Old 01-14-2008, 02:13 PM   #51 (permalink)
Need 19T'S
Fbc 978's Avatar
Drives: FWD-TT + 92 VR4
Trader Rating: (10)
Fbc 978 Level 1Fbc 978 Level 1
Default Re: Dave's TT Conversion Thread
Originally Posted by Barefoot View Post
Why did you go with those ss lines instead of ones you can cut to length? were they part of some kit?
Also, why did you have to retap your oil filter housing for the AN fittings? They make fittings that bolt right in
Lines came with the oil cooler. I only have one size AN fittings...it was easy to drill them out and tap them to M18.
13.7 @ 109...aka no traction and a bad launch(blown diff)
92 VR-4....work in progress.
http://www.3si.org/forum/f1/project-...5/#post4899857
Fbc 978 is online now   Reply With Quote
Old 01-22-2008, 07:51 AM   #52 (permalink)
Need 19T'S
Fbc 978's Avatar
Trader Rating: (10)
dropped pan...bearings had no play in them. There fore i continue.
bought a new front turbo last night...should be here before the weekend. I rebuilt my rear turbo this weekend so the front one should go smoothly.
Got my oil cooler and lines all squared away. I wrapped the stainless braided lines in 3/4 inch plastic tubing to keep them from rubbing on other parts.
Intercoolers are mounted on both sides....thank god for my dremel and 20 cut off wheels...they turn to dust like instantly. Dont know how im gonna get a clamp on the cold side of the intercooler...maybe a universal and 1/4 ratchet wrench.
Almost ready to put rear turbo in...need pressure switch..also need to make stupid banjo bolts. Im not paying $13 a piece. I hope to get the rear turbo all done this weekend.
Old 02-01-2008, 02:08 PM   #53 (permalink)
Need 19T'S
Fbc 978's Avatar
Trader Rating: (10)
Hey guys...can I run a 93' TT ECU, 360's, tt fuel pump, and fpr with no SAFC at wastegate boost---6psi. At what point will i need the safc for tuning. I am going to have wideband and logger.
Old 05-12-2008, 06:37 AM   #54 (permalink)
Need 19T'S
Fbc 978's Avatar
Trader Rating: (10)
Forgot about this thread
Ok guys huge news i guess...i am still 10:1 and yesterday I got running 13psi...no knock...kind of rich but I still have to pull some fuel. It runs like a champ and pulls soooo hard at 13 psi...i spin the tires in 2nd up to like 50(sucks). I wonder when I will start seeing knock I am more worried about my tranny now. My stage 2 southbend clutch is holding up well. My Toyos...not so much. Anyone have suggestions on maybe wider stickier tires? I like going to the track so thats why I am worried about my tranny.
Old 07-24-2008, 03:49 PM   #55 (permalink)
Need 19T'S
Fbc 978's Avatar
Trader Rating: (10)
hey guys...just figured i would tell you that i have gone 7k miles boosted. I am running wastegate on a factory TT tune and fuel...no knock. I run high 13's with no traction. My tranny is still good and the motor pulls hard. I love it as my DD. I still get the same gas mileage as before...31 mpg baby.
Old 07-24-2008, 04:17 PM   #56 (permalink)
Paid Member
shooter83's Avatar
Drives: Z15A Stealth ES!
shooter83 Level 7shooter83 Level 7shooter83 Level 7shooter83 Level 7shooter83 Level 7shooter83 Level 7shooter83 Level 7
congrats man!
-Evan
My AWD Conversion
My Photo Gallery
^Live in Florida? Clicky Clicky ^
shooter83 is offline   Reply With Quote
Old 07-24-2008, 05:51 PM   #57 (permalink)
boosted
gipper72488's Avatar
Drives: 1990 gsx eclipse
gipper72488 Level 2gipper72488 Level 2gipper72488 Level 2
nice work!!!!!
for your tranny concerns why dont you see if you can find a getrag for a good price and convert it to FWD
no more worries
I <3 booost. 90gsx. 3inch turbo back magnaflow exhaust,K&N, shortshifter, stage 2 clutch, mbc at 16psi
gipper72488 is offline   Reply With Quote
Old 07-25-2008, 08:41 PM   #58 (permalink)
Need 19T'S
Fbc 978's Avatar
Trader Rating: (10)
114k on the car...im not putting money into it...its a dd and 6 psi isnt too hard on it. I dont drive it hard unless im at the track. I put my money into my vr4
Old 07-26-2008, 08:06 AM   #59 (permalink)
boosted
fwd-tt and vr4...im envious
Old 07-26-2008, 08:27 AM   #60 (permalink)
cyber bully
Trader Rating: (8)
green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7
Originally Posted by gipper72488 View Post
nice work!!!!!
no more worries
I am in the process now LSD, flywheel, clutch, and tranny in the end will be around $3400
congratulations Dave! I have been DD mine for close to a year now.
edit: pics or ban!
