#222 (permalink) |
The Math Man
ok thats when you do what I'm doin and just tell them all those parts are for the 60k tuneup! Ya they are a little suspect, but all I keep saying is that being it's an import there is more stuff (my parents only have domestics). What they don't know won't hurt them, and then you still get your college 1/2 payed for (thats what I'm doin too).
1995 3000GT FWD-TT: Sold
![]() Motor: 3.1L, Forged Crank, Forged Rods, Ross 93mm Forged Pistons, clevite bearings, custom 3 inch exhaust, K&N cone intake, solid motor mounts, IPO MBC, PTE 550cc injectors, Drivetrain: ACT Maxx clutch, Nitto555R Drag Radials, Kormex LSD Electronics: SAFC II, Autometer EGT/ Boost, LM-1 wideband o2, 95 TT ecu/Harness |
#223 (permalink) |
Alright guys I have decided to drop a hint on my project. Only IPO or JB can possibly be using a larger turbo(s) than the configuration I chose.
In progress 1. SpeedFreakSteve (TT engine swap with 5spd AWD tranny and 13G's) 3KGT SOHC 5spd (est. finish date April 25/2004) 2. Jeremy C (conversion) collecting parts 3. xtremewlr (conversion) collecting parts slowly 5. Import Power Online Project SL-T [url]www.ProjectSL-T.com 4. sipe16 (conversion) collecting parts 6. rtrotter (supercharged) 3KGT 7. cred05 (conversion) collecting parts 3kgt 8. Whitewavesea (single turbo) 3kgt Installation in progress 9. ZUMin3K (JDM TT swap) 3kgt SL Estimated date of completion - Dec 7 2004 10. 3kGTbase collecting parts for conversion 11. Aph (conversion) - Dec 17 '03 12. 3000gtdriver (tt swap) td05-14b's 13. JRock4000 (conversion) 3000GT -should be done this January 14. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 15. 93_black_R/T Waitin on a front motor mount! 16. PhazinBlack92RT (Conversion) Needs Coolant & Oil lines, IC piping, O2 housings, DP and oil cooler then im done 17. 95red3000GT (conversion)- conversion has started 18. 93 Stealth R/T (TT conversion)- Started, need IC's and Oilcooler...and 19. Kadius (Single T conversion) - collecting parts 20. BigTyla (TT conversion) - collecting...expected completion date 7/04 21. hardocp_geek (T04S single) Engine completion this summer
94 SL, 62-1 single turbo - sold
#224 (permalink) | |
"The Fisherman"
![]() BTW does anyone know anything about JB's new setup? i knew he was going with Ryan's 19C turbos, but then he PM'ed me saying he was going bigger! ![]()
#226 (permalink) | |
Hitokiri Battousai
#227 (permalink) |
3000GT Driver
In progress
1. SpeedFreakSteve (TT engine swap with 5spd AWD tranny and 13G's) 3KGT SOHC 5spd (est. finish date April 25/2004) 2. Jeremy C (conversion) collecting parts 3. xtremewlr (conversion) collecting parts slowly 5. Import Power Online Project SL-T [url]www.ProjectSL-T.com 4. sipe16 (conversion) collecting parts 6. rtrotter (supercharged) 3KGT 7. cred05 (conversion) collecting parts 3kgt 8. Whitewavesea (single turbo) 3kgt Installation in progress 9. ZUMin3K (JDM TT swap) 3kgt SL Estimated date of completion - Dec 7 2004 10. 3kGTbase collecting parts for conversion 11. Aph (conversion) - Dec 17 '03 12. 3000gtdriver (tt swap) td05-14b's 13. JRock4000 (conversion) 3000GT -should be done this January 14. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 15. 93_black_R/T Waitin on a front motor mount! 16. PhazinBlack92RT (Conversion) Needs Coolant & Oil lines, IC piping, O2 housings, DP and oil cooler then im done 17. 95red3000GT (conversion)- conversion has started 18. 93 Stealth R/T (TT conversion)- Started, need IC's and Oilcooler...and 19. Kadius (Single T conversion) - collecting parts 20. BigTyla (TT conversion) - collecting...expected completion date 7/04 21. hardocp_geek (T04S single) Engine completion this summer 22. Mitch007 (conversion) expected completion by beginning of summer |
#228 (permalink) |
Resident rocket scientist
Looks like we need more TT ATX representation up here. It'd be nice to see some ATX's dip into the 12's. Perhaps SLguy will accomplish that this summer if his twin 16G setup works.
As for me, I'll stick to 9B's ![]()
![]() 1993 3000GT FWD ATX TT - daily<------------------->2009 Honda Fit - 40 mpg? Yes pls. Topline Engineering ground wire kit Ground wire GB is back!!! |
#230 (permalink) |
1. stu_04 (conversion) 3KGT SL ATX
2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd <---- the bad ass 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo 7. silverbullet (conversion) Stealth ES 5 spd <--- 9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 10.Thump`Master (conversion) 3KGT 5 spd 11. JAL (conversion) 3KGT SOHC TT 12. ZachRT (single turbo) Stealth RT 13. 3KHI (supercharged) 3KGT 14. Juko (supercharged) 3KGT 15. SLAYER4ALL (supercharged) 3KGT 16. Snake93gt (supercharged) 3KGT SL 17. Spawn (supercharged) 3KGT SOHC ATX 18. OhFoSho (engine swap) SOHC Stealth 19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 20. shooter83 (engine swap) Stealth es 5spd 21. upyun (engine swap) 3kgt sl 22. Greedy Bones (engine swap) stealth es 5 spd <--can't believe you forgot the SuperES!!! aka 500HP ES 23. Evangelist (TT Conversion) Stealth ES/TT 5 spd 24. Blue-GTO (TT Conversion) 3kgt SL 25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 26 tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 27.bigballsofpaint (TT conversion) 95 3k base....i finally finished 28.92-3000GT (Single turbo) 3000gt sl 5spd 29. Iceman3K15 (engine swap) 3KGT SL 5spd <---- your daddy 30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 31. Quintop (engine swap) '95 SL 5 sp 32. Jigzibit (conversion) '95 SL ATX 33. 93 Stealth R/T (TT conversion) In progress 1. SpeedFreakSteve (TT engine swap with 5spd AWD tranny and 13G's) 3KGT SOHC 5spd (est. finish date April 25/2004) 2. Jeremy C (conversion) collecting parts 3. xtremewlr (conversion) collecting parts slowly 5. Import Power Online Project SL-T [url]www.ProjectSL-T.com 4. sipe16 (conversion) collecting parts 6. rtrotter (supercharged) 3KGT 7. cred05 (conversion) collecting parts 3kgt 8. Whitewavesea (single turbo) 3kgt Installation in progress 9. ZUMin3K (JDM TT swap) 3kgt SL Estimated date of completion - Dec 7 2004 10. 3kGTbase collecting parts for conversion 11. Aph (conversion) - Dec 17 '03 12. 3000gtdriver (tt swap) td05-14b's 13. JRock4000 (conversion) 3000GT -should be done this January 14. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 15. 93_black_R/T Waitin on a front motor mount! 16. PhazinBlack92RT (Conversion) Needs Coolant & Oil lines, IC piping, O2 housings, DP and oil cooler then im done 17. 95red3000GT (conversion)- conversion has started 18. Kadius (Single T conversion) - collecting parts 19. BigTyla (TT conversion) - collecting...expected completion date 7/04 20. hardocp_geek (T04S single) Engine completion this summer 21. Mitch007 (conversion) expected completion by beginning of summer Moved my completed conversion out of the in progress section ;-)
1993 Stealth RT w/ TT conv and then some...
I've grounded myself from the key until I'm convinced it has enough engine protection mods to not blow up. |
