Old 04-27-2008, 01:05 AM   #41 (permalink)
doing the impossible
lDoomZdaYl's Avatar
Drives: Her Crazy
lDoomZdaYl Level 7lDoomZdaYl Level 7lDoomZdaYl Level 7lDoomZdaYl Level 7lDoomZdaYl Level 7lDoomZdaYl Level 7lDoomZdaYl Level 7lDoomZdaYl Level 7
Default Re: ATX TT owners post up.
with fuel controller i should be able to max out the 9b's since you cant do that with 360cc. And the Turbo ECU i dont think that ill need since im going to use bigger injectors which need fuel controller anyway.
lDoomZdaYl is offline   Reply With Quote
Old 04-27-2008, 06:18 AM   #42 (permalink)
3S-less
maTT's Avatar
Drives: 1990 Montero
Trader Rating: (19)
maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7
jomojr has run 17psi on race gas with 9b's and 360 injectors. I would NOT do one of these conversions without the TT ecu, but that's just me.
I'm converting my sohc atx to dohc tt atx as we speak. This will be my 3rd atx tt conversion.
FWHP on 9b's will be around 225.
1992 VR4 - Sold
1991 SL - Sold
1993 RT/TT - Sold
1992 Stealth - Sold
maTT is offline   Reply With Quote
Old 04-27-2008, 06:49 AM   #43 (permalink)
bane of unintelligence
inperfectdarkness's Avatar
Drives: dreaming of a TT ecu
Trader Rating: (13)
inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7
^ WITHOUT a tt ecu on 8:1 compression.
hey maTT....when you get finished with that swap; could you post what differences and cost there is between the DOHC > TT and the SOHC > DOHC TT there is?
WhiteSmokeRacing pussified out on me doing something like this, and i'm curious.
thanks!
if you're good with fiberglass...REALLY good...pm me. i have work for you.
ditto if you're an automotive painter in middle Georgia.
Originally Posted by beepbeep View Post
I got neg rep'd when I offered to give my hubby a bj. If THAT doesn't demonstrate the importance of the rep system, I don't know what does!
inperfectdarkness is offline   Reply With Quote
Old 04-27-2008, 07:09 AM   #44 (permalink)
H to the izzO
Hannibalzero's Avatar
Drives: Recklessly
Trader Rating: (55)
Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7
What fuel controller are you going to use?
The problem with running 450cc injectors is that your timing is going to be through the roof with an NA ECU. While you are driving off-boost, your pulse width is going to be extremely low and your ECU will advance timing (a lot).
When I started my TT/ATX conversion, I also convinced myself that I could use the NA ECU. My tune ended up being richer than I would have liked due to low throttle timing-induced knock. Now, I am in the process of installing a TT ECU and fan controller. I recommend you do the same (unless you get an AEM ).
Old 04-27-2008, 07:13 AM   #45 (permalink)
H to the izzO
Drives: Recklessly
Trader Rating: (55)
Also, regardless of fuel you are not going to be able to max out the 9bs without serious knock prevention. Assuming it is a street-driven car, meth, toulene, or alcohol injection is probably the way to go. IPO used to sell propane kits too, which some people swear by. (maTT, does 3sx sell those kits now?)
Race gas is good, but not practical for street driving.
Old 04-27-2008, 10:01 AM   #46 (permalink)
S3KGT18's Avatar
Drives: 94, 95 RT
S3KGT18 level 6S3KGT18 level 6S3KGT18 level 6S3KGT18 level 6S3KGT18 level 6S3KGT18 level 6
If you're set on larger injectors just go ahead and get 13g's or 15g's. Forget about the 9b's.
Also you won't be able to go any larger than 525cc injectors on the stock ecu with a fuel controller.
94 R/T Luxury ATX- Silver For Sale $2500 OBO
95 R/T Sport ATX- WhiteFor Sale $4750 OBO
91 R/T ATX- White - sold
92 VR4-Black - sold
S3KGT18 is offline   Reply With Quote
Old 04-27-2008, 11:25 AM   #47 (permalink)
Trader Rating: (13)
since when can't you max out 9b's on 360's? 9b's are only good to about 14psi (no meth, on pump).
Old 04-27-2008, 07:33 PM   #48 (permalink)
lDoomZdaYl's Avatar
Drives: Her Crazy
1992 VR4 - Sold
1991 SL - Sold
1993 RT/TT - Sold
1992 VR4 - Sold
1994 VR4 - Sold
1992 SOHC ATX - Still kick'n
1993 SL - Retired
1991 VR4 - Retired
1993 VR4 - Sold
maTT is offline Add to maTT's Reputation Report Post Reply With Quote Multi-Quote This Message Quick reply to this message
maTT
View Public Profile
Send a private message to maTT
Send email to maTT
Find More Posts by maTT
Add maTT to Your Buddy List
View maTT's vbGarage
View maTT's Photo Gallery
Unread Today, 08:49 AM #43 (permalink)
inperfectdarkness
buy my 99!!!!!!!!!
Drives: with a shitty ECU
Trader Rating: (12)
inperfectdarkness Level 1inperfectdarkness Level 1
Send a message via MSN to inperfectdarkness Send a message via Yahoo to inperfectdarkness
thanks!
Rented by:
Eljefefx
you can rent this spot if you outbid his $15 per month.
inperfectdarkness is offline Add to inperfectdarkness's Reputation Report Post Reply With Quote Multi-Quote This Message Quick reply to this message
inperfectdarkness
View Public Profile
Send a private message to inperfectdarkness
Send email to inperfectdarkness
Visit inperfectdarkness's homepage!
Find More Posts by inperfectdarkness
Add inperfectdarkness to Your Buddy List
View inperfectdarkness's vbGarage
View inperfectdarkness's Photo Gallery
Unread Today, 09:09 AM #44 (permalink)
Hannibalzero
H to the izzO
Drives: Recklessly
Trader Rating: (50)
Hannibalzero Level 5Hannibalzero Level 5Hannibalzero Level 5Hannibalzero Level 5Hannibalzero Level 5Hannibalzero Level 5
Hannibalzero is offline Add to Hannibalzero's Reputation Report Post Reply With Quote Multi-Quote This Message Quick reply to this message
Hannibalzero
View Public Profile
Send a private message to Hannibalzero
Send email to Hannibalzero
Visit Hannibalzero's homepage!
Find More Posts by Hannibalzero
Add Hannibalzero to Your Buddy List
View Hannibalzero's vbGarage
View Hannibalzero's Photo Gallery
Unread Today, 09:13 AM #45 (permalink)
Hannibalzero
H to the izzO
Drives: Recklessly
Trader Rating: (50)
Hannibalzero
View Public Profile
Unread Today, 12:01 PM #46 (permalink)
S3KGT18
WVU fan @ MU
S3KGT18's Avatar
Drives: 94, 95 RT
S3KGT18 is an unknown quantity at this point
Send a message via AIM to S3KGT18
92 VR4-Black - sold
hey guys thanks for that info ill get the turbo ECU than. Fuel controller is either going to be Apexi AFC NEO
Old 04-27-2008, 10:49 PM   #49 (permalink)
3S-less
maTT's Avatar
Trader Rating: (19)
I'd highly recommend getting an older SAFC.
Old 04-27-2008, 11:19 PM   #50 (permalink)
92PearlTT's Avatar
Drives: 91 FWD TT,00 R6
92PearlTT Level 292PearlTT Level 292PearlTT Level 2
There is no reason not to run a turbo ecu. It will make your life easier cause it has a base to for turbos unlike the na ecu. No reason to risk running lean or rich if you don't have to.
92PearlTT is offline   Reply With Quote
