power is online now   Reply With Quote
Old 07-04-2005, 02:08 AM   #447 (permalink)
Hitokiri Battousai
Jeremy C's Avatar
Drives: A car that runs
Trader Rating: (47)
Jeremy C is an unknown quantity at this point
Day before yesterday. Didn't you get the memo?
Jeremy C is offline   Reply With Quote
Old 07-04-2005, 09:02 AM   #448 (permalink)
Crap
Old 07-05-2005, 02:20 PM   #449 (permalink)
Youngest FWD-TT
ajp52987's Avatar
Drives: 95 3000gt Base-TT
Trader Rating: (11)
ajp52987 is an unknown quantity at this point
72. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness.
[COLORFONT][/color]
ajp52987 is offline   Reply With Quote
Old 07-18-2005, 01:46 PM   #450 (permalink)
Presto97sl's Avatar
Drives: 2003 lancer es
Trader Rating: (59)
Presto97sl is an unknown quantity at this point
21. Presto97sl - TT conversion ATX check sig for days until install
Presto97sl is offline   Reply With Quote
