Closed Thread
Old 05-30-2005, 10:52 AM   #1 (permalink)
Verified
jackhammer's Avatar
Drives: RC46
Trader Rating: (60)
jackhammer Level 1jackhammer Level 1jackhammer Level 1
Default 1g harness in a 2g body
I have recieved many emails asking how i wired up the 91tt ecu/harness to a 94 NA car, as well as seeing posts on a regular basis on the same subject. Heres how i did it.
as Posted on US3S sept 04. I have to find some time to get the pics back online.........Keep in mind this was a 91tt harness/ecu in a 94 RT base
The following items need to be re-wired..........
1. Reverse switch wires
2. Front O2 sensor
3. Radiator fan control circuit
4. OBD diagnostic port
1. Reverse switch
On all 3s's the reverse switch is shared with the control harness, on the 91-93 cars, these wires are tied into connector C-29, pins 10 & 11 (black/white & red/blue wires) inside the car next to the blower motor. On the 94+ cars, these wires are tied into connector C-30, pins 2 & 3 (same wire colors) also next to the blower motor assembly. You need to splice these 4 wires (2 pairs) together. The wire colors are the same so it should be pretty straight forward.
2. Front o2 sensor
The front o2 sensor on 1g tt cars is wired to the control harness, through the body harness. It uses pins 1,2,7,8,10 of connector A-67 located at the underhood relay box near the air filter. The NA cars have the sensor connector already as part of the body harness, it's tucked away and taped to the harness that goes to the alternator and A/C compressor. Unfortunatly these wires travel PAST connector A-67 and continue into the fender near the abs pump. Since there was not enough slack to cut these wires and insert them into A-67, i chose to run a new custom built harness from the sensor connector to connector A-67. I got a 5 pin wether pack connector with contacts from NAPA and made a new connection near A-67. I cut the wires from the 5 pins (1,2,7,8,10) on the control harness side and used those 5 wires for my new NAPA harness so now there are 2 connectors near the relay box (i call the new connedtor "A-67b") I used 2 cables, first one was 18ga/2 cond. for the heater/ground, and 22ga/2 conductor with shield for the signal wire (i grounded the shield, and used the 2 main conductors for the signal) Heres a picture of this new connection.........
3. Radiator fans
On the 1g cars, the fans are controlled by 2 switches mounted in the radiator, on 2g cars they are controlled through the ecu. This is how i wired them without modification to the fan harnesses, and keeping the 2g fans with a 1g tt radiator.......Take the black wire from each switch, tie them together, and attach a grounding lug to them. Next take the other wire from each switch and run them into the passenger compartment to connector C-29 near the blower motor. tie these wires into pins 3 & 11 of C-29 (pin 3 high, pin 11 low). Heres a couple pictures of how i did it. I chose to use another weather pack connector from NAPA so the connection can be unplugged to remove the radiator without cutting any wires.
4. OBD port
This is pretty simple. Insert paper clips into the following positions (or wire up a 1g port)
- Signal/data + = Pin 7 of OBDII connector
- Signal/data - = Pin 1 of OBDII connector
- Ground = pin 4 of OBDII connector
That should pretty much cover it.
jackhammer is offline
Old 05-30-2005, 11:24 AM   #2 (permalink)
Verified
jackhammer's Avatar
Drives: RC46
Trader Rating: (60)
Default Re: 1g harness in a 2g body
This should be a sticky too.
I don't want to have to dig up this thread everytime someone has a 1g-2g question, which seems to happen on a regular basis
Old 05-30-2005, 02:46 PM   #3 (permalink)
MilkyClr69's Avatar
Trader Rating: (13)
MilkyClr69 is an unknown quantity at this point
Thanks,
so i'm guessing these would all need done if using a 92 vr4 ecu/harness on a 96 sl, right?
96 SL
MagnaFlow Catback, K&N Intake, 18 x 8 ADR Sterling, 245 40 18 Ecsta Supra, Limo/15% window tint, Cross-drilled and slotted rotors, 12" sealed IDMAX w/ 1000 Watt Hifonics amp. Infinity & JBL speakers powered by Hinfonics amp, Alpine 7893.
TT engine/tranny swap
Fixing a few problems and she'll be back on the road!
MilkyClr69 is offline
Old 05-30-2005, 02:49 PM   #4 (permalink)
Verified
jackhammer's Avatar
Drives: RC46
Trader Rating: (60)
the post above refers to a 94.
The circuits/controls are the same but the wire colors may differ for 95+
Old 06-01-2005, 11:05 AM   #5 (permalink)
TPW Educator
LVA3KGT's Avatar
Drives: with EDFC at 0/0
LVA3KGT Level 3LVA3KGT Level 3LVA3KGT Level 3LVA3KGT Level 3LVA3KGT Level 3LVA3KGT Level 3LVA3KGT Level 3
Awesome post.
I have a 97 SL with a 91 TT ECU. I've been wondering about the OBDII-I situation. I'll check the wires and see if it works for me.....
97 SLtt- What is this traction you speak of?
410 Ft/lbs of torque-steer and 390HP to the front wheels, making 1-3 gear useless @17psi. Built and tuned by 3SX
(Firebird) = Best 60ft 2.4 Best ET 13.8 , best trap 110.8MPH , picked up almost 30mph on the big end of the track.
3SI member # 5422
Originally Posted by inperfectdarkness View Post
Even the ford pinto had SOME satisfied owners....
LVA3KGT is offline
Old 06-01-2005, 07:14 PM   #6 (permalink)
NG09 Associate Sponsor
Venom13132's Avatar
Drives: Small Car Big Engine
Trader Rating: (109)
Venom13132 Level 1Venom13132 Level 1
so what if on the front o2 sensor all i have is the wire coming off the o2 sensor. I dont have any kind of wire harness running to it. how do i hook that up?
Venom13132 is offline
Old 06-01-2005, 07:46 PM   #7 (permalink)
Verified
jackhammer's Avatar
Drives: RC46
Trader Rating: (60)
It's there, but it tucked away and taped to the main harness near the ac compressor.
I found it, cut it off, and extended it as described in post #1
Old 06-02-2005, 06:50 PM   #8 (permalink)
Head of Society of Bob
Drives: 1993 Stealth R/T AWD
Trader Rating: (11)
Bob The Great is an unknown quantity at this point
agreed. also, I locked it to avoid it getting cluttered.
Bob The Great has spoken.....
1993 Dodge Stealth R/T Turbo
Currently In Hibernation...
238awhp 265awtq (old dyno on 9b's @ 10psi)
Click to go to my website
Twin Turbo Conversion
All Wheel Drive Conversion All Wheel Steering Conversion
Factory Options
One of 482
Black Leather Interior
Removable Moonroof
5spd Manual
Modifications
3SX Light Crank Pulley
Cold Air Wall and Cone Filter
Snake Eyes
Fidanza Aluminum Flywheel
SBC DXD Clutch
DN Precat Eliminators
ESP Downpipe
Test Pipe
DSM SMIC's
450cc Black Top Injectors
TD04-9B/13G combo @ 10psi on 10:1 CR
Bob The Great is offline
Old 01-17-2007, 09:02 PM   #9 (permalink)
Verified
jackhammer's Avatar
Drives: RC46
Trader Rating: (60)
Default Pictures for above sticky thread
Here they are, since the thread has X's
They are named appropiate to the step in the thread.
Mods and admins feel free to sticky this or edit the other thread
Old 01-17-2007, 09:04 PM   #10 (permalink)
Verified
jackhammer's Avatar
Drives: RC46
Trader Rating: (60)
Default Re: Pictures for above sticky thread
Here are the other 2
Closed Thread
