#1 (permalink) |
Well I thought I had bought all the parts, but it turns out that I forgot the TT oil housing. Is there another way to get oil to the front turbo? The only thing that I could think of is tapping it into the front head (right under the vavle cover). Like with DSM's.
Or, not sure if this would work, somehow splitting the rear oil feed bolt to go into both turbo oil feed lines. It's kinda too late to buy the oil housing now. I need my car driving by Monday. Any ideas or suggestions are greatly appreciated.
1995 3000GT Base BPU+ (10:1 @ 10psi)
HKS, Apex-i, GReddy, AEM, K&N, Stillen, ACT, 3SX Performance, Maximal Performance, Ground Zero Performance. *500+ FWHP soon to be in the works* |
#2 (permalink) | |
H to the izzO
The oil housing costs around $30. Even with overnight shipping, that is going to be a cheaper option than custom SS lines from the rear joint. I suppose you can try running that in an emergency for a few days, but I don't think I'd permanently feed both turbos from the rear.
#3 (permalink) |
boosted
yeah feeding the turbos like that might end up starving one of them the oil they need under a good pull. just play it safe and get the oil housing
I <3 booost. 90gsx. 3inch turbo back magnaflow exhaust,K&N, shortshifter, stage 2 clutch, mbc at 16psi
