Old 04-20-2008, 12:35 PM   #11 (permalink)
Forum user
raven1231's Avatar
Drives: Singleturbo3k/Z31T
raven1231 Level 1raven1231 Level 1
Default Re: 13.9 at 103mph, fwd-tt 10:1, 6 psi, no tune
Originally Posted by Fbc 978 View Post
Thanks guys...I was almost thinking about selling the car after driving it in the rain...i hate traction issues but I am going to keep it. I am getting around 6 counts in 4th and 5th gear sometimes...1 time I saw 11 counts after a backfire...when driving normally or driving hard in 1st and 2nd...I get at most 2 counts usually none. It doesnt always knock but it does worry me. I am selling things in parts for sale so that i can get a safc II this week. I really hope to get to low 13's at 10 psi...then it would be a rocket ship
Not exactly lol, but good run
Built and Tuned By RUSH6432,IPS motorsports and myself.
Currently 384whp@wategate 6.8psi
Weight=2890lbs
Tials are in Dyno pull on the way pushing for 10-13 on pump and 15-18 on meth or race fuel....hell maybe even run both and go for 19-22
raven1231 is offline   Reply With Quote
Old 04-20-2008, 01:36 PM   #12 (permalink)
Drives: 92 RT-TT
Trader Rating: (43)
markoverclock is an unknown quantity at this point
you might be getting heat soak. if you have the stock sidemounts. you can only do one run at a time and have to let it cool off. what is your iat temps? higher the heat temps easier the knock.
markoverclock is offline   Reply With Quote
Old 04-20-2008, 01:46 PM   #13 (permalink)
15t's ... ? yep
DigiiManDan3KGT's Avatar
Drives: 80Gig WesternDigital
Trader Rating: (7)
DigiiManDan3KGT Level 2DigiiManDan3KGT Level 2DigiiManDan3KGT Level 2
its a 10:1 motor. Hes running no fuel control and the TT ecu thinks its playing with a 8:1. I would take the PSI down a notch untill you get some fuel control. Then look into some meth you'll pull numbers there also.
Green 1995 3000GT FWD-TT 8:1 // 15t Turbos // ATX to MTX // NA to TT // Purchased 11/12/02
White 1999 3000GT Black Dash/Tan Leather Interior // SOHC // MTX // Stock Daily Driver Purchased 7/25/07
Red.._1992 Stealth RT/TT Twin Turbo AWD // Organ Donor // Purchased 05/19/08
<-- Click Here Join FL3S
DigiiManDan3KGT is offline   Reply With Quote
Old 04-20-2008, 01:47 PM   #14 (permalink)
Forum user
raven1231's Avatar
yeah that or get a AFC
Old 04-20-2008, 02:02 PM   #15 (permalink)
Wanna be Z06
Fbc 978's Avatar
Drives: 19T VR4
Trader Rating: (20)
Fbc 978 Level 4Fbc 978 Level 4Fbc 978 Level 4Fbc 978 Level 4Fbc 978 Level 4
how do I go down from wastegate boost...i have no mbc at the moment...except a crappy ebay one that makes me boost 10 psi
19T Pump 1/4 Mile-12.8 @ 111 booooost leeaaakkk
Fbc 978 is online now   Reply With Quote
Old 04-20-2008, 02:41 PM   #16 (permalink)
Been here since 01!
HenesseygtoMR's Avatar
Drives: 100 yds downfield
HenesseygtoMR Level 1HenesseygtoMR Level 1
lookin good. get a tune.
Soarer Turbonetics T66.
HenesseygtoMR is offline   Reply With Quote
Old 04-20-2008, 05:27 PM   #17 (permalink)
15t's ... ? yep
Trader Rating: (7)
Get some fuel control SAFC2 for basic tuning.. Emanage blue to really get the fuel tuned out or emanage ultimate or other piggy back/standalones that will control timing are your step up from that.
There could be lots of reasons your seeing knock. lots...
Old 04-20-2008, 05:41 PM   #18 (permalink)
Resident rocket scientist
BigTyla's Avatar
Drives: '93 3000GT ATX TT
Trader Rating: (179)
BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7
I'm getting more knock than you running wastegate pressure and stock fuel. I'd check your fuel pressure to make sure it is sufficient. I'm thinking of hotwiring my fuel pump to see if that will get rid of my knock, as mine is definitely from running lean. I bet yours is too.
1993 3000GT FWD ATX TT - mods coming<---------------->2009 Honda Fit - 40 mpg ftw
Nov/Dec ground wire GB!!!
Old 04-20-2008, 06:20 PM   #19 (permalink)
Wanna be Z06
Fbc 978's Avatar
Drives: 19T VR4
Trader Rating: (20)
hmm how do I check the pressure...im running a tt fpr...maybe I should upgrade to a walbro fp.
Old 04-21-2008, 09:25 AM   #20 (permalink)
BigTyla's Avatar
Just put a fuel pressure gauge in between one of the connections for the fuel hard line. You can do it yourself with the correct fittings. 3sx sells a complete one with an adapter and it's not overpriced.
Fuel Pressure Adapter Kit*-*Mitsubishi 3000GT*/*Dodge Stealth
