Old 03-10-2005, 05:04 PM   #391 (permalink)
Venom Speed Shop
Venom13132's Avatar
Drives: Small Car Big Engine
Trader Rating: (101)
Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7
Default Re: FWD TT cars.. how many are there now?
Originally Posted by stealthguy29
question can you put a turbo coversion on a auto?
You sure can. there was a member that did that a few years ago. His name is Kunal. He is from indiana i dont remember his board name
Venom13132 is offline   Reply With Quote
Old 03-10-2005, 05:09 PM   #392 (permalink)
I'm a Troll
BIG_BALLER's Avatar
Drives: MODS SUCK DICK
Trader Rating: (25)
BIG_BALLER is an unknown quantity at this point
1. stu_04 (conversion) 3KGT SL ATX
2. punkasscrab (conversion) 3KGT 5 spd
3. SLguy (conversion) 3KGT ATX <---going down to 8:1
4. JB (engine swap) 3KGT 5spd <---- the bad ass
5. Mikes95RT (conversion) Stealth R/T 5 spd
6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo
7. silverbullet (conversion) Stealth ES 5 spd <--- 9b/13g combo, 13psi on 10:1
8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original
9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd
10. X GTO X (engine swap) 3KGT (VR-2)
10.Thump`Master (conversion) 3KGT 5 spd
11. JAL (conversion) 3KGT SOHC TT
12. ZachRT (single turbo) Stealth RT
13. 3KHI (supercharged) 3KGT
14. Juko (supercharged) 3KGT
15. SLAYER4ALL (supercharged) 3KGT
16. Snake93gt (supercharged) 3KGT SL
17. Spawn (supercharged) 3KGT SOHC ATX
18. OhFoSho (engine swap) SOHC Stealth
19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd
20. shooter83 (engine swap) Stealth es 5spd
21. upyun (engine swap) 3kgt sl
22. Greedy Bones (engine swap) stealth es 5 spd <--can't believe you forgot the SuperES!!! aka 500HP ES
23. Evangelist (TT Conversion) Stealth ES/TT 5 spd
24. Blue-GTO (TT Conversion) 3kgt SL
25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd
26. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe
27. bigballsofpaint (TT conversion) 95 3k base....i finally finished
28. 92-3000GT (Single turbo) 3000gt sl 5spd
29. Iceman3K15 (engine swap) 3KGT SL 5spd <---- your daddy
30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months)
31. Quintop (engine swap) '95 SL 5 sp
32. Jigzibit (conversion) '95 SL ATX
33. 93 Stealth R/T (TT conversion)
34. Bob The Great (TT conversion) 93 R/T AWD 5spd
35. SpeedFreakSteve (TT swap) 5spd AWD tranny and 13G's 3KGT SOHC 5spd
36. HikariGT (TT conversion) 97 SL 5sp, DR500s, FMIC, VR4 ECU with NA harness.
37. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT
38. 3000hybrid (TT swap) ATX to 5spd AWD tranny- (Emanage/timing harness soon)
39. 95red3000gt (TT conversion) only one in Colorado!
40. Jeremy C (TT conversion) - weekend project
41. Vortac (TT Conversion) SL ATX
42. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd.
43. ES 3000TT (TT swap) 93 ES with 92TT ECU/Harness/Engine/AWD welded VCU
44. Braincrater (JDM TT Swap) 92 ES with 93TT ECU/Harness/Engine/AWD welded VCU
45. Import Power Online-116.7MPH on All Season Radials-Untuned
46.93_black_R/T - Finished May 2004
47. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu
48. rush6432 (TT conversion) 13Gs, VR4 ECU. 14.1 @ 103 (6 psi on 9Bs w/ stock clutch)
49. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 140K
50. Zumin3K - TT Swap) 9bs, TT ECU + Harness
51. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap
52. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL
53. aaron97- (conversion) 3000GT SL
54. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc
55. |4x4 nv| - (TT Conversion) TT ecu/LSD/450cc
56. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain
BIG_BALLER is offline   Reply With Quote
Old 03-10-2005, 05:20 PM   #393 (permalink)
Head of Society of Bob
Drives: 1993 Stealth R/T AWD
Trader Rating: (11)
Bob The Great Level 3Bob The Great Level 3Bob The Great Level 3Bob The Great Level 3
yes. please visit the F/I and ATX forums under FWD.
Bob The Great has spoken.....
1993 Dodge Stealth R/T Turbo
Currently In Hibernation...
238awhp 265awtq (old dyno on 9b's @ 10psi)
Click to go to my website
Twin Turbo Conversion
All Wheel Drive Conversion All Wheel Steering Conversion
Factory Options
One of 482
Black Leather Interior
Removable Moonroof
5spd Manual
Modifications
3SX Light Crank Pulley
Cold Air Wall and Cone Filter
Snake Eyes
Fidanza Aluminum Flywheel
SBC DXD Clutch
DN Precat Eliminators
ESP Downpipe
Test Pipe
DSM SMIC's
450cc Black Top Injectors
TD04-9B/13G combo @ 10psi on 10:1 CR
Bob The Great is offline   Reply With Quote
Old 03-13-2005, 06:43 PM   #394 (permalink)
Trader Rating: (7)
[h]ardocp_geek is an unknown quantity at this point
57. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo
94 SL, 62-1 single turbo - sold
[h]ardocp_geek is offline   Reply With Quote
Old 03-13-2005, 06:56 PM   #395 (permalink)
Say What?
kdog109sd's Avatar
Trader Rating: (11)
kdog109sd is an unknown quantity at this point
58. kdog109sd (TT Conversion) - one of the first automatics to do it
I should proally be in the first 10 but i'll just add my name to #58 I had one of the first automatic TT conversions running. I belive Mikes95rt was the first one but his was just bolted on to the engine he never turned on the car or drove it, but I think I'm the first one to drive and have a running AT TT
Kunal S.
95 3KGT aka. "007" - Automatic Twin Turbo @ 9psi.... Best Believe It!
Indiana University Baby!!!
kdog109sd is offline   Reply With Quote
Old 03-14-2005, 06:29 AM   #396 (permalink)
New User
pearl3k is an unknown quantity at this point
i just ordered a vr4 engine. i'm doing a swap into my sl. i ordered the fuel pump, ecu, and wiring harness as well. but i don't know what to do about the transmission. i'm under the impression that an sl tranny is not gonna hold up to the 320 hp. any suggestions? i'm on a budget
pearl3k is offline   Reply With Quote
Old 03-14-2005, 06:39 AM   #397 (permalink)
Hitokiri Battousai
Jeremy C's Avatar
Drives: A car that runs
Trader Rating: (47)
Jeremy C is an unknown quantity at this point
I would say 80% of the conversions are using the stock tranny. Just get some sort of diff for it (wether an insert or a full diff) as that is the weak point in the tranny.
Jeremy C is offline   Reply With Quote
Old 03-14-2005, 06:55 AM   #398 (permalink)
Corn Its whats for boost
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (210)
Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7
I think I have proven the FWD 5 spd handles plenty power
AEM Factory Trained Tuner
91VR4-3.0L-Stock heads and Cams-762AWHP 747AWTQ 30psi E100 Daily Driver 10.63@121mph
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
91VR4 Red-17Gs w/supporting mods-sold
93SLTT/T2
91VR4 Pearl White-sold
91VR4 Black-sold
92VR4 Sandstone-sold
94VR4 Green-sold
93VR4 Pearl White-sold
NG09 Title Sponsor
3SX Performance
3SX Performance Service Email
Import Power is online now   Reply With Quote
Old 03-14-2005, 08:32 AM   #399 (permalink)
I'm a Troll
BIG_BALLER's Avatar
Trader Rating: (25)
How are speedfreaks diff inserts holding up ?
Old 03-14-2005, 08:39 AM   #400 (permalink)
I should prpbably Add to my post, I have proven that with solid mounts and a Quiafe the FWD 5 spd can handle power (131MPH Traps 11.4 ETs)
Wheel hop KILLS tranny parts dead. Solid mounts (or at least poly ones) help this BIG TIME. REPLACE YOUR STOCK WORN MOUNTS. Maximal Performance mounts are so cheap it's stupid not to.
