Old 05-11-2008, 09:34 AM   #41 (permalink)
J-Groove Level 7J-Groove Level 7J-Groove Level 7J-Groove Level 7J-Groove Level 7J-Groove Level 7J-Groove Level 7J-Groove Level 7J-Groove Level 7J-Groove Level 7
Default Re: abraham's tt conversion with lots of questions
I just read through your thread, how did I miss this before?
Great progress!
As for the pans and the oil pumps, the one they sent you is wider as it is set up for the 2nd gen style CAS. The narrower oil pump was for the 1st gen style that you can manually adjust.
Since you're using a 1st gen narrower oil pump you will be able to use a '91-'92 TT oil pan. That is pretty cool actually.
Old 05-11-2008, 09:44 AM   #42 (permalink)
cyber bully
Trader Rating: (10)
green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7
did you get the oil and water lines figured out?
Old 05-11-2008, 09:50 AM   #43 (permalink)
cyber bully
Trader Rating: (10)
Originally Posted by Abraham View Post
Go here
the TT conversion link thread
There is everything you need to know if you are doing a tt conversion.
WOW that's a cool thread I should +rep that guy LOL
Old 05-11-2008, 10:24 AM   #44 (permalink)
Paid Member
Jomojr's Avatar
Drives: 1993 TT ATX w/TT ECU
Jomojr is an unknown quantity at this point
Dont know how I missed this thread either. Good luck on the rpoject, I hope you get her up and running soon.
1993 GT TTATX
Pimpin the TT-ECU and NA-TCU Baby!
Link to Pics Vids and Info
3SX FANBOY
Jomojr is offline   Reply With Quote
Old 05-14-2008, 06:50 PM   #45 (permalink)
aka maharba
Abraham's Avatar
Drives: 92 SL
Trader Rating: (14)
Abraham Level 1Abraham Level 1
Sorry for the lack of updates on this but I was looking for the adapter that ther oil sending unit uses for the rear oil feed line. But I have fount out that I already have one. If you look at the pics that I posted at the start of the thread you will see a big white package next to my engine stand. That is a spare block that I ended up with and on it there is one adapter so now I'm not behind.
I know I keep saying that this weekend I will try to do most of it but seriously this weekend I'm going to do most of it. So stay tuned.
And I will also be parting out a 93 3000gt base automatic with 130k mi (green) I will post pics later.
I wanted to tell you guys first incase you need something let me know.
Wheels/brakes/Suspension: ---------------- exhaust:
Hawk HPS Brake Pads
-------------------fdf---2.5" test pipe
R1 concepts cross drilled and slotted rotors
-- 2.5" cat back (angled out)
Megan Racing "Street Series" Coilover Kit ----Misc.:
Adjustable control arms -------------------vb--Short throw shifter
adjustable toe arms
Soon to come:
TT Conversion w/AEM UEGO, AEM Ttru-boost, APEXi AFC II, solid motormounts, Dattalogger (hand held halo), etc...
Abraham is offline   Reply With Quote
Old 05-23-2008, 08:09 PM   #46 (permalink)
aka maharba
Abraham's Avatar
Drives: 92 SL
Trader Rating: (14)
updates by monday. i promise
but i wanted to know if you guys could help me out. i want to see if any one knows how much could my car put out at 14psi? i will be running higher octane and 450cc injectors with some other stuff.
Old 05-23-2008, 08:50 PM   #47 (permalink)
Forum user
3000hybrid's Avatar
Drives: 93 VR4, 97GT FWDTT
Trader Rating: (48)
3000hybrid is an unknown quantity at this point
Alot ...
VR4-"FOR OFF ROAD USE ONLY"
97 FWDTT
Mods
SOHC to 3.1L TT swap, ATX to 5-SPEED GETRAG, TE04H DR-19T's,Wiseco Forged Pistons, Custom FMIC, RPS MAX Street clutch,Tial BOV, Walbro 255,Custom Magnaflow 3'' exhaust,ATR DP,Custom FMIC,ATR DP,Catless, 3SX crank pulley, Emanage/E01, Derale fan controller, PTE 550 inj, AEM UEGO wideband, Re-located Optima Red Top,Krank Vents, EGR Blockoffs, MMCD logger, Stillen pads, drilled rotors, EibachPro springs, 3SX intake, intake hard pipes, IPO SX AFPR, 99 lifters,99 rear garnish, Racing Hart MP3 wheels,Snow Stg 2D Meth injection/Safe inj, http://www.hesspower.com/racecar.html
3000hybrid is offline   Reply With Quote
Old 05-23-2008, 09:04 PM   #48 (permalink)
aka maharba
Abraham's Avatar
Drives: 92 SL
Trader Rating: (14)
Do you know at what psi 9bs are efficient to?
And also remember that my compression is 10.5:1 thanks to carbon build up.
Old 05-26-2008, 12:02 PM   #49 (permalink)
aka maharba
Abraham's Avatar
Drives: 92 SL
Trader Rating: (14)
more question.
1.can i follow this diagram to wire in my afc to my n/a harness?
2.and on the air flow out connection (pink wire) from the afc harness do i have to cut it from going to the ecu like the diagram shows and just into the afc?
3.and do i leave the orange wire with out being connected to anything?
4.and there is also a yellow, white and blue wires that are left from the afc harness, what do i do with them?
Old 05-26-2008, 02:05 PM   #50 (permalink)
aka maharba
Abraham's Avatar
Drives: 92 SL
Trader Rating: (14)
And I also need to know where I could find a B+ wire that passes thru a 10 amp fuse so I can wire in my truboost and wideband.
edit: or can i just tap into the ignition (source voltage) and place a fusable link for each?
