Old 11-03-2009, 06:52 PM   #11 (permalink)
pomp_08's Avatar
Drives: '97 3000gt sl
pomp_08 is an unknown quantity at this point
Default Re: eliminate egr on 3000gt sl?
so basically the only thing thats coming from eliminating it is the cel light. ive heard some cars run better with it deleted. is that true?
pomp_08 is offline   Reply With Quote
Old 11-03-2009, 07:01 PM   #12 (permalink)
mikemet28's Avatar
mikemet28 is an unknown quantity at this point
Originally Posted by Stealthee View Post
I was able to on mine because there is a way to deal with the CEL. On 96+ you're screwed.
yea fuckin cali-spec ftl
and the main reason for a egr delete is to free up some room in the engine bay
Photobucket
Photobucket
mikemet28 is offline   Reply With Quote
Old 11-03-2009, 07:09 PM   #13 (permalink)
pomp_08's Avatar
so whether mines fucked up or i delete the prick its not gonna make a diff w/ the cel at all.. and its not gonna make any significant diff in anything else? so basically f it? haha
Old 11-03-2009, 07:23 PM   #14 (permalink)
Drives: 1994 3000GT Base
x2xtreme360 is an unknown quantity at this point
I would still find out what's wrong with it. If it is bad (stuck open on idle) your idle may be rough. You may get poorer mileage with a bad EGR valve. At least when you eliminate it you know it's not causing an issue. Whatever the issue is though, it may cost just as much to fix the issue as it would to buy block off plates and get rid of it all together. At least if you fix it you don't have to stare at the ugly red light on your dash.
x2xtreme360 is offline   Reply With Quote
Old 11-03-2009, 07:29 PM   #15 (permalink)
mikemet28's Avatar
block off plates still wont get rid of the cel
Old 11-03-2009, 07:37 PM   #16 (permalink)
I know... that's why i said he might want to fix the problem. Block off plates don't really fix the problem it just avoids it.
Old 11-03-2009, 07:41 PM   #17 (permalink)
mikemet28's Avatar
ahhh, second time i did that 2day, sorry i havent had much sleep, been workin on the car the last 2 days lol
Old 11-03-2009, 09:16 PM   #18 (permalink)
pomp_08's Avatar
alright boys. thanks for the help. ill find out whats going on with it and see what i can do. if i need anything ill post a new thread. hopefully you can help more if need be. thanks again.
