#1 (permalink) |
boosted
ok well as many know im working on a turbo kit for my sohc.im heading to the local junkyard tommorow and i was thinking about grabbing some 240cc injectors off of a NA dsm while i was there. i have read on the dsm forums that they are high impedence injectors. will they work with our cars? i dont see why they wouldnt, but i want to make sure
I <3 booost. 90gsx. 3inch turbo back magnaflow exhaust,K&N, shortshifter, stage 2 clutch, mbc at 16psi
#2 (permalink) |
Damage Control
They will work but you are still going to need a controller. Depending on how much boost you want to run 240's may not be enough.
Kbizzle [11:25 P.M.]: this is most displeasing |
#6 (permalink) |
Boiler Up
Why start off with 240s when you'll have to upgrade eventually anyways? You mise well start off with stock VR4 360cc injectors and Walbro 190 lph & go from there... You can tune it from there especially if you're running SAFC II.
1997 3000GT SOHC 3SX Downpipe 3SX Testpipe 3SX Lightweight Pulley 4" Air Intake Custom 2.5" Catback MSD 8.5mm Plugwires 18" DR Rims 10% Tint Sony Xplod Components ![]() |
#7 (permalink) |
boosted
i was thinking about it. but as stated in the other thread, the safc2 might not be able to recognize the change from the 210 to 360cc. im starting out with low boost and i will work my way up. but as i am dding the car right now, as my dad has been using my truck, the 240s will work fine. theres no reason for me to not use them as they will be dirt cheap or maybe free lol. i know that some of the nissans used 270cc injectors so i will keep my eyes open for them while im there. the main thing im worried about right now is getting the manifolds fabbed up.
#9 (permalink) | |
***** User
The safc doesnt 'recognize' the change in injector size per say. However it will be able to handle tuning in 360cc injectors from the stock size. However, seeing as the stock NA ecu isn't programmed to see boost you may have other issues in your tune, such as timing etc. Id personally recommend a more versatile tuner like emanage or maft pro where you can control timing and get more tune adjustment points. Although an safc would probably suffice if you are on budget restraints. |
#10 (permalink) | |
boosted
well right now on 210cc injectors my a/f is 11.2. so im thinking for 4-6psi, that the 240s would suffice. like i said i may just go with the 270s if i can find some at the junkyard. the turbo i am using is a 14b. its small for the 3.0 i know, and i have already discussed with brent in detail about how it will not really make any power above 5k rpms. but its what i got for 20$ freshly rebuilt from a buddy of mine, so im gonna put it to use. it will suffice for 4-6psi. |
