Old 03-15-2008, 07:20 PM   #11 (permalink)
Forum user
raven1231's Avatar
Drives: Singleturbo3k/Z31T
raven1231 Level 1raven1231 Level 1
Default Re: Any FWD TT's running 12 or lower in the 1/4
Originally Posted by maTT View Post
you would have to cut a 1.6 or 1.7 60' to run a 12 with a 5 speed.
I predict jomojr will run 12's the next time he goes to the track with the ATX. He run a 13.2 with 9b's and a 2.1 60'. Now he has dr650's and we will throw on some DOT slicks.
oh and T2 has a traction bar on the back. It does help a lot but still does not provide anywhere near as much traction as an AWD car.
How much horsepower is he pushing?
Built and Tuned By RUSH6432,IPS motorsports and myself.
Currently 384whp@wategate 6.8psi
Weight=2890lbs
Tials are in Dyno pull on the way pushing for 10-13 on pump and 15-18 on meth or race fuel....hell maybe even run both and go for 19-22
raven1231 is offline   Reply With Quote
Old 03-16-2008, 07:46 AM   #12 (permalink)
Forum user
raven1231's Avatar
So do you think a 475whp FWD-TT weighing 2890lbs with an LSD and front/rear three point sway bars as well as coilovers and using Drag Radials could accomplish this?
Old 03-16-2008, 08:29 AM   #13 (permalink)
Damn It!
3startuna's Avatar
Drives: Without Traction
3startuna Level 73startuna Level 73startuna Level 73startuna Level 73startuna Level 73startuna Level 73startuna Level 73startuna Level 7
You should be able to run 11s on that setup. thats ALOT of power!
Our biggest enemy is weight transfer during the launch, And also the final drive ratio of the FWD gearbox is too high. Switching to the Getrag tranny will help us get traction.
All we need to do as FWD people is follow the honda crowd, slicks, gut the car, and run wheelie bars
The problem is too much 3s owners have false pride. They all want to say i did "X on street tires" and tey are afraid of being called a ricer, so they wont do whats necessary to get the results.
In my eyes its just plain retarded, you would do every power mod under the sun but wouldnt get slicks wow your such a genius
96 3000GT FWD TT -Rebuilt 2 bolt 8:1 block, balanced stock internals, valve job, 99 Lifters, Maximal Performance Motor mounts and valve cover!! Quaife LSD, ACT Max Extreme 6 puck, RPS flywheel, Greddy emanage Ultimate, custom fuel system i designed my self, profec B spec2, walbro 255lph, stock turbos, Braided steel upper and lower radiator hoses, KNN FPIK, FMIC, FM oil cooler, cusco Oil catch can, stillen DP, IPS 3" single, Full AC delete, stripped interior, Corbeau Forza 2 seat, 2 inch harness, ALL Greddy electronic gauges, brakes: 4 piston calipers from Yogurts TT, Hawk pads, Valvoline DOT 4, Russells steel lines
Coming soon:
Thats right 12G72TT
3startuna is offline   Reply With Quote
Old 03-16-2008, 08:31 AM   #14 (permalink)
3S-less
maTT's Avatar
Drives: 1990 Montero
Trader Rating: (19)
maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7
Jomojr put down about 230FWHP with the ATX and 9b's.
475 should get you deep into the 12's.
1992 VR4 - Sold
1991 SL - Sold
1993 RT/TT - Sold
1992 Stealth - Sold
maTT is offline   Reply With Quote
Old 03-16-2008, 08:34 AM   #15 (permalink)
Damn It!
3startuna's Avatar
So the result is a FWDTT goes to the track, cant hook till third, runs a 14.2 @ 112
Is pissed off goes spends another 1500 on turbo upgrades goes to the track again runs a 13.4 @ 120. Keeps doing this and when you suggest slicks their like "I dont want a race car" or "I cant afford slicks"
Old 03-16-2008, 01:38 PM   #16 (permalink)
Forum user
raven1231's Avatar
In a way it makes sense I meen to go to the track with the same tires you come off it with and I would like to have the same balls on and off the track but if DR's or slicks is what its going to take then its well worth it
Old 03-16-2008, 01:43 PM   #17 (permalink)
Forum user
raven1231's Avatar
So would the Getrag 6spd help that much?
Old 03-16-2008, 07:51 PM   #18 (permalink)
Damn It!
3startuna's Avatar
Yeah but think about it. Trap speed is what your car can do with its power and weight.
E/T is a function of traction and driving skills. In fact mainly traction. Like they say power is nothing without control, so why not buy good tires?
Old 03-16-2008, 08:15 PM   #19 (permalink)
Kibwe Walker's Avatar
Drives: 93 RT/tt
Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7
http://www.dsmtimes.org/times.php?He...ype=AWD&Page=1
http://www.dsmtimes.org/times.php?He...ype=FWD&Page=1
You know when ipo was hyping up building T2, I gave him these links to point out the obvious. This platform is NOT going to reinvent the wheel. There is nothing we can do in a 3s that has not already been done extensively in a DSM. What the DSM platform has proven years ago is that the FWD has NO advantage over a AWD car with the same setup.
By no, I mean zero, none, nothing. They don't trap any higher, the don't handle any better, they don't provide any better E.T's at the strip.
You know based on the method of mathematically winning races you may want to say that oh a car that weighs less with the same power has got to run faster right? It makes perfect sense, then you test said hypothesis against the data that you have and it doesn't compute.
You pick a turbo or setup on the DSM or 3s platform and guarunteed you will find that the AWD car with that setup TRAPS either the same or HIGHER despite the weight and the et is a second or more difference with the same setup.
Apply it to our platform and it still holds true.
http://www.3squicklist.com/
His - Red 93 RT/tt
Mods: Hallman's MBC @ 16 psi, turbo XS type H BOV, stillen dp, custom exhaust, Spec stage 2 clutch, RPS FW, 3sx lightweight crank pulley, BCP7RES-11 @ .030 gap, autometer gauges, slightly gutted mas, dsm SMIC's, ACPT 1 piece CFDS, Tein S springs, pte 580 inj's, safc neo/SITC, 13t's, hotwired walbro, maximal performance solid motor mounts, DR plenum spacer.
Hers - BPU Green 94 vr4
Kibwe Walker is offline   Reply With Quote
Old 03-16-2008, 08:21 PM   #20 (permalink)
bane of unintelligence
inperfectdarkness's Avatar
Drives: dreaming of a TT ecu
Trader Rating: (13)
inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7
and if it WASN'T true...vr4's would be losing to camaro's more frequently.
inperfectdarkness is offline   Reply With Quote
