K, so i'm in the middle of a rebuild and a tt conversion and was buying a new crankshaft. Something he told me puzzled me an i wanted to get you guy's input. He said he had a bunch of forged cranks because they are crappy and most people with 3k's end up putting in a cast crank.
I knew, well thought i guess, that forged cranks were stronger. I don't know if this guy was full of s**t or what. Anyway input would be appreciated
Yes forged cranks are definitely stronger. You can tell if its a forged crank by tapping the end where the crank pulley bolt goes on and it will make a high pitched ring if it is forged. Cast cranks FTL
how much power do you want to make?
For a 9b setup, just take a crankshaft out of a minivan. It will be fine. Probably only cost 50 bucks, and it won't have been beaten on!
No point getting a forged crankshaft for that.
I only use cast crankshafts and have never had a problem
Brent
1992 Duster 11.54@125 22psi STOCK n/a 6g72 12 valve - 12.7@114 14psi boost -516whp 519ft/lb 20psi (Old 3.13L built shortblock) - Precision 6765, Tial 38mm open dump, 3" open downpipe, 20x12x3" evo style intercooler, Stock 10:1 diamante 12 valve shortblock with regapped rings. heavily ported heads (+40% on flowbench), Ferrea Competition Plus +2 +1 stainless valves, Nielson Vintage Racing 278 custom turbo cams, RPW cam gears, Custom Ram Style short runner intake manifold, 12 Gal Jaz Fuel cell, Duel hotwired external Walbro 255s with dual feed lines, 3 puck solid hub & 3300# DD plate, OBX Torsional Diff, Zeitronix wideband/EGT/Boost sensors, 2100cc DevilsOwn Meth. Running on Megasquirt II
1994 Spirit - 13.987@101.89 - 5psi- 6g72 SOHC, K27 Turbo
how mach power you can make with forger??/ i mean TOP power and wahts TOP power with cast ?
1996 3000GT N/A AWD TT
2G brakes with drilled/slot rotors
KYB GR2 shocks with coilovers
Side mount intercoolers
6SP TRANNY 25 SPLINE
6 speed rear end
4 BOLT ENIGNE
FORGED CRANK
TT PORTE HEADS
X02 racing exhaust manifold KIT
F1 Stage 3 clutch
F1 aluminum flywheel 10.5p
GTO Speedometer
clutch pedal and shifter base
18X9 Rims
255/35/R18
FOR MORE PICS http://s488.photobucket.com/albums/rr241/D22A_2008/
