Old 04-21-2008, 10:01 AM   #21 (permalink)
15t's ... ? yep
DigiiManDan3KGT's Avatar
Drives: 80Gig WesternDigital
Trader Rating: (7)
DigiiManDan3KGT Level 2DigiiManDan3KGT Level 2DigiiManDan3KGT Level 2
Default Re: 13.9 at 103mph, fwd-tt 10:1, 6 psi, no tune
your crazy to not be running an upgraded fuel pump. Make sure its hotwired. The car has a way to go before you work out all the kinks. Your on your way though.
Green 1995 3000GT FWD-TT 8:1 // 15t Turbos // ATX to MTX // NA to TT // Purchased 11/12/02
White 1999 3000GT Black Dash/Tan Leather Interior // SOHC // MTX // Stock Daily Driver Purchased 7/25/07
Red.._1992 Stealth RT/TT Twin Turbo AWD // Organ Donor // Purchased 05/19/08
<-- Click Here Join FL3S
DigiiManDan3KGT is offline   Reply With Quote
Old 04-21-2008, 01:03 PM   #22 (permalink)
Resident rocket scientist
BigTyla's Avatar
Drives: '93 3000GT ATX TT
Trader Rating: (179)
BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7
Did you experience similar problems with your car at 6 psi and a stock fuel pump? Inquiring minds want to know.
1993 3000GT FWD ATX TT - mods coming<---------------->2009 Honda Fit - 40 mpg ftw
Nov/Dec ground wire GB!!!
Old 04-21-2008, 01:10 PM   #23 (permalink)
Wanna be Z06
Fbc 978's Avatar
Drives: 19T VR4
Trader Rating: (20)
Fbc 978 Level 4Fbc 978 Level 4Fbc 978 Level 4Fbc 978 Level 4Fbc 978 Level 4
I will get a walbro soon...my IAT's are like 107* at low rpms cruising...and like 100* on the gas hard...is that bad? Maybe high intake temps are causing more knock? i am using side mounts
19T Pump 1/4 Mile-12.8 @ 111 booooost leeaaakkk
Fbc 978 is offline   Reply With Quote
Old 04-21-2008, 04:33 PM   #24 (permalink)
15t's ... ? yep
Trader Rating: (7)
Im a 8:1 direct swap. I did the swap at the same time as the fuel pump. I have 2 best friends that also own FWDTT's Chas-k and Shooter83 were all 8:1 swap and we all upgraded our pumps when we did our swaps.
Stock sidemounts are good till 400hp. It wouldnt be on my list of possible problems thats for sure.
Not guna lie your track times are right where they need to be for what you have set up. You just need to get rid of the Knock. First things you need to do is get fuel control & a fuel pump. Dont waste time getting these items since your a 10:1 swap you cant trust the Stock TT ecu, its programed for a 8:1 motor.
Old 04-21-2008, 04:58 PM   #25 (permalink)
BigTyla's Avatar
I should have clarified - I meant stock TT pump. That's what I upgraded to and I still have knock at WOT and my trims are all maxed at 139%. I'm assuming you mean you made a direct upgrade to a Walbro and bypassed the stock TT pump.
Old 04-22-2008, 08:42 AM   #26 (permalink)
15t's ... ? yep
Trader Rating: (7)
I can't promise you that it will get rid of your knock, we all run Walbro's and its a replacment for the stock fuel pump not really a bypass. ( fyi just incase u didnt realize).
Me and my friends have no worry about fuel pressure unless its a kinked fuel line or a collapsed fuel filter. etc etc.. I honestly would replace the stock TT/VR4 Fuel pump with a Supra pump(Quieter) or Walbro (Loud ass bastard) Both rated at the same flow levels. Its been highly recommended in the past and it still remains that way. I wouldnt waste another dollar it would be the next thing i do. That and for the OP some type of fuel control. SAFC2's are like 100$ on ebay now.
Bigtyla what type of fuel control are you using?
Old 04-22-2008, 11:47 AM   #27 (permalink)
BigTyla's Avatar
Seems I keep using the wrong terms to mislead you. I meant replacement, not a "bypass." I was always worried that going with a bigger pump would give me too much fuel, as the other conversions I have seen have used the stock TT pump with great results. I seemed to be the exception until recently with this post.
Right now I am simply using a stock TT ECU for the same reason as above. I've seen quite a few people use it without fuel control and they have not had problems with knock. So I've been avoiding fuel control, thinking that there must be something wrong with one or more of the facets of my conversion (ie leaking fuel pump, lack of fuel pressure, etc). However, you're steadily convincing me otherwise. A fuel controller may just be the next thing on my list.
Old 04-22-2008, 12:14 PM   #28 (permalink)
cyber bully
green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7
You would think that a stock TT fuel pump would be fine with stock injectors and pressure but I am getting some knock also.
Originally Posted by crazycracka928 View Post
^ lol "be the bigger man, poop on his hood"
Old 04-22-2008, 05:10 PM   #29 (permalink)
Spins all 4
Trader Rating: (15)
rush6432 Level 7rush6432 Level 7rush6432 Level 7rush6432 Level 7rush6432 Level 7rush6432 Level 7rush6432 Level 7rush6432 Level 7rush6432 Level 7rush6432 Level 7
its all in the timing
your running boost plus high compression and the ecu is mapped for an 8:1 motor with boost. obviously the timing curves will be completely diffrent for both applications but for low boost (6-10psi) you should be ok as the knock sensor is doing its job. i honestly wouldn't worry if you see 3-4 counts and it tappers off. Your going to see knock in 5th gear as your putting the motor under a nice load at somewhat low rpms....... if i recall the stock tt ecu doesn't actually pull timing till about 5-6 counts or so (although ive heard 8 as well)
The ecu will advance until it sees knock then pull timing it repeats this process over and over unless its just REAL bad knock, then it will just yank all your timing.
As far as the stock fuel pump, your jsut running on barrowed time.... replace it. I ran 12 psi on a t67 in a 4g63 in my dodge colt on a STOCK 1.5 fuel pump for 2-3 pulls.....wasn't knocking, but honestly if your running your fuel system on the ragged edge its just a recipe for a blown motor.
rush6432 is offline   Reply With Quote
Old 04-22-2008, 05:12 PM   #30 (permalink)
Formerlly Ps933kgt
Vital Velocity's Avatar
Drives: 93 Vr4 / Blown Viper
Trader Rating: (18)
Vital Velocity Level 3Vital Velocity Level 3Vital Velocity Level 3Vital Velocity Level 3
Jeff?
I thought you got booted from the site and moved to arizona?
2002 Viper GTS- Intake and Exhaust Work
Vital Velocity is offline   Reply With Quote
