OK guys I've been working on this project ever since December. My car has a custom 3/S body style with mix and matched side skirts, spoilers, bumpers and rear pillar covers. I have all the other information on engine and Drivetrain under my ES 3000TT nearing completion post under the Forced Induction Forum. I hope you guys like let me hear what you think feedback is very welcome. ohh yeah I know its way past July 4th. but Complications do occur. and the intercooler custom kit will be done but Im running with the stock setup for now until my welder gets some free time. for more pics and info check out my post!
ES 3000TT nearing completion.
1. stu_04 (conversion) 3KGT SL ATX
2. punkasscrab (conversion) 3KGT 5 spd
3. SLguy (conversion) 3KGT ATX <---going down to 8:1
4. JB (engine swap) 3KGT 5spd <---- the bad ass
5. Mikes95RT (conversion) Stealth R/T 5 spd
6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo
7. silverbullet (conversion) Stealth ES 5 spd <--- 9b/13g combo, 13psi on 10:1
8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original
9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd
10. X GTO X (engine swap) 3KGT (VR-2)
10.Thump`Master (conversion) 3KGT 5 spd
11. JAL (conversion) 3KGT SOHC TT
12. ZachRT (single turbo) Stealth RT
13. 3KHI (supercharged) 3KGT
14. Juko (supercharged) 3KGT
15. SLAYER4ALL (supercharged) 3KGT
16. Snake93gt (supercharged) 3KGT SL
17. Spawn (supercharged) 3KGT SOHC ATX
18. OhFoSho (engine swap) SOHC Stealth
19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd
20. shooter83 (engine swap) Stealth es 5spd
21. upyun (engine swap) 3kgt sl
22. Greedy Bones (engine swap) stealth es 5 spd <--can't believe you forgot the SuperES!!! aka 500HP ES
23. Evangelist (TT Conversion) Stealth ES/TT 5 spd
24. Blue-GTO (TT Conversion) 3kgt SL
25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd
26. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe
27. bigballsofpaint (TT conversion) 95 3k base....i finally finished
28. 92-3000GT (Single turbo) 3000gt sl 5spd
29. Iceman3K15 (engine swap) 3KGT SL 5spd <---- your daddy
30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months)
31. Quintop (engine swap) '95 SL 5 sp
32. Jigzibit (conversion) '95 SL ATX
33. 93 Stealth R/T (TT conversion)
34. Bob The Great (TT conversion) 93 R/T AWD 5spd
35. SpeedFreakSteve (TT swap) 5spd AWD tranny and 13G's 3KGT SOHC 5spd
36. HikariGT (TT conversion) 97 SL 5sp, DR500s, FMIC, VR4 ECU with NA harness.
37. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT
38. 3000hybrid (SOHC to Vr4 motor) ATX to 5spd AWD tranny
39. 95red3000gt (TT conversion) only one in Colorado!
40. Jeremy C (TT conversion) - weekend project
41. Vortac (TT Conversion) SL ATX
42. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd.
43. ES 3000TT (TT swap) 93 ES with 92TT ECU/Harness/Engine/AWD welded VCU
In progress
1. xtremewlr (conversion) collecting parts slowly
2. Import Power Online Project SL-T
www.ProjectSL-T.com 600+HP@2500 Pounds
3. sipe16 (conversion) collecting parts
4. rtrotter (supercharged) 3KGT
5. Whitewavesea (single turbo) 3kgt Installation in progress
6. ZUMin3K (JDM TT swap) 3kgt SL Estimated date of completion - Dec 7 2004
7. 3kGTbase collecting parts for conversion
8. Aph (conversion) - Dec 17 '03
9. 3000gtdriver (tt swap) td05-14b's
10. JRock4000 (conversion) 3000GT -should be done this January
11. TheChosenOne (Eaton SC) 3KGT SL saving money like mad
12. 93_black_R/T Waitin on a front motor mount!
13. PhazinBlack92RT (Conversion) Needs Coolant & Oil lines, IC piping, O2 housings, DP and oil cooler then im done
14. BigTyla (TT conversion) - collecting...starting Winter '04
15. hardocp_geek (T04S single) Engine completion this summer
16. Mitch007 (conversion) expected completion by beginning of summer
17. Big_Baller (conversion) Install date June 15th. CAN'T WAIT
18. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend.
19. ES 3000TT(8:1 TT & AWD converted transmission) due out by July 4!!
20. AkiraGT (TT swap already started)
21. StealthTT (just need turbos and ICs with pipes)
22. Chant (TT / SuperCharger Conversion) :0)
23. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger
24. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap.
