Old 04-03-2008, 07:30 AM   #11 (permalink)
Drives: 1994 VR-4
Trader Rating: (16)
dlabonte Level 1dlabonte Level 1
Default Re: Water/Meth Injection Q&A (Labonte MotorSports)
Originally Posted by Nightviper19 View Post
Could this be added to an NA setup? Or would that be a waste of time/money? Im just trying to get more MPG and save some money somewhere...
You can add it to a NA setup. You would use our VC-MAF controller. Injection is based on engine load so not spraying all the time. Fuel savings would be in open loop mode of ECU operation. You can remove about 10% of the fuel with W/M on an NA engine.
dlabonte is offline   Reply With Quote
Old 04-03-2008, 01:30 PM   #12 (permalink)
You Gotta be Kidding...
Nightviper19's Avatar
Drives: Erradically
Nightviper19 is an unknown quantity at this point
Sorry, I am still learning. So adding the VC-MAF, along with the rest of the system, would add 2-3 more mpg? Although Im not worried about horses just yet, would there be a significant increase there as well? Basically would it be worth the cost in an everyday driver? And I drive about 2 hours a day back and forth to work, so the miles and gallons add up quick.
Obviously asking the vendor isnt the brightest idea for an unbiased opinion on a product, but this is my first car worth doing upgrades to, so I want to get all the help I can.
1998 3000GT SL
- 120K Tune up, Short Ram with K&N Intake, Custom Downpipe and Exhaust straight to a Super 44, Ralliart Ground wire kit, Tons of extras...
2001 Kawasaki ZR-7S
- 18K Tune up, Headlamp relay kit, Seat Reshaped, K&N, Stock Exhaust mod, LED Gauges, Fuel Gauge Calibrated, Polished and Painted Rims, Blacked out Windscreen, Homemade Phone Shock Mount, Homemade Fender Eliminator, Polished Header, Engine Guards, and 135lb driver mod
(Theres no place to put a Super 44 on my bike )
Nightviper19 is offline   Reply With Quote
Old 04-03-2008, 02:13 PM   #13 (permalink)
Drives: 1994 VR-4
Trader Rating: (16)
I will post a straight answer, if I don't, someone on this forum will jump in and raise the flag
The systems are designed to inject based on engine load, in a 2hr drive on the highway, you will be at light load while cruising and see little or no injection. Your ECU would be in closed loop mode most of the time.
When the ECU is in open loop mode, that is when injection will normally happen. On a '06 NA Mustang using our system, gain was about 20awhp.
So fuel savings would not be across the board with the current systems available, only during injection under load.
Old 04-03-2008, 02:32 PM   #14 (permalink)
Drives: Erradically
Ah, so its not gonna be active revving at 2-3 grand, so no savings in gas. Well, it was worth a shot. I might think about it in the future when I start opening the car up more.
Thanks again!
Old 04-16-2008, 03:05 PM   #15 (permalink)
Drives: 1994 VR-4
Trader Rating: (16)
Thanks for your interest. With the way gas prices going, will have to work out a fuel saving method just to save my own wallet.
Best regards,
Dan
Old 04-22-2008, 08:56 PM   #16 (permalink)
Drives: 92 RT-TT
Trader Rating: (43)
markoverclock is an unknown quantity at this point
is the prestone de-icer you posted bad for meth injection. i see 3 of them contain the glycol. are those ones we should stay away from.
thanks again.
markoverclock is offline   Reply With Quote
Old 04-23-2008, 06:10 AM   #17 (permalink)
Drives: 1994 VR-4
Trader Rating: (16)
thanks again.
Yes, you do not want to use any products that contain glycol for meth injection. The glycol will result in a build up in the engine over time and most have anticorrosion additives that are bad for O2 sensors.
Best regards,
Dan
BSEE, MBA
