#261 (permalink) |
Spins all 4
1. stu_04 (conversion) 3KGT SL ATX
2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd <---- the bad ass 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--- 9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 10.Thump`Master (conversion) 3KGT 5 spd 11. JAL (conversion) 3KGT SOHC TT 12. ZachRT (single turbo) Stealth RT 13. 3KHI (supercharged) 3KGT 14. Juko (supercharged) 3KGT 15. SLAYER4ALL (supercharged) 3KGT 16. Snake93gt (supercharged) 3KGT SL 17. Spawn (supercharged) 3KGT SOHC ATX 18. OhFoSho (engine swap) SOHC Stealth 19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 20. shooter83 (engine swap) Stealth es 5spd 21. upyun (engine swap) 3kgt sl 22. Greedy Bones (engine swap) stealth es 5 spd <--can't believe you forgot the SuperES!!! aka 500HP ES 23. Evangelist (TT Conversion) Stealth ES/TT 5 spd 24. Blue-GTO (TT Conversion) 3kgt SL 25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 26. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 27. bigballsofpaint (TT conversion) 95 3k base....i finally finished 28. 92-3000GT (Single turbo) 3000gt sl 5spd 29. Iceman3K15 (engine swap) 3KGT SL 5spd <---- your daddy 30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 31. Quintop (engine swap) '95 SL 5 sp 32. Jigzibit (conversion) '95 SL ATX 33. 93 Stealth R/T (TT conversion) 34. Bob The Great (TT conversion) 93 R/T AWD 5spd 35. SpeedFreakSteve (TT swap) 5spd AWD tranny and 13G's 3KGT SOHC 5spd 36. HikariGT (TT conversion) 97 SL 5sp, DR500s, FMIC, VR4 ECU with NA harness. In progress 1. Jeremy C (conversion) collecting parts 2. xtremewlr (conversion) collecting parts slowly 3. Import Power Online Project SL-T www.ProjectSL-T.com 600+HP@2500 Pounds 4. sipe16 (conversion) collecting parts 5. rtrotter (supercharged) 3KGT 6. cred05 (conversion) collecting parts 3kgt 7. Whitewavesea (single turbo) 3kgt Installation in progress 8. ZUMin3K (JDM TT swap) 3kgt SL Estimated date of completion - Dec 7 2004 9. 3kGTbase collecting parts for conversion 10. Aph (conversion) - Dec 17 '03 11. 3000gtdriver (tt swap) td05-14b's 12. JRock4000 (conversion) 3000GT -should be done this January 13. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 14. 93_black_R/T Waitin on a front motor mount! 15. PhazinBlack92RT (Conversion) Needs Coolant & Oil lines, IC piping, O2 housings, DP and oil cooler then im done 16. 95red3000GT (conversion)- conversion has started 17. Kadius (Single T conversion) - collecting parts 18. BigTyla (TT conversion) - collecting...expected completion date 7/04 19. hardocp_geek (T04S single) Engine completion this summer 20. Mitch007 (conversion) expected completion by beginning of summer 21. Big_Baller (conversion) Install date June 15th. CAN'T WAIT 22. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend. 23. ES 3000TT(8:1 TT & AWD converted transmission) due out by July 4!! 24. 3000hybrid (97 SOHC to 92 VR4 ---ATX to Gtrag 5speed) test drive 5/28!!! 25. AkiraGT (TT swap already started) 26. StealthTT (just need turbos and ICs with pipes) |
#263 (permalink) | |
Nick Lukow
91 Stealth R/T FWD TT BABY!!! Twin Turbo Swap with stock 9b's, HKS catback exhaust, 6 puck racing clutch, 3' testpipe (no cats), Supra Fuel Pump, DN performance y-pipe, 17 inch Rota wheels, Nitto 555 rubber, Erebuni shogun front bumper, Cross drilled and slotted rotors, Intrax Springs, KYB GR2 gas struts, Autometer guages, NGK Platinum plugs, Accel Wires, K&N Filter, Proboost MBC set @ 14psi, much more to come!!! "If you havent drive a FWD TT before, I suggest you do it. It is well worth it" |
#264 (permalink) |
2 of 3 in the US!
I cant find where i connect the front and rear o2 sensors. My donor car was running on AEM o2 sensors and they rewired sh**. I need to know which wires i wire to what! I know i wire the front one to the wires under the junction but i dont know what wires i splice them into. I need help!
#265 (permalink) |
Finally boosted
2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd <---- the bad ass 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--- 9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 10.Thump`Master (conversion) 3KGT 5 spd 11. JAL (conversion) 3KGT SOHC TT 12. ZachRT (single turbo) Stealth RT 13. 3KHI (supercharged) 3KGT 14. Juko (supercharged) 3KGT 15. SLAYER4ALL (supercharged) 3KGT 16. Snake93gt (supercharged) 3KGT SL 17. Spawn (supercharged) 3KGT SOHC ATX 18. OhFoSho (engine swap) SOHC Stealth 19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 20. shooter83 (engine swap) Stealth es 5spd 21. upyun (engine swap) 3kgt sl 22. Greedy Bones (engine swap) stealth es 5 spd <--can't believe you forgot the SuperES!!! aka 500HP ES 23. Evangelist (TT Conversion) Stealth ES/TT 5 spd 24. Blue-GTO (TT Conversion) 3kgt SL 25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 26. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 27. bigballsofpaint (TT conversion) 95 3k base....i finally finished 28. 92-3000GT (Single turbo) 3000gt sl 5spd 29. Iceman3K15 (engine swap) 3KGT SL 5spd <---- your daddy 30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 31. Quintop (engine swap) '95 SL 5 sp 32. Jigzibit (conversion) '95 SL ATX 33. 93 Stealth R/T (TT conversion) 34. Bob The Great (TT conversion) 93 R/T AWD 5spd 35. SpeedFreakSteve (TT swap) 5spd AWD tranny and 13G's 3KGT SOHC 5spd 36. HikariGT (TT conversion) 97 SL 5sp, DR500s, FMIC, VR4 ECU with NA harness. 37. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT In progress 1. Jeremy C (conversion) collecting parts 2. xtremewlr (conversion) collecting parts slowly 3. Import Power Online Project SL-T www.ProjectSL-T.com 600+HP@2500 Pounds 4. sipe16 (conversion) collecting parts 5. rtrotter (supercharged) 3KGT 6. cred05 (conversion) collecting parts 3kgt 7. Whitewavesea (single turbo) 3kgt Installation in progress 8. ZUMin3K (JDM TT swap) 3kgt SL Estimated date of completion - Dec 7 2004 9. 3kGTbase collecting parts for conversion 10. Aph (conversion) - Dec 17 '03 11. 3000gtdriver (tt swap) td05-14b's 12. JRock4000 (conversion) 3000GT -should be done this January 13. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 14. 93_black_R/T Waitin on a front motor mount! 15. PhazinBlack92RT (Conversion) Needs Coolant & Oil lines, IC piping, O2 housings, DP and oil cooler then im done 16. 95red3000GT (conversion)- conversion has started 17. BigTyla (TT conversion) - collecting...expected completion date 7/04 18. hardocp_geek (T04S single) Engine completion this summer 19. Mitch007 (conversion) expected completion by beginning of summer 20. Big_Baller (conversion) Install date June 15th. CAN'T WAIT 21. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend. 22. ES 3000TT(8:1 TT & AWD converted transmission) due out by July 4!! 23. 3000hybrid (97 SOHC to 92 VR4 ---ATX to Gtrag 5speed) test drive 5/28!!! 24. AkiraGT (TT swap already started) 25. StealthTT (just need turbos and ICs with pipes)
1995 3000GT Single Turbo
2002 Yamaha YZF R1 ![]() ![]() |
#266 (permalink) |
Member # 2818
2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd <---- the bad ass 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--- 9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 10.Thump`Master (conversion) 3KGT 5 spd 11. JAL (conversion) 3KGT SOHC TT 12. ZachRT (single turbo) Stealth RT 13. 3KHI (supercharged) 3KGT 14. Juko (supercharged) 3KGT 15. SLAYER4ALL (supercharged) 3KGT 16. Snake93gt (supercharged) 3KGT SL 17. Spawn (supercharged) 3KGT SOHC ATX 18. OhFoSho (engine swap) SOHC Stealth 19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 20. shooter83 (engine swap) Stealth es 5spd 21. upyun (engine swap) 3kgt sl 22. Greedy Bones (engine swap) stealth es 5 spd <--can't believe you forgot the SuperES!!! aka 500HP ES 23. Evangelist (TT Conversion) Stealth ES/TT 5 spd 24. Blue-GTO (TT Conversion) 3kgt SL 25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 26. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 27. bigballsofpaint (TT conversion) 95 3k base....i finally finished 28. 92-3000GT (Single turbo) 3000gt sl 5spd 29. Iceman3K15 (engine swap) 3KGT SL 5spd <---- your daddy 30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 31. Quintop (engine swap) '95 SL 5 sp 32. Jigzibit (conversion) '95 SL ATX 33. 93 Stealth R/T (TT conversion) 34. Bob The Great (TT conversion) 93 R/T AWD 5spd 35. SpeedFreakSteve (TT swap) 5spd AWD tranny and 13G's 3KGT SOHC 5spd 36. HikariGT (TT conversion) 97 SL 5sp, DR500s, FMIC, VR4 ECU with NA harness. 37. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT In progress 1. Jeremy C (conversion) collecting parts 2. xtremewlr (conversion) collecting parts slowly 3. Import Power Online Project SL-T www.ProjectSL-T.com 600+HP@2500 Pounds 4. sipe16 (conversion) collecting parts 5. rtrotter (supercharged) 3KGT 6. Whitewavesea (single turbo) 3kgt Installation in progress 7. ZUMin3K (JDM TT swap) 3kgt SL Estimated date of completion - Dec 7 2004 8. 3kGTbase collecting parts for conversion 9. Aph (conversion) - Dec 17 '03 10. 3000gtdriver (tt swap) td05-14b's 11. JRock4000 (conversion) 3000GT -should be done this January 12. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 13. 93_black_R/T Waitin on a front motor mount! 14. PhazinBlack92RT (Conversion) Needs Coolant & Oil lines, IC piping, O2 housings, DP and oil cooler then im done 15. 95red3000GT (conversion)- conversion has started 16. BigTyla (TT conversion) - collecting...expected completion date 7/04 17. hardocp_geek (T04S single) Engine completion this summer 18. Mitch007 (conversion) expected completion by beginning of summer 19. Big_Baller (conversion) Install date June 15th. CAN'T WAIT 20. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend. 21. ES 3000TT(8:1 TT & AWD converted transmission) due out by July 4!! 22. 3000hybrid (97 SOHC to 92 VR4 ---ATX to Gtrag 5speed) test drive 5/28!!! 23. AkiraGT (TT swap already started) 24. StealthTT (just need turbos and ICs with pipes) removed name from list |
#267 (permalink) |
Added to list ^_^
1. stu_04 (conversion) 3KGT SL ATX 2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd <---- the bad ass 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--- 9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 10.Thump`Master (conversion) 3KGT 5 spd 11. JAL (conversion) 3KGT SOHC TT 12. ZachRT (single turbo) Stealth RT 13. 3KHI (supercharged) 3KGT 14. Juko (supercharged) 3KGT 15. SLAYER4ALL (supercharged) 3KGT 16. Snake93gt (supercharged) 3KGT SL 17. Spawn (supercharged) 3KGT SOHC ATX 18. OhFoSho (engine swap) SOHC Stealth 19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 20. shooter83 (engine swap) Stealth es 5spd 21. upyun (engine swap) 3kgt sl 22. Greedy Bones (engine swap) stealth es 5 spd <--can't believe you forgot the SuperES!!! aka 500HP ES 23. Evangelist (TT Conversion) Stealth ES/TT 5 spd 24. Blue-GTO (TT Conversion) 3kgt SL 25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 26. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 27. bigballsofpaint (TT conversion) 95 3k base....i finally finished 28. 92-3000GT (Single turbo) 3000gt sl 5spd 29. Iceman3K15 (engine swap) 3KGT SL 5spd <---- your daddy 30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 31. Quintop (engine swap) '95 SL 5 sp 32. Jigzibit (conversion) '95 SL ATX 33. 93 Stealth R/T (TT conversion) 34. Bob The Great (TT conversion) 93 R/T AWD 5spd 35. SpeedFreakSteve (TT swap) 5spd AWD tranny and 13G's 3KGT SOHC 5spd 36. HikariGT (TT conversion) 97 SL 5sp, DR500s, FMIC, VR4 ECU with NA harness. 37. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT In progress 1. Jeremy C (conversion) collecting parts 2. xtremewlr (conversion) collecting parts slowly 3. Import Power Online Project SL-T www.ProjectSL-T.com 600+HP@2500 Pounds 4. sipe16 (conversion) collecting parts 5. rtrotter (supercharged) 3KGT 6. Whitewavesea (single turbo) 3kgt Installation in progress 7. ZUMin3K (JDM TT swap) 3kgt SL Estimated date of completion - Dec 7 2004 8. 3kGTbase collecting parts for conversion 9. Aph (conversion) - Dec 17 '03 10. 3000gtdriver (tt swap) td05-14b's 11. JRock4000 (conversion) 3000GT -should be done this January 12. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 13. 93_black_R/T Waitin on a front motor mount! 14. PhazinBlack92RT (Conversion) Needs Coolant & Oil lines, IC piping, O2 housings, DP and oil cooler then im done 15. 95red3000GT (conversion)- conversion has started 16. BigTyla (TT conversion) - collecting...expected completion date 7/04 17. hardocp_geek (T04S single) Engine completion this summer 18. Mitch007 (conversion) expected completion by beginning of summer 19. Big_Baller (conversion) Install date June 15th. CAN'T WAIT 20. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend. 21. ES 3000TT(8:1 TT & AWD converted transmission) due out by July 4!! 22. 3000hybrid (97 SOHC to 92 VR4 ---ATX to Gtrag 5speed) test drive 5/28!!! 23. AkiraGT (TT swap already started) 24. StealthTT (just need turbos and ICs with pipes) 25. Chant (TT / SuperCharger Conversion) :0) Chant ![]()
Current Mods:
Eibach Pro kit springs K&N Filter Charger Kit Custom Flowmaster Exhaust Clear turn signals with Titanium bulbs Recaro SRD seats WEAPON-R 5 pt harness Neon undercar kit Short throw shifter Mods waiting to be installed: M90 SC with intercooler & modified manifold T3/T4 Hybrid Turbos Modified VR4 Manifolds Mustang Injectors Custom Hood with scoop for M90 FMIC To Come in immediate future: Godzilla BOV Custom intake Piping New Flowmaster exhaust @ 3" Brembo crossdrilled/slotted rotors 6 puk sprung clutch |
#268 (permalink) |
3/S Certified Mechanic
Well, you guys will have another TT FWD to add on or before WEDNESDAY (6/23). Install begins Sunday afternoon. Lots of secrets/goodies. Hopefully everything will go well. I think AL has the most conversions (or will...)? Maybe I'm wrong. =P
AEM V2 CAI
Ported/Polished intake mani Modern Performance 60mm TB NGK BKR5E-11's Screamin' Demon Coil Crane Firewire 8.5mm wires GReddy Header and downpipe 2.5" GReddy EVO catback AF/X UDP Phantom Grip LSD w/ upgraded springs Neon 3.55 Gearbox Zex Wet Kit - Jetted for 75HP ![]() |
#269 (permalink) | |
Resident rocket scientist
Don't know if that's the most or not. Regardless, w00t Bama Cr3w. ![]()
![]() 1993 3000GT FWD ATX TT - mods coming<---------------->2009 Honda Fit - 40 mpg ftw Topline Engineering ground wire kit Nov/Dec ground wire GB!!! |
#270 (permalink) | |
Spins all 4
Count me in too! by the end of july or early august i should have it done completely. |
