Old 07-01-2007, 11:15 PM   #21 (permalink)
J-Groove Level 3J-Groove Level 3J-Groove Level 3J-Groove Level 3J-Groove Level 3J-Groove Level 3J-Groove Level 3
Default Re: Do I really need a Fan Controller?
Originally Posted by Tug View Post
So why do you need this exactly?
The 1st gen ECU which a lot of us TT conversion guys use does not have a Fan controller within it. Where as the 2nd gen ECU does. So when switching over to a 1st gen ECU while having a 2nd gen harness the fans will not turn on.
The standalone gives a very simple fix to this problem that works great.
Old 07-01-2007, 11:53 PM   #22 (permalink)
Forum user
3000hybrid's Avatar
Drives: 93 VR4, 04 350ZR
Trader Rating: (49)
3000hybrid is an unknown quantity at this point
Originally Posted by Turbo27 View Post
I have a 1st gen, a 91 SL. Im going TT and was wnodering if I need it or not? You said if I have a 1G radiator I wont need the controller? What do i do?
If you ae using your 1st gen ECU and radiator you will be fine without one. Your 1st Gen radiator has temp sensors screwed in the radiator.
93 VR4 (under the knife)
97 FWDTT (Getting parted)
Mods
3.1L TE04H DR-19T's,Wiseco Forged Pistons, Custom FMIC, RPS MAX Street clutch,Tial BOV, Walbro 255,Custom Magnaflow 3'' exhaust,ATR DP,ATR DP,Catless, 3SX crank pulley, Emanage/E01, Derale fan controller, PTE 550 inj, AEM UEGO wideband, Re-located Optima Red Top,Krank Vents, EGR Blockoffs, MMCD logger, Stillen pads, drilled rotors, EibachPro springs, 3SX intake, intake hard pipes, IPO SX AFPR, 99 lifters,99 rear garnish, Racing Hart MP3 wheels,Snow Stg 2D Meth injection/Safe inj, http://www.hesspower.com/racecar.html
3000hybrid is offline   Reply With Quote
