Old 07-25-2008, 07:49 AM   #1 (permalink)
My car whines!!
casperlynn's Avatar
Drives: damn fast!!
casperlynn Level 1casperlynn Level 1
Default Busting the myths..Roots supercharged 3kGt with video
Ok..ok...I need to bust up some misinformation and clarify mentioned points!
I have been running a Eaton M90 sc on my 95 base for over 4 years (with the NA ECU ) and it has always ran great! The first SC was a first gen, Thunderbird with the oval inlet which is not the most efficient and was only pushing 9psi which is about the max psi a 10:1 engine can safely handle. The only difficulty I experienced was intercooling as it would kill the engine when coming to a stop. That bug was never worked out but I am sure it is because the throttle body is before the SC. This setup was dyno'd at 416 at the crank and I had an unabated top end of 152mph capable of doing a bit more but the interior pressure was trying to blow the sunroof out.
I have since, installed a new, OEM VR4 shorty (to allow for increased boost) with the same stage 3 DR heads with 99 oilers, 450cc's, alchy injection, 3.5" GM MAF translator and Mirage Corp data logger, 7 1/2" diameter crank pulley (from a 2.5 98 Avenger), 3.33" diameter SC pulley, all coverted to a 6 rib contact, and am currently swaping out the SC with a 3rd gen Eaton with the rectangular inlet, teflon coated rotors and porting (capable of pushing 18 to 20 psi). I was wise enough to refresh the trans and install a Quaiffe LSD in the process. All the power is transferred to Yokahama rubber via a Spec, 6 puck clutch.
I have not had the opportunity to dyno the current setup but all indications are, I should be pushing around 450 chp or about 375hp to the road
Due to the insane low-in torque, it is extremely advisable to install the Quaiffe (not some cheap locking insert) and replace the mounts with solids (in my case, polys which are a bit more forgiving). I have absolutely no engine rock or wheel hop, just a bit of clutch chatter which is to be expected with a racing clutch.
In summary, a 3kgt base platform is a great candidate for supercharging. The SC is self contained (no external oiling, etc.) and are pretty much maintenance free for over 100k miles. Just change the oil once a year and put on a fresh Gatorback.
Yes, it is much more expensive then going TT (and I do admire those that have done the conversion as it is a lot of work.....much more than supercharging) but it is much more reliable if built properly (NO shortcuts!). Most peeps that have experienced SC problems did not build the car correctly. Above all, it is very rewarding not "following the crowd" going with a conversion. It may not be unique but it sure is not main-stream. Set my car alongside a TT'd conversion or VR4, my setup always gets more attention.
My .08 cents.
BTW.....I will be attending the BRG so those that may be interested in the setup, please feel free to chat....see ya!
casperlynn is offline   Reply With Quote
Old 07-25-2008, 09:25 AM   #2 (permalink)
Paid Member
shooter83's Avatar
Drives: Z15A Stealth ES!
shooter83 Level 7shooter83 Level 7shooter83 Level 7shooter83 Level 7shooter83 Level 7shooter83 Level 7shooter83 Level 7
Default Re: Busting the myths..Roots supercharged 3kGt with video
very nice man, do you have any driving videos?
-Evan
My AWD Conversion
My Photo Gallery
^Live in Florida? Clicky Clicky ^
shooter83 is offline   Reply With Quote
Old 07-25-2008, 09:42 AM   #3 (permalink)
My car whines!!
casperlynn's Avatar
Drives: damn fast!!
Sorry, I do not. 95% of the time I am in solo. Maybe soon.
Garrie
Old 07-25-2008, 10:27 AM   #4 (permalink)
2xmks's Avatar
Drives: 1996 VR-4
2xmks Level 22xmks Level 22xmks Level 2
8psi at an idle! I am jealous! Very nice set up, super clean. Yeah a driving video would be cool.
93mm Ross Pistons,Pauter Rods,3SX Port and polished heads,Webcams race cams,ARP main/head studs,South Bend Stage 4"FE" clutch,720 cc injectors,Supra fuel pump,IPS FMIC, IPS TD05 headers/EVO III turbo kit,Tanabe exhaust, Hiro Axis 19x9.5 rear 8.5 front, Toyo Proxes T1R 285 rear 245 front
2xmks is offline   Reply With Quote
Old 07-25-2008, 10:38 AM   #5 (permalink)
bane of unintelligence
inperfectdarkness's Avatar
Drives: dreaming of a TT ecu
Trader Rating: (12)
inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7
nothing wrong with a roots blower.
i just happen to want 500hp at the wheels. and unless you can figure out a way to run a twin-screw--instead of the roots--i'm really not interested. i just can't get the power i'd need out of it.
and their (roots) thermal efficiency is even WORSE than turbo's.
inperfectdarkness is online now   Reply With Quote
Old 07-25-2008, 10:52 AM   #6 (permalink)
My car whines!!
casperlynn's Avatar
Drives: damn fast!!
Personally, I would not want 500whp on a street driven, daily driver........all out race car, yes. If it was exclusively a quarter mile'r all I would need to do is go with forged rods/pistons and slap a 100-150shot fogger on her.
Old 07-25-2008, 11:16 AM   #7 (permalink)
yetterben's Avatar
Drives: 91 dohc N/A power
yetterben is an unknown quantity at this point
Whats up with the collapsed silicone boots? sucking that much vacuum
yetterben is offline   Reply With Quote
Old 07-25-2008, 11:24 AM   #8 (permalink)
My car whines!!
casperlynn's Avatar
Drives: damn fast!!
Yep, you are one of only a few that noticed ha! I will be changing over to hard elbows.
Old 07-25-2008, 03:08 PM   #9 (permalink)
Pow! Slam! Bam! Baff!
Patch's Avatar
Drives: 2 tons of fun
Patch Level 2Patch Level 2Patch Level 2
Wow! looks/sounds good. Now I wanna make one...
Patch is offline   Reply With Quote
Old 07-25-2008, 03:13 PM   #10 (permalink)
My car whines!!
casperlynn's Avatar
Drives: damn fast!!
Well, what is stopping you
In the next month or so, I'll have the very SC that is in the vid up for sell......you gotta start somewhere!
