#81 (permalink) | |
cyber bully
air cleaner to mas to turbos to ICs to Y pipe to TB to plenum to cylinders to exhaust manifolds back through turbos to spin then that bad ass custom exhaust I built. LOL so you don't have a problem when the IC is disconnected and do you have a pic of the setup with out the IC hooked up?
#82 (permalink) | |
My car whines!!
This is the SC plenum without the IC pipes connected. Eaton M90 supercharger- FMIC not connected - 3000GT/Stealth International Photo Gallery
#84 (permalink) |
SOHC you in the FACE
Where are the posts about hoses crushing?
I still think you are pressurizing your IC piping and that BOV you tried was the wrong kind for a SC setup and you need to recirculate the air. Do you have evidence this is not happening? Have you tried opening the throttle stop a little bit on the TB to see if that makes a difference. There are weird problems you can have when coming to a stop like the speed sensor not telling the AIS to open etc.
Brent
1992 Duster -13.9@107.4 - 5psi - 6g72 3.13L "built" SOHC, Precision T67 P-trim, Tial 38mm open dump, 3" downpipe, 20x12x3" evo style intercooler, 7:1 compression, balanced, shot peened rods, heavily ported heads (+40% on flowbench), Ferrea Competition Plus +2 +1 stainless valves, Nielson Vintage 278 duration custom turbo cams, Custom Ram Style short runner intake manifold, Walbro 255hp, 6*47# injectors, +0.096" Forged Venolias, Total Seal chrome gapless top rings, Fidandza Flywheel, Clutchnet 3 puck solid hub, OBX Helical LSD, Zeitronix wideband/EGT/Boost sensors, 100watt DevilsOwn Meth Kit. 1994 Spirit - 13.987@101.89 - 5psi- 6g72 SOHC, K27 Turbo ![]() ![]() |
#85 (permalink) | |
My car whines!!
When stopping, there is so much vacuum in the system that by the time I come to a stop the internal pressures have not had time to stabilize. The only way I can keep it from stalling, is to slip into neutral and blip the gas. |
