Old 04-29-2008, 02:29 PM   #1 (permalink)
VA 3S
Tool Man's Avatar
Drives: 94 3000GT NA
Trader Rating: (23)
Tool Man Level 3Tool Man Level 3Tool Man Level 3Tool Man Level 3
Default Fuel pump assembly question Turbo vs NA
Are the fuel pump assemblies the same and just the pump needs to be changed for the conversion? The assembly is frozen on the parts car, but if all I need is the pump, I can cut the lines to get it out.
Under the knife for a TT conversion.
Pics of my car, click me!_______ August 2006 ROTM
Tool Man is offline   Reply With Quote
Old 04-29-2008, 03:29 PM   #2 (permalink)
DSM GURU
Mike1992's Avatar
Drives: 91 Stealth RT/TT
Trader Rating: (23)
Mike1992 is an unknown quantity at this point
Default Re: Fuel pump assembly question Turbo vs NA
The assemblies are different
1992 Mitsubishi 3000GT VR-4 RIP 3/06
1990 Eagle Talon TSI AWD - 11.29@126 - SOLD
1991 Dodge Stealth RT/TT - K&N / MSD Wires / 2.5" Downpipes Merged 4" Cat-back / Hotwired Walbro 255hp / Aeromotive AFPR / Scanmaster 3 / Innovate LM-1 / F&R Solid Motor Mounts / Greddy RS BOV / TD04-13T / Seattle STS / CXRacing FMIC
Mike1992 is offline   Reply With Quote
Old 04-29-2008, 03:47 PM   #3 (permalink)
cyber bully
Trader Rating: (7)
green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7
they are different but you can mod the n/a one like I did. I assume the fuel line is striped to the assembly? I cant remember if I have pics of mine or not. I will send you a pm.
Old 05-04-2008, 10:32 AM   #4 (permalink)
VA 3S
Tool Man's Avatar
Trader Rating: (23)
Well, I got it out, and I'm guessing it's a NA assembly since the pump was hose clamped to the housing.
Old 05-04-2008, 12:27 PM   #5 (permalink)
cyber bully
Trader Rating: (7)
lol you have a pic?
edit I did find a pic of mine that coop took. not a great pic though.
Old 05-04-2008, 01:59 PM   #6 (permalink)
VA 3S
Tool Man's Avatar
Trader Rating: (23)
Originally Posted by green-lantern View Post
lol you have a pic?
Looks a lot like that, but mine was better, he used 2 clamps
Old 05-05-2008, 03:43 AM   #7 (permalink)
cyber bully
Trader Rating: (7)
LOL
I am getting a little bit of knock up top that makes me wonder if mine is leaking in the tank. I wouldn’t know it was unless I had a fuel pressure gauge. I need to find a TT assembly and upgrade the pump.
Old 05-05-2008, 04:27 AM   #8 (permalink)
H to the izzO
Hannibalzero's Avatar
Drives: Recklessly
Trader Rating: (53)
Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7
I use a TT pump with an NA housing. If I recall correctly, all I did was bend the NA housing slightly so that the bottom will hold the pump firmly in place. I may have also used an extra washer on the screw.
