#201 (permalink) |
Corn Its whats for boost
I think I got something going on.
AEM Factory Trained Tuner
![]() 91VR4-3.0L-Stock heads and Cams-762AWHP 747AWTQ 30psi E100 Daily Driver 10.63@121mph SLTT-10.9 @ 140MPH Stock NA motor and NA heads/Cams T4 AWD 9.21 @ 154.98 T2 FWD 10.19 @ 140.31 T4-159.23 MPH Ran on 6G72 3.1L! T4-995AWHP Uncorrected 6G72 3.0L C16 T2-820FWHP 3.1L 27psi C16 91VR4 Red-17Gs w/supporting mods-sold 93SLTT/T2 91VR4 Pearl White-sold 91VR4 Black-sold 92VR4 Sandstone-sold 94VR4 Green-sold 93VR4 Pearl White-sold NG09 Title Sponsor 3SX Performance 3SX Performance Service Email |
#203 (permalink) |
1. stu_04 (conversion) 3KGT SL ATX (*sold* new owner unknown)
2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX 4. JB (engine swap) 3KGT 5spd <---- the bad ass 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd 7. silverbullet (conversion) Stealth R/T 5 spd 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 10.Thump`Master (conversion) 3KGT 5 spd 11. JAL (conversion) 3KGT SOHC TT 12. ZachRT (single turbo) Stealth RT 13. 3KHI (supercharged) 3KGT 14. Juko (supercharged) 3KGT 15. SLAYER4ALL (supercharged) 3KGT 16. Snake93gt (supercharged) 3KGT SL 17. Spawn (supercharged) 3KGT SOHC ATX 18. OhFoSho (engine swap) SOHC Stealth 19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 20. shooter83 (engine swap) Stealth es 5spd 21. upyun (engine swap) 3kgt sl 22. Greedy Bones (engine swap) stealth es 5 spd <--can't believe you forgot the SuperES!!! aka 500HP ES 23. Evangelist (TT Conversion) Stealth ES/TT 5 spd 24. Blue-GTO (TT Conversion) 3kgt SL 25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 26 tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 27.bigballsofpaint (TT conversion) 95 3k base....i finally finished 28.92-3000GT (Single turbo) 3000gt sl 5spd 29. Iceman3K15 (engine swap) 3KGT SL 5spd <---- your daddy 30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) In progress 1. SpeedFreakSteve (TT engine swap with 5spd AWD tranny and 13G's) 3KGT SOHC 5spd (est. finish date March 30/2004) 2. Jeremy C (conversion) collecting parts 3. xtremewlr (conversion) collecting parts slowly 4. sipe16 (conversion) collecting parts 5. Jigzibit (conversion 9b/DR500 setup) 3KGT ATX - in progress 6. rtrotter (supercharged) 3KGT 7. cred05 (conversion) collecting parts 3kgt 8. Whitewavesea (single turbo) 3kgt Installation in progress 9. ZUMin3K (JDM TT swap) 3kgt SL Estimated date of completion - Dec 7 2004 10. 3kGTbase collecting parts for conversion 11. Aph (conversion) - Dec 17 '03 12. 3000gtdriver (tt swap) td05-14b's 13. JRock4000 (conversion) 3000GT -should be done this January 14. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 15. 93_black_R/T Waitin on a front motor mount! 16. PhazinBlack92RT (Conversion) Needs Coolant & Oil lines, IC piping, O2 housings, DP and oil cooler then im done 17. 95red3000GT (conversion)- conversion has started 18. 93 Stealth R/T (TT conversion)- Started, need IC's and Oilcooler...and money to buy them with ![]()
1993 Stealth RT w/ TT conv and then some...
I've grounded myself from the key until I'm convinced it has enough engine protection mods to not blow up. |
#204 (permalink) |
2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX 4. JB (engine swap) 3KGT 5spd <---- the bad ass 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd 7. silverbullet (conversion) Stealth R/T 5 spd 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 10.Thump`Master (conversion) 3KGT 5 spd 11. JAL (conversion) 3KGT SOHC TT 12. ZachRT (single turbo) Stealth RT 13. 3KHI (supercharged) 3KGT 14. Juko (supercharged) 3KGT 15. SLAYER4ALL (supercharged) 3KGT 16. Snake93gt (supercharged) 3KGT SL 17. Spawn (supercharged) 3KGT SOHC ATX 18. OhFoSho (engine swap) SOHC Stealth 19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 20. shooter83 (engine swap) Stealth es 5spd 21. upyun (engine swap) 3kgt sl 22. Greedy Bones (engine swap) stealth es 5 spd <--can't believe you forgot the SuperES!!! aka 500HP ES 23. Evangelist (TT Conversion) Stealth ES/TT 5 spd 24. Blue-GTO (TT Conversion) 3kgt SL 25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 26 tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 27.bigballsofpaint (TT conversion) 95 3k base....i finally finished 28.92-3000GT (Single turbo) 3000gt sl 5spd 29. Iceman3K15 (engine swap) 3KGT SL 5spd <---- your daddy 30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) In progress 1. SpeedFreakSteve (TT engine swap with 5spd AWD tranny and 13G's) 3KGT SOHC 5spd (est. finish date March 30/2004) 2. Jeremy C (conversion) collecting parts 3. xtremewlr (conversion) collecting parts slowly 4. sipe16 (conversion) collecting parts 5. Jigzibit (conversion 9b/DR500 setup) 3KGT ATX - in progress 6. rtrotter (supercharged) 3KGT 7. cred05 (conversion) collecting parts 3kgt 8. Whitewavesea (single turbo) 3kgt Installation in progress 9. ZUMin3K (JDM TT swap) 3kgt SL Estimated date of completion - Dec 7 2004 10. 3kGTbase collecting parts for conversion 11. Aph (conversion) - Dec 17 '03 12. 3000gtdriver (tt swap) td05-14b's 13. JRock4000 (conversion) 3000GT -should be done this January 14. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 15. 93_black_R/T Waitin on a front motor mount! 16. PhazinBlack92RT (Conversion) Needs Coolant & Oil lines, IC piping, O2 housings, DP and oil cooler then im done 17. 95red3000GT (conversion)- conversion has started 18. 93 Stealth R/T (TT conversion)- Started, need IC's and Oilcooler...and money to buy them with 19. Import Power Online Project SL-T www.ProjectSL-T.com |
#205 (permalink) | |
Banned from selling
#206 (permalink) |
2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX 4. JB (engine swap) 3KGT 5spd <---- the bad ass 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd 7. silverbullet (conversion) Stealth R/T 5 spd 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 10.Thump`Master (conversion) 3KGT 5 spd 11. JAL (conversion) 3KGT SOHC TT 12. ZachRT (single turbo) Stealth RT 13. 3KHI (supercharged) 3KGT 14. Juko (supercharged) 3KGT 15. SLAYER4ALL (supercharged) 3KGT 16. Snake93gt (supercharged) 3KGT SL 17. Spawn (supercharged) 3KGT SOHC ATX 18. OhFoSho (engine swap) SOHC Stealth 19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 20. shooter83 (engine swap) Stealth es 5spd 21. upyun (engine swap) 3kgt sl 22. Greedy Bones (engine swap) stealth es 5 spd <--can't believe you forgot the SuperES!!! aka 500HP ES 23. Evangelist (TT Conversion) Stealth ES/TT 5 spd 24. Blue-GTO (TT Conversion) 3kgt SL 25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 26 tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 27.bigballsofpaint (TT conversion) 95 3k base....i finally finished 28.92-3000GT (Single turbo) 3000gt sl 5spd 29. Iceman3K15 (engine swap) 3KGT SL 5spd <---- your daddy 30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 31. Quintop (engine swap) '95 SL 5 sp In progress 1. SpeedFreakSteve (TT engine swap with 5spd AWD tranny and 13G's) 3KGT SOHC 5spd (est. finish date March 30/2004) 2. Jeremy C (conversion) collecting parts 3. xtremewlr (conversion) collecting parts slowly 4. sipe16 (conversion) collecting parts 5. Jigzibit (conversion 9b/DR500 setup) 3KGT ATX - in progress 6. rtrotter (supercharged) 3KGT 7. cred05 (conversion) collecting parts 3kgt 8. Whitewavesea (single turbo) 3kgt Installation in progress 9. ZUMin3K (JDM TT swap) 3kgt SL Estimated date of completion - Dec 7 2004 10. 3kGTbase collecting parts for conversion 11. Aph (conversion) - Dec 17 '03 12. 3000gtdriver (tt swap) td05-14b's 13. JRock4000 (conversion) 3000GT -should be done this January 14. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 15. 93_black_R/T Waitin on a front motor mount! 16. PhazinBlack92RT (Conversion) Needs Coolant & Oil lines, IC piping, O2 housings, DP and oil cooler then im done 17. 95red3000GT (conversion)- conversion has started 18. 93 Stealth R/T (TT conversion)- Started, need IC's and Oilcooler...and money to buy them with 19. Import Power Online Project SL-T www.ProjectSL-T.com |
#207 (permalink) |
I'm a dork.
2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX 4. JB (engine swap) 3KGT 5spd <---- the bad ass 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd 7. silverbullet (conversion) Stealth R/T 5 spd 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 10.Thump`Master (conversion) 3KGT 5 spd 11. JAL (conversion) 3KGT SOHC TT 12. ZachRT (single turbo) Stealth RT 13. 3KHI (supercharged) 3KGT 14. Juko (supercharged) 3KGT 15. SLAYER4ALL (supercharged) 3KGT 16. Snake93gt (supercharged) 3KGT SL 17. Spawn (supercharged) 3KGT SOHC ATX 18. OhFoSho (engine swap) SOHC Stealth 19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 20. shooter83 (engine swap) Stealth es 5spd 21. upyun (engine swap) 3kgt sl 22. Greedy Bones (engine swap) stealth es 5 spd <--can't believe you forgot the SuperES!!! aka 500HP ES 23. Evangelist (TT Conversion) Stealth ES/TT 5 spd 24. Blue-GTO (TT Conversion) 3kgt SL 25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 26 tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 27.bigballsofpaint (TT conversion) 95 3k base....i finally finished 28.92-3000GT (Single turbo) 3000gt sl 5spd 29. Iceman3K15 (engine swap) 3KGT SL 5spd <---- your daddy 30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 31. Quintop (engine swap) '95 SL 5 sp 32. Jigzibit (conversion) '95 SL ATX In progress 1. SpeedFreakSteve (TT engine swap with 5spd AWD tranny and 13G's) 3KGT SOHC 5spd (est. finish date March 30/2004) 2. Jeremy C (conversion) collecting parts 3. xtremewlr (conversion) collecting parts slowly 5. Import Power Online Project SL-T [url]www.ProjectSL-T.com 4. sipe16 (conversion) collecting parts 6. rtrotter (supercharged) 3KGT 7. cred05 (conversion) collecting parts 3kgt 8. Whitewavesea (single turbo) 3kgt Installation in progress 9. ZUMin3K (JDM TT swap) 3kgt SL Estimated date of completion - Dec 7 2004 10. 3kGTbase collecting parts for conversion 11. Aph (conversion) - Dec 17 '03 12. 3000gtdriver (tt swap) td05-14b's 13. JRock4000 (conversion) 3000GT -should be done this January 14. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 15. 93_black_R/T Waitin on a front motor mount! 16. PhazinBlack92RT (Conversion) Needs Coolant & Oil lines, IC piping, O2 housings, DP and oil cooler then im done 17. 95red3000GT (conversion)- conversion has started 18. 93 Stealth R/T (TT conversion)- Started, need IC's and Oilcooler...and money to buy them with |
#208 (permalink) |
Large Member
Just making a correction to the list..
1. stu_04 (conversion) 3KGT SL ATX (*sold* new owner unknown) 2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX 4. JB (engine swap) 3KGT 5spd <---- the bad ass 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd 7. silverbullet (conversion) Stealth ES 5 spd <--- 9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 10.Thump`Master (conversion) 3KGT 5 spd 11. JAL (conversion) 3KGT SOHC TT 12. ZachRT (single turbo) Stealth RT 13. 3KHI (supercharged) 3KGT 14. Juko (supercharged) 3KGT 15. SLAYER4ALL (supercharged) 3KGT 16. Snake93gt (supercharged) 3KGT SL 17. Spawn (supercharged) 3KGT SOHC ATX 18. OhFoSho (engine swap) SOHC Stealth 19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 20. shooter83 (engine swap) Stealth es 5spd 21. upyun (engine swap) 3kgt sl 22. Greedy Bones (engine swap) stealth es 5 spd <--can't believe you forgot the SuperES!!! aka 500HP ES 23. Evangelist (TT Conversion) Stealth ES/TT 5 spd 24. Blue-GTO (TT Conversion) 3kgt SL 25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 26 tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 27.bigballsofpaint (TT conversion) 95 3k base....i finally finished 28.92-3000GT (Single turbo) 3000gt sl 5spd 29. Iceman3K15 (engine swap) 3KGT SL 5spd <---- your daddy 30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 31. Quintop (engine swap) '95 SL 5 sp 32. Jigzibit (conversion) '95 SL ATX In progress 1. SpeedFreakSteve (TT engine swap with 5spd AWD tranny and 13G's) 3KGT SOHC 5spd (est. finish date March 30/2004) 2. Jeremy C (conversion) collecting parts 3. xtremewlr (conversion) collecting parts slowly 5. Import Power Online Project SL-T [url]www.ProjectSL-T.com 4. sipe16 (conversion) collecting parts 6. rtrotter (supercharged) 3KGT 7. cred05 (conversion) collecting parts 3kgt 8. Whitewavesea (single turbo) 3kgt Installation in progress 9. ZUMin3K (JDM TT swap) 3kgt SL Estimated date of completion - Dec 7 2004 10. 3kGTbase collecting parts for conversion 11. Aph (conversion) - Dec 17 '03 12. 3000gtdriver (tt swap) td05-14b's 13. JRock4000 (conversion) 3000GT -should be done this January 14. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 15. 93_black_R/T Waitin on a front motor mount! 16. PhazinBlack92RT (Conversion) Needs Coolant & Oil lines, IC piping, O2 housings, DP and oil cooler then im done 17. 95red3000GT (conversion)- conversion has started 18. 93 Stealth R/T (TT conversion)- Started, need IC's and Oilcooler...and money to buy them with
2001 Ford Explorer - AWD 5.0L V8 lifted w/ 32" BFG AT K/O's
2004 Mazda6 ![]() |
#209 (permalink) | |
Member # 2818
#210 (permalink) |
2. punkasscrab (conversion) 3KGT 5 spd 3. SLguy (conversion) 3KGT ATX <---going down to 8:1 4. JB (engine swap) 3KGT 5spd <---- the bad ass 5. Mikes95RT (conversion) Stealth R/T 5 spd 6. mitsugtocars (conversion) 3KGT 5 spd 7. silverbullet (conversion) Stealth ES 5 spd <--- 9b/13g combo, 13psi on 10:1 8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original 9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd 10. X GTO X (engine swap) 3KGT (VR-2) 10.Thump`Master (conversion) 3KGT 5 spd 11. JAL (conversion) 3KGT SOHC TT 12. ZachRT (single turbo) Stealth RT 13. 3KHI (supercharged) 3KGT 14. Juko (supercharged) 3KGT 15. SLAYER4ALL (supercharged) 3KGT 16. Snake93gt (supercharged) 3KGT SL 17. Spawn (supercharged) 3KGT SOHC ATX 18. OhFoSho (engine swap) SOHC Stealth 19. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd 20. shooter83 (engine swap) Stealth es 5spd 21. upyun (engine swap) 3kgt sl 22. Greedy Bones (engine swap) stealth es 5 spd <--can't believe you forgot the SuperES!!! aka 500HP ES 23. Evangelist (TT Conversion) Stealth ES/TT 5 spd 24. Blue-GTO (TT Conversion) 3kgt SL 25. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd 26 tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe 27.bigballsofpaint (TT conversion) 95 3k base....i finally finished 28.92-3000GT (Single turbo) 3000gt sl 5spd 29. Iceman3K15 (engine swap) 3KGT SL 5spd <---- your daddy 30. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months) 31. Quintop (engine swap) '95 SL 5 sp 32. Jigzibit (conversion) '95 SL ATX In progress 1. SpeedFreakSteve (TT engine swap with 5spd AWD tranny and 13G's) 3KGT SOHC 5spd (est. finish date March 30/2004) 2. Jeremy C (conversion) collecting parts 3. xtremewlr (conversion) collecting parts slowly 5. Import Power Online Project SL-T [url]www.ProjectSL-T.com 4. sipe16 (conversion) collecting parts 6. rtrotter (supercharged) 3KGT 7. cred05 (conversion) collecting parts 3kgt 8. Whitewavesea (single turbo) 3kgt Installation in progress 9. ZUMin3K (JDM TT swap) 3kgt SL Estimated date of completion - Dec 7 2004 10. 3kGTbase collecting parts for conversion 11. Aph (conversion) - Dec 17 '03 12. 3000gtdriver (tt swap) td05-14b's 13. JRock4000 (conversion) 3000GT -should be done this January 14. TheChosenOne (Eaton SC) 3KGT SL saving money like mad 15. 93_black_R/T Waitin on a front motor mount! 16. PhazinBlack92RT (Conversion) Needs Coolant & Oil lines, IC piping, O2 housings, DP and oil cooler then im done 17. 95red3000GT (conversion)- conversion has started 18. 93 Stealth R/T (TT conversion)- Started, need IC's and Oilcooler...and
94 TT Auto
8.5:1 Arias Forged Pistons, Pauter Rods, DR Stage 3 heads, EVO III 16G's, and supporting mods |
