Old 04-23-2008, 04:40 AM   #31 (permalink)
cyber bully
Trader Rating: (6)
green-lantern Level 3green-lantern Level 3green-lantern Level 3green-lantern Level 3
Default Re: abraham's tt conversion with lots of questions
Originally Posted by Abraham View Post
i dont know but the shop told me that in 1992 the n/a oil pump had a split in the middle of the year so they had 2 different oil pump, and the tt had 3 different pumps that year. so basically what they told me is that i got a 20% chance of getting the pump that i needed. and i DIDNT. so they will ship another one tomorrow.
hell you may be able to use the TT oil pan now.
Old 04-23-2008, 01:32 PM   #32 (permalink)
aka maharba
Abraham's Avatar
Drives: 92 SL
Trader Rating: (13)
Abraham is an unknown quantity at this point
i couldnt because i have 2 tt oil pans and both of the are just like my n/a one that i have now. so i decided to get another oil pump that would actually fit instead of hunting another oil pan. because right now i have 2 tt and 2 n/a oil pans including the one that is in the car at the moment.
Wheels/brakes/Suspension: ---------------- exhaust:
Hawk HPS Brake Pads
-------------------fdf---2.5" test pipe
R1 concepts cross drilled and slotted rotors
-- 2.5" cat back (angled out)
Megan Racing "Street Series" Coilover Kit ----Misc.:
Adjustable control arms -------------------vb--Short throw shifter
adjustable toe arms
Soon to come:
TT Conversion w/AEM UEGO, AEM Ttru-boost, APEXi AFC II, solid motormounts, Dattalogger (hand held halo), etc...
Abraham is offline   Reply With Quote
Old 04-23-2008, 08:43 PM   #33 (permalink)
aka maharba
Abraham's Avatar
Drives: 92 SL
Trader Rating: (13)
V sub frame half way cleaned
V misc picture with the turbos mounted
V weird looking misc picture. with turbo mounted
V front of engine with oil pump missing and pan hanging because i left the plate on that goes between the block and trans.
V 2 intame manifolds 3 oil pans and a oil cooler.
maximal motor mounts
hand held halo. (can someone help me figure it out i cant get it to work with my pc)
Old 04-23-2008, 09:04 PM   #34 (permalink)
aka maharba
Abraham's Avatar
Drives: 92 SL
Trader Rating: (13)
V new clutch
V brake lines
V dsm bov with adapter, grounding wires, walbro fuel pump,
V s-afc II, aem wideband and tru boost gauge
V all of the stuff that i got from the dealer
V here you can see 2 of my half shafts as you can see the one on the jack is is missing a piece because the keeper ring held the other piece on the trans. (and also my back seats)
V look at what is still in the trans.(the other peace of the passanger half shaft)
Old 04-23-2008, 09:06 PM   #35 (permalink)
92PearlTT's Avatar
Drives: 91 RT,00 Focus,00 R6
92PearlTT is an unknown quantity at this point
Nice, lots of new stuff is always fun.
92PearlTT is offline   Reply With Quote
Old 04-23-2008, 10:08 PM   #36 (permalink)
3.S.I's Certified Asshole
bstewart87's Avatar
Drives: 92 Stealth
Trader Rating: (12)
bstewart87 Negative 2
Can you post up a list of those gaskets and misc parts? It would help me and others out in the future.
bstewart87 is offline   Reply With Quote
Old 04-24-2008, 06:51 AM   #37 (permalink)
aka maharba
Abraham's Avatar
Drives: 92 SL
Trader Rating: (13)
Go here
the TT conversion link thread
There is everything you need to know if you are doing a tt conversion.
Old 04-24-2008, 07:35 PM   #38 (permalink)
aka maharba
Abraham's Avatar
Drives: 92 SL
Trader Rating: (13)
Quick question:
What is the color of the power and ground wires that go to the injectors?
Because I want to wire the resistors in since I'm using the n/a harness.
Old 05-01-2008, 09:34 PM   #39 (permalink)
bstewart87's Avatar
Drives: 92 Stealth
Trader Rating: (12)
**Cough** UPDATE **Cough**
Old 05-02-2008, 08:47 PM   #40 (permalink)
aka maharba
Abraham's Avatar
Drives: 92 SL
Trader Rating: (13)
no actual pics at the moment but so far the shop told me that the oil pump will be here tomorrow so that is all i need to put most of the stuff together and i also removed the ecu and hopefully this weekend try to finish all of the wiring. the thing that i need to wire right now is a wideband, bosst gauge/controller, apex safc II, oil pressure gauge, and a datta logger. and the resistors also.
later down the road i will also install a emanage blue.
and some other big news i got another 3000gt is a 93 base model automatic and will post pics of it later in the week.
