Old 03-18-2008, 09:11 PM   #1 (permalink)
3KGT509's Avatar
Drives: 1992 VR-4
3KGT509 is an unknown quantity at this point
Default 91 vr4 tt engine into a 93 base
How easy is this since it's a 1stgen engine swap? will the TT ecu need to be switched over to the base? Will wiring be affected with the fan controls?
3KGT509 is offline   Reply With Quote
Old 03-19-2008, 05:11 AM   #3 (permalink)
Corn Its whats for boost
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (210)
Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7
Default Re: 91 vr4 tt engine into a 93 base
since you are already a DOHC it isn't that hard. (you have a base 3K right?)
The main changes are resistors on the ground wires of each injector.
Hole cut for IC pipe on driver's side.
Install an SAFC2 and TT fuel pump.
That's about it for the hard stuff.
You can use your stock harness and ECU.
You can change out the ECU for a TT ECU, then you don't need the SAFC and you will gain power from better In Boost mapping.
AEM Factory Trained Tuner
91VR4-3.0L-Stock heads and Cams-762AWHP 747AWTQ 30psi E100 Daily Driver 10.63@121mph
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
91VR4 Red-17Gs w/supporting mods-sold
93SLTT/T2
91VR4 Pearl White-sold
91VR4 Black-sold
92VR4 Sandstone-sold
94VR4 Green-sold
93VR4 Pearl White-sold
NG09 Title Sponsor
3SX Performance
3SX Performance Service Email
Old 03-22-2008, 08:55 PM   #4 (permalink)
92rt99ta is an unknown quantity at this point
Originally Posted by WhiskeyIsQuick View Post
damn man y dont people searchhhhhh
everything will drop in, if u swap harnesses then no problem, if u use base harness, then u gotta do some mods, search it!
In defense of people that don't/didn't search on this forum, I will somewhat politely say that the "search" feature on this forum SUCKS! I searched "new twin turbo motor" earlier here today , and unlike Google, Yahoo, or any other somewhat reliable search engine, I got 95+ pages of threads that had every instance of the word "new", "twin", "turbo", and "motor" contained in the thread, which is almost completely worthless.
I mean really people, this forum is for discussion (so I thought). This car has been gone, out of production for almost 10 years. There is little new to discover anymore. So obviously most of the questions asked are going to seem and be repetitive. Be patient.
Weekend Car: 2004 Corvette Commemorative Editon - 14k miles. 6-speed, Factory Polished Wheels, all stock.
2nd Weekend Car: 1999 Trans Am - 54k miles.
A4, Borla Cat-Back, K&N Filter, Whisper Lid, Firehawk Rims, otherwise all stock.
296 hp/312 lbs. torque AT THE WHEELS.
Daily Driver: 1992 Stealth R/T - 54k miles.
5-speed, 18 inch VR-4 chromies, K&N, Stillen Rotors, Brake Pads, 3SX Stainless Steel Lines, Viper Alarm, Alpine CD.
92rt99ta is offline   Reply With Quote
