Old 03-11-2008, 09:58 PM   #731 (permalink)
Damn It!
3startuna's Avatar
Drives: Without Traction
Trader Rating: (14)
3startuna Level 33startuna Level 33startuna Level 33startuna Level 3
Default Re: FWD TT cars.. how many are there now?
finally have all my parts waiting for my engine to come from the shop
96 3000GT FWD TT -Rebuilt 2 bolt 8:1 block, balanced stock internals, valve job, 99 Lifters, Maximal Performance Motor mounts and valve cover!! Quaife LSD, ACT Max Extreme 6 puck, RPS flywheel, Greddy emanage Ultimate, custom fuel system i designed my self, profec B spec2, walbro 255lph, stock turbos, Braided steel upper and lower radiator hoses, KNN FPIK, FMIC, FM oil cooler, cusco Oil catch can, stillen DP, IPS 3" single, Full AC delete, stripped interior, Corbeau Forza 2 seat, 2 inch harness, ALL Greddy electronic gauges, brakes: 4 piston calipers from Yogurts TT, Hawk pads, Valvoline DOT 4, Russells steel lines
Coming soon: Tranny number 3
Special thanks: IPS, Maximal Performance, 3SX, Evans Performance and all 3si and FL3s members that sold me parts
3startuna is offline   Reply With Quote
Old 03-12-2008, 03:58 AM   #732 (permalink)
cyber bully
Trader Rating: (10)
green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7
good luck my friend!
Old 04-15-2008, 06:55 PM   #733 (permalink)
3000GT-LA's Avatar
Drives: 1993 3000GT
3000GT-LA Negative 43000GT-LA Negative 4
woking on my FWDTT conversion too ...all i need is a new oil pan..and my gauges
3000GT-LA is offline   Reply With Quote
Old 04-15-2008, 08:57 PM   #734 (permalink)
TPW Educator
LVA3KGT's Avatar
Drives: with EDFC at 0/0
LVA3KGT Level 5LVA3KGT Level 5LVA3KGT Level 5LVA3KGT Level 5LVA3KGT Level 5LVA3KGT Level 5
Originally Posted by thetjkid View Post
1. stu_04 (conversion) 3KGT SL ATX
2. punkasscrab (conversion) 3KGT 5 spd
3. SLguy (conversion) 3KGT ATX <---going down to 8:1
4. JB (engine swap) 3KGT 5spd
5. Mikes95RT (conversion) Stealth R/T 5 spd
6. mitsugtocars (conversion) 3KGT 5 spd <----- 13T/9b Combo
7. silverbullet (conversion) Stealth ES 5 spd <--9b/13g combo, 13psi on 10:1
8. Gatecrasher (engine swap) Stealth ESX (FWD TT w/6spd) <---the original
9. Gonskanator (gt pro conversion) GT347's with a host of mods, 3kgt 5spd
10. X GTO X (engine swap) 3KGT (VR-2)
11.Thump`Master (conversion) 3KGT 5 spd
12. JAL (conversion) 3KGT SOHC TT
13. ZachRT (single turbo) Stealth RT
14. 3KHI (Engine Swap) 3KGT DR-900's, Stage 3 Heads, Street Cams.
15. Juko (supercharged) 3KGT
16. SLAYER4ALL (supercharged) 3KGT
17. Snake93gt (supercharged) 3KGT SL
18. Spawn (supercharged) 3KGT SOHC ATX
19. OhFoSho (engine swap) SOHC Stealth
20. Telepathy (TT conversion by 3kgtmotorsports) Stealth R/T 5 spd
21. shooter83 (engine swap) Stealth es 5spd
22. upyun (engine swap) 3kgt sl
23. Greedy Bones (engine swap) stealth es 5 spd SuperES!!! aka 500HP ES
24. Evangelist (TT Conversion) Stealth ES/TT 5 spd
25. Blue-GTO (TT Conversion) 3kgt SL
26. 92 Stealth ES (13G TT Conversion) Stealth ES 5 Spd
27. tim3kgt 94/91 hybrid TT conversion 5spd TRE quaiffe
28. bigballsofpaint (TT conversion) 95 3k base....i finally finished
29. 92-3000GT (Single turbo) 3000gt sl 5spd
30. Optamix (engine swap) 3KGT SL 5spd
31. Ikilledit29 (TT conversion) 95 3000gt 5 sp Youngest? (16 + 2 months)
32. Quintop (engine swap) '95 SL 5 sp
33. Jigzibit (conversion) '95 SL ATX
34. 93 Stealth R/T (TT conversion)
35. Bob The Great (TT conversion) 93 R/T AWD 5spd
36. SpeedFreakSteve (TT swap) '98 3000GT base 5spd AWD w/SFR LSD and 18T's
37. HikariGT (TT conversion) 97 SL 5sp, DR500s,VR4 ECU with NA harness.
38. Kadius (Xtremeboost single T3 turbo conversion) 95 3000GT
39. 3000hybrid (TT swap) 97 base GT- ATX to 5spd AWD tranny w/SFR LSD 19T's
40. 95red3000gt (TT conversion) only one in Colorado!
41. Jeremy C (TT conversion) - weekend project
42. Vortac (TT Conversion) SL ATX
43. Maddux317 (TT Conversion) 92 3GKT SL 5 Spd.
44. ES 3000TT (15G TT swap) 93ES w/92TT..ECU/Harness/Engine/AWD
45. Braincrater (JDM TT Swap) 92 ES w/ 93TT ECU/Harness/Engine/AWD
46. Import Power Online-Fastest-Quickest-Dyno Record 132.97MPH/11.44-14bs/519HP EVOIIIs-5spd AWD The new FWD Record
47.93_black_R/T - Finished May 2004
48. drone007 (TT conversion) 9b's, 6psi, 95 cali harness/95 fed ecu
49. rush6432 ( Single turbo conversion, stock 10:1 motor)
50. Jon Mills- (TT conversion) 9b's, 8psi, TT ECU & Harness, SFR LSD, & so on. . . 156K
51. Zumin3K - TT Swap) 9bs, TT ECU + Harness
52. sipe16 - (TT Conversion) tt ecu/harness, 6spd swap
53. moneypitGT- (TT Swap) tt ecu/harness/14psi/3KGT SL
54. aaron97- (conversion) 3000GT SL
55. sportcars_16-(TT Swap) 15gs/550 injectors/rps 6 puck disc
56. |4x4 nv| - (TT Swap) Evo3 16G's/Forged Internals(8.1:1 compression)/680cc injectors/Garrett FMIC/Propane/maftpro
57. BIG_BALLER( TT Conversion) TT ECU/Blow Thu/ Propain/FMIC
58. [h]ardocp_geek (Single Turbo Conversion) SL 5spd / 62-1 turbo
59. kdog109sd (TT Conversion) - one of the first automatics to do it
60. ~~the~links~~ (supercharged) 1997 3KGT SOHC 5spd @ 9psi
61. Deft Spyder (TT Conversion) '95 3000GT Spyder ATX
62. KevD23 (single turbo) '94 stealth ATX
63. NeoValentine (TT Conversion) 96 SL 5spd @ 8psi TT ECU,Quaife
64. LVA3KGT (TT Swap) DR500s 390FWHP, 410 FWTQ @ 17psi
65. Pantherchams (Supercharged) 93 Stealth ES ATX
66. Drag_Knight (93 J-spec TT engine swap) '93 Base 3000GT
67. Nireez(TT Conversion) 95 Base 5sp (Stock boost for now!)
68. BillyBADASS09(TT Conversion) 96 RT 5sp (First 96 Stealth fwd TT???)
69. Jomojr (TT Conversion 93 Base ATX)
70. Cobane (J-Spec Swap) 94 r/t 5-spd.
71. LeRoyDL (92 R/T DR650 Blow through TT Conv. JDM ECU, N/A harness)
72. AJP52987 (95 3000gt, TT conversion) TT exhaust cat->axel, NA 2.5" wicked exhaust, Turbo XS rfl BOV, SS oil feed lines, TT plenum, EGR deleted, 95 VR4 ECU 94 VR4 harness.
73. Digiimandan3kgt (95 3kgt, TT swap) Atx to Mtx 5 spd-awd converted to fwd Swap, + many mods
74. LongDDong (13G TT conversion) 95 Dodge Stealth RT ATX
75. ccrunner84 (92 Stealth RT) MTX Swap, NA Engine w/ 8:1 Pistons, 9b's
76.Chris95RT (95RT Blue!) Normal Conversion... for now, ESX the second comming mk2.
77. Xtreme2k2 - TT Conversion, Greddy Emanage, PLX r500
78. Stealth13 - Sohc to DOHC TT with dr500s, standalone EMS and ignition
79. OneWingedAngel - 97 3000GT SL T/T conversion
80. 91StealthBaseTT - TT 10:1 compression fully rebuilt engine including valve job (:
81. PearlRyde - '92 TT Swap into a '99Base... Running on SOHC Tranny until i can rebuild the Getrag...
82. 94mitsumichael7 - 94 Stealth RT... FWD 9b's 8 psi, TT ECU, 10:1 motor, new EVERYTHING. lol. But its finally done and running!!!
83. templar - 94 3000GT ATX TT Conversion.
84. Nojinxz - .080 over supercharged running 6lbs boost - running very well
85. GTOGIRL3000 ~ 94 SL-TT and 5 speed NA MTX swap, 10:1 comp.,TT ECU and harness, SFR LSD.
86. Forsakenwolf - '91 ES-TT w/ 5spd NA MTX, 8:1 comp
87. white96tt - (engine swap) 95 Stealth Base ATX; 15gs
88. DSMGTO - 94 SL N/A motor, TT ECU, TT Fuel pump, 360 inj.
89. AyeKay 94 SL Twin Turbo with all the TT Parts 10:1 7lbs of Boost
90. blk92sl - now SLTT!!! just started her for the first time last night..6/17/06
91. Zeiss - 94 Stealth RT Luxury with 13gs 10:1 and SFR LSD insert.
92. Wildarmz - 94 SL TT, 92 TT Ecu
93.MagnaVR4 - 99 base single cam to TT, 4bolt motor swap, 6spd
94. SeekNStrike- Stock TT swap. blitz boost con. S-AFCII
95. Rican3kgt- (Supercharged) Low comp pistons with forged internals, 12psi, tt ecu
96. King_Milo- TT swap, many mods, still stock turbo's
97. Guywit94sl - TT conversion 94 SLTT
98. J-Groove - 9:1 Ross forged '95 base TT
99. 94ATXVR2- TT engine swap, 17g's and Atx to 5spd getrag conversion.
100. Gen13kgt - TT Engine Swap.
101. 4u2nV - TT Conversion; 98SLTT; Stock 9b's @ 8PSI; Mod's in Sig.
102. Ryan94rt- TT convo, Two many mods
103. BigTyla - TT conversion on ATX with TT ECU
104. Rowlandzz - JDM TT Swap running smooth
105. Ghetoriger12 - single turbo supert70 running 21psi. running and happy...
106. Mr.30000 - TT Conversion w/ Custom Hybrid 13T's and a bunch of BPU on a 95 Base 3000GT
107. Tug - 9b's, TT ecu, 360cc injectors, 10:1 motor, VR4 heads
108. boardFreak5 - front mount, 4inch ICH, 99lifters, getting tuned soon
109. green-lantern - 95 base TT lots of mods and having fun
110. Yask4it- 91 R/T Auto TT conversion with mods
111. Fbc_978- 93 3000gt base TT conversion with bpu
112. thetjkid- 92 r/t stealth tt conversion running great
________________________________________________________
In Progress (remove your name when finished and add to completed list)
1. xtremewlr (conversion) collecting parts slowly
2. rtrotter (supercharged) 3KGT
3. Whitewavesea (single turbo) 3kgt Installation in progress
4. Aph (conversion) - Dec 17 '03
5. JRock4000 (conversion) 3000GT -should be done this January
6. TheChosenOne (Eaton SC) 3KGT SL saving money like mad
7. Mitch007 (conversion) expected completion by beginning of summer
8. Saigon_Sam1 '93 3kGT base ATX, TT going in Memorial Day weekend.
9. AkiraGT (TT swap already started)
10. StealthTT (just need turbos and ICs with pipes)
11. Chant (TT / SuperCharger Conversion) :0)
12. Scolex (Supercharger Conversion) Buying 3KHI's SuperCharger
13. 3kgtslflip-Twin Turbo Conversion Bought from TokayGecko, starting asap.
14. Renegadex181- Saving money and collecting parts...to start by April 15th
15. Clipse20 - 94TT Swap w/ JapSpec ECU & Harness
16. spaceace60 - 96'base w/98'tt vr4motor
17. Presto97sl - TT conversion ATX check sig for days until install
18. MilkyClr69 - 96SL w/ 92JDMTT motor/5spd TT tranny waiting on parts
19. Nobodylikeswood - 94 SL u TT conversion
20. WolfSL - TT conversion - collecting parts
21. 92StealthR/T - Have all parts but oil cooler for my tt conversion
22. TruPnoyFlava - 94 base (VR4 swaP)
23. Ellery Clinton - Got all my parts... just need the 94/95 Harness and Ceramic Coat everything
24. Its Fwd - 94 base coming back to life, soon to be TT
25. My92Stealth - 92 Base, Putting in a TT this winter!
26. 2inTrbo - Some TT parts already installed...TRUELY IN PROGRESS!!
27. zack6G72- A few parts on there way and then a clutch replacement.
28. ATXSUX- gathering parts as we speak, lack downpipe, gauges, ECU and Harness and a couple of little things.
29. Guywit94sl - everythings bolted up, jus need to finish o2 and ecu wiring
30. 3startuna - limited by founds expected completion date summer 07
31. 963KSLTT - hoping to be done by summer '07 =]
32. BStewart87 - ( 15g TT Swap | ATX --> MTX ) - Summer 2007!!!
Just wanted to update my info
97 SLtt
World's fastest fwdTT 97SL in Phoenix
410 Ft/lbs of torque-steer and 390HP to the front wheels, making 1-3 gear useless @17psi. Built and tuned by 3SX
(Firebird) = Best 60ft 2.4 Best ET 13.8 , best trap 110.8MPH , picked up almost 30mph on the big end of the track.
3SI member # 5422
LVA3KGT is offline   Reply With Quote
Old 04-15-2008, 10:26 PM   #735 (permalink)
3000GT-LA's Avatar
Drives: 1993 3000GT
weres my name ....
Old 04-16-2008, 10:52 AM   #736 (permalink)
Venom Speed Shop
Venom13132's Avatar
Drives: Small Car Big Engine
Trader Rating: (100)
Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7
Originally Posted by 3000GT-LA View Post
weres my name ....
you have to put your own name on the list. there isnt a moderator on this thread who does it for you. And if you did that already and its gone most likely someone copied an older copy of the current list from an older post.
this list isnt really up to date. there are people listed on there who no longer have their cars. I took my stealth off there cause I parted it out. Im building another one right now but i dont care to put my name on the "in progress" list.
Venom13132 is offline   Reply With Quote
Old 04-17-2008, 06:45 PM   #737 (permalink)
xiongsta_00 is an unknown quantity at this point
in progress in collecting parts.
hold back is my ebrake cable. have no idea on fixing it. no special tools for getting the flange nut to replace old ebrake shoes.
xiongsta_00 - tt engine swap - 5sp
xiongsta_00 is offline   Reply With Quote
Old 05-31-2008, 05:25 PM   #738 (permalink)
stu_04's Avatar
stu_04 is an unknown quantity at this point
Wow it sure has been a long time since ive posted on these boards. So awesome to see all these TT conversions up and running. My car is still running strong, havent been driving it for a few years do to a blemished driving record and insurance being rediculous but the Auto TT is still tearing up the road.
Looking to put some more effort into it this summer and hit the track so ill try and post some times here soon. keep up the good work all.
STU
1998 3000GT SL TT ATX
Full tsunami stereo system
Twin turbo conversion
2 9b turbo's
HKS air intake
DNP intake pipes
Greddy Blow off
Apexi SAFC
Apexi AVCR
Autometer boost, EGT, AF guages
Borla exhaust
Test pipe
TT manifold
Jspec down pipe
stu_04 is offline   Reply With Quote
Old 06-15-2008, 03:36 PM   #739 (permalink)
Panda Master
maTT's Avatar
Drives: with one foot.
Trader Rating: (19)
maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7
113. maTT- 92 SOHC ATX -> 8:1 DOHC TT ATX
I no longer work for 3SX however I still strongly recommend them for your 3S parts and service needs!
maTT is offline   Reply With Quote
Old 06-15-2008, 05:52 PM   #740 (permalink)
TPW Educator
LVA3KGT's Avatar
Nice job, Matt!!!!!
