#1 (permalink) |
Forum user
Hey are any of you FWD-TT converted guys running 12's or lower if so at what power levels and weight as well as supporting mods?
![]() Built and Tuned By RUSH6432,IPS motorsports and myself. Currently 384whp@wategate 6.8psi Weight=2890lbs Tials are in Dyno pull on the way pushing for 10-13 on pump and 15-18 on meth or race fuel....hell maybe even run both and go for 19-22 ![]() |
#3 (permalink) |
Woot!
That is basically it. Traction is the real problem. you should be able to slap on 9b or 13G and run 12s (of course with the supporting mods). FWD models are lighter than the AWD so you have the advantage there.
But you will want to run slicks or similar.
1995 Dodge Stealth R/T TT, Dark Green ext, Dark Int, 1 of 20 available to the US.
Mods: 13T turbos, FMIC 3" in/out, Spec Stage 3 clutch, RPS Billet Aluminum Flywheel, Gutted front and rear precat, test pipe, MSD 8.5mm SC Wires, 3rd Gen lifters, EGR Delete, 3SX EGR Block off plates, Blitz DD BOV, Hotwire Walbro 255 Fuel pump, Map ECU, Dual Pillar pod w/ AEM Wideband and AEM Tru Boost, Halo Hybrid Data logger, Supercar Engineering 1/2 billet aluminum Shift fork, fresh 1/2/3 friction rings, custom solid front and rear engine mounts, 3" Straight pipe exhaust single out. Looks: DCC Conversion, White face glow gauges. Sound: Infinity components up front, infinity 10" sub in back with Smokin' VR4 corner sub box, Pioneer HU. Myspace Must go faster project underway. Front E3 16G installed, next is the rear one! Equal length headers custom made. |
#4 (permalink) |
Damn It!
traction and tranny reliability are our biggest enemys.
We have the power, but the problems are that were too heavy and big to be FWD. the car has to spin off the line.
96 3000GT FWD TT -Rebuilt 2 bolt 8:1 block, balanced stock internals, valve job, 99 Lifters, Maximal Performance Motor mounts and valve cover!! Quaife LSD, ACT Max Extreme 6 puck, RPS flywheel, Greddy emanage Ultimate, custom fuel system i designed my self, profec B spec2, walbro 255lph, stock turbos, Braided steel upper and lower radiator hoses, KNN FPIK, FMIC, FM oil cooler, cusco Oil catch can, stillen DP, IPS 3" single, Full AC delete, stripped interior, Corbeau Forza 2 seat, 2 inch harness, ALL Greddy electronic gauges, brakes: 4 piston calipers from Yogurts TT, Hawk pads, Valvoline DOT 4, Russells steel lines
![]() Coming soon: Tranny number 3 ![]() Special thanks: IPS, Maximal Performance, 3SX, Evans Performance and all 3si and FL3s members that sold me parts |
#5 (permalink) |
Damage Control
Look at it like the DSM guys are. Take a GSX and a GST and put the same mods on them. The GSX will be a full second quicker because of traction. This is the same issue with FWD TT guys here. There are very few even in the 12's.
Kbizzle [11:25 P.M.]: this is most displeasing |
#8 (permalink) |
aka maharba
can someone else validate this? if with 9bs i could run 12's (with traction ofcourse)
![]() Wheels/brakes/Suspension: ---------------- exhaust: Hawk HPS Brake Pads -------------------fdf---2.5" test pipe R1 concepts cross drilled and slotted rotors-- 2.5" cat back (angled out) Megan Racing "Street Series" Coilover Kit ----Misc.: Adjustable control arms -------------------vb--Short throw shifter adjustable toe arms Soon to come: TT Conversion w/AEM UEGO, AEM Ttru-boost, APEXi AFC II, solid motormounts, Dattalogger (hand held halo), etc... |
#10 (permalink) |
Panda Master
you would have to cut a 1.6 or 1.7 60' to run a 12 with a 5 speed.
I predict jomojr will run 12's the next time he goes to the track with the ATX. He run a 13.2 with 9b's and a 2.1 60'. Now he has dr650's and we will throw on some DOT slicks. oh and T2 has a traction bar on the back. It does help a lot but still does not provide anywhere near as much traction as an AWD car.
![]() I no longer work for 3SX however I still strongly recommend them for your 3S parts and service needs! |
