#1 (permalink) |
Well I have been working on this for a while now, its been going slow cause I can only work on it during the weekends due to college. I was originally gonna do just a 10:1 conversion but I started having oil pressure issues so I figured I might as well tear it down and do it right the first time.
So I started the disassembly process and when I got down to the bearings sure enough 2 of them were worn down to the copper. Also I found out the my crank had a gouge in it so I had to replace that. I also ordered some CP pistons. I was going to use stock rods, but I was a little nervous about the quality of the rods I had. So I looked into getting a new stock set but I got some Pauter rods instead for cheaper. I then got the block bored out and all prepped. I also brought everything in and had it balanced. Here are some before and after pictures of the block. Before: ![]() After: ![]() ![]() I got my intercoolers mounted, cutting the hole for the driver side turned out the be a pain cause I didn't have the correct tools. Also the jackass I bought the intercoolers from sent me a intercooler full of what looks to be bird food. So I have to see if I can get everything flushed out otherwise I am gonna have to buy some new ones. I am also stripping as much stuff out of the engine bay while the engine is out. So far I have gotten rid of ac and components, cruise control, abs delete, vac reduction. I went to the dodge dealership to get brake lines and the prop valve. The idiot who worked there was getting mad at me because he couldn't figure out which numbers were for the correct lines. Then he told me to come look at the computer and pick them out my self and it wasn't my their fault if I ordered the wrong parts . So I kindly told him that I wasn't going to do his job for him and left. So now I am stuck with no brake lines. I think its looks much better with all of that stuff out of there. Still pretty dirty, I need to clean it and do some paint touch up.![]() Here is how it sits now. My torque wrench broke when I was torquing down one of the heads, so now I have to see if I can find one tomorrow. ![]() ![]() ![]() ![]() Here are a few of the mods I will also be putting on in the process. I just want to get it up and running before winter so I can put a few miles on it. Then this winter I would like to either put 13t's or 14b's on and I will also be doing front mount (money permitting of course). I also have a few mods sitting around in the garage that I will probably throw in also. Then eventually the nitrous once everything is running well again. ![]() I still need to get a few more parts, before I can put the engine in and start it up. Anybody have: a first gen rear pre cat, 1st gen tt oil pan, good condition knock sensor let me know. I hope to have it done by the end of the month. Well thats all I have for today more updates to come. Vince Last edited by 92PearlTT : 10-13-2008 at 01:14 PM. |
#2 (permalink) |
Here for the tuna.
Vince - Looks like an awesome project. Glad to see you're not half-assing it like it's so temping to do (and I am guilty of with my own car). Should kick ass and take names when it's all back together! Boy is that shorty pretty!
--Ryan
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts ![]() |
#4 (permalink) | |
having it my way
now go back there to the sales man thats only good at giving "Clap" out to people, and ask for these overnight for your incovince. btw your car is looking great.
been screwed around with to long -Jimmy ![]() |
#5 (permalink) | |
#6 (permalink) |
having it my way
they are all that way.
no did you open the link? Your lazy if you didn't. Its just the part numbers for the lines you need, and the portion valve. please open link its just a single post of info. Be luck I did this, <----------i have no fear of red ![]() |
#8 (permalink) |
Great work lol found the same thing when I got to my crank... was fixin to spin a bearing! Thank god I went for the 8:1 or I'da never seen it and I'da been, to say the least, very pissed.
But the bay looks great! I would do the A/C delete but, FL summers are a bitch! |
#10 (permalink) | |
