#411 (permalink) |
MI SCUZI! MI SCUZI!
In Progress (remove your name when finished and add to completed list)
1. xtremewlr (conversion) collecting parts slowly 2. rtrotter (supercharged) 3KGT 3. Whitewavesea (single turbo) 3kgt Installation in progress 4. Aph (conversion) - Dec 17 '03 5. JRock4000 (conversion) 3000GT -should be done this January 6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 7. hardocp_geek (T04S single) Engine completion this summer 8. Mitch007 (conversion) expected completion by beginning of summer 9. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend. 10. AkiraGT (TT swap already started) 11. StealthTT (just need turbos and ICs with pipes) 12. Chant (TT / SuperCharger Conversion) :0) 13. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger 14. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap. 15. Venom13132- 96TT Engine Swap Starts March 1st 05 16. Renegadex181- Saving money and collecting parts...to start by April 15th 17. ImportPower-SLT converting to SLTT with twin TD05-14bs with Bullseye housings-New motor almost built-Est completion March 6th. 18. LVA3KGT- SLTT (97SL w/ 2bolt vr4 swap should be done by 3/18/05. 19. templar - SLTT (94SL ATX) 20. Neovalentine 96 SL Should be done today. |
#412 (permalink) |
Spins all 4
Completed!!!!
1. stu_04 (conversion) 3KGT SL ATX 2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd <---- the bad ass 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--- 9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 10.Thump`Master (conversion) 3KGT 5 spd 11. JAL (conversion) 3KGT SOHC TT 12. ZachRT (single turbo) Stealth RT 13. 3KHI (supercharged) 3KGT 14. Juko (supercharged) 3KGT 15. SLAYER4ALL (supercharged) 3KGT 16. Snake93gt (supercharged) 3KGT SL 17. Spawn (supercharged) 3KGT SOHC ATX 18. OhFoSho (engine swap) SOHC Stealth 19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 20. shooter83 (engine swap) Stealth es 5spd 21. upyun (engine swap) 3kgt sl 22. Greedy Bones (engine swap) stealth es 5 spd <--can't believe you forgot the SuperES!!! aka 500HP ES 23. Evangelist (TT Conversion) Stealth ES/TT 5 spd 24. Blue-GTO (TT Conversion) 3kgt SL 25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 26. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 27. bigballsofpaint (TT conversion) 95 3k base....i finally finished 28. 92-3000GT (Single turbo) 3000gt sl 5spd 29. Iceman3K15 (engine swap) 3KGT SL 5spd <---- your daddy 30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 31. Quintop (engine swap) '95 SL 5 sp 32. Jigzibit (conversion) '95 SL ATX 33. 93 Stealth R/T (TT conversion) 34. Bob The Great (TT conversion) 93 R/T AWD 5spd 35. SpeedFreakSteve (TT swap) 5spd AWD tranny and 13G's 3KGT SOHC 5spd 36. HikariGT (TT conversion) 97 SL 5sp, DR500s, FMIC, VR4 ECU with NA harness. 37. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 38. 3000hybrid (TT swap) ATX to 5spd AWD tranny- (Emanage/timing harness soon) 39. 95red3000gt (TT conversion) only one in Colorado! 40. Jeremy C (TT conversion) - weekend project 41. Vortac (TT Conversion) SL ATX 42. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 43. ES 3000TT (TT swap) 93 ES with 92TT ECU/Harness/Engine/AWD welded VCU 44. Braincrater (JDM TT Swap) 92 ES with 93TT ECU/Harness/Engine/AWD welded VCU 45. Import Power Online-131MPH/11.48-The new beast has come out 46.93_black_R/T - Finished May 2004 47. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 48. rush6432 (TT conversion) 13Ts, VR4 ECU. 14.1 @ 103 (6 psi on 9Bs w/ stock clutch) 49. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 140K 50. Zumin3K - TT Swap) 9bs, TT ECU + Harness 51. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 52. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 53. aaron97- (conversion) 3000GT SL 54. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 55. |4x4 nv| - (TT Conversion) TT ecu/LSD/450cc 56. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain 57. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 58. kdog109sd (TT Conversion) - one of the first automatics to do it 59. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 60. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 61. KevD23 (single turbo) '94 stealth ATX |
#413 (permalink) |
Working out minor bugs before full boost tuning, otherwise the project is complete. It sucks to have so many other commitments. At least it runs with 0-2 counts of knock and 0 engine DTC codes. I think this turbo will not wake up until ~3000 rpm, looking at how certain bmw M3's run a similar size in a kit.
94 SL, 62-1 single turbo - sold
#414 (permalink) |
MI SCUZI! MI SCUZI!
Completed!!!!
1. stu_04 (conversion) 3KGT SL ATX 2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd <---- the bad ass 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--- 9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 10.Thump`Master (conversion) 3KGT 5 spd 11. JAL (conversion) 3KGT SOHC TT 12. ZachRT (single turbo) Stealth RT 13. 3KHI (supercharged) 3KGT 14. Juko (supercharged) 3KGT 15. SLAYER4ALL (supercharged) 3KGT 16. Snake93gt (supercharged) 3KGT SL 17. Spawn (supercharged) 3KGT SOHC ATX 18. OhFoSho (engine swap) SOHC Stealth 19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 20. shooter83 (engine swap) Stealth es 5spd 21. upyun (engine swap) 3kgt sl 22. Greedy Bones (engine swap) stealth es 5 spd <--can't believe you forgot the SuperES!!! aka 500HP ES 23. Evangelist (TT Conversion) Stealth ES/TT 5 spd 24. Blue-GTO (TT Conversion) 3kgt SL 25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 26. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 27. bigballsofpaint (TT conversion) 95 3k base....i finally finished 28. 92-3000GT (Single turbo) 3000gt sl 5spd 29. Iceman3K15 (engine swap) 3KGT SL 5spd <---- your daddy 30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 31. Quintop (engine swap) '95 SL 5 sp 32. Jigzibit (conversion) '95 SL ATX 33. 93 Stealth R/T (TT conversion) 34. Bob The Great (TT conversion) 93 R/T AWD 5spd 35. SpeedFreakSteve (TT swap) 5spd AWD tranny and 13G's 3KGT SOHC 5spd 36. HikariGT (TT conversion) 97 SL 5sp, DR500s, FMIC, VR4 ECU with NA harness. 37. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 38. 3000hybrid (TT swap) ATX to 5spd AWD tranny- (Emanage/timing harness soon) 39. 95red3000gt (TT conversion) only one in Colorado! 40. Jeremy C (TT conversion) - weekend project 41. Vortac (TT Conversion) SL ATX 42. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 43. ES 3000TT (TT swap) 93 ES with 92TT ECU/Harness/Engine/AWD welded VCU 44. Braincrater (JDM TT Swap) 92 ES with 93TT ECU/Harness/Engine/AWD welded VCU 45. Import Power Online-131MPH/11.48-The new beast has come out 46.93_black_R/T - Finished May 2004 47. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 48. rush6432 (TT conversion) 13Ts, VR4 ECU. 14.1 @ 103 (6 psi on 9Bs w/ stock clutch) 49. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 140K 50. Zumin3K - TT Swap) 9bs, TT ECU + Harness 51. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 52. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 53. aaron97- (conversion) 3000GT SL 54. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 55. |4x4 nv| - (TT Conversion) TT ecu/LSD/450cc 56. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain 57. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 58. kdog109sd (TT Conversion) - one of the first automatics to do it 59. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 60. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 61. KevD23 (single turbo) '94 stealth ATX 62. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife |
#415 (permalink) |
2 of 3 in the US!
Updated again
1. stu_04 (conversion) 3KGT SL ATX 2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd <---- the bad ass 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--- 9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 10.Thump`Master (conversion) 3KGT 5 spd 11. JAL (conversion) 3KGT SOHC TT 12. ZachRT (single turbo) Stealth RT 13. 3KHI (supercharged) 3KGT 14. Juko (supercharged) 3KGT 15. SLAYER4ALL (supercharged) 3KGT 16. Snake93gt (supercharged) 3KGT SL 17. Spawn (supercharged) 3KGT SOHC ATX 18. OhFoSho (engine swap) SOHC Stealth 19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 20. shooter83 (engine swap) Stealth es 5spd 21. upyun (engine swap) 3kgt sl 22. Greedy Bones (engine swap) stealth es 5 spd <--can't believe you forgot the SuperES!!! aka 500HP ES 23. Evangelist (TT Conversion) Stealth ES/TT 5 spd 24. Blue-GTO (TT Conversion) 3kgt SL 25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 26. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 27. bigballsofpaint (TT conversion) 95 3k base....i finally finished 28. 92-3000GT (Single turbo) 3000gt sl 5spd 29. Iceman3K15 (engine swap) 3KGT SL 5spd <---- your daddy 30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 31. Quintop (engine swap) '95 SL 5 sp 32. Jigzibit (conversion) '95 SL ATX 33. 93 Stealth R/T (TT conversion) 34. Bob The Great (TT conversion) 93 R/T AWD 5spd 35. SpeedFreakSteve (TT swap) 5spd AWD tranny and 13G's 3KGT SOHC 5spd 36. HikariGT (TT conversion) 97 SL 5sp, DR500s, FMIC, VR4 ECU with NA harness. 37. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 38. 3000hybrid (TT swap) ATX to 5spd AWD tranny- (Emanage/timing harness soon) 39. 95red3000gt (TT conversion) only one in Colorado! 40. Jeremy C (TT conversion) - weekend project 41. Vortac (TT Conversion) SL ATX 42. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 43. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD welded VCU SFR LSD FMIC 44. Braincrater (JDM TT Swap) 92 ES with 93TT ECU/Harness/Engine/AWD welded VCU 45. Import Power Online-131MPH/11.48-The new beast has come out 46.93_black_R/T - Finished May 2004 47. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 48. rush6432 (TT conversion) 13Ts, VR4 ECU. 14.1 @ 103 (6 psi on 9Bs w/ stock clutch) 49. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 140K 50. Zumin3K - TT Swap) 9bs, TT ECU + Harness 51. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 52. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 53. aaron97- (conversion) 3000GT SL 54. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 55. |4x4 nv| - (TT Conversion) TT ecu/LSD/450cc 56. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain 57. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 58. kdog109sd (TT Conversion) - one of the first automatics to do it 59. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 60. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 61. KevD23 (single turbo) '94 stealth ATX 62. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife
ES 3000TT
Soon something else!!2 of 3 in the US! |
#416 (permalink) |
Corn Its whats for boost
watch the F out...SLTT is done and already ran 11's on it's first track day running like shit, with no boost and 14:1 AFR. There's gonna be trouble next satruday...
AEM Factory Trained Tuner
![]() 91VR4-3.0L-Stock heads and Cams-762AWHP 747AWTQ 30psi E100 Daily Driver 10.63@121mph SLTT-10.9 @ 140MPH Stock NA motor and NA heads/Cams T4 AWD 9.21 @ 154.98 T2 FWD 10.19 @ 140.31 T4-159.23 MPH Ran on 6G72 3.1L! T4-995AWHP Uncorrected 6G72 3.0L C16 T2-820FWHP 3.1L 27psi C16 91VR4 Red-17Gs w/supporting mods-sold 93SLTT/T2 91VR4 Pearl White-sold 91VR4 Black-sold 92VR4 Sandstone-sold 94VR4 Green-sold 93VR4 Pearl White-sold NG09 Title Sponsor 3SX Performance 3SX Performance Service Email |
#417 (permalink) |
3/S Addict
I used to 29 on the list, but ownership of the SL TT has changed to Optamix. I sold it to him, so he is now 29 on the list in place of me.
1. stu_04 (conversion) 3KGT SL ATX 2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--- 9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 10.Thump`Master (conversion) 3KGT 5 spd 11. JAL (conversion) 3KGT SOHC TT 12. ZachRT (single turbo) Stealth RT 13. 3KHI (supercharged) 3KGT 14. Juko (supercharged) 3KGT 15. SLAYER4ALL (supercharged) 3KGT 16. Snake93gt (supercharged) 3KGT SL 17. Spawn (supercharged) 3KGT SOHC ATX 18. OhFoSho (engine swap) SOHC Stealth 19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 20. shooter83 (engine swap) Stealth es 5spd 21. upyun (engine swap) 3kgt sl 22. Greedy Bones (engine swap) stealth es 5 spd <--can't believe you forgot the SuperES!!! aka 500HP ES 23. Evangelist (TT Conversion) Stealth ES/TT 5 spd 24. Blue-GTO (TT Conversion) 3kgt SL 25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 26. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 27. bigballsofpaint (TT conversion) 95 3k base....i finally finished 28. 92-3000GT (Single turbo) 3000gt sl 5spd 29. Optamix (engine swap) 3KGT SL 5spd 30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 31. Quintop (engine swap) '95 SL 5 sp 32. Jigzibit (conversion) '95 SL ATX 33. 93 Stealth R/T (TT conversion) 34. Bob The Great (TT conversion) 93 R/T AWD 5spd 35. SpeedFreakSteve (TT swap) 5spd AWD tranny and 13G's 3KGT SOHC 5spd 36. HikariGT (TT conversion) 97 SL 5sp, DR500s, FMIC, VR4 ECU with NA harness. 37. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 38. 3000hybrid (TT swap) ATX to 5spd AWD tranny- (Emanage/timing harness soon) 39. 95red3000gt (TT conversion) only one in Colorado! 40. Jeremy C (TT conversion) - weekend project 41. Vortac (TT Conversion) SL ATX 42. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 43. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD welded VCU SFR LSD FMIC 44. Braincrater (JDM TT Swap) 92 ES with 93TT ECU/Harness/Engine/AWD welded VCU 45. Import Power Online-131MPH/11.48-The new beast has come out 46.93_black_R/T - Finished May 2004 47. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 48. rush6432 (TT conversion) 13Ts, VR4 ECU. 14.1 @ 103 (6 psi on 9Bs w/ stock clutch) 49. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 140K 50. Zumin3K - TT Swap) 9bs, TT ECU + Harness 51. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 52. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 53. aaron97- (conversion) 3000GT SL 54. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 55. |4x4 nv| - (TT Conversion) TT ecu/LSD/450cc 56. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain 57. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 58. kdog109sd (TT Conversion) - one of the first automatics to do it 59. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 60. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 61. KevD23 (single turbo) '94 stealth ATX 62. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife
1994 RT/TT DR Turn Key Car, SOLD but never forgotten
Intake/Turbos/Exhaust: ARC2 w/82mm MAS, Apex ITC, Greddy Type-S BOV, DR-650s, DN o2 housings, ATR downpipe, ATR Single-Shot Cat-Back Fuel: Denso Fuel Pump, Hot wire kit, Denso 720cc Injectors, Snow Performance Methonal Injection Ingition: MSD 8.5mm ignition wires, NGK 9's at .024 Engine: new Mitsu shortblock, 3rd gen lifters, Unorthodox lightened crank pulley Control: Blitz DSBC, Blitz FATT, Greddy Boost and EGT gauges Drivetrain: 3SX S/S clutch hose, RPS Max Street Disc Clutch, RPS flywheel, cross drilled rotors w/ stainless braided brakes lines, 5Zigen FN01R-C 18x9.5s, Kuhmo Ecsta Supra's 265/35/18 Other: 3SX poly motor mounts, DR carbon fiber spark plug cover, 99 front end, carbon fiber hood, 15% tint ![]() 1994 SL TT 8:1 motor swap, Quiafe LSD, etc. SOLD |
#418 (permalink) |
TPW Educator
1. xtremewlr (conversion) collecting parts slowly 2. rtrotter (supercharged) 3KGT 3. Whitewavesea (single turbo) 3kgt Installation in progress 4. Aph (conversion) - Dec 17 '03 5. JRock4000 (conversion) 3000GT -should be done this January 6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 7. hardocp_geek (T04S single) Engine completion this summer 8. Mitch007 (conversion) expected completion by beginning of summer 9. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend. 10. AkiraGT (TT swap already started) 11. StealthTT (just need turbos and ICs with pipes) 12. Chant (TT / SuperCharger Conversion) :0) 13. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger 14. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap. 15. Venom13132- 96TT Engine Swap Starts March 1st 05 16. Renegadex181- Saving money and collecting parts...to start by April 15th 17. templar - SLTT (94SL ATX) 1. stu_04 (conversion) 3KGT SL ATX 2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--- 9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 10.Thump`Master (conversion) 3KGT 5 spd 11. JAL (conversion) 3KGT SOHC TT 12. ZachRT (single turbo) Stealth RT 13. 3KHI (supercharged) 3KGT 14. Juko (supercharged) 3KGT 15. SLAYER4ALL (supercharged) 3KGT 16. Snake93gt (supercharged) 3KGT SL 17. Spawn (supercharged) 3KGT SOHC ATX 18. OhFoSho (engine swap) SOHC Stealth 19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 20. shooter83 (engine swap) Stealth es 5spd 21. upyun (engine swap) 3kgt sl 22. Greedy Bones (engine swap) stealth es 5 spd <--can't believe you forgot the SuperES!!! aka 500HP ES 23. Evangelist (TT Conversion) Stealth ES/TT 5 spd 24. Blue-GTO (TT Conversion) 3kgt SL 25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 26. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 27. bigballsofpaint (TT conversion) 95 3k base....i finally finished 28. 92-3000GT (Single turbo) 3000gt sl 5spd 29. Optamix (engine swap) 3KGT SL 5spd 30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 31. Quintop (engine swap) '95 SL 5 sp 32. Jigzibit (conversion) '95 SL ATX 33. 93 Stealth R/T (TT conversion) 34. Bob The Great (TT conversion) 93 R/T AWD 5spd 35. SpeedFreakSteve (TT swap) 5spd AWD tranny and 13G's 3KGT SOHC 5spd 36. HikariGT (TT conversion) 97 SL 5sp, DR500s, FMIC, VR4 ECU with NA harness. 37. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 38. 3000hybrid (TT swap) ATX to 5spd AWD tranny- (Emanage/timing harness soon) 39. 95red3000gt (TT conversion) only one in Colorado! 40. Jeremy C (TT conversion) - weekend project 41. Vortac (TT Conversion) SL ATX 42. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 43. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD welded VCU SFR LSD FMIC 44. Braincrater (JDM TT Swap) 92 ES with 93TT ECU/Harness/Engine/AWD welded VCU 45. Import Power Online-131MPH/11.48-The new beast has come out 46.93_black_R/T - Finished May 2004 47. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 48. rush6432 (TT conversion) 13Ts, VR4 ECU. 14.1 @ 103 (6 psi on 9Bs w/ stock clutch) 49. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 140K 50. Zumin3K - TT Swap) 9bs, TT ECU + Harness 51. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 52. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 53. aaron97- (conversion) 3000GT SL 54. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 55. |4x4 nv| - (TT Conversion) TT ecu/LSD/450cc 56. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain 57. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 58. kdog109sd (TT Conversion) - one of the first automatics to do it 59. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 60. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 61. KevD23 (single turbo) '94 stealth ATX 62. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife 63. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads _________ Ty called me a little bit ago so I could hear it! It's alive!!!! a little bit of clean up work, and I should have her back very soon! engine/clutch break in period.
97 SLtt
World's fastest fwdTT 97SL in Phoenix 410 Ft/lbs of torque-steer and 390HP to the front wheels, making 1-3 gear useless @17psi. Built and tuned by 3SX (Firebird) = Best 60ft 2.4 Best ET 13.8 , best trap 110.8MPH , picked up almost 30mph on the big end of the track. 3SI member # 5422 ![]() |
#419 (permalink) |
LAS VEGAS
2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--- 9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 10.Thump`Master (conversion) 3KGT 5 spd 11. JAL (conversion) 3KGT SOHC TT 12. ZachRT (single turbo) Stealth RT 13. 3KHI (supercharged) 3KGT 14. Juko (supercharged) 3KGT 15. SLAYER4ALL (supercharged) 3KGT 16. Snake93gt (supercharged) 3KGT SL 17. Spawn (supercharged) 3KGT SOHC ATX 18. OhFoSho (engine swap) SOHC Stealth 19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 20. shooter83 (engine swap) Stealth es 5spd 21. upyun (engine swap) 3kgt sl 22. Greedy Bones (engine swap) stealth es 5 spd <--can't believe you forgot the SuperES!!! aka 500HP ES 23. Evangelist (TT Conversion) Stealth ES/TT 5 spd 24. Blue-GTO (TT Conversion) 3kgt SL 25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 26. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 27. bigballsofpaint (TT conversion) 95 3k base....i finally finished 28. 92-3000GT (Single turbo) 3000gt sl 5spd 29. Optamix (engine swap) 3KGT SL 5spd 30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 31. Quintop (engine swap) '95 SL 5 sp 32. Jigzibit (conversion) '95 SL ATX 33. 93 Stealth R/T (TT conversion) 34. Bob The Great (TT conversion) 93 R/T AWD 5spd 35. SpeedFreakSteve (TT swap) 5spd AWD tranny and 13G's 3KGT SOHC 5spd 36. HikariGT (TT conversion) 97 SL 5sp, DR500s, FMIC, VR4 ECU with NA harness. 37. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 38. 3000hybrid (TT swap) ATX to 5spd AWD tranny- (Emanage/timing harness soon) 39. 95red3000gt (TT conversion) only one in Colorado! 40. Jeremy C (TT conversion) - weekend project 41. Vortac (TT Conversion) SL ATX 42. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 43. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD welded VCU SFR LSD FMIC 44. Braincrater (JDM TT Swap) 92 ES with 93TT ECU/Harness/Engine/AWD welded VCU 45. Import Power Online-131MPH/11.48-The new beast has come out 46.93_black_R/T - Finished May 2004 47. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 48. rush6432 (TT conversion) 13Ts, VR4 ECU. 14.1 @ 103 (6 psi on 9Bs w/ stock clutch) 49. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 140K 50. Zumin3K - TT Swap) 9bs, TT ECU + Harness 51. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 52. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 53. aaron97- (conversion) 3000GT SL 54. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 55. |4x4 nv| - (TT Conversion) TT ecu/LSD/450cc 56. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain 57. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 58. kdog109sd (TT Conversion) - one of the first automatics to do it 59. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 60. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 61. KevD23 (single turbo) '94 stealth ATX 62. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife 63. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads 64. Pantherchams (Supercharged) 93 Stealth ES ATX |
#420 (permalink) |
Member since Feb 2002
2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--- 9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 10.Thump`Master (conversion) 3KGT 5 spd 11. JAL (conversion) 3KGT SOHC TT 12. ZachRT (single turbo) Stealth RT 13. 3KHI (supercharged) 3KGT 14. Juko (supercharged) 3KGT 15. SLAYER4ALL (supercharged) 3KGT 16. Snake93gt (supercharged) 3KGT SL 17. Spawn (supercharged) 3KGT SOHC ATX 18. OhFoSho (engine swap) SOHC Stealth 19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 20. shooter83 (engine swap) Stealth es 5spd 21. upyun (engine swap) 3kgt sl 22. Greedy Bones (engine swap) stealth es 5 spd <--can't believe you forgot the SuperES!!! aka 500HP ES 23. Evangelist (TT Conversion) Stealth ES/TT 5 spd 24. Blue-GTO (TT Conversion) 3kgt SL 25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 26. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 27. bigballsofpaint (TT conversion) 95 3k base....i finally finished 28. 92-3000GT (Single turbo) 3000gt sl 5spd 29. Optamix (engine swap) 3KGT SL 5spd 30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 31. Quintop (engine swap) '95 SL 5 sp 32. Jigzibit (conversion) '95 SL ATX 33. 93 Stealth R/T (TT conversion) 34. Bob The Great (TT conversion) 93 R/T AWD 5spd 35. SpeedFreakSteve (TT swap) 5spd AWD tranny and 13G's 3KGT SOHC 5spd 36. HikariGT (TT conversion) 97 SL 5sp, DR500s, FMIC, VR4 ECU with NA harness. 37. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT 38. 3000hybrid (TT swap) ATX to 5spd AWD tranny- (Emanage/timing harness soon) 39. 95red3000gt (TT conversion) only one in Colorado! 40. Jeremy C (TT conversion) - weekend project 41. Vortac (TT Conversion) SL ATX 42. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd. 43. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD welded VCU SFR LSD FMIC 44. Braincrater (JDM TT Swap) 92 ES with 93TT ECU/Harness/Engine/AWD welded VCU 45. Import Power Online-131MPH/11.48-The new beast has come out 46.93_black_R/T - Finished May 2004 47. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu 48. rush6432 (TT conversion) 13Ts, VR4 ECU. 14.1 @ 103 (6 psi on 9Bs w/ stock clutch) 49. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 140K 50. Zumin3K - TT Swap) 9bs, TT ECU + Harness 51. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap 52. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL 53. aaron97- (conversion) 3000GT SL 54. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc 55. |4x4 nv| - (TT Conversion) TT ecu/LSD/450cc 56. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain 57. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo 58. kdog109sd (TT Conversion) - one of the first automatics to do it 59. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi 60. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX 61. KevD23 (single turbo) '94 stealth ATX 62. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife 63. LVA3KGT (TT Swap) DR500s/LSD/ DR Stage 3 heads 64. Pantherchams (Supercharged) 93 Stealth ES ATX 65. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT
THE 3S, TURNING REGULAR PEOPLE INTO MECHANICS SINCE 1991....
93 Sable Black 3000GT FWDTT: Fully rebuilt VR4 engine, oversized to 3.1L, Full Engine Balancing, blueprinted, Forged Wiseco pistons & Rods, multiangle valve job, polished and ported Stage II heads, spec stage III clutch, K&N Filter, 10mm Magnacore Competition wires, custom 3" Magnaflow cat-back exhaust, DR-650 turbos, EVO 560cc injectors, Denso Fuel pump, Mallory high flow fuel filter, fuel pump hot wire kit, and Aeromotive fuel pressure regulator, 3.5" ARC II system, forged adjustable wastegates, Apexi SBC-ID Boostcontroller, Custom Front Mount Intercooler , PWR Radiator, Stillen Downpipe, 3SX Short Throw Shifter, Blitz FATT turbo timer, HKS SSQV BOV, Intrax lowering springs, Full Motor Dress up kit, 99 Combat wing, 99 front end conversion, 99 Taillight Garnish, Victory Hood , Silverstar blue head lights and matching fog lights. 19x9 - 19x10 Gewalt EVO II's 91 MR2 N/A: JDM Camry V6 swap, custom CT26 Turbo setup & supporting mods (SOLD) 93 MR2 Turbo BPU King.(SOLD) |
