Old 05-04-2008, 05:38 PM   #301 (permalink)
Forum user
raven1231's Avatar
Drives: Singleturbo3k/Z31T
raven1231 Level 1raven1231 Level 1
Default Re: Any FWD TT's running 12 or lower in the 1/4
Originally Posted by maTT View Post
Why can't you hold boost? Have you checked for leaks? Have you tried to run wastegate pressure? What wastegate/spring do you have?
Its at wastegate pressure now and there are no leaks
Built and Tuned By RUSH6432,IPS motorsports and myself.
Currently 384whp@wategate 6.8psi
Weight=2890lbs
Tials are in Dyno pull on the way pushing for 10-13 on pump and 15-18 on meth or race fuel....hell maybe even run both and go for 19-22
raven1231 is offline   Reply With Quote
