Old 05-11-2008, 09:34 AM   #41 (permalink)
J-Groove Level 7J-Groove Level 7J-Groove Level 7J-Groove Level 7J-Groove Level 7J-Groove Level 7J-Groove Level 7J-Groove Level 7
Default Re: abraham's tt conversion with lots of questions
I just read through your thread, how did I miss this before?
Great progress!
As for the pans and the oil pumps, the one they sent you is wider as it is set up for the 2nd gen style CAS. The narrower oil pump was for the 1st gen style that you can manually adjust.
Since you're using a 1st gen narrower oil pump you will be able to use a '91-'92 TT oil pan. That is pretty cool actually.
--3Si# 592--ROTM Dec. '07--www.IPSMotorsports.net--www.3SX.com
Old 05-11-2008, 09:44 AM   #42 (permalink)
cyber bully
Trader Rating: (6)
green-lantern Level 3green-lantern Level 3green-lantern Level 3green-lantern Level 3
did you get the oil and water lines figured out?
Old 05-11-2008, 09:50 AM   #43 (permalink)
cyber bully
Trader Rating: (6)
Originally Posted by Abraham View Post
Go here
the TT conversion link thread
There is everything you need to know if you are doing a tt conversion.
WOW that's a cool thread I should +rep that guy LOL
Old 05-11-2008, 10:24 AM   #44 (permalink)
Paid Member
Jomojr's Avatar
Drives: 1993 TT ATX w/TT ECU
Jomojr is an unknown quantity at this point
Dont know how I missed this thread either. Good luck on the rpoject, I hope you get her up and running soon.
1993 GT TTATX
Pimpin the TT-ECU and NA-TCU Baby!
Link to Pics Vids and Info
3SX FANBOY
Jomojr is offline   Reply With Quote
Old Yesterday, 06:50 PM   #45 (permalink)
aka maharba
Abraham's Avatar
Drives: 92 SL
Trader Rating: (13)
Abraham is an unknown quantity at this point
Sorry for the lack of updates on this but I was looking for the adapter that ther oil sending unit uses for the rear oil feed line. But I have fount out that I already have one. If you look at the pics that I posted at the start of the thread you will see a big white package next to my engine stand. That is a spare block that I ended up with and on it there is one adapter so now I'm not behind.
I know I keep saying that this weekend I will try to do most of it but seriously this weekend I'm going to do most of it. So stay tuned.
And I will also be parting out a 93 3000gt base automatic with 130k mi (green) I will post pics later.
I wanted to tell you guys first incase you need something let me know.
Wheels/brakes/Suspension: ---------------- exhaust:
Hawk HPS Brake Pads
-------------------fdf---2.5" test pipe
R1 concepts cross drilled and slotted rotors
-- 2.5" cat back (angled out)
Megan Racing "Street Series" Coilover Kit ----Misc.:
Adjustable control arms -------------------vb--Short throw shifter
adjustable toe arms
Soon to come:
TT Conversion w/AEM UEGO, AEM Ttru-boost, APEXi AFC II, solid motormounts, Dattalogger (hand held halo), etc...
Abraham is offline   Reply With Quote
