#51 (permalink) | |
cyber bully
#52 (permalink) |
My car whines!!
She ran fine, absolutely no problems for the first three years after I installed the SC, until the day I spun a rod bearing (leaned out on oil while taking a hard curve). That is when my misfortune fell in place, that is when I switched to the VR4 bottom end to allow for more boost. Anthing that could go wrong did. Primarily because my shop was not familiar with 3kgt's and especially my supercharger mods. With the car in the shop for over 7 months last year, it did give me the opportunity to rebuild the trans, suspension, etc.
Yes, it will be worth it. Obviously, I have a lot of patience ha! |
#53 (permalink) |
My car whines!!
Being the car seems to be running fine again (3 builds later), I am back to my original delima. With the IC connected, the engine stalling out when coming to a stop.
It was suggested that I install a BOV. Being this is experimental, I am going real cheap to see if the concept works. Do you think this is the BOV I should try? http://cgi.ebay.com/ebaymotors/39MM-...spagenameZWDVW I am thinking about connecting it in-line with the cold air return from the IC to the intake to relieve any accessive air flow to the intake when letting off the gas.
#55 (permalink) | |
My car whines!!
Something like so? http://cgi.ebay.com/ebaymotors/Type-...spagenameZWDVW Where does the vacuum line connect...to the boost source on the SC? |
#56 (permalink) | |
-John edit: Yeah, just like that. |
#57 (permalink) | |
My car whines!!
Ok, that is the BOV I will purchase...wish me luck ha! Garrie |
#59 (permalink) |
My car whines!!
BOV is installed but the IC piping is not connected to the SC yet as I am in the process of connecting up a digital AIT gauge to the plenum. I will probably have everything connected by next weekend.
#60 (permalink) |
06 Cobalt SS Supercharged
Entirely different platform, but my eaton uses it's own by-pass valve and it seems to do fine for as far as the M62 seems to be pushed (3.35" stock SC pulley and even those with 2.6's & 2.5's typically find no problem with that bypass valve). none of us SS/SC cobalts use a BOV that I've seen to date(and I'm an avid reader of 3si and those forums).
The extreme high majority of us with the M62's use Heat Exchangers (come stock, as do Cobras) (air-to-water) only and I've probably only seen a couple people do air-to-air intercooler conversions (typically when planning for turbo swaps). If you'd be interested in trying a heat exchanger, CX Racing is a popular ebay company that sells awesome front-mount HE's so you should check them out (Alot of us are running them inline with the stock HE and IATs drop ~20-30 degrees). Not sure if that will be any help, but figured I'd throw some information out from another heaton supercharged vehicle setup and how ours works. If you have any questions, shoot a PM or post back here. Edit: This is the one we use, but check out their ebay store, they have like 2 or 3 other kinds. eBay Motors: Heat Exchanger Air to Water Intercooler Cobalt Mustang (item 350044176054 end time May-02-08 18:42:48 PDT)
My Cobalt SS Supercharged
Dyno: 228whp 204tq (w/CAI, Cat-back, S2 and 3.06" pulley) Mods: AEM Cold Air Intake || GM Stage 2 Tune || 42.5lb/hr Injectors || 2.9" S/C Pulley (3.35 stock) || Magnaflow Cat-Back Exhaust || NGK Copper Plugs || BWoody Solid Front Transmission Mount || Ingall's Engine Torque Damper || DC Sports Front Strut Tower Bar || 35% Carbon Black Tint || ARK Shorty Antennae ![]() Last edited by LittleGoose : 04-27-2008 at 09:08 PM. |
