#11 (permalink) | |
'92 SOHC Stealth
I am using 525cc injectors on my SOHC 20G conversion. Should be lots.
'92 Dodge Stealth SOHC - 3SX Adjustable Camber & Toe Arms, Eiback Springs, KYB Struts, 3SX Steel Braided Brake Lines, Stillen Brake Pads on Stillen Cross-Drilled Rotors, 3SX Steel Braided Clutch Line, 3SX Lightweight Aluminum Crank Pulley w/ Gatorback Belts, 65mm Big-Bore Throttle Body w/ Half-Shaft Mod, ARP Head Stud Kit, 3SX Poly Motor Mounts, 3SX Short-Throw Shifter w/ Solid Shifter Bushings, 3SX 2.5" Downpipe, RT High-Flow Cat, Custom Stainless 2.5" Cat-Back w/ Flowmaster 40, 18" ADR SZ1 Wheels, Etc...
SOHC Single Turbo Project in progress. ![]() |
#12 (permalink) | |
Boiler Up
And SOHCStealth... Are you planning on doing a writeup on your experience and build pictures? I would definitely be interested. It might even make me want to ditch the 6g74 swap I was planning this summer.
1997 3000GT SOHC [3SX Downpipe] [3SX Testpipe] [3SX Lightweight Pulley] [4" Air Intake] [Custom 2.5" Catback] [MSD 8.5mm Plugwires] [18" DR Rims] ![]() |
#13 (permalink) | |
'92 SOHC Stealth
#14 (permalink) |
SOHC PowA
ok i here all these fuel managing systems. What is emanage or Maft Pro or SAFC, they have to do with tuning right? dont u need an OBD 2 to use these?
Stage "2'' F1 Racing Clutch
Bomz Racing Intake 18" Konig Unknowns, Nexen 245 45ZR 18 Northgate 2'' Custom Catback Exhaust KYB Shocks & Struts, Intrax Lowering Springs SOHC 5 spd, Sound: Pioneer HU, Pioneer 6-disc CD Player, 2 Pioneer 10's, Pioneer 760w amp, 130 DB Work in progress: |
#17 (permalink) |
like a bunch of the other guys said the 360's would probably be your best bet....if its just you dont want to break the bank on them, just shoot me a pm i have a set that im not using that id certainly let go for cheap
#18 (permalink) | ||
boosted
i picked up some 270cc injectors today for free. so more than likely i will use those for now. its not much work to change the injectors. the thing im trying to accomplish is to do a budget turbo build to give the other sohc guys some insight as to what they could for the price. as matt has already proven the sohc can take one hell of a beating and keep going. Quote:
I <3 booost. 90gsx. 3inch turbo back magnaflow exhaust,K&N, shortshifter, stage 2 clutch, mbc at 16psi
#19 (permalink) |
Where would I get the resistors? I have been searching for a resistor box from a turbo stealth/3000gt and I have a couple from turbo dsm's but dont know if they would work on it or if the one off the turbo S/3 has more wires than a Inline 4 has, anyone know?
Could i use two I4 resistor boxes for the V6? Instead of useing a turbo S/3 resistor box? ![]() |
