Old 03-20-2008, 12:22 PM   #1 (permalink)
Drives: 1994 VR-4
Trader Rating: (16)
dlabonte is an unknown quantity at this point
Default Water/Meth Injection Q&A (Labonte MotorSports)
Hello 3Si Members,
Water-Methanol Injection might be new for a number of you. The below write up is to help you get a beter understanding of what it is all about.
We hope that members of this forum find the below information related to water-methanol injection beneficial. If you have any questions please post them and we would be glad to help.
History:
First off water-methanol injection is nothing new. Water Injection was first successfully implemented in WWII on the P-47 “Thunderbolt”. The Turbo Charged Pratt & Whitney R-2800 engine normally produced 2000 HP, with water injection the engine could produce up to 3800 HP. With water injection, the P-47 had 20 minutes worth of high power output for combat situations. One initial problem was that at high altitudes the water would freeze. So to prevent freezing, methanol was finally added to the injection mixture. Later studies done by the Army Corp of Engines actually determined that with a 50/50 mix of water-methanol even more power could be produced over water injection alone.
On Demand Octane Boost:
Octane is simple a measure of a fuels ability to resist spontaneous combustion, also known as preignition. Due to high temperatures and pressures associated with forced induction, a fuel might ignite before the spark event. This results in a very fast flame and extreme combustion pressures that can destroy an engine. The higher the fuel octane, the slower the fuel will burn and less chance of preignition.
Engine knock is actually different then preignition. Knock is the result of the spontaneous combustion of left over gasses in the cylinder. The engine damaging effect is similar to preignition.
Higher octane will not make more horse power by itself. If an engine is tuned for 93 octane, and C116 race fuel is added to the tank, the engine will not make more power simply from the different fuel. If the engine is tuned for C116, then more power can be made, either by more spark advance or more boost. Problem with C116 is one, it is expensive, and two you are wasting that high octane fuel at idle or low engine loads when it is not needed.
The octane rating of water is infinite. It can’t spontaneously combust as you can’t burn water. Methanol is also a high octane fuel in itself. Here are some octane ratings of various fuels:
Chemical / RON / MON
(The octane number you see in the US is [RON + MON]/2)
Methanol / 133 / 105
Ethanol / 129 / 102
Isopropyl Alcohol / 118 /98
MTBE / 116 / 103
Toluene / 124 / 112
Meta Xylene / 164 / 124
Dicyclopentadiene / 229 /167
As a rule of thumb, 50/50 Water/Methanol injection will increase the octane rating of pump gas by 25% during injection. (Note that C16 Race gas is already 116 octane, W/M will slow flame more). So with a load based injection system, you only get the octane increase when needed.
Water is capable of cooling the combustion chamber more efficiently then gasoline. Water has a higher Latent Heat of Vaporization then gasoline. When water is injected in very small droplet sizes into the combustion chamber, it readily absorbs heat as the partials go from liquid to gas state. The water particles actually “pop” or create multiple micro explosions. These micro explosions help to slow the flame front, effectively increasing the octane rating. These micro explosions also help to “stir” the air fuel charge or create a swirl effect in the combustion chamber. This swirl effect results in a more complete combustion of the fuel, leading to lower NOx emissions. With a more complete combustion, engine knock is reduced. This is due to the lower amount of gases available after combustion that can spontaneously combust.
Air / Fuel Ratios:
A gasoline engine will make the most power at an A/F of 12 to 12.5 to 1. The problem is that at this lean of A/F ratio, a forced induction engine will have a tendency for preignition when using regular octane pump gas. That is why most forced inductions engines are tuned for an A/F of around 11.5/1. At 11.5/ 1, 10-15% extra fuel is being added to cool the cylinder and top of the piston to prevent preignition. This extra fuel is not burned in the combustion process and goes out the tail pipe.
A 50/50 mix of water-methanol, when injected in the right quantity, will lower A/F by at least ½ point. Now the engine fueling can be reduced, more timing added, or more boost can be added allowing the engine to make more power.
Chemical Intercooling:
Most water-methanol injection systems are designed to spray the injection mix after the intercooler and before the throttle body. These systems are designed to inject the mixture with a high pressure pump and fluid atomizing nozzle. The smaller the injection particles, the more surface area there is of the small droplets, and the more heat that can be removed. As mentioned above, the high Latent Heat of Vaporization of water lowers in the Intake Air Temp as the water absorbs heat going from a liquid to gas state. A cooler air charge reduces the chance of pre-ignition allowing for more timing or higher boost levels.
An intercooler does the same thing to lower air charge temperatures. One draw back of an intercooler is the boost pressure drop across the intercooler. A second is that in an air to air intercooler, cooling efficiency is limited to that of ambient air temperatures. A third draw back is cost and weight of large front mount intercoolers.
Injection Fluids:
The most common question we get is “Where can I buy Methanol”. Most are surprised to find out that everyday window washer fluid is nothing more then water and methanol.
When using window washer fluid for injection, look for these items to insure you have a good product.
  • The fluid is Blue
  • The label says protects to -20 or -25F
  • No soap bubble form when you shack the bottle.
Note you want to avoid mixtures that contain propylene glycol (anti-freeze). This is commonly added to window washer fluid to lower the temperature rating and is harmful to the engine if injected.
Here are some methanol ratios of commonly available washer fluids per the manufactures MSDS.
dlabonte is offline   Reply With Quote
Old 03-20-2008, 12:23 PM   #2 (permalink)
Pensky3Thousand's Avatar
Drives: 92 RT/TT
Trader Rating: (26)
Pensky3Thousand is an unknown quantity at this point
Default Re: Water/Meth Injection Q&A (Labonte MotorSports)
great post!!!
1992 red Stealth RT/TT 76k miles TD05 16Gs etc....
2008 black on black on blizzaks Dodge Caliber SRT4 TD04HL4S-20G turbo @18psi (18" R/T wheels painted black(winter), K&N cone, Pulstar plugs, HKS black SSQ BOV, Bwoody check valve, Mopar strut bar, PTP Inlet Pipe, PTP WGA, BOP, Aeroforce interceptor scan gauge, AEM wideband sensor, MAP/TIP Clamp, MS1 ECU)
Pensky3Thousand is offline   Reply With Quote
Old 03-20-2008, 12:30 PM   #3 (permalink)
'92 VR4
ras463us's Avatar
Drives: 1992 VR4
Trader Rating: (16)
ras463us is an unknown quantity at this point
Great info. I have a question. I am converting to a speed density setup. In doing so I will be adding an intake air temp sensor. I plan on adding a water/meth kit soon, but my question is:
Where should I locate the air temp sensor in relation to the injection nozzle? Before / After? - Closest / farthest?
Photobucket
ras463us is offline   Reply With Quote
Old 03-20-2008, 12:43 PM   #4 (permalink)
MadgwickTT's Avatar
Drives: 94 Stealth TT
MadgwickTT is an unknown quantity at this point
Washer fluid seriously??? haha thats great, very informative thanks!!!!
1994 Stealth RT/TT
Black/Yellow Two-Tone UD Pully, Blitz DSBC Spec-R, Stillen DP, K&N filter, Hotwired 255LPH Fuel Pump.
MadgwickTT is offline   Reply With Quote
Old 03-20-2008, 01:30 PM   #5 (permalink)
Livin' the dream
chargerx3's Avatar
Drives: 92 R/T TT
chargerx3 Level 1chargerx3 Level 1chargerx3 Level 1
Great write up! Now i better understand how to set up my meth kit. Quick question...How much can you usually raise your boost and timing with meth? ive got the Snow Performance setup with the small nozzle installed (i belive the 300hp nozzle).
thanks again for the help
1967 Dodge Charger (440)... 1969 Dodge Charger SE (383)... 1972 Dodge Charger (400)...
1992 Dodge Stealth R/T TT 1992 Dodge Stealth R/T TT (Z) 1996 Nissan 300ZX TT
chargerx3 is offline   Reply With Quote
Old 03-20-2008, 03:23 PM   #6 (permalink)
oohnoo's Avatar
Trader Rating: (213)
oohnoo Level 1oohnoo Level 1oohnoo Level 1
Hey Dan I'm finally gonna install your setup......I know, i know.lol
I'm currently at 513awhp on pump gas. Question is what size nozzel/nezzels should I use?
----------------[2007 Ride of the Year.................................. 3.5 Stroker I did. w/DBB DR1000's
oohnoo is offline   Reply With Quote
Old 03-20-2008, 03:37 PM   #7 (permalink)
Drives: 1994 VR-4
Trader Rating: (16)
You want to place the W/M nozzle after the IAT so that the IAT does not get misted on. Reason being that colder air measure by the ECU will increase the fuel injector duty cycle, there by richening up the fuel mixture. This can lead to combustion quench from to much fluid that the spark can't ignite properly.
Let the ECU measure the actual temp and thus air volume out of the turbo and it will do its thing. Then let the W/M cool it down and do its job.
Best regards,
Dan
Old 03-20-2008, 04:45 PM   #8 (permalink)
Drives: 1994 VR-4
Trader Rating: (16)
On a stock V$-4 I was able to do 17psi, I think RustangCobra on this board did 20psi a while back on his.
But really depends on setup- General Rule of Thumb - for every 4pt in octane increase you can add 3-4 deg timing or 2-3psi boost.
Old 03-20-2008, 04:50 PM   #9 (permalink)
Drives: 1994 VR-4
Trader Rating: (16)
That means you would be about 640hp at flywheel and 25+psi boost. Use at least an M12 nozzle. When you install the VCS3G let me know what software version you have. Have made some software updates and you will want the newest version.
Old 04-03-2008, 10:16 AM   #10 (permalink)
160WHP NA. You're Jealous
Nightviper19's Avatar
Drives: with 1 axle bolted
Trader Rating: (7)
Nightviper19 is an unknown quantity at this point
Could this be added to an NA setup? Or would that be a waste of time/money? Im just trying to get more MPG and save some money somewhere...
2001 Kawasaki ZR-7S 1998 3000GT SL
Nightviper19 is offline   Reply With Quote
