Old 07-19-2008, 03:01 PM   #1 (permalink)
xiongsta_00 is an unknown quantity at this point
Default downpipe conversion help?
Hi. Just wondering, if I was to convert my na to tt, will I need to change my down pipe? I am really hopeing to just using my na downpipe, but if not, then converting it must. My engine, by the way, right now is a 8:1 and almost complete with my collecting of parts.
Thanks.
xiongsta_00 is offline   Reply With Quote
Old 07-20-2008, 07:25 AM   #2 (permalink)
One Wheel Wonder
B-Man0660's Avatar
Drives: '92 3000gt SL
B-Man0660 is an unknown quantity at this point
Default Re: downpipe conversion help?
It won't work. You can try converting it, but it'll save you time and money to just buy a new one.
15.0009sec@93.00mph 1/4mi
http://www.stealth316.com/2-calc-hp-et-mph.htm <-216hp-269hp according to this.
B-Man0660 is online now   Reply With Quote
Old 07-20-2008, 07:44 AM   #3 (permalink)
if you're talking about buying a new downpipe, will it fit the na exhaust? or do you mean to just buy a whole new system?
Old 07-20-2008, 07:45 AM   #4 (permalink)
bane of unintelligence
inperfectdarkness's Avatar
Drives: dreaming of a TT ecu
Trader Rating: (12)
inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7
you can make it fit to the n/a exhaust...though i'd really recommend going with at a MINIMUM, a 2.5" single shot catback. i currently have said setup running on my FWD tt.
inperfectdarkness is offline   Reply With Quote
Old 07-20-2008, 08:25 AM   #5 (permalink)
cyber bully
Trader Rating: (8)
green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7
Thanks.
just buy an ebay down pipe with solid or polly motor mounts (solid are cheaper). you will need a cat back also. the na cat back will not fit + it is way to restrictive. you can get a stock TT exhaust or go aftermarket or you can make one or have one made.
lots of or's there.
Old 07-20-2008, 09:22 AM   #6 (permalink)
boosted
gipper72488's Avatar
Drives: 1990 gsx eclipse
gipper72488 Level 2gipper72488 Level 2gipper72488 Level 2
yeah the stock NA exhaust will choke out alot of your power.
since you are building a 8:1 motor, id say you are planning on running a pretty high boost, and it would probably be best to go with 3 inch piping.
there are bolt up kits, but it would probably be more cost efficient to go to the local muffler shop and have them fab you up a custom exhaust
I <3 booost. 90gsx. 3inch turbo back magnaflow exhaust,K&N, shortshifter, stage 2 clutch, mbc at 16psi
gipper72488 is offline   Reply With Quote
