Old 10-08-2007, 07:24 AM   #21 (permalink)
H to the izzO
Hannibalzero's Avatar
Drives: Recklessly
Trader Rating: (55)
Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7
Default Re: ATX TT owners post up.
Originally Posted by S3KGT18 View Post
How's your traction with the SC?
Keep in mind, the Speed Freak LSD is going to help a lot. Expect more traction problems from a SCed car with stock drivetrain.
Old 10-09-2007, 08:55 AM   #22 (permalink)
Now a VR-4 driver
boardFreak5's Avatar
Drives: 94 VR-4, 93 fwdtt.
boardFreak5 is an unknown quantity at this point
i will sell my car and buy a vr4 before i switch to a 5speed in my car. I was just saying i would rather have a manual, but my car will be a lot nicer than a vr4 when its all said and done imo.
Gewalt evoII's
boardFreak5 is offline   Reply With Quote
Old 10-10-2007, 08:12 PM   #23 (permalink)
SICK's Avatar
Drives: 97 SL
SICK is an unknown quantity at this point
What I am looking to do is a 4-500HP FWD ATXTT, what have others done to combat the traction problems? I am thinking a mild turbo upgrade from stock, then spray when I need it in 3rd-4th gear would yield this effect without having to basically weld steel weights to the front of my car.
I want to be able to smoke other cars from a roll as well as on a track or from a stop (hence spray in higher gears, to catch up).
I have a 95 NA DOHC as a donor motor that I plan to rebuild as a TT motor then doing the swap.
Not exactly sure how much hp I can put to the FWD with out having traction problems, although I do know I can upgrade front end components to help with traction but when getting into 300-450 range it may be impossible.
Just throwing out my thoughts and dreams for my 97 SL
95 3000GT totaled on 8/17/07 | 97 3000GT SL purchased on 8/24/07
NGK Iridium Plugs
MSD 8.5mm Wires
3sx Test pipe
KN intake
3sx Downpipe
Gutted pre-cat
SICK is offline   Reply With Quote
Old 10-10-2007, 09:13 PM   #24 (permalink)
Forum user
ldcarson's Avatar
Drives: 98SOHC SDS/95VR-4
Trader Rating: (27)
ldcarson is an unknown quantity at this point
Traction, even with the LSD is tough. The LSD insert made a big difference, the SC is building boost off the line and can hole shot pretty damn quick. Keeping the wheeps from sping and hopping is another issue. When RAYP tuned it he said it was faster than a stock VR4, we wanted me to consider building up the engine and adding some more boost. The SC has potential, the problem is cost, right now its just cheaper to go TT. I would love to add a ripps kit to a VR4 engine and drivetrain just to see what kind of power we could make. The Vortech V5 is capable of 30 psi and there are some eclipses that are running it, but again cost is an issue right now, doing a TT conversion is just so much cheaper. But as kits go, the SC is a nice add on for a base model SOHC!
ldcarson is offline   Reply With Quote
Old 10-11-2007, 04:59 AM   #25 (permalink)
H to the izzO
Drives: Recklessly
Trader Rating: (55)
I'm sure IPO must have a bunch of threads regarding traction and the SL-TT. He was making a lot of power off of his twin Evo 16G knock-offs. The fat drag slicks in the front helped a lot - you may want to start off by picking out an excellent pair of drag radials.
Old 10-16-2007, 07:55 PM   #26 (permalink)
Paid Member
Jomojr's Avatar
Drives: 1993 TT ATX w/TT ECU
Jomojr Level 1Jomojr Level 1
Sorry I havent been on here in a while. I did "WITH A WHOLE LOT OF HELP" my conversion like two years ago and have put a little over 40k on it. Really with minor problems. I have chewed up one transmission, But I have tracked the car quite alot. My best time at the track so far was on the 9b's @16lbs. Ran the 1/4 in a 13.22. Havent really been to track since the DR650's went on. Having a wierd boosting issue. Was at the NG and stuck at 10.5 psi on the DR650's and ran a consistent 13.5 all day. lol
Once I get time to concentrate on the car more we will get things figured out, and she should fly. As far as the way the car drives...... erm im putting about----20k a year on it 8)
I have never regretted doing the conversion, and given the chance I will do it again.... on a Spyder
Performance:TT Conversion 10:1 DR650 Turbos
Stock VR4 Side mount intercoolers
Speedfreak Racing LSD & Urethane Motor Mounts
3" custom exhaust, 3SX Downpipe, Random Tech High Flow Cat, 22" Power Stick, Created by Tim Bradhams Chassis works
550 Injectors, ECU, FPR, MAS, Hotwired Walbro 255Fuel Pump
Lightweight's Alky Injection
Import Performance Modified Valve Body W/ Shift Kit
Import Performance Upgraded End Clutch Kit
DNP Polished Hard Y-Pipe
Turbo XS RFL BOV, SAFC2, scanmaster3, Manual Boost Controller
Open Element Air Filter
Rims : Kazera KZ-A 18x8.5
Tires : Fusion 245/40/18
Suspension : Intrax
Tunes:Infinity BassLink, Alpine SPS690A 6X9 upgrade for rears , Alpine SPS-170A 6.5" upgrade in the front
Engine Apperance:Polished Plenum "3SX" Aluminum Plug Cover "3SX" Valve Cover "3SX Stainless Dress up kit "3SX" Red Silicone Hoses "3SX" Red Wire Loom "3SX" Red Anodized Caps Water, PS, Brake, Oil
DIY Polished Parts: Throttle Body, Front Turbo, Alternator, Wastegate Actuators, Intercooler piping, Water Housing,
Misc Mods : Snake eyes mod, Chrome Mitsu emblem on front, Painted Calipers
99 Rear Center Garnish,
99 Sail Panels
1993 GT TTATX
Pimpin the TT-ECU and NA-TCU Baby!
Link to Pics Vids and Info
3SX FANBOY
Jomojr is offline   Reply With Quote
Old 10-22-2007, 10:03 AM   #27 (permalink)
S3KGT18's Avatar
Drives: 94, 95 RT
S3KGT18 is an unknown quantity at this point
Has anyone rode in both an atx and a mtx fwd tt? Is the traction actually better in the atx from the huge gears?
94 R/T Luxury ATX- Silver
95 R/T Sport ATX- White
91 R/T ATX- White - sold
92 VR4-Black - sold
S3KGT18 is offline   Reply With Quote
Old 10-22-2007, 10:46 AM   #28 (permalink)
bane of unintelligence
inperfectdarkness's Avatar
Drives: dreaming of a TT ecu
Trader Rating: (12)
inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7
i don't know how gearing would effect traction. that's a function of whp, tires, road conditions, and throttle--moreso than what ratio you're running in.
i would definately disregard those who say fwd can't hook up. 3sx's t2 would beg to differ.
if you're good with fiberglass...REALLY good...pm me. i have work for you.
ditto if you're an automotive painter in middle Georgia.
Originally Posted by beepbeep View Post
I got neg rep'd when I offered to give my hubby a bj. If THAT doesn't demonstrate the importance of the rep system, I don't know what does!
inperfectdarkness is online now   Reply With Quote
Old 10-22-2007, 11:59 AM   #29 (permalink)
Resident rocket scientist
BigTyla's Avatar
Drives: '93 3000GT ATX TT
Trader Rating: (178)
BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7
Jomojr, SLguy, BigTyla, anyone? Really curious as to how SLguy is coming along with his.
Ask and you shall receive.
I completed my TT conversion in late July. Since then I have put about 4000 miles on my car. Yes, that's 4000 miles in a little less than three months. So needless to say I have been driving the car a lot and it has given me NO issues in reliability (knock on wood).
I have a sizable oil leak coming from the front of my oil filter housing. I attempted to fix it last weekend but to no avail. I'll get it fixed during Thanksgiving or Christmas break.
I'm getting smoke under heavy vacuum after cruise, which I believe is due to oil being sucked into my intake. I have a makeshift oil catch can I will be putting on this week.
I'm also getting a lot of knock under any amount of boost. I believe it to be caused by spark blowout so I will also be re-gapping my plugs this week. Apparently the numbers the shop manual gives (.037-.043) will not work.
I'm running the TT ECU and it is awesome. No need to tune. I'm so glad I figured out how to make it work. It's so easy! There's no excuse for any ATX TT conversion to go without one now that I wrote the book on how to do it!
Traction is not an issue. You have to be careful of torque steer when hitting the gas in a turn, but that is to be expected with a high hp FWD car. No need to get crazy on the throttle at every stoplight.
Here are my mods:
TT conversion
Every stock part from a TT unless otherwise mentioned (including intercoolers, BOV, plenum, etc)
TT ECU
3sx crank pulley
3" testpipe
front mount oil cooler
sidemount transmission cooler
ksports
Might be forgetting some stuff, but that's the beef of it. Simple and effective.
1993 3000GT FWD ATX TT - daily<------------------->2009 Honda Fit - 40 mpg? Yes pls.
Ground wire GB is back!!!
Old 10-22-2007, 09:31 PM   #30 (permalink)
S3KGT18's Avatar
Drives: 94, 95 RT
Nice. Good luck with getting all of the little issues worked out. That's two down one to go...SLguy I'm really curious to see how SLguy feels about traction since he has e16g's. I think 475-500 fwhp would be a little scary.
