Old 12-05-2007, 08:20 AM   #21 (permalink)
Resident rocket scientist
BigTyla's Avatar
Drives: '93 3000GT ATX TT
Trader Rating: (174)
BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7
Default Re: Dave's TT Conversion Thread
After reading Mr. 3000's previous post, I think there are a few things to touch on as lessons learned from all of us as TT converts:
1) Rebuild your used turbos! Mine were from a newer VR4 and after driving for about 5000 miles they are pouring smoke. I'm not sure if the seals dried out since the turbos sat for so long, but if I were to do it all over again I would have rebuilt them for piece of mind.
2) Take your time! If you can find a way to get something as small as a heat shield to fit, do it! The factory put it there for a reason. The only thing I left off my car is one of the plates that bolts to the starter and transmission housing. Everything else is the way the factory put it and that's the way it should be (unless you are a self-professed automotive engineer, which I am sometimes guilty of).
3) Always be prepared to cough up money for something unexpected. I did my conversion when I probably should not have due to college taking up most of my expenses, and I have been lucky so far that nothing has gone boom. I'll have to rebuild my turbos but over the past 5000 miles that has been the only problem with my car. Don't walk the money tightrope with this car like I am!
1993 3000GT FWD ATX TT - daily<----------------------->1984 Nissan Maxima - selling
Ground wire GB is back!!!
Old 12-05-2007, 08:43 AM   #22 (permalink)
Forum user
3000hybrid's Avatar
Drives: 93 VR4, 97GT FWDTT
Trader Rating: (48)
3000hybrid is an unknown quantity at this point
I agree. Especially about items like the heat shield. I haven't ran heat shields for 3 years, but I never took the car on a long trip. I just drove the car from NM to FLA and I was about to die from the heat coming into the car from the firewall. Like Bigtyla said - the factory put it there for a reason. I'm installing heat shields as soon as I can.
VR4-"FOR OFF ROAD USE ONLY"
97 FWDTT
Mods
SOHC to 3.1L TT swap, ATX to 5-SPEED GETRAG, TE04H DR-19T's,Wiseco Forged Pistons, Custom FMIC, RPS MAX Street clutch,Tial BOV, Walbro 255,Custom Magnaflow 3'' exhaust,ATR DP,Custom FMIC,ATR DP,Catless, 3SX crank pulley, Emanage/E01, Derale fan controller, PTE 550 inj, AEM UEGO wideband, Re-located Optima Red Top,Krank Vents, EGR Blockoffs, MMCD logger, Stillen pads, drilled rotors, EibachPro springs, 3SX intake, intake hard pipes, IPO SX AFPR, 99 lifters,99 rear garnish, Racing Hart MP3 wheels,Snow Stg 2D Meth injection/Safe inj, http://www.hesspower.com/racecar.html
3000hybrid is offline   Reply With Quote
Old 12-05-2007, 09:05 AM   #23 (permalink)
J-Groove Level 7J-Groove Level 7J-Groove Level 7J-Groove Level 7J-Groove Level 7J-Groove Level 7J-Groove Level 7J-Groove Level 7J-Groove Level 7
Great points all around.
Old 12-05-2007, 09:55 AM   #24 (permalink)
Need 19T'S
Fbc 978's Avatar
Drives: FWD-TT + 92 VR4
Trader Rating: (10)
Fbc 978 Level 1Fbc 978 Level 1
BigTyla- I am in the same place as you in terms of turbos. I bought some from HennessyGTO (a member on here) and he said they had 20k miles on them. I got them and one turbo had 2 broken studs, both had shaft play when he said there was none, 1 didnt come with a wastegate which he said he would send me and never did, and one has what looks like burnt oil inside the housing. I am either going to get them rebuilt or do it myself.
13.7 @ 109...aka no traction and a bad launch(blown diff)
92 VR-4....work in progress.
http://www.3si.org/forum/f1/project-...5/#post4899857
Fbc 978 is offline   Reply With Quote
Old 12-05-2007, 11:27 AM   #25 (permalink)
BigTyla's Avatar
That sucks. I'm not so sure that my turbo spewing oil has to do with seller dishonesty. I really think the turbos sitting so long is what did one or both of them in (haven't been able to determine if both are blown yet).
Oh well. Live and learn.
Old 12-05-2007, 04:34 PM   #26 (permalink)
Forum user
3000hybrid's Avatar
Trader Rating: (48)
My turbo's were pretty new and I was sure I had a blown turbo since I had new VSS and the car still smoked like a train. I found out it was my PCV system. I added crank vents and the smokes a memory. Something to think about if you haven't changed your PCV valve to a TT one.
Old 12-05-2007, 05:59 PM   #27 (permalink)
I love her▼
Mr.3000's Avatar
Drives: T70 3000GT
Trader Rating: (38)
Mr.3000 level 6Mr.3000 level 6Mr.3000 level 6Mr.3000 level 6Mr.3000 level 6Mr.3000 level 6
Sucks about your bad used turbo experiences guys. Yea I got mine fully custom built with a full rebuild done at the same time. That's interesting about the heat shields. I personally don't think I could ever run them but yea I do understand the logic behind them lol. Yea as everybody said, do things right the first time. The only reason I said anything about the ebay ypipe is cuz I have a local guy who did my FMIC who could fix any fitment issues really easily. But I think I am just going to go and get my DP fixed.
Also, you need to have some money in the bank because things go wrong on you sometimes. Keep up the good work bro.
Project Z11A:My T70 Build
Courtesy of Piedmont Custom Motorsports
Mr.3000 is online now   Reply With Quote
Old 12-06-2007, 05:42 AM   #28 (permalink)
Need 19T'S
Fbc 978's Avatar
Trader Rating: (10)
yea its hard for me to have more than a couple hundred dollers at a time because I have to pay for my own insurance, gas, and car. As well as paying for the conversion. I am just glad that I have a car to drive as long as I need it. My brother is letting me drive his old ram 1500...now gas is gonne suck me dry. Good thing I live less than 1 mile from high school and less than 1 mile from work
Old 12-08-2007, 02:47 PM   #29 (permalink)
Need 19T'S
Fbc 978's Avatar
Trader Rating: (10)
UPDATE 2
Small update I guess, did a little disassembling. Started by pulling battery and plenum off. Replaced spark plugs with some champions gapped at .029-.030 (i know...im going to ngk's at some point). Started putting on my MSD wires and noticed 2 of the rear bank wires are the same length. Dont know if thats right or not. I dont have time to keep installing them. Ill finish them tomarrow. Also dont know if I can get to the last bolt on the front header without removing the alternator. Loosened up the ac belt...did other little things. I need more parts before I can get really into it. Tomarrow my goal is to get both TT headers on. Anyone have any tips for replacing them?
Pics-
Old 12-09-2007, 01:01 PM   #30 (permalink)
Need 19T'S
Fbc 978's Avatar
Trader Rating: (10)
cant get the rear header off even though all the nuts are off....when will the madness end!...i know...never
